path: root/include
2015-12-13rockchip: Add basic support for kylin boardhuang lin
kylin board use rk3036 SOC, 512M sdram, 8G emmc. This add some basic files required to allow the board to output serial message and can run command(mmc info etc). Signed-off-by: Lin Huang <hl@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-13Enable console log from earlyconsole in Linux bootargsPratiyush Mohan Srivastava
Remove 115200 from "earlycon" to avoid loss of initial log messages during linux kernel 4.1 bootup Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-12-13armv8/ls1043ardb: Add support for >2GB memoryShaohui Xie
This patch also expose the complete DDR region(s) to Linux. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-12-13fsl/ddr: updated ddr errata-A008378 for arm and power SoCsShengzhou Liu
DDR errata-A008378 applies to LS1021-20-22A-R1.0, T1023-R1.0, T1024-R1.0, T1040-42-20-22-R1.0/R1.1, it has been fixed on LS102x Rev2. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-12-13fsl/errata: move fsl_errata.h to common directoryShengzhou Liu
move arch/powerpc/include/asm/fsl_errata.h to include/fsl_errata.h to make it public for both ARM and POWER SoCs. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> [York Sun: fix soc.h path in fsl_errata.h] Reviewed-by: York Sun <yorksun@freescale.com>
2015-12-13driver/ddr/fsl: Update DDR4 RTT valuesYork Sun
DDR4 has different RTT value and code according to JEDEC spec. Update the macros and options . Signed-off-by: York Sun <yorksun@freescale.com>
2015-12-12stm32: Convert serial driver to DMKamil Lulko
Signed-off-by: Kamil Lulko <kamil.lulko@gmail.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-12-11Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
2015-12-11imx: mx7dsabresd: Add QSPI supportPeng Fan
Support qspi flashes for mx7dsabresd 1. introduce pin mux settings 2. enable qspi clock 3. introduce related macro definitions Default QSPI is not enabled, since we need hardware rework to use QSPI, see SPF-28590, page 9: " QSPI signals are muxed with EPDC_D[7:0] When using QSPI: de-populate R388-R391, R396-R399 populate R392-R395, R299, R300 " After hardware rework, define CONFIG_FSL_QSPI in mx7dsabresd.h. qspi flashes can be deteced and read/erase/write. Log info: " => sf probe SF: Detected MX25L51235F with page size 256 Bytes, erase size 64 KiB, total 64 MiB => sf read 0x80000000 0 0x4000000 device 0 whole chip SF: 67108864 bytes @ 0x0 Read: OK => sf erase 0 0x4000000 SF: 67108864 bytes @ 0x0 Erased: OK => sf write 0x80000000 0 0x4000000 device 0 whole chip SF: 67108864 bytes @ 0x0 Written: OK " Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Adrian Alonso <aalonso@freescale.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Jagan Teki <jteki@openedev.com> Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-12-10sunxi: power: enabled support for axp818vishnupatekar
Enabled support for AXP818 in SPL and u-boot. DCDC1, DCDC2, DCDC3 and DCSC5 are enabled. Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-12-10sunxi: power: axp818: add support for axp818 drivervishnupatekar
AXP818 is rsb based PMIC and used on Allwinner A83T H8 Homlet dev board. It's registers are different and calculating reg config is different than that of earlier axp power ICs. DCDC1, DCDC2, DCDC3 and DCDC5 is implemented at the moment. all other voltages can be added subsequently. AXP datasheet is uploaded to wiki: http://linux-sunxi.org/File:AXP818_datasheet_Revision1.0.pdf Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-12-10sunxi: Add Machine Support for A83T SOCvishnupatekar
Allwinner A83T is octa-core cortex-a7 SOC. This enables support for A83T. SMP is not yet supported. Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-12-09x86: Clean up ivybridge/chrome Kconfig optionsBin Meng
There are some options which are never used, and also some options which are selected by others but have never been a Kconfg option. Clean these up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-12-07CONFIG_NEEDS_MANUAL_RELOC: Fix warnings when not setTom Rini
Now that we may compile (but not link) code calling fixup_cmdtable when this is not set, we need to always have the declaration available. We should also make sure that anyone calling the function includes <command.h> as that's where the function declaration is. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-12-07Merge branch 'zynq' of git://www.denx.de/git/u-boot-microblazeTom Rini
2015-12-07ARM: zynq: Extend malloc sizeMichal Simek
SPL DM MMC FAT requires more malloc space(3k fat buffers + dm) that it is available now. Extend SPL malloc space. Current OCM layout: 0xffff0000 - 0xfff2000 - Full malloc space 0xffff2000 - 0xffff300 - Stack location 0xfffff300 - CONFIG_SYS_MALLOC_F_LEN - Early malloc space 0xfffffd00 - sizeof(GD) - GD 0xfffffe00 - 0xffffffff - SoC specific boot code Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-07ARM: zynq: Fix location of stack and malloc areasMichal Simek
The patch "board_init: Change the logic to setup malloc_base" (sha1: 9ac4fc82071ce346e3885118242ff45d22f69b82) breaks SPL for Zynq because it puts early alloc area on the stack which caused that stack was decreased by CONFIG_SYS_MALLOC_F_LEN (0x400) and there was not enough space for regular stack. This patch changes memory layout to better utilize the last 64k OCM block. 0xffff0000 - 0xfff1000 - Full malloc space 0xffff1000 - 0xffff300 - Stack location 0xfffff300 - CONFIG_SYS_MALLOC_F_LEN - Early malloc space 0xfffffd00 - sizeof(GD) - GD 0xfffffe00 - 0xffffffff - SoC specific boot code Signed-off-by: Michal Simek <michal.simek@xilinx.com> Tested-by: Moritz Fischer <moritz.fischer@ettus.com>
2015-12-07ARM64: zynqmp: Enable FIT config option via KconfigMichal Simek
Remove configuration options from board file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-07net: gem: Move gem to KconfigMichal Simek
Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-12-07net: gem: Move driver to DMMichal Simek
- Enable DM_ETH by default for Zynq and ZynqMP - Remove board_eth_init code - Change miiphy_read function to return value instead of error code based on DM requirement - Do not enable EMIO DT support by default Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-07net: gem: Remove zynq_gem_of_init()Michal Simek
This function was used for OF init before DM. Remove this function as the part of move to DM. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-12-07ARM: zynq: Remove CONFIG_APIMichal Simek
CONFIG_API is causing compilation error when DM_ETH is enabled because eth_get_dev() is not available. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-12-07ARM: zynq: Remove PHYLIB from config to defconfigMichal Simek
Move PHYLIB from board config to defconfig Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-12-06Merge git://git.denx.de/u-boot-usbTom Rini
2015-12-07arm: socfpga: Add SoCFPGA SR1500 boardStefan Roese
The SR1500 board is a CycloneV based board, similar to the EBV SoCrates, equipped with the following devices: - SPI NOR - eMMC - Ethernet Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Cc: Pavel Machek <pavel@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Acked-by: Pavel Machek <pavel@denx.de>
2015-12-07usb: xhci: zynqmp: Removing unused function usb_phy_resetMarek Vasut
This patch removes unsued function usb_phy_reset, rather common function dwc3_phy_reset is used. Signed-off-by: Marek Vasut <marex@denx.de>
2015-12-07drivers:usb:fsl: Add T4080 as affected soc for Erratum A007792 sw workaroundRajesh Bhagat
Apply Erratum A007792 sw workaround for T4080 Signed-off-by: Sriram Dash <sriram.dash@freescale.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@freescale.com> Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2015-12-07usb: zynqmp: Enable USB XHCI supportSiva Durga Prasad Paladugu
Enable USB XHCI support for ZynqMP Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
2015-12-07usb: zynqmp: Add XHCI driver supportSiva Durga Prasad Paladugu
Added USB XHCI driver support for zynqmp. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
2015-12-05eeprom: Zap CONFIG_SYS_I2C_MULTI_EEPROMSMarek Vasut
This symbol is no longer used anywhere, remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@konsulko.com> Acked-by: Heiko Schocher <hs@denx.de>
2015-12-05Fix typo: commmand -> command.Vagrant Cascadian
Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2015-12-04Merge branch 'master' of http://git.denx.de/u-boot-sparcTom Rini
2015-12-04Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-12-03sparc: Add CONFIG_DISPLAY_BOARDINFO variable to all LEON boardsFrancois Retief
Signed-off-by: Francois Retief <fgretief@spaceteq.co.za>
2015-12-03sparc: leon2: Updates for generic board initializationFrancois Retief
Reworked the LEON2 start.S code to call board_init_f function at startup. Also implemented the relocate_code function in assembly to relocate the monitor and setup the stack pointer before calling relocated board_init_r. Add the CONFIG_SYS_GENERIC_BOARD variable to all the LEON2 boards. Signed-off-by: Francois Retief <fgretief@spaceteq.co.za>
2015-12-03sparc: leon3: Updates for generic board initializationFrancois Retief
Reworked the LEON3 start.S code to call board_init_f function at startup. Also implemented the relocate_code function in assembly to relocate the monitor and setup the stack pointer before calling relocated board_init_r. Add the CONFIG_SYS_GENERIC_BOARD variable to all the LEON3 boards. Signed-off-by: Francois Retief <fgretief@spaceteq.co.za>
2015-12-03sparc: Move SYS_SPARC_NWINDOWS to KconfigFrancois Retief
2015-12-01iocon: Disable FIT_VERBOSETom Rini
In order to fit into image constraints again, remove this feature. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-12-01arm: imx6: novena: Enable extfs support in SPLMarek Vasut
Simple patch to enable support for extfs filesystem in SPL, this is useful to those who want to avoid vfat like plague. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2015-12-01rockchip: move SYS_MALLOC_SIMPLE to mach-rockchip KconfigAriel D'Alessandro
Commit 1eb0c03c2198a7ec9de456b83dacdc4831b96cbf added SPL_SYS_MALLOC_SIMPLE Kconfig option and changed the way it is evaluated. Thus, the definitions of CONFIG_SYS_MALLOC_SIMPLE in rk3***_common.h board configs are now incorrect because CONFIG_SPL_BUILD is enabled so CONFIG_IS_ENABLED(SYS_MALLOC_SIMPLE) will look for SPL_SYS_MALLOC_SIMPLE instead of SYS_MALLOC_SIMPLE. This commit fix this enabling SPL_SYS_MALLOC_SIMPLE with the new Kconfig option by default in rockchip-mach. Signed-off-by: Ariel D'Alessandro <ariel@vanguardiasur.com.ar> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01rockchip: Add basic support for evb-rk3036 boardhuang lin
This add some basic files required to allow the board to dispaly serial message and can run command(mmc info etc) Signed-off-by: Lin Huang <hl@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Moved board Kconfig fragment from previous patch into this one to fix build error: Signed-off-by: Simon Glass <sjg@chromium.org> Series-changes: 8 - moved board Kconfig fragment from previous patch into this one
2015-12-01rockchip: rk3036: Add core Soc start-up codehuang lin
rk3036 only 4K size SRAM for SPL, so only support timer, uart, sdram driver in SPL stage, when finish initial sdram, back to bootrom.And in rk3036 sdmmc and debug uart use same iomux, so if you want to boot from sdmmc, you must disable debug uart. Signed-off-by: Lin Huang <hl@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Fixed build error for chromebook_jerry, firefly-rk3288: Signed-off-by: Simon Glass <sjg@chromium.org> Series-changes: 8 - Fix build error for chromebook_jerry, firefly-rk3288
2015-12-01mmc: dw_mmc: support fifo mode in dwc mmc driverhuang lin
some soc(rk3036 etc) use dw_mmc but do not have internal dma, so we implement fifo mode to read and write data. Signed-off-by: Lin Huang <hl@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01rockchip: Bring in RK3036 device tree file includes and bindingshuang lin
Since rk3036 device tree file still in reviewing, bring it from https://patchwork.kernel.org/patch/7203371/ and add some aliases we need in uboot Signed-off-by: Lin Huang <hl@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01rockchip: add config decide whether to build common.chuang lin
some rockchips soc will not use uclass in SPL stage, so define config to decide whether to build common.c Signed-off-by: Lin Huang <hl@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01rockchip: add timer driverhuang lin
some rockchip soc will not include lib/timer.c in SPL stage, so implement timer driver for some soc can use us delay function in SPL. Signed-off-by: Lin Huang <hl@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01rockchip: firefly: Save the environment on SD cardSjoerd Simons
Save the environment on the SD card for Firefly in the empty space between the SPL and the u-boot image. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01rockchip: Also load the initrd below 512MSjoerd Simons
Similar to load an fdt, when loading an initrd about the 512Mb mark things seem to break. For now force loading below 512Mb until the reason why this fails has been determined/solved. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01dm: pci: Disable PCI compatibility functions by defaultSimon Glass
We eventually need to drop the compatibility functions for driver model. As a first step, create a configuration option to enable them and hide them when the option is disabled. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-01dm: pci: Convert 'pci' command to driver modelSimon Glass
Adjust this command to use the correct PCI functions, instead of the compatibility layer. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
