path: root/include
2008-03-31ColdFire: Added MCF5275 cpu support.Matthew Fettke
Signed-off-by: Matthew Fettke <mfettke@videon-central.com> Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-03-31ColdFire: Define bootdelay in configuration file for M52277EVBTsiChung Liew
Signed-off-by: Matt Wadel <Matt.Waddel@freescale.com> Acked-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-03-27Fix host tool build breakage, take twoBartlomiej Sieka
Revert commit 87c8431f and fix build breakage so that the build continues to work on FC systems. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-03-27new-image: Fix host tool build breakageHaavard Skinnemoen
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-03-27Merge branch 'master' of git://www.denx.de/git/u-boot-mpc85xxWolfgang Denk
2008-03-27Fix compilation error in cmd_usb.cAnatolij Gustschin
This patch fixes compilation error cmd_usb.c: In function 'do_usb': cmd_usb.c:552: error: void value not ignored as it ought to be Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-03-27Coding style cleanup, update CHANGELOGWolfgang Denk
2008-03-26ata: add the fis struct for SATADave Liu
Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-03-26ata: add the libata supportDave Liu
add simple libata support in u-boot Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-03-26ata: make the ata_piix driver using new SATA frameworkDave Liu
original ata_piix driver is using IDE framework, not real SATA framework. For now, the ata_piix driver is only used by x86 sc520_cdp board. This patch makes the ata_piix driver use the new SATA framework, so - remove the duplicated command stuff - remove the CONFIG_CMD_IDE define in the sc520_cdp.h - add the CONFIG_CMD_SATA define to sc520_cdp.h Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-03-26ata: add the support for SATA frameworkDave Liu
- add the SATA framework - add the SATA command line Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-03-26ata: merge the header of ata_piix driverDave Liu
move the sata.h from include/ to drivers/block/ata_piix.h Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-03-26ata: merge the ata_piix driverDave Liu
move the cmd_sata.c from common/ to drivers/ata_piix.c, the cmd_sata.c have some part of ata_piix controller drivers. consolidate the driver to have better framework. Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-03-2685xx: Update multicore boot mechanism to ePAPR v0.81 specKumar Gala
The following changes are needed to be inline with ePAPR v0.81: * r4, r5 and now always set to 0 on boot release * r7 is used to pass the size of the initial map area (IMA) * EPAPR_MAGIC value changed for book-e processors * changes in the spin table layout * spin table supports a 64-bit physical release address Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-26FSL: Clean up board/freescale/common/MakefileJon Loeliger
Each file that can be built here now follows some CONFIG_ option so that they are appropriately built or not, as needed. And CONFIG_ defines were added to various board config files to make sure that happens. The other board/freescale/*/Makefiles no longer need to reach up and over into ../common to build their individually needed files any more. Boards that are CDS specific were renamed with cds_ prefix. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-03-2685xx: Expand CCSR space with more DDR controller registers.James Yang
Signed-off-by: James Yang <James.Yang@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-2685xx: Speed up get_ddr_freq() and get_bus_freq()James Yang
get_ddr_freq() and get_bus_freq() used get_sys_info() each time they were called. However, get_sys_info() recalculates extraneous information when called each time. Have get_ddr_freq() and get_bus_freq() return memoized values from global_data instead. Signed-off-by: James Yang <James.Yang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-26Update SVR numbers to expand supportAndy Fleming
FSL has taken to using SVR[16:23] as an SOC sub-version field. This is used to distinguish certain variants within an SOC family. To account for this, we add the SVR_SOC_VER() macro, and update the SVR_* constants to reflect the larger value. We also add SVR numbers for all of the current variants. Finally, to make things neater, rather than use an enormous switch statement to print out the CPU type, we create and array of SVR/name pairs (using a macro), and print out the CPU name that matches the SVR SOC version. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-03-26Add the Freescale PCI device IDsAndy Fleming
2008-03-2685xx: Added support for multicore boot mechanismKumar Gala
Added the cpu command that provides a generic mechanism to get status, reset, and release secondary cores in multicore processors. Added support for using the ePAPR defined spin-table mechanism on 85xx. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-2685xx: Add the concept of CFG_CCSRBAR_PHYSKumar Gala
When we go to 36-bit physical addresses we need to keep the concept of the physical CCSRBAR address seperate from the virtual one. For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-26Cleanup coding style, update CHANGELOGWolfgang Denk
2008-03-26Merge branch 'new-image' of git://www.denx.de/git/u-boot-testingBartlomiej Sieka
Conflicts: common/cmd_bootm.c cpu/mpc8xx/cpu.c Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-03-2583xx/fdt_support: let user specifiy FSL USB Dual-Role controller roleAnton Vorontsov
Linux understands "host" (default), "peripheral" and "otg" (broken). Though, U-Boot doesn't restrict dr_mode variable to these values (think of renames in future). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-25Modified the DDR SDRAM clock control register to delay MCK/MCK_B 3/4 clockJoe D'Abbraccio
With the original value of 1/2 clock cycle delay, the system ran relatively stable except when we run benchmarks that are intensive users of memory. When I run samba connected disk with a HDBENCH test, the system locks-up or reboots sporadically. Signed-off by: Joe D'Abbraccio <Joe.D'abbraccio@freescale.com>
2008-03-25mpc83xx: Set PCI I/O bus-address base to zero.Scott Wood
The device trees for these boards describe PCI I/O as starting from address zero from the device's perspective. Placing I/O elsewhere may cause problems with certain PCI boards, and may cause problems with Linux. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-03-25mpc83xx: MPC8360E-RDK: use 33.3(3)MHz CLKIN/SYS_CLKAnton Vorontsov
At least on the "33MHz Pilot" board crystal is actually 33.3MHz. This patch fixes "system time drifting" problem. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2008-03-25mpc83xx: MPC8360E-RDK: define CONFIG_OF_STDOUT_VIA_ALIASAnton Vorontsov
This is needed to update /choosen/linux,stdout-path properly. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2008-03-25mpc83xx: MPC8360E-RDK: add dhcp commandAnton Vorontsov
Plus modify environment to use it and remove bootfile env variable, it is internal and CONFIG_BOOTFILE is used for these purposes. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2008-03-25mpc83xx: MPC8360E-RDK: rework ddr setup, enable eccAnton Vorontsov
Current DDR setup easily causes memory corruption, this patch fixes it. Also fix TIMING_CFG0_MRS_CYC definition. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2008-03-25mpc83xx: MPC8360E-RDK: add support for NANDAnton Vorontsov
2008-03-25mpc83xx: MPC8360E-RDK: use RGMII_RXID interface modeAnton Vorontsov
This is needed for BCM PHYs to work on this board. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2008-03-2583xx: define CONFIG_OF_STDOUT_VIA_ALIAS for the MPC837XERDB boardsAnton Vorontsov
This is primarily for the early console support. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2008-03-2583xx: initialize serdes for MPC837XRDB boardsAnton Vorontsov
On the MPC8377ERDB: 2 SATA and 2 PCI-E. On the MPC8378ERDB: 2 PCI-E On the MPC8379ERDB: 4 SATA Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2008-03-2583xx: serdes setup routinesAnton Vorontsov
This patch adds few routines to configure serdes on 837x targets. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2008-03-2583xx: nand support for MPC837XRDB boardsAnton Vorontsov
2008-03-25Enable CONFIG_FLASH_SHOW_PROGRESS on the MPC8360EMDS.Jerry Van Baren
Signed-off-by: Gerald Van Baren <vanbaren@cideas.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-25mpc8323erdb: remove RTC and add EEPROMMichael Barkowski
There's no on-board RTC on the MPC8323ERDB, but there is an EEPROM. Signed-off-by: Michael Barkowski <michael.barkowski@freescale.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-25mpc8323erdb: Improve the system performanceMichael Barkowski
The following changes are based on kernel UCC ethernet performance: 1. Make the CSB bus pipeline depth as 4, and enable the repeat mode 2. Optimize transactions between QE and CSB. Added CFG_SPCR_OPT switch to enable this setting. The following changes are based on the App Note AN3369 and verified to improve memory latency using LMbench: 3. CS0_CONFIG[AP_n_EN] is changed from 1 to 0 4. CS0_CONFIG[ODT_WR_CONFIG] set to 1. Was a reserved setting previously. 5. TIMING_CFG_1[WRREC] is changed from 3clks to 2clks (based on Twr=15ns, and this was already the setting in DDR_MODE) 6. TIMING_CFG_1[PRETOACT] is changed from 3clks to 2clks. (based on Trp=15ns) 7. TIMING_CFG_1[ACTTOPRE] is changed from 9clks to 6clks. (based on Tras=40ns) 8. TIMING_CFG_1[ACTTORW] is changed from 3clks to 2clks. (based on Trcd=15ns) 9. TIMING_CFG_1[REFREC] changed from 21 clks to 11clks. (based on Trfc=75ns) 10. TIMING_CFG_2[FOUR_ACT] is changed from 10 clks to 7clks. (based on Tfaw=50ns) 11. TIMING_CFG_2[ADD_LAT] and DDR_MODE[AL] changed from 0 to 1 (based on CL=3 and WL=2). Signed-off-by: Michael Barkowski <michael.barkowski@freescale.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-25mpc8323erdb: use readable DDR config macrosMichael Barkowski
Use available shift/mask macros to define DDR configuration. Signed-off-by: Michael Barkowski <michael.barkowski@freescale.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-2583xx: Add Vitesse VSC7385 firmware uploadingTimur Tabi
Update the MPC8349E-mITX, MPC8313E-RDB, and MPC837XE-RDB board files to upload the Vitesse VSC7385 firmware. Changed CONFIG_VSC7385 to CONFIG_VSC7385_ENET. Cleaned up the board header files to make selecting the VSC7385 easier to control. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-25NET: Add Vitesse VSC7385 firmware uploadingTimur Tabi
The Vitesse VSC7385 is a 5-port switch found on the Freescale MPC8349E-mITX and other boards. A small firwmare must be uploaded to its on-board memory before it can be enabled. This patch adds the code which uploads firmware (but not the firmware itself). Previously, this feature was provided by a U-Boot application that was made available only on Freescale BSPs. The VSC7385 firmware must still be obtained separately, but at least there is no longer a need for a separate application. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2008-03-26Merge branch 'master' of git://www.denx.de/git/u-boot-mipsWolfgang Denk
2008-03-26Remove deprecated CONFIG_OF_HAS_UBOOT_ENV and CONFIG_OF_HAS_BD_TJerry Van Baren
These defines embedded the u-boot env variables and/or the bd_t structure in the fdt blob. The conclusion of discussion on the u-boot email list was that embedding these in the fdt blob is not useful: there are better ways of passing the data (in fact, the fdt blob itself replaces the bd_t struct). The only board that enables these is the stxxtc and they don't appear to be used by linux. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-258xx: Update OF support on 8xxBryan O'Donoghue
This patch does some shifting around of OF support on 8xx. Signed-off-by: Bryan O'Donoghue <bodonoghue@codehermit.ie>
2008-03-258xx : Add OF support to Adder875 board port - resubmitBryan O'Donoghue
2008-03-25Add setexpr commandKumar Gala
Add a simple expr style command that will set an env variable as the result of the command. This allows us to do simple math in shell. The following operations are supported: &, |, ^, +, -, *, /. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-25[MIPS] Introduce _machine_restartShinya Kuribayashi
Handles machine specific functions by using weak functions. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-03-25[MIPS] cpu/mips/cache.S: Introduce NESTED/LEAF/END macrosShinya Kuribayashi
This patch replaces the current function definitions with NESTED, LEAF and END macro. They specify some more additional information about the function; an alignment of symbol, type of symbol, stack frame usage, etc. These information explicitly tells the assembler and the debugger about the types of code we want to generate. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-03-25[MIPS] asm headers' updatesShinya Kuribayashi
Make some asm headers adjusted to the latest Linux kernel. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
