path: root/include
2005-07-25* Patch by Jon Loeliger, 2005-05-05Jon Loeliger
Implemented support for MPC8548CDS board. Added DDR II support based on SPD values for MPC85xx boards. This roll-up patch also includes bugfies for the previously published patches: DDRII CPO, pre eTSEC, 8548 LBIU, Andy's TSEC, eTSEC 3&4 I/O
2005-07-25* Patch by Jon Loeliger, 2005-Feb-10Jon Loeliger
Add config option CONFIG_HAS_FEC calling out 8540 FEC features.
2005-07-25* Patch by Jon Loeliger, Kumar Gala, 2005-02-08Jon Loeliger
For MPC85xxCDS: Adds Relaxed Timing TRLX bit to FLASH ORx regs to allow for faster flash parts. Add documentation for BR/OR for FLASH.
2005-07-23* Patch by Jon Loeliger, Kumar Gala 2005-02-08Jon Loeliger
- Convert the CPM2 based functionality to use new CONFIG_CPM2 option rather than a myriad of CONFIG_MPC8560-like variants. Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560. Eliminates the CONFIG_MPC8560 option entirely. Distributes the new CONFIG_CPM2 option to each 8260 board.
2005-07-21Add CompactFlash support for HMI1001 board.Wolfgang Denk
2005-07-21Fix low-level OHCI transfers for ARM920t and MPC5xxxWolfgang Denk
A new, Windows compatible init sequence was also backported from Linux 2.6, but disabled with #undef NEW_INIT_SEQ as it wouldn't change the behaviour of the memopry sticks we tested. Maybe it's not relevant for mass storage devices. For recerence, see file common/usb.c, function usb_new_device(), section #ifdef NEW_INIT_SEQ.
2005-07-04* Patch by Detlev Zundel, 30 Jun 2005:LABEL_2005_07_04_0202wdenk
Fix LCD logo for lwmon board which got lost in the merge of 8xx and PXA LCD code
2005-07-01* Patch by Stefan Roese, 1 Jul 2005:stroese
Fix PHY address for CATcenter board (now correct!)
2005-06-30* Patch by Stefan Roese, 30 Jun 2005:stroese
Fix PHY addresses for PPChameleon and CATcenter boards Change MAINTAINER for most esd boards
2005-06-27* Fix baudrate calculation problem on MPC5200 systemswdenk
* Add MPC8220 boards to MAKEALL script * Add EEPROM and RTC support for HMI1001 board * Patch by Detlev Zundel, 20 Jun 2005: Fix initialization of low active GPIO pins on inka4x0 board
2005-06-20Enable redundant environment, disable HW flash protection of HMI1001 boardwdenk
2005-06-10* Add support for HMI1001 boardwdenk
* Disable "date" and "sntp" commands on TQM866M which has no RTC
2005-05-30Patch by Juergen Selent, 17 May 2005:wdenk
Add support for Funkwerk VoVPN gateway module.
2005-05-23* Extend burst mode RAM test program to take a loop countwdenk
(0 = infinite) * Use CONFIG_DRIVER_KS8695ETH to enable KS8695 ethernet driver on those boards that use it.
2005-05-19Patch by Greg Ungerer, 19 May 2005:wdenk
add support for the OpenGear CM4008 board
2005-05-19* Patch by Greg Ungerer, 19 May 2005:wdenk
add support for the KS8695P (ARM 922 based) CPU * Patch by Steven Scholz, 19 May 2005: Add support for CONFIG_SERIAL_TAG on ARM boards
2005-05-16Add PCI support for Sorcery board.wdenk
Code cleanup (especially Sorcery / Alaska / Yukon serial driver).
2005-05-13Fix timer handling on MPC85xx systemswdenk
2005-05-12* Fix debug code in omap5912osk flash driverLABEL_2005_05_13_0050wdenk
* Add support for MPC8247 based "IDS8247" board.
2005-05-10Add support for 2 x TSEC interfaces on the TQM8540 board.wdenk
2005-05-05It's better to handle LZO and LZARI compression mdoes for JFFS2 withLABEL_2005_05_05_1920wdenk
a single #define.
2005-05-05Increase CFG_MONITOR_LEN for Rattler board to match actual code size.wdenk
2005-05-05Major upate of JFFS2 code; now in sync with snapshot of MTD CVS ofwdenk
March 13, 2005); new configuration options CONFIG_JFFS2_LZO and CONFIG_JFFS2_LZARI are added. Both are undefined by default.
2005-05-03* Patch by Matthias Fuchs, 03 May 2005:stroese
Added missing variable declaration in cmd_nand.c Modified CFG_PCI_PTM1MS in configs/PLU405.h to map 128MB ram
2005-05-03* Patch by Stefan Roese, 03 May 2005:stroese
Update for P3G4 Fix problems in cmd_universe.c
2005-04-22Fix INKA4x0: use CS1 as gpio_wkup_6 outputwdenk
2005-04-21Fix bug in the SDRAM initialization code for canmb, IceCube andwdenk
PM520 boards. Fix PHY address for canmb board.
2005-04-20get rid of obsolete CFG_AT91C_BRGR_DIVISOR definitionwdenk
2005-04-20Auto-size RAM on canmb board.wdenk
Cleanup.
2005-04-20* Patch by Matthias Fuchs, 18 Apr 2005:stroese
Make PCI target address spaces on PMC405 and CPCI405 boards configurable via environment variables
2005-04-13Add support for canmb boardLABEL_2005_04_14_0115wdenk
2005-04-13Update for esd apc405stroese
2005-04-07* Patch by Steven Scholz, 07 Apr 2005:wdenk
Add i2c_reg_write() and i2c_reg_write() for at91rm9200 I2C * Patch by Steven Scholz, 07 Apr 2005: Fix compiler warning in altera.c * Patch by Ladislav Michl, 06 Apr 2005: Fix voiceblue configuration.
2005-04-07* Patch by Stefan Roese, 06 Apr 2005:stroese
Updates for OCOTEA board: - Changed U-Boot size from 512kByte to 256kByte - Fixed flash driver to support boot from soldered user flash - Added README for switch from PIBS firmware to U-Boot
2005-04-07Add PPC440GX Revision Cstroese
2005-04-06Patch by Steven Scholz, 06 Apr 2005:wdenk
- creating SoC subdir for Atmel AT91RM9200 cpu/arm920t/at91rm9200 - moving code out of cpu/at91rm9200 into cpu/arm920t/at91rm9200
2005-04-06* Patches by Robert Whaley, 29 Nov 2004:wdenk
- update the pxa-regs.h file for PXA27x chips - add PXA27x based ADSVIX board - add support for MMC on PXA27x processors * Patch by Andrew E. Mileski, 28 Nov 2004: Fix PPC4xx SPD SDRAM detection bug * Patch by Hiroshi Ito, 26 Nov 2004: Fix logic of "test -z" and "test -n" commands
2005-04-05* Patch by Ladislav Michl, 05 Apr 2005:wdenk
Add support for VoiceBlue board. * Patch by Ladislav Michl, 05 Apr 2005: Fix netboot_common() prototypes. * Cleanup.
2005-04-05Patches by Steven Scholz, 05 Apr 2005:wdenk
- Use i.MX watchdog timer for reset_cpu() - Move reset_cpu() out of cpu/arm920t/start.S into the SoC specific subdirectories cpu/arm920t/imx/ and cpu/arm920t/s3c24x0/ (now in interupts.c)
2005-04-05Add support for MPC8220 based "sorcery" board.LABEL_2005_04_05_2345wdenk
2005-04-05Add support for TQM8560 boardLABEL_2005_04_05_1830wdenk
2005-04-04* Add FEC support for TQM8540 board.wdenk
Interfaces are named as follows: "ENET1" - TSEC2, "ENET2" - FEC * Patch by Martin Krause, 04 Apr 2005: Update default configuration for CMC_PU2 board.
2005-04-04Patch by Steven Scholz, 4 Apr 2005:wdenk
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards - introduce two new configuration options instead: CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT
2005-04-04Fix timer code for ARM systems: make sure that udelay() does notwdenk
reset timers so it's save to use udelay() in timeout code.
2005-04-03Patch by Jerry Van Baren, 08 Nov 2004:wdenk
- Add low-boot option for MPC8260ADS board (if lowboot is selected, the jumper for the HRCW source should select flash. If lowboot is not selected, the jumper for the HRCW source should select the BCSR. - change default load base address to 0x00400000
2005-04-03* Patch by Yuli Barcohen, 08 Nov 2004:wdenk
Add support for Analogue & Micro Rattler boards. Tested on Rattler8248. * Patch by Andre Renaud, 08 Nov 2004: Fix watchdog support in common/lcd.c * Patch by Marc Leeman, 05 Nov 2003: Enable all 4 PCMBRW buffers for the MPC8245 processor since the CPU bug only affects the XPC8245 processors
2005-04-03Patches by Josef Wagner, 29 Oct 2004:wdenk
- Add support for MicroSys CPU87 board - Add support for MicroSys PM854 board
2005-04-03Patch by David Adair, 27 Oct 2004:wdenk
Add missing 440GX SDRAM Controller reset
2005-04-03Patch by Steven Scholz, 25 Oct 2004:wdenk
Declare reset_cpu() in include/common.h instead locally
2005-04-03* Patch by Yusdi Santoso, 22 Oct 2004:wdenk
- Add support for HIDDEN_DRAGON board - fix endianess problem in driver/rtl1839.c * Patch by Allen Curtis, 21 Oct 2004: support multiple serial ports
