CONFIG_CMD_EECONFIG
CONFIG_CMD_ECCTEST
This is only used by one board and always set to 0x51. Drop this option.
Now that dtt is gone, this is not used. Drop it.
This subsystem is quite old. It has been replaced with a driver-model
version (UCLASS_THERMAL). Boards are free to convert to that if required,
but here is a removal patch that could be applied in the meantime.
This subsystem has not been converted to driver model, there is only one
driver and only one board that uses it. Drop it and its CONFIG option.
Also drop the rtc4543 RTC driver since it uses TWS.
This option is only defined to a non-default value by canyonlands, which
needs conversion to driver model (where the I2C address would be defined
by the device tree).
Drop this option.
CONFIG_DS4510
This option enables a command in the driver. But the functions defined by
the driver are not called anywhere else in U-Boot. So it does not seem
useful to have this driver without its commands.
Drop this option, move the header file out of the common include/
directory and make all the function static.
This option is only used in one driver and two boards. It does not seem
worth having the ability to remove this part of the support.
Drop the option.
Commit 94e3c8c4fd7b ("crypto/fsl - Add progressive hashing support
using hardware acceleration.") created entries for CONFIG_SHA1,
CONFIG_SHA256, CONFIG_SHA_HW_ACCEL, and CONFIG_SHA_PROG_HW_ACCEL.
However, no defconfig has migrated to it. Complete the move by first
adding additional logic to various Kconfig files to select this when
required and then use the moveconfig tool. In many cases we can select
these because they are required to implement other drivers. We also
correct how we include the various hashing algorithms in SPL.
This commit was generated as follows (after Kconfig additions):
[1] tools/moveconfig.py -y SHA1 SHA256 SHA_HW_ACCEL
[2] tools/moveconfig.py -y SHA_PROG_HW_ACCEL
Note:
We cannot move SHA_HW_ACCEL and SHA_PROG_HW_ACCEL simultaneously
because there is dependency between them.
Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Cc: Naveen Burmi <NaveenBurmi@freescale.com>
Cc: Po Liu <po.liu@freescale.com>
Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Cc: Priyanka Jain <Priyanka.Jain@freescale.com>
Cc: Shaohui Xie <Shaohui.Xie@freescale.com>
Cc: Chunhe Lan <Chunhe.Lan@freescale.com>
Cc: Chander Kashyap <k.chander@samsung.com>
Cc: Steve Rae <steve.rae@raedomain.com>
Cc: Dirk Eibach <eibach@gdsys.de>
Cc: Feng Li <feng.li_2@nxp.com>
Cc: Alison Wang <alison.wang@freescale.com>
Cc: Sumit Garg <sumit.garg@nxp.com>
Cc: Mingkai Hu <Mingkai.Hu@freescale.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Akshay Saraswat <akshay.s@samsung.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
We rename CONFIG_FIT_DISABLE_SHA256 to CONFIG_FIT_ENABLE_SHA256_SUPPORT which
is enabled by default and now a positive option. Convert the handful of boards
that were disabling it before to save space.
Cc: Lukasz Dalek <luk0104@gmail.com>
CONFIG_SPL_BOARD_INIT
Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
[trini: Update the Kconfig logic]
Add config and defconfig for the Arria10 and update socfpga_common.h.
Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
Add reset driver support for Arria 10.
Switch to use DM USB.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Enable more DM drivers. The imx I2C/MMC DM drivers needs DM_GPIO
enabled. The 74x164 drivers needs SOFT_SPI and DM_GPIO enabled.
So needs to enable them together.
Sync with Linux commit 308ac756("Merge tag 'gpio-v4.11-3'").
Cc: Stefan Agner <stefan.agner@toradex.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Set fdt_file env variable during board_late_init
Cc: Matteo Lisi <matteo.lisi@engicam.com>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Let the runtime code can set the mmcdev and mmcroot based
on the devno using mmc_get_env_dev instead of defining
separately in build-time configs using mmc_late_init func.
Add runtime, modeboot env which is setting mmcboot, or
nandboot based on the bootdevice so-that conditional
macros b/w MMC and NAND for CONFIG_BOOTCOMMAND should
be avoided in config files.
Select CONFIG_FSL_IIM and CONFIG_CMD_FUSE so that the fuse API can
be used.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
- Add workaround code to make LD20 SoC boot from ARM Trusted Firmware
- Sync DT with Linux to fix DTC warnings
- Add new SoC support code
- Misc fix, updates
Reserve enough space below the kernel base.
The assumed address map is:
80000000 - 80ffffff : for IPP
81000000 - 81ffffff : for ARM secure
82000000 - : for Linux
This script command will be useful to update boot images in the
USB storage.
This new flag can be added to DM device drivers, which need to do some
final configuration before U-Boot exits and the OS (e.g. Linux) is
started. The remove functions of those drivers will get called at
this stage to do these last-stage configuration steps.
Cc: Bin Meng <bmeng.cn@gmail.com>
Convert the pci_mmc driver over to driver model and migrate all x86 boards
that use it.
Tested-by: Bin Meng <bmeng.cn@gmail.com>
- Add #undef CONFIG_DM_MMC_OPS to omap3_logic in the SPL build case, to
match other TI platforms in the same situation.
Due to a typo, the 24 bit-per-pixel configuration ends in 24BMP
instead of 24BPP. This change renames it throughout the source tree
for consistency and to make moving these options into Kconfig easier
and less error-prone.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Some DVI monitors don't show anything in HDMI mode since audio stream
confuses them. To solve this situation, this commit adds HDMI flag in
timing data and sets it accordingly during edid parsing.
First existence of extension block is checked. If it exists and it is
CEA861 extension, then data blocks are checked for presence of HDMI
vendor specific data block. If it is present, HDMI flag is set.
Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net>
Follow the exiting logic for the i.MX options when migrating this
option.
The following options are migrated over fully now:
- USB_EHCI_ATMEL
- USB_EHCI_MARVELL
- USB_EHCI_MX6
- USB_EHCI_MX7
- USB_EHCI_MSM
- USB_EHCI_ZYNQ
- USB_EHCI_GENERIC
This also requires fixing the depends on USB_EHCI_MARVELL as it's used
by Orion5X and Kirkwood as well.
Migrate the rest of the users of CONFIG_USB_EHCI_HCD over to Kconfig.
For a few SoCs, imply or default y this if USB is enabled. In some
cases we had not already migrated to CONFIG_USB so do that as well.
In order to be able to migrate the various SoC EHCI CONFIG options we
first need to finish the switch from CONFIG_USB_EHCI to
CONFIG_USB_EHCI_HCD.
The symbol CONFIG_OMAP3_LOGIC_USE_NEW_PRODUCT_ID was recently dropped
from usage and CONFIG_OMAP3_MICRON_DDR is unused in code.
Move this entry to Kconfig. As it is a hardware watchdog, select
HW_WATCHDOG. While we could default to enabling this for all platforms,
it is currently only enabled by default on AM33XX, so keep that logic
today.
Cc: Roger Meier <r.meier@siemens.com>
The symbols CONFIG_OMAP3_GPIO_X control if we enable the clocks for a
given GPIO bank in U-Boot. select the required banks for each target.
In some cases we need to also migrate from CONFIG_USB_EHCI (deprecated,
in include/configs/) to CONFIG_USB_EHCI_HCD as we only require the GPIO
bank to be enabled if USB is also enabled.
This driver is used often enough such that we want to have this enabled
by default on any ARCH_OMAP2PLUS board, and this only compiles on
ARCH_OMAP2PLUS due to required defines, so mark that as the depends.
We no longer have a need for a per-board CONFIG_OMAP3_xxx define (we
have CONFIG_TARGET_xxx when this is required), so drop these unused
references.
While there are a few different OMAP4 SoCs, today we always set
CONFIG_OMAP4430 and CONFIG_OMAP44XX. Convert the few test of
CONFIG_OMAP4430 to CONFIG_OMAP44XX.
Cc: Paul Kocialkowski <contact@paulk.fr>
We make use of CONFIG_OMAP3_EVM today to know when to do a specific
tweak in MUSB. This can be tested on via CONFIG_TARGET_OMAP3_EVM
instead, so switch there so we can drop the now unused symbol
CONFIG_OMAP3_EVM. In investigating what to do about the symbol usage we
see that the cairo board defines the same function, but never called it
(as it does not define CONFIG_OMAP3_EVM) and was just returning anyhow,
so drop that function from that board.
Cc: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr>
While in theory this value could be used in places outside of "omap5"
(such as OMAP4), we only make use of it today in OMAP5, so place the
Kconfig entry there. Given that Kconfig lets us provide a default, we
drop CONFIG_DEFAULT_OMAP_RESET_TIME_MAX_USEC entirely. The contents of
doc/README.omap-reset-time make a good help entry, so adjust them
slightly and delete the file. Move the comment about range to where we
use the value now, and have Kconfig enforce the upper bound.
In the two cases in the code where we use CONFIG_OMAP as a useful test
currently we can make use of CONFIG_ARCH_OMAP2PLUS instead. With that
changed we can drop all defines of CONFIG_OMAP. While in here,
CONFIG_OMAP3430 is only defined and then never used, so drop.
ATF(ARM Trusted Firmware) is used by ARM arch64 SoCs, find more infomation
about ATF at: https://github.com/ARM-software/arm-trusted-firmware
SPL is considered as BL2 in ATF terminology, it needs to load other parts
of ATF binary like BL31, BL32, SCP-BL30, and BL33(U-Boot). And needs to
prepare the parameter for BL31 which including entry and image information
for all other images. Then the SPL handle PC to BL31 with the parameter,
the BL31 will do the rest of work and at last get into U-Boot(BL33).
This patch needs work with patches from Andre for SPL support multi
binary in FIT.
The entry point of bl31 and bl33 are still using hard code because we
still can not get them from the FIT image information.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Tested-by: Heiko Stuebner <heiko@sntech.de>
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
