path: root/include
2012-02-27mx6q: mx6qsabrelite: Conditionally define macros for environment in serial flashEric Nelson
The default settings store the persistent environment on SD card and not serial flash (SPI NOR). To use SPI NOR to save the environment instead of SD card, edit include/configs/mx6qsabrelite.h and - undefine CONFIG_ENV_IS_IN_MMC - define CONFIG_ENV_IS_IN_SPI_FLASH The SPI driver can take as chip select the controller's chip selects as well as an external GPIO. The LSB byte has the value of the internal chip select, the highest (thought as 16-bit value) contains the GPIO number. The GPIO used on Sabre Lite is GP3:19 == 83. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Jason Liu <jason.hui@linaro.org> Tested-by: Jason Liu <jason.hui@linaro.org>
2012-02-27mx6q: mx6qsabrelite: Provide default serial flash bus and chip-selectEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Jason Liu <jason.hui@linaro.org> Tested-by: Jason Liu <jason.hui@linaro.org>
2012-02-27mx6q: mx6qsabrelite: Add ECSPI support to the Sabrelite platformEric Nelson
2012-02-27mx28evk: add SPI supportMatthias Fuchs
This patch adds SPI support for the MX28EVK. Support for an optionally installed SPI flash is also added. An example configuration for redundant envrionment from SPI flash is also added but disabled by default. This patch has been tested on a MX28EVK Rev. D with an installed SST25VF032B 32Mbit SPI flash. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-02-27mx28evk: add USB supportMatthias Fuchs
This patch enables USB host support on the MX28EVK board. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-02-27mx28evk: add RTC supportMatthias Fuchs
This patch adds support for the MX28 internal RTC and enables u-boot's date command. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-02-23microblaze: Enable TFTP put commandStephan Linz
Signed-off-by: Stephan Linz <linz@li-pro.net>
2012-02-17Merge branch 'master' of git://git.denx.de/u-boot-mmcWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mmc: mmc: make mmc_send_status() more reliable mmc: fix card busy polling Tegra: mmc: Fixed handling of interrupts in timeouts. omap_hsmmc: Wait for CMDI to be clear
2012-02-17Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mpc85xx: powerpc/8xxx:Add MPH controller support in USB device-tree fixup powerpc/8xxx: Cleanup USB device-tree fixup
2012-02-15mmc: make mmc_send_status() more reliableJan Kloetzke
Align the card status polling with the Linux kernel and retry the command at least five times. Also some cards apparently mishandle the status bits, so make sure to check the card state too. Signed-off-by: Jan Kloetzke <jan.kloetzke@dspg.com> Cc: Andy Fleming <afleming@gmail.com>
2012-02-15powerpc/8xxx:Add MPH controller support in USB device-tree fixupramneek mehresh
Add support for fixing usb mode and phy type for MPH(Multi Port Host) USB controllers in device-tree nodes. Required for socs like P3060, P5020, etc having MPH USB controller Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2012-02-13Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
* 'master' of git://git.denx.de/u-boot-blackfin: Blackfin: pata_bfin: fix printf warning Blackfin: bfin_nand: mark local func static linkage.h: move from blackfin to common includes Blackfin: br4: new board port Blackfin: add in/out le32 variants post: add blackfin to the post_time_ms list Blackfin: bf537-stamp: drop board reset workaround Blackfin: pr1: new board port
2012-02-12linkage.h: move from blackfin to common includesMacpaul Lin
1. Add linkage.h support from blackfin to common include, which is a reduced version from Linux. 2. Add architecture part support of linkage.h into blackfin 3. Fix include path of in blackfin related to linkage.h due to header file movement. Signed-off-by: Macpaul Lin <macpaul@andestech.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-02-12Blackfin: br4: new board portDimitar Penev
This adds support for the BR4 Appliance. It is a quad channel ISDN BRI board based on Blackfin BF537 CPU. Signed-off-by: Dimitar Penev <dpn@switchfin.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-02-12Blackfin: pr1: new board portDimitar Penev
This add support for the PR1 Appliance - Asterisk based ISDN PRI PBX. This board is Blackfin BF537 based. The schematics are not fully opened. Signed-off-by: Dimitar Penev <dpn@switchfin.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-02-12arm, davinci: Add support for the Calimain board from OMICRON electronicsChristian Riesch
This patch adds support for the Calimain board from OMICRON electronics GmbH. The board features a Texas Instruments AM1808 SoC, 128 MB DDR2 memory, and 64 MB NOR flash memory connected to CS2 and CS3. Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
2012-02-12Changes to move hawkboard to the new spl infrastructureSughosh Ganu
This patch moves hawkboard to the new spl infrastructure from the older nand_spl one. Removed the hawkboard_nand_config build option -- The spl code now gets compiled with hawkboard_config, after building the main u-boot image, using the CONFIG_SPL_TEXT_BASE. Modified the README.hawkboard to reflect the same. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Tom Rini <trini@ti.com> Acked-by: Christian Riesch <christian.riesch@omicron.at>
2012-02-12arm, arm926ejs: Add option CONFIG_SYS_EXCEPTION_VECTORS_HIGHChristian Riesch
The V bit of the c1 register of CP15 should not be cleared on DA850 SoCs since they have no valid memory at 0x00000000. This patch introduces a configuration option CONFIG_SYS_EXCEPTION_VECTORS_HIGH that allows setting the correct value for the V bit. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Reported-by: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Heiko Schocher <hs@denx.de>
2012-02-12arm, arm926ejs: Do cpu critical inits only for boards that require itChristian Riesch
This patch reverts commit ca4b55800ed74207c35271bf7335a092d4955416 "arm, arm926ejs: always do cpu critical inits" since it impacts all arm926ejs based configurations and caused problems, e.g., with the hawkboard. Instead the patch removes the CONFIG_SKIP_LOWLEVEL_INIT defines from the board configurations that need low level initialization. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de> Tested-by: Heiko Schocher <hs@denx.de>
2012-02-12davinci: add support for printing clock frequencyHadli, Manjunath
add support for printing various clock frequency info found in SOC such as ARM core frequency, DSP core frequency and DDR frequency as part of bdinfo command. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com>
2012-02-12davinci: remove macro CONFIG_DISPLAY_CPUINFOHadli, Manjunath
remove the macro CONFIG_DISPLAY_CPUINFO as it is no longer required. This is because clock info will be printed as part 'bdinfo' command and also remove support print_cpuinfo() as it will no longer be called. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com>
2012-02-12mcx: support for HTKW mcx boardIlya Yanok
This patch adds support for the HTKW mcx AM3517-based board. Serial, Ethernet, NAND, MMC, RTC, EHCI USB host and both NAND and MMC SPLs are supported. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <tom.rini@gmail.com> Cc: Detlev Zundel <dzu@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-02-12ARM: omap3: Added Teejet mt_ventouxStefano Babic
The mt_ventoux board is a custom board using the Technexion TAM3517 module. The patch fixes also the mtdparts variable in the TAM3517 common configuration file. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Ilya Yanok <yanok@emcraft.com> CC: Igor Grinberg <grinberg@compulab.co.il> CC: Tom Rini <tom.rini@gmail.com> Cc: Detlev Zundel <dzu@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-02-12OMAP3: TAM3517: update ehci interfaceStefano Babic
Changed the EHCI interface using the ulpi framework. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <tom.rini@gmail.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-02-12OMAP4: ehci-omap: enable ehci-omap for panda boardsGovindraj.R
For panda initialise the mux pins for ehci usage and enable ehci in omap4_panda config file. Signed-off-by: Govindraj.R <govindraj.raja@ti.com> Tested-by: Stefano Babic <sbabic@denx.de>
2012-02-12ehci-omap: driver for EHCI host on OMAP3Ilya Yanok
Taken from Beagle code. Tested on mcx board (AM3517-based). Signed-off-by: Ilya Yanok <yanok@emcraft.com> Tested-by: Stefano Babic <sbabic@denx.de>
2012-02-12usb: ulpi: Add omap-ulpi-view port supportGovindraj.R
Based on discussion from this thread [1]. Adding omap-view port that helps us in using the generic ulpi framework for any ulpi phy ops using the INSNREG05_ULPI viewport reg available on omap platform. Currently ehci ports are available on omap3/4 platforms so enable the same for beagle and panda, patch is tested on the same boards. Thanks to Igor Grinberg <grinberg@compulab.co.il> for reviewing the omap-ehci patches and suggesting this approach. [1]: http://www.mail-archive.com/u-boot@lists.denx.de/msg76076.html Tested-by: Stefano Babic <sbabic@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Govindraj.R <govindraj.raja@ti.com>
2012-02-12usb: ulpi: Extend the existing ulpi framework.Govindraj.R
Extend the existing ulpi viewport framework to pass the port number information for any ulpi ops. Fix the usage of ulpi api's accordingly. Tested-by: Stefano Babic <sbabic@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Govindraj.R <govindraj.raja@ti.com>
2012-02-12SMDK5250: Add ethernet supportChander Kashyap
This patch enable support for SMC911X based ethernet device. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-02-12EXYNOS: SMDK5250: Add MMC SPL supportChander Kashyap
This patch adds support for MMC SPL booting. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-02-12EXYNOS: Add SMDK5250 board supportChander Kashyap
SMDK5250 board is based on Samsungs EXYNOS5250 SoC. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-02-12Exynos: Clock.c: Use CONFIG_SYS_CLK_FREQ macroChander Kashyap
CONFIG_SYS_CLK_FREQ_C210 macro giving notion of S5PC2XX (Exynos4) architecture. Replace CONFIG_SYS_CLK_FREQ_C210 with CONFIG_SYS_CLK_FREQ to make it generic for exynos architecture. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-02-12ORIGEN: remove duplicated MACH_TYPE defineMinkyu Kang
Since MACH_TYPE_ORIGEN is updated on mach-types, remove the MACH_TYPE_ORIGEN on config file. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Cc: Chander Kashyap <chander.kashyap@linaro.org>
2012-02-12ARMV7: Exynos4: Add support for TRATS boardHeungJun, Kim
This patch adds support for Samsung TRATS board Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-02-12arm/km: speed up i2c access for keymile boardsHolger Brunck
We don't need 3us delay for our i2c bus. Decrease it to 1us. It would also be possible to use 100ns in the future, but currently kirkwood has no ndelay implementation. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Cc: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2012-02-12kirkwood: add support for D-Link DNS-325Stefan
This patch adds support for D-Link DNS-325 ShareCenter NAS. Signed-off-by: Stefan Herbrechtsmeier <stefan@code.herbrechtsmeier.net> Cc: prafulla@marvell.com Cc: albert.u.boot@aribaud.net
2012-02-12edminiv2: add USB host supportAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-02-12edminiv2: add hush parser, cmdline editing and long helpAlbert ARIBAUD
2012-02-12ARM: activate DISPLAY_CPUINFO for VCMA9 + SMDK2410 boardDavid Müller (ELSOFT AG)
Signed-off-by: David Mueller <d.mueller@elsoft.ch> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2012-02-12tt01: add MMC supportHelmut Raiger
board_mmc_init() initializes the pins of SDHC1 and turns on V_MMC1 of the PMIC. Config adds support for EXT2 and FAT. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
2012-02-12mc13783.h: create and add regulator mode 0 and 1Helmut Raiger
Add bit definitions for register 32 and 33 of Freescale MC13783. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
2012-02-12configs: Remove CONFIG_NET_MULTI from board filesFabio Estevam
CONFIG_NET_MULTI is not used anymore, so remove it from board files. Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Kumar Gala <kumar.gala@freescale.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefano Babic <sbabic@denx.de> Tested-by: Marek Vasut <marek.vasut@gmail.com> Tested-by: Heiko Schocher <hs@denx.de>
2012-02-12i.mx6q: mx6qsabrelite: Add the ethernet function supportJason Liu
Signed-off-by: Jason Liu <jason.hui@linaro.org> Signed-off-by: Eric Miao <eric.miao@linaro.org> CC: Jason Liu <jason.hui@linaro.org> CC: Stefano Babic <sbabic@denx.de>
2012-02-12i.mx6q: configs: Add fdt_high and initrd_high variablesDirk Behme
To be able to load the device tree and initrd correctly, set the fdt_high and initrd_high environment variables. Using 0xffffffff implies that the device tree and the initrd are initially copied to working addresses. This will avoid an additional copy. Loading the device tree to 0x30000000 and the initrd to 0x3c000000 should work for both boards, the ARM2 and SabreLite. Example (SabreLite): fatload mmc 0:2 0x10000000 uImage fatload mmc 0:2 0x3c000000 uInitrd fatload mmc 0:2 0x30000000 board.dtb bootm 0x10000000 0x3c000000 0x30000000 Note: This requires that the kernel has CONFIG_HIGHMEM enabled. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> CC: Jason Liu <jason.hui@linaro.org> CC: Stefano Babic <sbabic@denx.de> Acked-by: Jason Liu <jason.hui@linaro.org>
2012-02-12sdhc_boot: Introduce CONFIG_FSL_FIXED_MMC_LOCATION optionFabio Estevam
Since commit 97039ab98 (env_mmc: Allow board code to override the environment address) mmc_get_env_addr is a weak-aliased function in common/env_mmc.c The mmc_get_env_addr implementation that exists at board/freescale/common/sdhc_boot.c is meant to be used only for PowerPC boards, but currently it is being used for all platforms that have CONFIG_ENV_IS_IN_MMC defined. Introduce CONFIG_FSL_FIXED_MMC_LOCATION so that the boards that need to use the mmc_get_env_addr version from board/freescale/common/sdhc_boot.c could activate this config option on their board file. This fixes the retrieval of CONFIG_ENV_OFFSET on non-PowerPC boards. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefano Babic <sbabic@denx.de>
2012-02-12arm, davinci: cam_enc_4xx board updatesHeiko Schocher
- CONFIG_SYS_MMC_ENV_DEV, needed if environment on mmc - wait for 1 second timer in board_late_init() only, if timer is running. - add UBI/UBIFS support - add FIT images support - menu support - U-Boot max size now 0xa0000 - SPL now Block 0 page 0 - new MTD partitioning 0x00000000 SPL 0x00020000 UBL-Header 0x00040000 UBL-Header 0x00060000 UBL-Header 0x00080000 UBoot (0xa0000(U-Boot length) + 0x60000(3 spare blocks)) 0x00180000 ENV- Variablen (1) 0x001a0000 ENV- Variablen (2) 0x001c0000 ENV- Variablen (reserved for Bad Block) 0x001e0000 ENV- Variablen (reserved for Bad Block) 0x00200000 UBI-Device UBI Volumes: „default“: contain environment-default values „rootfs1“: UBIFS root-fs (1); contain linux kernel image „rootfs2“: UBIFS root-fs (2); contain linux kernel image „data-ro“: UBIFS data (read only) „data-rw“: UBIFS data (read/write) - new environment variables: - app_reset (this is only passed per cmdline to linux) - dvn_app_vers string from ramdisk description contained in the FIT image - dvn_boot_vers string from ubootimage description contained in the FIT image - saveparms, restoreparms, restoretmpparms, savetmpparms helper for saving network parameter. - ubiargs set ubi kernel cmdlinargs for booting with a ubifs rootfs - ubi_ubi boot with reading kernel image from ubifs, and use a ubifs as rootfs Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Tom Rini <tom.rini@gmail.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Wolfgang Denk <wd@denx.de>
2012-02-12common, menu: show menu on startup if CONFIG_MENU_SHOW is definedHeiko Schocher
show a menu on startup instead running the shell. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Jason Hobbs <jason.hobbs@calxeda.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Jason Hobbs <jason.hobbs@calxeda.com>
2012-02-12common, menu: add statusline supportHeiko Schocher
add the possibility to show a statusline when printing a menu Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Jason Hobbs <jason.hobbs@calxeda.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-02-12common: add possibility for readline_into_buffer timeoutHeiko Schocher
add possibility to add a timeout when reading a line into a buffer. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-02-12OMAP3: Add Corscience Tricorder boardThomas Weber
Tricorder is a board which is very similar to the Devkit8000. It is designed as a base platform for further medical devices. www.corscience.de/en/medical-engineering/products/multiparameter/mp10-board.html Signed-off-by: Thomas Weber <weber@corscience.de>
