path: root/include
2013-03-04ubifs: Allow ubifsmount volume reference by numberJoe Hershberger
UBI can mount volumes by name or number The current code forces you to name the volume by prepending every name with "ubi:". >From fs/ubifs/super.c * There are several ways to specify UBI volumes when mounting UBIFS: * o ubiX_Y - UBI device number X, volume Y; * o ubiY - UBI device number 0, volume Y; * o ubiX:NAME - mount UBI device X, volume with name NAME; * o ubi:NAME - mount UBI device 0, volume with name NAME. Now any name passed in any of the above forms are allowed. Also update the configs that referenced ubifsmount. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-03-04sandbox: config: Enable sandbox commandSimon Glass
The 'sb' command allows loading files from the host, and listing directories. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-04sandbox: Enable ext4 and fat filesystemsSimon Glass
These are useful for build-testing code, at least. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-04sandbox: Add 'sb' command to access filesystem featuresSimon Glass
The new 'sb' command is intended to deal with sandbox-specific features that have no parallel in other archs. This commit adds two sub-commands to list a directory and read a file from the host filesystem. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-04sandbox: Add host filesystemSimon Glass
This allows reading of files from the host filesystem in sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-04sandbox: Add a way of obtaining directory listingsSimon Glass
This implementation uses opendir()/readdir() to access the directory information and then puts it in a linked list for the caller's use. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-04fs: Move ls and read methods into ext4, fatSimon Glass
It doesn't make a lot of sense to have these methods in fs.c. They are filesystem-specific, not generic code. Add each to the relevant filesystem and remove the associated #ifdefs in fs.c. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-04Merge branch 'mem' of git://git.denx.de/u-boot-x86Tom Rini
2013-03-04Merge branch 'master' of git://git.denx.de/u-boot-blackfinTom Rini
2013-03-04blackfin: bf60x: add hw watchdog supportBob Liu
Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
2013-03-04blackfin: bf60x: add board and headers files to support bf609Sonic Zhang
Board and config header files for bf609-ezkit support. Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
2013-03-01OMAP3: drop CONFIG_SPL_OS_BOOT_KEY and use local defineStefano Babic
CONFIG_SPL_OS_BOOT_KEY is used only in board files. It is not required to have a general CONFIG_ option. Rename it and define it in board directory. Signed-off-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2013-02-28hash: Use lower case for hash algorithm namesSimon Glass
Rather than use strcasecmp() in the hash algorithm search, require the caller to do this first. Most of U-Boot can use lower case anyway, and the hash command can convert to lower case before calling hash_command(). This saves needing strcasecmp() for boards that use hashing but not the hash command. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28sandbox: config: Enable hash functions and mtestSimon Glass
Enable the hash command and sha1/256 hashing for sandbox. Also use a better address for memory testing (since the existing one is set up for linux host memory space). Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28Roll crc32 into hash infrastructureSimon Glass
Add the CRC32 algorithm to the list of available hashes, and make the crc32 command use hash_command(). Add a new crc32_wd_buf() to make this possible, which puts its result in a buffer rather than returning it as a 32-bit value. Note: For some boards the hash command is not enabled, neither are sha1, sha256 or the verify option. In this case the full hash implementation adds about 500 bytes of overhead. So as a special case, we use #ifdef to select very simple bahaviour in that case. The justification for this is that it is currently a very common case (virtually all boards enable crc32 but only some enable more advanced features). Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28hash: Add a flag to support saving hashes in the environmentSimon Glass
Some hashing commands permit saving the hash in an environment variable, and verifying a hash from there. But the crc32 command does not support this. In order to permit crc32 to use the generic hashing infrastructure, add a flag to select which behaviour to use. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28Update set_working_fdt_addr() to use setenv_addr()Simon Glass
We might as well use this common function instead of repeating the same code. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28sandbox: Add un/map_sysmen() to deal with sandbox's ram_bufSimon Glass
Sandbox doesn't actually provide U-Boot access to the machine's physical memory. Instead it provides a RAM buffer of configurable size, and all memory accesses are within that buffer. Sandbox memory starts at 0 and is CONFIG_DRAM_SIZE bytes in size. Allowing access outside this buffer might produce unpredictable results in the event of an error, and would expose the host machine's memory architecture to the sandbox U-Boot. Most U-Boot functions assume that they can just access memory at given address. For sandbox this is not true. Add a map_sysmem() call which converts a U-Boot address to a system address. In most cases this is a NOP, but for sandbox it returns a pointer to that memory inside the RAM buffer. To get a U-Boot feature to work correctly within sandbox, you should call map_sysmem() to get a pointer to the address, and then use that address for any U-Boot memory accesses. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28sandbox: Improve sandbox serial port keyboard interfaceTaylor Hutt
Implements the tstc() interface for the serial driver. Multiplexing the console between the serial port and a keyboard uses a polling method of checking if characters are available; this means that the serial console must be non-blocking when attempting to read characters. Signed-off-by: Taylor Hutt <thutt@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28Update print_buffer() to use constSimon Glass
The buffer cannot be changed by this function, so change the buffer pointer to a const. This allows callers with const pointer to use the function without a cast. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-19vsprintf: add ustrtoll functionPiotr Wilczek
Add 'ustrtoull' function to convert size from string (ex: 1GiB) to unsigned long long type Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2013-02-19malloc: make malloc_bin_reloc staticGabor Juhos
On architectures where manual relocation is needed, the 'malloc_bin_reloc' function must be called after 'mem_malloc_init'. Make the 'malloc_bin_reloc' function static and call it directly from 'mem_malloc_init' instead of calling that from board_init_{r,f} functions of the affected architectures. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Andreas Bießmann <andreas.devel@gmail.com> Cc: Jason Jin <Jason.jin@freescale.com> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2013-02-15powerpc/83xx/km: drop uneeded dtt_bus environment varHolger Brunck
There is no need for a environment variable to configure the dtt bus. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15powerpc/83xx/km: remove uneeded CONFIG_MISC_INIT_RHolger Brunck
Remove it from the processor specific headers. This is already defined in the common header km83xx.h. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15powerpc/83xx/km: add support for kmopti2 boardHolger Brunck
This board is similar to TUXX1 but it has a different sized second FPGA. Therefore the configuration for the third chipselect is different. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15powerpc/83xx/km: cleanup tuxx1 supportHolger Brunck
This is a preparation for the upcoming kmopti2 board. This board has also a second fpga on board which is different to the tuxx1 target. But we want to use the same header file. So remove the config option KM_DISABLE_APP2 and simply use the board names to distinguish the features. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15km/common: add eccmode to kernel commandlineHolger Brunck
If CONFIG_NAND_ECC_BCH is chosen from in the board configuration we add an ecc mode to the kernel commandline. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15powerpc/83xx: use NAND_ECC_BCH for kmcoge5neHolger Brunck
Switch from 1-bit ecc to 4-bit ecc. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15km/common: introduce $uimage variableAndreas Huber
Replace the hardcoded string with a variable. If CONFIG_NAND_ECC_BCH is set we use a specific name for the uImage (ecc_bch_uImage). Signed-off-by: Andreas Huber <andreas.huber@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15powerpc/83xx: use ppc_6xx as arch variable for kmvect1Holger Brunck
On this board we are using hard floating point, so select the correct toolchain. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15powerpc/83xx/km: add MV88E6122 switch support for kmvect1Karlheinz Jerg
kmvect1 has a UEC2 connection to the piggy board and a UEC0 connection to the switch MV88E6122. This switch has a connection to a frontport ethernet interface. The ethernet port used for network booting is automatically selected by u-boot. If a Piggy is plugged, the Piggy port is selected (UEC2, eth1). If the Piggy isn't present, the Frontport is selected (UEC0, eth0). The switch reset is connected to a GPIO on the PRIO3 board FPGA (GPIO28) and released at startup. Signed-off-by: Karlheinz Jerg <karlheinz.jerg@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-14x86: Rename CONFIG_NO_X86_RESET_VECTOR to CONFIG_X86_RESET_VECTORSimon Glass
Invert the polarity of this option to simplify the Makefile logic. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Gabe Black <gabeblack@chromium.org>
2013-02-14x86: Remove eNET boardsSimon Glass
These are no longer used and should be removed. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Graeme Russ <graeme.russ@gmail.com>
2013-02-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-02-11Tegra114: Add/enable Dalmore build (T114 reference board)Tom Warren
This build is stripped down. It boots to the command prompt. GPIO is the only peripheral supported. Others TBD. Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11tegra: cardhu: config: enable SPIAllen Martin
Turn on SPI in cardhu config file Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11tegra: add SPI SLINK driverAllen Martin
Add driver for tegra SPI "SLINK" style driver. This controller is similar to the tegra20 SPI "SFLASH" controller. The difference is that the SLINK controller is a genernal purpose SPI controller and the SFLASH controller is special purpose and can only talk to FLASH devices. In addition there are potentially many instances of an SLINK controller on tegra and only a single instance of SFLASH. Tegra20 is currently ths only version of tegra that instantiates an SFLASH controller. This driver supports basic PIO mode of operation and is configurable (CONFIG_OF_CONTROL) to be driven off devicetree bindings. Up to 4 devices per controller may be attached, although typically only a single chip select line is exposed from tegra per controller so in reality this is usually limited to 1. To enable this driver, use CONFIG_TEGRA_SLINK Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11tegra: spi: add fdt support to tegra SPI SFLASH driverAllen Martin
Add support for configuring tegra SPI driver from devicetree. Support is keyed off CONFIG_OF_CONTROL. Add entry in seaboard dts file for spi controller to describe seaboard spi. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11tegra: don't hard-code LCD into default TEGRA_DEVICE_SETTINGSStephen Warren
Only add "lcd" into TEGRA_DEVICE_SETTINGS if CONFIG_VIDEO_TEGRA. Otherwise, "lcd" is meaningless. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-08Clean up libfdt.h includesGerald Van Baren
The libfdt.h file is the definition file for libfdt. It is unnecessary to include other fdt header files (the necessary ones are pulled in by libfdt.h). Signed-off-by: Gerald Van Baren <gvb@unssw.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Stefan Roese <sr@denx.de>
2013-02-07common/fdt_support.c: sparse fixesKim Phillips
trivial: fdt_support.c:89:64: warning: Using plain integer as NULL pointer fdt_support.c:325:65: warning: Using plain integer as NULL pointer fdt_support.c:352:65: warning: Using plain integer as NULL pointer For the following bad constant expression, We hardcode the max. number of memory banks to four for the foreseeable future, and add an error with instructions on what to do once it's exceeded: fdt_support.c:397:22: error: bad constant expression For the rest below, sparse found a couple of wrong endian conversions in of_bus_default_translate() and fdt_get_base_address(), but otherwise the rest is mostly annotation fixes: fdt_support.c:64:24: warning: cast to restricted __be32 fdt_support.c:192:21: warning: incorrect type in assignment (different base types) fdt_support.c:192:21: expected unsigned int [unsigned] [usertype] tmp fdt_support.c:192:21: got restricted __be32 [usertype] <noident> fdt_support.c:201:21: warning: incorrect type in assignment (different base types) fdt_support.c:201:21: expected unsigned int [unsigned] [addressable] [usertype] tmp fdt_support.c:201:21: got restricted __be32 [usertype] <noident> fdt_support.c:304:13: warning: incorrect type in assignment (different base types) fdt_support.c:304:13: expected unsigned int [unsigned] [usertype] val fdt_support.c:304:13: got restricted __be32 [usertype] <noident> fdt_support.c:333:13: warning: incorrect type in assignment (different base types) fdt_support.c:333:13: expected unsigned int [unsigned] [usertype] val fdt_support.c:333:13: got restricted __be32 [usertype] <noident> fdt_support.c:359:13: warning: incorrect type in assignment (different base types) fdt_support.c:359:13: expected unsigned int [unsigned] [usertype] val fdt_support.c:359:13: got restricted __be32 [usertype] <noident> fdt_support.c:373:21: warning: cast to restricted __be32 fdt_support.c:963:48: warning: incorrect type in argument 1 (different base types) fdt_support.c:963:48: expected restricted __be32 const [usertype] *p fdt_support.c:963:48: got unsigned int [usertype] *<noident> fdt_support.c:971:48: warning: incorrect type in argument 1 (different base types) fdt_support.c:971:48: expected restricted __be32 const [usertype] *p fdt_support.c:971:48: got unsigned int [usertype] *<noident> fdt_support.c:984:29: warning: incorrect type in argument 1 (different base types) fdt_support.c:984:29: expected restricted __be32 const [usertype] *cell fdt_support.c:984:29: got unsigned int [usertype] *addr fdt_support.c:996:32: warning: incorrect type in argument 1 (different base types) fdt_support.c:996:32: expected restricted __be32 const [usertype] *cell fdt_support.c:996:32: got unsigned int [usertype] *addr fdt_support.c:1041:41: warning: incorrect type in argument 1 (different base types) fdt_support.c:1041:41: expected restricted __be32 const [usertype] *cell fdt_support.c:1041:41: got unsigned int [usertype] *addr fdt_support.c:1053:41: warning: incorrect type in argument 2 (different base types) fdt_support.c:1053:41: expected restricted __be32 const [usertype] *range fdt_support.c:1053:41: got unsigned int const [usertype] *[assigned] ranges fdt_support.c:1064:53: warning: incorrect type in argument 2 (different base types) fdt_support.c:1064:53: expected restricted __be32 const [usertype] *addr fdt_support.c:1064:53: got unsigned int [usertype] *addr fdt_support.c:1110:50: warning: incorrect type in argument 2 (different base types) fdt_support.c:1110:50: expected restricted __be32 const [usertype] *addr fdt_support.c:1110:50: got unsigned int *<noident> fdt_support.c:1121:49: warning: incorrect type in argument 1 (different base types) fdt_support.c:1121:49: expected restricted __be32 const [usertype] *cell fdt_support.c:1121:49: got unsigned int *<noident> fdt_support.c:1147:60: warning: incorrect type in argument 2 (different base types) fdt_support.c:1147:60: expected restricted __be32 const [usertype] *addr fdt_support.c:1147:60: got unsigned int *<noident> fdt_support.c:1081:5: warning: symbol '__of_translate_address' was not declared. Should it be static? fdt_support.c:1154:5: error: symbol 'fdt_translate_address' redeclared with different type (originally declared at include/fdt_support.h:95) - incompatible argument 3 (different base types) fdt_support.c: In function 'fdt_node_offset_by_compat_reg': fdt_support.c:1173:17: warning: initialization discards 'const' qualifier from pointer target type [enabled by default] See also linux kernel commit 0131d897 "of/address: use proper endianess in get_flags". Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Jerry Van Baren <gvb.uboot@gmail.com>
2013-02-07libfdt: update from upstream dtc commit 142419eKim Phillips
commit 142419e "dtc/libfdt: sparse fixes", for u-boot's libfdt copy. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Jerry Van Baren <gvb.uboot@gmail.com>
2013-02-07libfdt: update fdt.h from upstream dtcKim Phillips
upstream dtc commit feafcd972cb744750a65728440c99526e6199a6d "dtc/libfdt: introduce fdt types for annotation by endian checkers". Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Jerry Van Baren <gvb.uboot@gmail.com>
2013-02-07libfdt_env.h: add fdt type definitionsKim Phillips
fdt types are big endian. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Jerry Van Baren <gvb.uboot@gmail.com>
2013-02-07treewide: include libfdt_env.h before fdt.hKim Phillips
and, if including libfdt.h which includes libfdt_env.h in the correct order, don't include fdt.h before libfdt.h. this is needed to get the fdt type definitions set from the project environment before fdt.h uses them. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Jerry Van Baren <gvb.uboot@gmail.com>
2013-02-07AM335X: Set fdt_high for AM335X devices to enable booting with Device Treehvaibhav@ti.com
For AM335X boards, such as the EVM and Bone Linux kernel fails to locate the device tree blob on boot. The reason being is that u-boot is copying the DT blob to the upper part of RAM when booting the kernel and the kernel is unable to access the blob. By setting the fdt_high variable to 0xffffffff (to prevent the copy) the kernel is able to locate the DT blob and boot. This patch is tested on BeagleBone platform. Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Tom Rini <trini@ti.com>
2013-02-07pcm051: Add support for Phytec phyCORE-AM335xLars Poeschel
The board is named pcm051 and has this hardware: SOC: TI AM3359 DDR3-RAM: 2x MT41J256M8HX-15EIT:D 512MiB ETH 1: LAN8710AI SPI-Flash: W25Q64BVSSIG RTC: RV-4162-C7 I2C-EEPROM: CAT32WC32 NAND: MT29F4G08_VFPGA63 PMIC: TPS65910A3 LCD Supported: UART 1 MMC/SD ETH 1 USB I2C SPI Not yet supported: NAND RTC LCD Signed-off-by: Lars Poeschel <poeschel@lemonage.de> [trini: Add #define CONFIG_PHY_ADDR 0 to config] Signed-off-by: Tom Rini <trini@ti.com>
2013-02-07omap4: allow the use of a plain text env file instead boot scriptsJavier Martinez Canillas
For production systems it is better to use script images since they are protected by checksums and carry valuable information like name and timestamp. Also, you can't validate the content passed to env import. But for development, it is easier to use the env import command and plain text files instead of script-images. Since both OMAP4 supported boards (Panda and TI SDP4430) are used primarily for development, this patch allows U-Boot to load env var from a text file in case that an boot.scr script-image is not present. The variable uenvcmd (if existent) will be executed (using run) after uEnv.txt was loaded. If uenvcmd doesn't exist the default boot sequence will be started. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Acked-by: Nishanth Menon <nm@ti.com>
2013-02-07OMAP3: igep00x0: add boot status GPIO LEDJavier Martinez Canillas
This patch adds an GPIO LED boot status for IGEP boards. The GPIO LED used is the red LED0 while the Linux kernel uses the green LED0 as the boot status. By using different GPIO LEDs, the user can know in which step of the boot process the board currently is. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-02-07OMAP3: use a single board file for IGEP devicesJavier Martinez Canillas
Even when the IGEPv2 board and the IGEP Computer-on-Module are different from a form factor point of view, they are very similar in the fact that share many components and how they are wired. So, it is possible (and better) to have a single board file for both devices and just use the CONFIG_MACH_TYPE to make a differentiation between each board when needed. This change avoids code duplication by removing 298 lines of code and makes future maintenance easier. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
