verify, autostart and lmb fields are used regardless of CONFIG_FIT
setting, move their definitions to common section.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
Save FIT configuration provied in the first bootm argument and use it
when to get ramdisk/FDT subimages when second and third (ramdisk/FDT)
arguments are not specified.
autoscript() routine is updated to accept second argument, which
is only used for FIT images and provides a FIT subimage unit name.
autoscript() routine callers must now pass two arguments. For
non-interactive use (like in cmd_load.c, cmd_net.c), new environment
variable 'autoscript_uname' is introduced and used as a FIT
subimage unit name source.
autoscript command accepts extended syntax of the addr argument:
addr:<subimg_uname>
This patch adds new node offset fields to struct bootm_headers
and updates bootm_headers processing code to make use of them.
Saved node offsets allow to avoid repeating fit_image_get_node() calls.
boot_get_ramdisk() and image_get_ramdisk() do not need all
cmdtp, flag, argc and argv arguments. Simplify routines definition.
Support for the new uImage format (FIT) is added to mkimage tool.
Commandline syntax is appropriately extended:
mkimage [-D dtc_options] -f fit-image.its fit-image
mkimage (together with dtc) takes fit-image.its and referenced therein
binaries (like vmlinux.bin.gz) as inputs, and produces fit-image file -- the
final image that can be transferred to the target (e.g., via tftp) and then
booted using the bootm command in U-Boot.
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
Add FDT-based functions for handling new format component images,
configurations, node operations, property get/set, etc.
fit_ - routines handling global new format uImage operations
like get/set top level property, process all nodes, etc.
fit_image_ - routines handling component images subnodes
fit_conf_ - routines handling configurations node
initialize the UPIOx controller.
add support for the config Flash.
the dts file basenames were updated in linux - this helps avoid
inadvertently loading any old dtbs laying around.
1. Make the CSB bus pipeline depth as 4, and enable
the repeat mode;
2. Raise the eTSEC emergency priority;
3. Use the highest IP blocks clock.
Signed-off-by: Dave Liu <daveliu@freescale.com>
The latter version stops when "run load" fails for whatever reasons
rendering the combination *a lot* more secure.
Signed-off-by: Detlev Zundel <dzu@denx.de>
Originally pointed out by Laurent Pinchart <laurent.pinchart@tbox.biz>,
see http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/22846
Signed-off-by: Bernhard Nemec <bnemec <at> ganssloser.com>
This fixes the cluster size tests in the FAT32 file system.
The current implementation of VFAT support doesn't work if the
referred cluster has an offset > 16bit representation, causing
"fatload" and "fatls" commands etc. to fail.
Signed-off-by: michael trimarchi <trimarchi@gandalf.sssup.it>
The 405EZ only supports 512 bytes of rx-/tx-fifo EMAC sizes. But
currently 4k/2k is configured. This patch fixes this issue.
Thanks to Thomas Kindler <tkindler@lenord.de> for pointing this out.
Adds PCI support for MPC5121
Tested with drivers/net/rtl8139.c
Support is conditional since PCI on old silicon does not work.
ads5121_PCI_config turns on PCI
In this version, condition compilation of PCI code has been moved
from ifdef in board/ads5121/pci.c to board/ads5121/Makefile as
suggested by Jean-Christophe PLAGNIOL-VILLARD
Signed-off-by: John Rigby <jrigby@freescale.com>
Sync register definitions with linux
targets.
The previous patch was lacking of i386, microblaze, nios and nios2. This
patch tries to fix them.
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
This patch adds an fdt_next_node() function which can be used to
iterate through nodes of the tree while keeping track of depth. This
function is used to simplify the iteration code in a lot of other
functions, and is also exported for use by library users.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
This patch adds the following common routines:
1) Dedicated mkimage print_header() is replaced with common
image_print_contents()
image_print_contents_noindent()
2) Common os/arch/type/comp fields name <--> id translation routines
genimg_get_os_name()
genimg_get_arch_name()
genimg_get_type_name()
genimg_get_comp_name()
genimg_get_os_id()
genimg_get_arch_id()
genimg_get_type_id()
genimg_get_comp_id()
This patch introduces the following prefix convention for the
image format handling and bootm related code:
genimg_ - dual format shared code
image_ - legacy uImage format specific code
fit_ - new uImage format specific code
boot_ - booting process related code
Related routines are renamed and a few pieces of code are moved around and
re-grouped.
Allow the user to set 'bootm_low' and 'bootm_size' env vars as a way
to restrict what memory range is used for bootm.
Acked-by: Marian Balakowicz <m8@semihalf.com>
Convert generic ramdisk_high(), get_boot_cmdline(), get_boot_kbd()
functions over to using lmb for allocation of the ramdisk, command line
and kernel bd info.
Convert PPC specific fdt_relocate() to use lmb for allocation of the device
tree.
Provided a weak function that board code can call to do additional
lmb reserves if needed.
Also introduce the concept of bootmap_base to specify the offset in
physical memory that the bootmap is located at. This is used for
allocations of the cmdline, kernel bd, and device tree as they should
be contained within bootmap_base and bootmap_base + CFG_BOOTMAPSZ.
The autostart env variable was dropped as part of the initial new uImage
cleanup. Add it back here so the arch specific code can decide if it
wants to really boot or not.
Introduce the LMB lib used on PPC in the kernel as a clean way to manage
the memory spaces used by various boot images and structures. This code
will allow us to simplify the code in bootm and its support functions.
Changed image_get_ramdisk() to just return NULL on error and have
get_ramdisk() propogate that error to the caller. It's left to the
caller to call do_reset() if it wants to.
Also moved calling do_reset() in get_fdt() and fdt_relocate() on ppc
to a common location. In the future we will change get_fdt() and
fdt_relocate() to return success/failure and not call do_reset() at all.
We don't actually need the kdb param as we are just using it to get
bd->bi_memsize which we can get from gd->bd->bi_memsize. Also, if we
boot via OF we might not actually fill out a kdb.
Dual format image code must properly handle all three FDT passing methods:
- raw FDT blob passed
- FDT blob embedded in the legacy uImage
- FDT blob embedded in the new uImage
This patch enables proper raw FDT handling when no FIT imaeg support
is compiled in. This is a bit tricky as we must dected FIT format even
when FIT uImage handling is not enabled as both FIT uImages and raw FDT
blobs use tha same low level format (libfdt).
Do not pass image verification flag directly to related routines.
Simplify argument passing and move it to the bootm_header structure which
contains curently processed image specific data and is already being passed
on the argument list.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
This patch adds framework for dual format images. Format detection is added
and the bootm controll flow is updated to include cases for new FIT format
uImages.
When the legacy (image_header based) format is detected appropriate
legacy specific handling is invoked. For the new (FIT based) format uImages
dual boot framework has a minial support, that will only print out a
corresponding debug messages. Implementation of the FIT specific handling will
be added in following patches.
targets.
Olaf Hering [Wed, 17 Oct 2007 06:27:13 +0000 (23:27 -0700)]
Remove the __STRICT_ANSI__ check from the __u64/__s64 declaration on
32bit targets.
GCC can be made to warn about usage of long long types with ISO C90
(-ansi), but only with -pedantic. You can write this in a way that even
then it doesn't cause warnings, namely by:
#ifdef __GNUC__
__extension__ typedef __signed__ long long __s64;
__extension__ typedef unsigned long long __u64;
#endif
The __extension__ keyword in front of this switches off any pedantic
warnings for this expression.
Signed-off-by: Olaf Hering <olh@suse.de>
Cc: <linux-arch@vger.kernel.org>
The Linux commit fac8b209b1084bc85748bd54e13d00c1262b220f ("Remove
final traces of long-deprecated "ramdisk" kernel parm") makes these
changes neccessary.
Some boards (e.g. lwmon5) may use rather small watchdog intervals, so
causing it to reboot the board if U-Boot does a long busy-wait with
udelay(). Thus, for these boards we have to restart WD more
frequently.
This patch splits the busy-wait udelay() into smaller, predefined,
intervals, so that the watchdog timer may be resetted with the
configurable (CONFIG_WD_PERIOD) interval.
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Adds configuration option for ATI Radeon 9200 card
support to sequoia config file. If CONFIG_VIDEO
is enabled, TEXT_BASE should be changed to 0xFFF80000.
A few duplicate of the ARRAY_SIZE macro sneaked in since we put
the define in common.h.
