The SPL image overflows when cpsw dt nodes are added and SPL_OF_CONTROL
is enabled. Use static platdata instead to save space.
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
ti_cm_get_macid() is used to get a syscon node from the dt, read the
efuse address and then assign the macid read from the address. Divide
these two steps into separate functions one of which can be called from
ofdata_to_platdata() while the other can be called from _probe(). This
ensures that platdata can be assigned statically in a board file when
OF_CONTROL is not enabled. Also add a macid_sel_compat in private data
to get information about the macid byte placement.
cpsw_phy_sel() is a configuration step that should not be in
ofdata_to_platdata(). Add phy_sel_compat to the cpsw_platform_data
structure so that it is accessible in _probe. Then move the call of
cpsw_phy_sel() to _probe.
Add a priv member for eth_pdata for platform specific platform data.
DMSC can use certain amount of msmc memory available in the
system. Also certain part of msmc memory can be marked as L3
cache using board config. But users might not know what size
is being used and the remaining available msmc memory. In order
to fix this TISCI protocol provides a messages that can query
the available msmc memory in the system. Add support for this
message.
Now that NAND is supported on DRA71x include various NAND environment
settings
In order to fully support SPL_OF_CONTROL, we need BSS to be a bit
larger. This patch relocates BSS to SDRAM instead of SRAM which
is similar to how ARMv7 boards (like OMAP2+) do it.
This means two new variables are required:
CONFIG_SPL_BSS_START_ADDR set to DAVINCI_DDR_EMIF_DATA_BASE
CONFIG_SPL_BSS_MAX_SIZE is set to 0x1080000 which is 1 byte
before the location where U-Boot will load.
Add support for the Bosch Guardian board.
CPU : AM335X-GP rev 2.1
Model: Bosch AM335x Guardian
I2C: ready
DRAM: 256 MiB
NAND: 512 MiB
MMC: OMAP SD/MMC: 0
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Signed-off-by: Martyn Welch <martyn.welch@collabora.com>
Reviewed-by: Felix Brack <fb@ltec.ch>
Merge drivers/soc/keystone/ into drivers/soc/ti/
and convert CONFIG_TI_KEYSTONE_SERDES into Kconfig.
Signed-off-by: Vignesh R <vigneshr@ti.com>
The UDMA-P is intended to perform similar (but significantly upgraded) functions
as the packet-oriented DMA used on previous SoC devices. The UDMA-P module
supports the transmission and reception of various packet types.
The UDMA-P also supports acting as both a UTC and UDMA-C for its internal
channels. Channels in the UDMA-P can be configured to be either Packet-Based or
Third-Party channels on a channel by channel basis.
The initial driver supports:
- MEM_TO_MEM (TR mode)
- DEV_TO_MEM (Packet mode)
- MEM_TO_DEV (Packet mode)
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Add TI Communications Port Programming Interface (CPPI) 5
interface description and helpers
The Ring Accelerator (RINGACC or RA) provides hardware acceleration to
enable straightforward passing of work between a producer and a consumer.
There is one RINGACC module per NAVSS on TI AM65x SoCs.
The RINGACC converts constant-address read and write accesses to equivalent
read or write accesses to a circular data structure in memory. The RINGACC
eliminates the need for each DMA controller which needs to access ring
elements from having to know the current state of the ring (base address,
current offset). The DMA controller performs a read or write access to a
specific address range (which maps to the source interface on the RINGACC)
and the RINGACC replaces the address for the transaction with a new address
which corresponds to the head or tail element of the ring (head for reads,
tail for writes). Since the RINGACC maintains the state, multiple DMA
controllers or channels are allowed to coherently share the same rings as
applicable. The RINGACC is able to place data which is destined towards
software into cached memory directly.
Supported ring modes:
- Ring Mode
- Messaging Mode
- Credentials Mode
- Queue Manager Mode
TI-SCI integration:
Texas Instrument's System Control Interface (TI-SCI) Message Protocol now
has control over Ringacc module resources management (RM) and Rings
configuration.
The Ringacc driver manages Rings allocation by itself now and requests
TI-SCI firmware to allocate and configure specific Rings only. It's done
this way because, Linux driver implements two stage Rings allocation and
configuration (allocate ring and configure ring) while TI-SCI Message
Protocol supports only one combined operation (allocate+configure).
Texas Instruments' System Control Interface (TI-SCI) Message Protocol
abstracts management of NAVSS resources, like PSI-L pairing and
unpairing, UDMAP tx/rx/flow configuration and Rings.
This patch adds support for requesting and configuring such resources
from TI-SCI firmware.
- Various rmobile fixes
The command line is:
ln <interface> <dev[:part]> target linkname
Currently symbolic links are supported only in ext4 and only if the option
CMD_EXT4_WRITE is enabled.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Re-use the functions used to write/create a file, to support creation of a
symbolic link.
The difference with a regular file are small:
- The inode mode is flagged with S_IFLNK instead of S_IFREG
- The ext2_dirent's filetype is FILETYPE_SYMLINK instead of FILETYPE_REG
- Instead of storing the content of a file in allocated blocks, the path
to the target is stored. And if the target's path is short enough, no block
is allocated and the target's path is stored in ext2_inode.b.symlink
As with regulars files, if a file/symlink with the same name exits, it is
unlinked first and then re-created.
[trini: Fix ext4 env code]
There is no need to modify the buffer passed to ext4fs_write_file().
The memset() call is not required here and was likely copied from the
equivalent part of the ext4fs_read_file() function where we do need it.
When a file contains extents, U-Boot currently reads extent-related data
for each block in the file, even if that data is located in the same
block each time. This significantly slows down loading of files that use
extents. Implement a very dumb cache to prevent repeatedly reading the
same block. Files with extents now load as fast as files without.
Note: There are many cases where read_allocated_block() is called. This
patch only addresses one of those places; all others still read redundant
data in any case they did before. This is a minimal patch to fix the
load command; other cases aren't fixed.
Increase the USB power good delay on Alt, this is required with
certain USB sticks, otherwise they might not be detected.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Synchronize R-Car Gen3 clock tables with Linux 5.0,
commit 1c163f4c7b3f621efff9b28a47abb36f7378d783 .
Synchronize R-Car Gen2 clock tables with Linux 5.0,
Add required Kconfig symbols, Makefile bits and macro fixes in a
few places to support LZO and DT compression in U-Boot. This can
save a lot of space with multi-DTB fitImages.
Split fdtdec_setup_memory_banksize() into fdtdec_setup_memory_banksize_fdt(),
which allows the caller to pass custom blob into the function and the
original fdtdec_setup_memory_banksize(), which uses the gd->fdt_blob. This
is useful when configuring the DRAM properties from a FDT blob fragment
passed in by the firmware.
Split fdtdec_setup_mem_size_base() into fdtdec_setup_mem_size_base_fdt(),
original fdtdec_setup_mem_size_base(), which uses the gd->fdt_blob. This
First set of u-boot-atmel features and fixes for 2019.07 cycle
Add slew rate support for SAM9X60 pin controller.
Signed-off-by: Claudiu Beznea <claudiu.beznea@microchip.com>
The GARDENA smart Gateway boards are equipped with an Atmel / Microchip
AT91SAM9G25 SoC and with 128 MiB of RAM and 256 MiB of NAND storage.
This patch adds support for this board including SPL support. Therefore
the AT91Boostrap is not needed on this platform any more.
Cc: Andreas Bießmann <andreas@biessmann.org>
Cc: Eugen Hristev <eugen.hristev@microchip.com>
This patch adds the necessary defines to the Siemens AT91SAM based
boards (smartweb, corvus and taurus) to generate the combined binary
image with SPL and main U-Boot image combined (u-boot-with-spl.bin).
Tested on the taurus board:
Tested-by: Heiko Schocher <hs@denx.de>
This patch adds some checks, so that the watchdog can be enabled in main
U-Boot proper but can be disabled in SPL.
This will be used by some AT91SAM based boards, which might enable the
watchdog in the main U-Boot proper and not in SPL. It will be enabled in
SPL by default there, so no need to configure it there. This approach
saves some space in SPL.
Migrate the following options to CONFIG_DM:
CONFIG_DM_GPIO
CONFIG_DM_MMC
CONFIG_DM_ETH
CONFIG_DM_SERIAL
CONFIG_DM_USB
Signed-off-by: Ilko Iliev <iliev@ronetix.at>
Those two functions will be used later to re-implement do_bootefi_exec().
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
To meet UEFI spec v2.7a section 9.2, we should add
EFI_LOADED_IMAGE_DEVICE_PATH_PROTOCOL to image handle,
instead of EFI_DEVICE_PATH_PROTOCOL.
Currently, image's image_base points to an address where the image was
temporarily uploaded for further loading. Since efi_loader relocates
the image to final destination, image_base and image_size should reflect
that.
This bug was detected in UEFI SCT, "Loaded Image Protocol Test - test 2,"
which shows that 'Unload' function doesn't fit into a range suggested by
image_base and image_size.
TestCase/UEFI/EFI/Protocol/LoadedImage/BlackBoxTest/
LoadedImageBBTestMain.c:1002
Changes in this patch also includes:
* reverts a patch, "efi_loader: save image relocation address
and size" since newly added fields are no longer needed.
* copy PE headers as well since those information will be needed
for module loading, in particular, at gurb.
(This bug was reported by Heinrich.)
Reported-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Rebase patch.
Remove unused fields from struct efi_loaded_image_obj.
Fixes for 2019.04
- fix bashism for MX8
- fix ethernet for MX53
- fix docs for i.MX8
Signed-off-by: Lukasz Majewski <lukma@denx.de>
After running tools/moveconfig.py it turned out that for various boards
there are an empty #ifdef statements.
Remove them to clean u-boot source code.
Minor fixes for the Alt board and PHY use on Gen2.
With UUID support, the root can now point to UUID. This makes
swiching between mmc 0 and mmc 1 easier by simplying changing
mmcdev between 0 and 1. From there, the scripts handle the rest.
Commit d245059ff797 ("ARM: rmobile: rcar-gen3: Activate bootm_size")
only fixed the superfluous CONFIG_SYS_BOOTMAPSZ for R-Car Gen3, even
though it listed all affected boards. Apply the same fix to Gen2.
Fixes: d245059ff797 ("ARM: rmobile: rcar-gen3: Activate bootm_size")
Cc: Eugeniu Rosca <erosca@de.adit-jv.com>
- Bugfixes:
- mmc: correct the HS400 initialization process
- configs: ti: Move FIT image load address to avoid overwrite
- lib: time: update module enable MACRO
- Add mbrugger as RPi board maintainer, correct agraf's email address.
The FIT image is loaded to 0x8700_0000 followed by extracting from that
several large images also into the 0x8x00_0000 range. Large images
can end up overwriting the FIT image as it is being extracted from.
Move the FIT load address clear out to 0x9000_0000, this will require
a board to have at least 256MB of DRAM, if less then more careful
planning will be required for that platform.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Pull request for UEFI system for v2019.04-rc5-2
This patch series contains a bug fix for a double free in a UEFI unit
test. The other patches are documentation only (except for the definition
of two additional constants).
On AXS10x boards we have non-standard NAND controller
which was never really used a lot as there're other much more
convenient [as they are standard & removable] persistent media
like SD-card and USB mass storage.
Moreover after recent changes we face with some NAND controller
runtime issues. So instead of keeping support of yet another
non-standard peripheral we're dropping its support for good.
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
We currently only support EFI_FILE_PROTOCOL_REVISION while
UEFI specs 2.4 - 2.7 prescribe EFI_FILE_PROTOCOL_REVISION2.
Add a todo.
Add missing constants for the EFI file protocol revision.
CONFIG_ENV_SPI_BUS
CONFIG_ENV_SPI_CS
CONFIG_ENV_SPI_MAX_HZ
CONFIG_ENV_SPI_MODE
Most of time these value are not needed, CONFIG_SF_DEFAULT
with same value is used, so I introduced CONFIG_USE_ENV_SPI_*
to force the associated value for the environment.
CONFIG_DEFAULT_SPI_BUS
CONFIG_DEFAULT_SPI_MODE
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
Replace CONFIG_ENV_SPI_BASE by the better CONFIG_SYS_SPI_BASE
(it is not the location for environment but the location for U-Boot)
and, as it is the only platform with use this define, remove
it from whitelist.
Move some configurations in defconfig file
- CONFIG_CMD_I2C
- CONFIG_CMD_SPI
This allow correct dependency handling in Kconfig.
