Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
Changed storage type of cfg_simulate_spd_eeprom to const
Changed storage type of gpio_tab to stack storage
(Cannot access global data declarations in .bss until afer code relocation)
Improved SDRAM tests to catch problems where data is not uniquely addressable
(e.g. incorrectly programmed SDRAM row or columns)
Added CONFIG_PROG_SDRAM_TLB to support Bamboo SIMM/DIMM modules
Fixed AM29LV320DT (OpCode Flash) sector map
Signed-off-by: Eugene OBrien <eugene.obrien@advantechamt.com>
- Clear ECC status regs after ECC POST test
- Set dcbz for ECC generation with caches enabled as default
- Code cleanup
Change Lime SDRAM initialization to now support 100MHz and
133MHz (if enabled). Also the framebuffer is initialized to
display a blue rectangle with a white border.
The used Intel NOR FLASH chips have internally two dies, and are now
treated as two seperate chips.
This patch adds ECC Post test for the Lwmon5 board based
on PPC440EPx to U-Boot.
Signed-off-by: Pavel Kolesnikov <concord@emcraft.com>
Acked-by: Yuri Tikhonov <yur@emcraft.com>
This patch fixes the negative consequences for 8xx of the recent
"ppc4xx: Clean up 440 exceptions handling" commit.
Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
The new function remove_tlb() can be used to remove the TLB's used to
map a specific memory region. This is especially useful for the DDR(2)
setup routines which configure the SDRAM area temporarily as a cached
area (for speedup on auto-calibration and ECC generation) and later
need this area uncached for normal usage.
Signed-off-by: Piotr Kruszynski <ppk@semihalf.com>
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
- now the Flash ST M29W040B is supported (not tested)
- fix the "led" command
- fix compile error, if BUILD_DIR is used
Add unlock=yes environment variable to default variables to unlock
the CFI flash by default.
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
Signed-off-by: Niklaus Giger <niklaus.giger@nestal.com>
- Add optional ECC generation routine to preserve existing
RAM values. This is needed for the Linux log-buffer support
- Add optional DDR2 setup with CL=4
- GPIO50 not used anymore
- Lime register setup added
Signed-off-by: mushtaq khan <mushtaqk_921@yahoo.co.in>
This patch removes the CFG_PCI_PRE_INIT option completely, since
it's not needed anymore with the patch from Matthias Fuchs with
the "weak" pci_pre_init() implementation.
-add pci_pre_init() for pci interrupt fixup code
-disable phy sleep mode via reset_phy() function
-use correct io accessors
-cleanup
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
A new environment variable, "logversion", selects the log buffer
behaviour. If it is not set or set to a value other than 2, then the
old, Linux 2.4.4, behaviour is selected.
Signed-off-by: Igor Lisitsin <igor@emcraft.com>
Added memory, CPU, UART, I2C and SPR POST tests for PPC440.
- Show on the Status LEDs, some States of the board.
- Get the MAC addresses from the EEProm
- use PREBOOT
- use the CF on the board.
- check the U-Boot image in the Flash with a SHA1
checksum.
- use dynamic TLB entries generation for the SDRAM
- adapt to the more generic EXCEPTION_PROLOG and CRIT_EXCEPTION macros
- minor 4xx cleanup
The latest changes showed a problem with the location of the NAND-SPL
image in the OCM and the init-data area (incl. cache). This patch
fixes this problem.
Now CONFIG_440 has to be defined in all PPC440 board config files.
- Introduced dedicated switches for building 440 and 405 images required
for 440-specific machine instructions like 'rfmci' etc.
- Exception vectors moved to the proper location (_start moved away from
the critical exception handler space, which it occupied)
- CriticalInput now serviced (with default handler)
- MachineCheck properly serviced (added a dedicated handler and return
subroutine)
- Overall cleanup of exceptions declared with STD_EXCEPTION macro (unused,
unhandled and those not relevant for 4xx were eliminated)
- Eliminated Linux leftovers, removed dead code
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
This patch adds initial support for the Liebherr lwmon5 board euqipped
with an AMCC 440EPx PowerPC.
The board config array CFG_440_GPIO_TABLE for the ppc440 GPIO setup
is extended with the default GPIO output state (level).
Signed-off-by: Jan Wrobel <wrr@semihalf.com>
Acked-by: Bartlomiej Sieka <tur@semihalf.com>
