RSA provides a public key encryption facility which is ideal for image
signing and verification.
Images are signed using a private key by mkimage. Then at run-time, the
images are verified using a private key.
This implementation uses openssl for the host part (mkimage). To avoid
bringing large libraries into the U-Boot binary, the RSA public key
is encoded using a simple numeric representation in the device tree.
Add support for signing images using a new signature node. The process
is handled by fdt_add_verification_data() which now takes parameters to
provide the keys and related information.
Add a structure to describe an algorithm which can sign and (later) verify
images.
Add configs to enable tracing when it is needed.
Add tracing to Exynos5 boards, so that tracing can be enabled when building
with 'make FTRACE=1'. We use a 16MB trace buffer.
For tracing it is useful to run as much of U-Boot as possible so as to get
a complete picture. Quite a bit of work happens in bootm, and we don't want
to have to stop tracing before bootm starts.
Add a way of doing a 'fake' boot of the OS - which does everything up to
the point where U-Boot is about to jump to the OS image. This allows
tracing to record right until the end.
This requires arch support to work.
At present the bootm code is mostly duplicated for the plain 'bootm'
command and its sub-command variant. This makes the code harder to
maintain and means that changes must be made to several places.
Introduce do_bootm_states() which performs selected portions of the bootm
work, so that both plain 'bootm' and 'bootm <sub_command>' can use the
same code.
Additional duplication exists in bootz, so tidy that up as well. This
is not intended to change behaviour, apart from minor fixes where the
previously-duplicated code missed some chunks of code.
Support tracing on sandbox by adding suitable CONFIG options. To enable it,
compile U-Boot with FTRACE=1.
The timer functions are marked to skip tracing, since these are called from
the tracing code itself, and we want to avoid an infinite loop.
Add hooks for tracing to generic board, including:
- allow early tracing to start early as possible in U-Boot
- reserve memory for trace buffer
- copy early trace buffer to main trace buffer after relocation
- setup full tracing support after relocation
Add a library which supports tracing of execution using built-in gcc
features and a microsecond timer. This can be used to record a list of
function which are executed, along with a timestamp for each. Later
this information can be sent to the host for processing.
Move bootstage's numbering printing code into a generic place so that it can
be used by tracing also.
I am not sure of the meaning of extern inline, but this gives errors
when building with function instrumenting enabled. Change these functions
to static inline.
This patch initiates cros-ec in board_init() to enable it for smdk5250.
This patch depends on the patch in the MMC series that brings in exynos5-dt.c.
Refer to http://patchwork.ozlabs.org/patch/240084.
Signed-off-by: Vincent Palatin <vpalatin@chromium.org>
Signed-off-by: Hung-ying Tyan <tyanh@chromium.org>
This patch adds the driver for keyboard that's controlled by ChromeOS EC.
Signed-off-by: Randall Spangler <rspangler@chromium.org>
This patch adds SPI support for carrying out the cros_ec protocol.
This patch adds the cros_ec driver that implements the protocol for
communicating with Google's ChromeOS embedded controller.
Signed-off-by: Bernie Thompson <bhthompson@chromium.org>
Signed-off-by: Bill Richardson <wfrichar@chromium.org>
Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
Signed-off-by: Doug Anderson <dianders@chromium.org>
Signed-off-by: Gabe Black <gabeblack@chromium.org>
Signed-off-by: Louis Yung-Chieh Lo <yjlou@chromium.org>
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Faraday FTMAC110 10/100Mbps supports half-word data transfer for Linux.
However it has a weird DMA alignment issue:
(1) Tx DMA Buffer Address:
1 bytes aligned: Invalid
2 bytes aligned: O.K
4 bytes aligned: O.K
(2) Rx DMA Buffer Address:
4 bytes aligned: Invalid!!!
Signed-off-by: Kuo-Jung Su <dantesu@faraday-tech.com>
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Cc: Tom Rini <trini@ti.com>
Add function ksz9031_phy_extended_write and ksz9031_phy_extended_read
Signed-off-by: Leo Sartre <lsartre@adeneo-embedded.com>
add network support with ksz8851_16mll on at91sam9n12ek board
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
The device interface is 16 bits wide.
All the available packets are read from the incoming fifo.
Signed-off-by: Roberto Cerati <roberto.cerati@bticino.it>
Signed-off-by: Raffaele Recalcati <raffaele.recalcati@bticino.it>
[voice.shen@atmel.com: address comments from review results]
[voice.shen@atmel.com: clean up for submit]
Tested-by: Raffaele Recalcati <raffaele.recalcati@bticino.it>
commit 39695029bc15041c809df3db4ba19bd729c447fa
Author: Charles Coldwell <coldwell@ll.mit.edu>
Date: Tue Feb 19 08:27:33 2013 -0500
Changes to support the Xilinx 1000BASE-X phy (GTX/MGT)
Signed-off-by: Charles Coldwell <coldwell@ll.mit.edu>
for use with sparse.
Make do_bootz available for other functions like do_bootm is.
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
This patch adds support for the WEMAC, the ethernet controller included
in the Allwinner A10 SoC. It will get used in the upcoming A10 board
support.
Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net>
- remove the builtin 'rootpath' spec (according to U-Boot project
policy) and require user provided environments to contain these
- rephrase the evaluation of the 'muster_nr' approach which allows to
quickly switch among several network boot setups (make the setting
transparent when empty, resulting in default DULG behaviour)
- reduce the ARP timeout for faster network boot
Signed-off-by: Gerhard Sittig <gsi@denx.de>
remove remaining "k6" code names, switch to the official 'ac14xx' name
- use the default baudrate table for serial communication
- remove hostname/boofile/rootpath defines which were not referenced elsewhere
fix typos, minor rephrasing, remove obsolete notes and TODO items
Flag status register polling is required for micron 512Mb flash
devices onwards, for performing erase/program operations.
Like polling for WIP(Write-In-Progress) bit in read status register,
spi_flash_cmd_wait_ready will poll for PEC(Program-Erase-Control)
bit in flag status register.
Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
Defined bank addr code on CONFIG_SPI_FLASH_BAR macro, to reduce the
size for existing boards which has < 16Mbytes SPI flashes.
It's upto user which has provision to use the bank addr code for
flashes which has > 16Mbytes.
Read the flash bank addr register to get the state of bank in
a perticular flash. and also bank write happens only when there is
a change in bank selection from user.
bank read only valid for flashes which has > 16Mbytes those are
opearted in 3-byte addr mode, each bank occupies 16Mytes.
Suppose if the flash has 64Mbytes size consists of 4 banks like
bank0, bank1, bank2 and bank3.
Bank/Extended addr commands are specific to particular
flash vendor so discover them based on the idocode0.
Assign the discovered bank commands to spi_flash members
so-that the bank read/write will use their specific operations.
Discard all .dynsym sections from linker scripts
Remove all __dynsym_start definitions from linker scripts
Remove all __dynsym_start references from the codebase
Note: this touches include/asm-generic/sections.h, which
is not ARM-specific, but actual uses of __dynsym_start
are only in ARM, so this patch can safely go through
the ARM repository.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Tested-by: Lubomir Popov <lpopov@mm-sol.com>
Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl>
Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
P1023RDB Specification:
Memory subsystem:
512MB DDR3 (Fixed DDR on board)
64MB NOR flash
128MB NAND flash
Ethernet:
eTSEC1: Connected to Atheros AR8035 GETH PHY
eTSEC2: Connected to Atheros AR8035 GETH PHY
PCIe:
Three mini-PCIe slots
USB:
Two USB2.0 Type A ports
I2C:
AT24C08 8K Board EEPROM (8 bit address)
Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com>
Cc: Scott Wood <scottwood@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
There will need the environment in SPL for reasons other than network
support (in particular, hwconfig contains info for how to set up DDR).
Add a new symbol CONFIG_SPL_ENV_SUPPORT to replace CONFIG_SPL_NET_SUPPORT
for environment in common/Makefile.
Signed-off-by: Ying Zhang <b40530@freescale.com>
Reviewed-by: Tom Rini <trini@ti.com>
Relax parameters to give address latching more time to setup.
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
When a T4 board boots from SRIO or PCIE, it needs to finish these processes:
1. Set all the cores in holdoff status.
2. Set the boot location to one PCIE or SRIO interface by RCW.
3. Set a specific TLB entry for the boot process.
4. Set a LAW entry with the TargetID of one PCIE or SRIO for the boot.
5. Set a specific TLB entry in order to fetch ucode and ENV from
master.
6. Set a LAW entry with the TargetID one of the PCIE ports for
ucode and ENV.
7. Slave's u-boot image should be generated specifically by
make xxxx_SRIO_PCIE_BOOT_config.
This will set SYS_TEXT_BASE=0xFFF80000 and other configurations.
For more information about the feature of Boot from SRIO/PCIE, please
refer to the document doc/README.srio-pcie-boot-corenet.
Signed-off-by: Liu Gang <Gang.Liu@freescale.com>
T4 can support the feature of Boot from SRIO/PCIE, and the macro
"CONFIG_SRIO_PCIE_BOOT_MASTER" will enable the master module of this feature
when building the u-boot image.
You can get some description about this macro in README file, and for more
information about the feature of Boot from SRIO/PCIE, please refer to the
When a b4860qds board boots from SRIO or PCIE, it needs to finish these
processes:
master.
ucode and ENV.
B4860QDS can support the feature of Boot from SRIO/PCIE, and the macro
Currently, the macro "CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER" can enable
the master module of Boot from SRIO and PCIE on a platform. But this
is not a silicon feature, it's just a specific booting mode based on
the SRIO and PCIE interfaces. So it's inappropriate to put the macro
into the file arch/powerpc/include/asm/config_mpc85xx.h.
Change the macro "CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER" to
"CONFIG_SRIO_PCIE_BOOT_MASTER", remove them from
arch/powerpc/include/asm/config_mpc85xx.h file, and add those macros
in configuration header file of each board which can support the
master module of Boot from SRIO and PCIE.
BSC9131RDB has 1GB DDR.
Out of this, only 880MB is passed on to Linux via bootm_size.
Remaining
-16MB is reserved for PowerPC-DSP shared control area
-128MB is reserved for DSP private area.
Also 256MB, out of this 880MB is required for data communication between
PowerPC and DSP core.
For this bootargs are modified to pass parameter to create 1 hugetlb
page of 256MB via default_hugepagesz, hugepagesz and hugepages
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
BSC9131RDB is a Freescale Reference Design Board for
BSC9131 SoC which is a integrated device that contains
one powerpc e500v2 core and one DSP starcore.
To support DSP starcore
-Creating LAW and TLB for DSP-CCSR space.
-Creating LAW for DSP-core subsystem M2 memory
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
BSC9131RDB supports Sysclk
-66MHz if jumper J16 is close (default state)
-100MHz if jumper J16 is open
Add targets
-BSC9131RDB_NAND_SYSCLK100 : for NAND boot at Sysclk 100MHz
-BSC9131RDB_SPIFLASH_SYSCLK100: for SPI boot at Sysclk 100MHz
Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
- Add NAND boot target
- defines constants
- Add spl_minimal.c to initialise DDR
- update TLB, LAW entries as per NAND boot
