Prepare for 1.0.1 release
add I2C support; add support for DS1337 RTC
* Add CompactFlash support for BMS2003 board
* Add support for status LED on BMS2003 board
* Patch by Scott McNutt, 02 Jan 2004:
Add support for the Nios Active Serial Memory Interface (ASMI)
on Cyclone devices
* Patch by Andrea Marson, 16 Dec 2003:
Add support for the PPChameleon ME and HI modules
* Patch by Yuli Barcohen, 22 Dec 2003:
Add support for Motorola DUET ADS board (MPC87x/88x)
add support for cramfs (uses JFFS2 command interface)
- more documentation for NIOS port
- new struct nios_pio_t, struct nios_spi_t
- Reconfiguration for NIOS Development Kit DK1C20:
o move board related code from board/dk1c20
to board/altera/dk1c20
o create a new common source path board/altera/common
and move generic flash access stuff into it
o change/expand configuration file DK1C20.h
- Add support for NIOS Development Kit DK1S10
- Add status LED support for NIOS systems
- Add dual 7-segment LED support for Altera NIOS DevKits
Add support for the Marvell DB64360 / DB64460 development boards
* Patch by Detlev Zundel, 10 Dec 2003:
fix dependency problem in examples/Makefile
- add support for the PATI board (MPC555)
- add SPI support for the MPC5xx
* Patch by Anders Larsen, 08 Dec 2003:
add configuration options CONFIG_SERIAL_TAG and CONFIG_REVISION_TAG
to pass ATAG_SERIAL and ATAG_REVISION, resp., to the ARM target;
cleanup some redundand #defines
* Minor code cleanup (coding style)
* Patch by Reinhard Meyer, 30 Dec 2003:
- cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE,
- added CONFIG_PHY_ADDR to include/configs/IceCube.h,
- turned debug print of PHY registers into a function (called in two places)
- added support for EMK MPC5200 based modules
* Fix MPC8xx PLPRCR_MFD_SHIFT typo
* Add support for TQM866M modules
* Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash)
* Fix a few compiler warnings
Add initial support for TOP5200 board
environment variable which can set to "100", "133", or "150". The
CPU clock will be configured accordingly upon next reboot. Other
values are ignored. In case of an invalid or undefined "cpuclk"
value, the compile-time default CPU clock speed will be used.
* Enable Quad-UART on BMS2003 board (initialize the PCMCIA memory
window that is used to access the UART registers by the Linux driver)
* Patch by Reinhard Meyer, 20 Dec 2003:
Fix clock calculation for the MPC5200 for higher clock frequencies
(above 2**32 / 10 = 429.5 MHz).
* Add new configuration for IceCube board with DDR memory
* Update TRAB memory configurations
add support for Coldfire CPU
add support for Motorola M5272C3 and M5282EVB boards
- add a return value for the fpga command
- add ide_preinit() function called in ide_init if CONFIG_IDE_PREINIT
is defined. If ide_preinit fails, ide_init is aborted.
- fix an endianess problem in fat.h
Add support for SNMC's QS850/QS823/QS860T boards
"revive" U-Boot support for old Motorola MPC860ADS board
* Patch by Cam(ilo?), 03 Dec 2003:
make examples build even with broken Montavista objcopy
* Patch by Pavel Bartusek, 27 Nov 2003:
fix conversion problem with "bootretry" evironment variable
add support for mvblue (mvBlueLYNX and mvBlueBOX) boards
* Patch by Pavel Bartusek, 21 Nov 2003:
set ZMII bridge speed on 440
* Patch by Anders Larsen, 17 Nov 2003:
Fix mismatched #ifdef / #endif in include/asm-arm/arch-pxa/hardware.h
- board/mpl/common/common_util.c
* implement support for BZIP2 compressed images
* various cleanups (printf -> puts, ...)
- board/mpl/common/flash.c
* report correct errors to upper layers
* check the erase fail and VPP low bits in status reg
- board/mpl/vcma9/cmd_vcma9.c
- board/mpl/vcma9/flash.c
- common/cmd_usb.c
* fix typo in comment
- cpu/arm920t/usb_ohci.c
* support for S3C2410 is missing in #if line
- drivers/cs8900.c
* reinit some registers in case of error (cable missing, ...)
- fs/fat/fat.c
* support for USB/MMC devices is missing in #if line
- include/configs/MIP405.h
- include/configs/PIP405.h
* enable BZIP2 support
* enlarge malloc space to 1MiB because of BZIP2 support
- include/configs/VCMA9.h
* enable USB support
- lib_arm/armlinux.c
* change calling convention of ARM Linux kernel as
described on http://www.arm.linux.org.uk/developer/booting.php
* Patch by Thomas Lange, 14 Nov 2003:
Split dbau1x00 into dbau1000, dbau1100 and dbau1500 configs to
support all these AMD boards.
Workaround for mips au1x00 physical memory accesses (the au1x00
uses a 36 bit bus internally and cannot access physical memory
directly. Use the uncached SDRAM address instead of the physical
one.)
add Realtek 8019 ethernet driver
* Patch by Yuli Barcohen, 13 Nov 2003:
MPC826xADS/PQ2FADS cleanup
* Patch by Anders Larsen, 12 Nov 2003:
Update README to mark the PORTIO commands non-standard
update for for Atmel AT91RM9200DK development kit:
- support for environment variables in DataFlash
- Atmel DataFlash AT45DB1282 support
* Patch by Jeff Carr, 11 Nov 2003:
add support for new version of 8270 processors
* Patches by George G. Davis, 05 Nov 2003:
- only pass the ARM linux initrd tag to the kernel when an initrd
is actually present
- update omap1510inn configuration file
- more endianess fixes for LAN91C111 driver
- CFG_HZ configuration patch for NIOS Cyclone board
* Patch by Stephan Linz, 28 Oct 2003:
fix PHY_INT_REG vs. PHY_MASK_REG bug in drivers/smc91111.c
* Patch by Steven Scholz, 20 Oct 2003:
- make "mii info <addr>" show infor for PHY at "addr" only
- Endian fix for miiphy_info()
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c
* Patch by Anders Larsen, 17 Sep 2003:
Bring ARM memory layout in sync with the documentation:
stack and malloc-heap are now located _below_ the U-Boot code
* Fix configuration problem with IceCube in LOWBOOT configuration:
environment got embedded, corrupting the image layout.
(featuring a NEC NL6448BC33-54. 10.4", 640x480 TFT display).
Fix NEC display names (it's 6440 [for 640x480], not 6640).
recent tools
* Add checksum verification to 'imls' command
* Add bd_info fields needed for 4xx Linux I2C driver
* Patch by Martin Krause, 4 Nov. 2003:
Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap)
* Print used network interface when CONFIG_NET_MULTI is set
Add low boot support for MPC5200
* Fix problem with dual PCMCIA support (NSCU)
* Fix MPC5200 I2C initialization function
* Patch by Kyle Harris, 30 Oct 2003:
Fix build errors for ixdp425 board
* Patch by David M. Horn, 29 Oct 2003:
Fixes to build under CYGWIN
* Get IceCube MGT5100 working (again)
* Fix problems in memory test on some boards (which was not
non-destructive as intended)
* Patch by Gary Jennejohn, 28 Oct 2003:
Change fs/fat/fat.c to put I/O buffers in BSS instead on the stack
to prevent stack overflow on ARM systems
fix init sequence error for NIOS port
* Allow lowercase spelling for IceCube_5200; support MPC5200LITE name
* Add CONFIG_VERSION_VARIABLE to TRAB configuration
Fix AT91RM9200 ethernet driver
* Patch by Nye Liu, 17 Oct 2003:
Fix typo in include/mpc8xx.h
* Patch by Richard Woodruff, 16 Oct 03:
Fixes for cpu/arm925/interrupt.c
- Initialize timestamp & lastdec vars.
- fix timestamp overflows.
- fix lastdec overflow.
- smarter normalization to allow udelay() below 1ms to work.
* Patch by Scott McNutt, 16 Oct
add networking support for the Altera Nios Development Kit,
Cyclone Edition (DK-1C20)
* Patch by Jon Diekema, 14 Oct 2003:
add hint about doc/README.silent to README file
* TRAB auto-update: image type patch by Martin Krause, 17 Oct 2003
- Added Motorola CPU 8540/8560 support (cpu/85xx)
- Added Motorola MPC8540ADS board support (board/mpc8540ads)
- Added Motorola MPC8560ADS board support (board/mpc8560ads)
* Make 5200 reset command _really_ reset the board, without running
any other code after it
* Fix flash mapping and display on P3G4 board
* Patch by Kyle Harris, 15 Jul 2003:
- add support for Intel IXP425 CPU
- add support for IXDP425 eval board
for more information
- Add support for Altera FPGA ACEX1K
* Patches by Thomas Lange, 09 Oct 2003:
- Endian swap ATA identity for all big endian CPUs, not just PPC
- MIPS only: New option CONFIG_MEMSIZE_IN_BYTES for passing memsize
args to linux
- add support for dbau1x00 board (MIPS32)
- fix cmd_ide.c for non ppc boards (read/write functions did not
add ATA base address)
- fix for shannon board
- #ifdef CONFIG_IDE_8xx_DIRECT some otherwise unused code
* Patch by Sangmoon Kim, 07 Oct 2003:
add support for debris board
Fixes for TRAB board
- /board/trab/rs485.c: correct baudrate
- /board/trab/cmd_trab.c: bug fix for problem with timer overflow in
udelay(); fix some timing problems with adc controller
- /board/trab/trab_fkt.c: add new commands: gain, eeprom and power;
modify commands: touch and buzzer
* Disable CONFIG_SUPPORT_VFAT when used with CONFIG_AUTO_UPDATE
(quick & dirty workaround for rogue pointer problem in get_vfatname());
Use direct function calls for auto_update instead of hush commands
- add support for Altera Nios-32 CPU
- add support for Nios Cyclone Development Kit (DK-1C20)
* Patch by Steven Scholz, 29 Sep 2003:
- A second parameter for bootm overwrites the load address for
"Standalone Application" images.
- bootm sets environment variable "filesize" to the resulting
(uncompressed) data length for "Standalone Application" images
when autostart is set to "no". Now you can do something like
if bootm $fpgadata $some_free_ram ; then
fpga load 0 $some_free_ram $filesize
fi
* Patch by Denis Peter, 25 Sept 2003:
add support for the MIP405 Rev. C board
add support for Zephyr Engineering ZPC.1900 board
* Patch by Anders Larsen, 23 Sep 2003:
add CMD_PORTIO to CFG_CMD_NONSTD (commands in question are only
implemented for the x86 architecture)
fix pll_pci_to_mem_multiplier table for MPC8245
* Patch by Anders Larsen, 22 Sep 2003:
enable timed autoboot on PXA
* Patch by David Müller, 22 Sep 2003:
- add $(CFLAGS) to "-print-libgcc-filename" so compiler driver
returns correct libgcc file path
- "latency" reduction of busy-loop waiting to improve "U-Boot" boot
time on s3c24x0 systems
* Patch by Jon Diekema, 19 Sep 2003:
- Add CFG_FAULT_ECHO_LINK_DOWN option to echo the inverted Ethernet
link state to the fault LED.
- In NetLoop, make the Fault LED reflect the link status. The link
status gets updated on entry, and on timeouts.
allow mkimage to build and run on Cygwin-hosted systems
* Patch by Frank Müller, 18 Sep 2003:
use bi_intfreq instead of bi_busfreq to compute fec_mii_speed in
cpu/mpc8xx/fec.c
* Patch by Pantelis Antoniou, 16 Sep 2003:
add tool to compute fileds in the PLPRCR register for MPC86x
* Make fatload set filesize environment variable
fix potential buffer overlow problem
* enable basic / medium / high-end configurations for PPChameleonEVB
board; fix NAND code
* enable TFTP client code to specify to the server the desired
timeout value (see RFC-2349)
Cleanup for submitted patches.
