path: root/include
2019-05-23stm32mp1: migrate PREBOOT to KconfigPatrick Delaunay
Use Kconfig to activate CONFIG_PREBOOT (empty by default). Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-05-23stm32mp1: Move ENV_SIZE and ENV_OFFSET to KconfigPatrick Delaunay
Add arch stm32mp for ENV migration step and drop more items from include/configs/xxx.h. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-05-23stm32mp1: Move config SYS_MALLOC_LEN to KconfigPatrick Delaunay
This patch moves the the config SYS_MALLOC_LEN to Kconfig as it is already done for zynq arch in commit 01aa5b8f0503 ("Kconfig: Move config SYS_MALLOC_LEN to Kconfig for zynq") Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-05-22armv8: lx2160: Drop useless CONFIG_CMDLINE_EDITING from config.hAndy Shevchenko
commit 58c3e62040be ("armv8: lx2160ardb : Add support for LX2160ARDB platform") brought a new boards support with redundancy in the config.h. One of them is CONFIG_CMDLINE_EDITING which is removed by this change. Cc: Priyanka Jain <priyanka.jain@nxp.com> Cc: Peng Ma <peng.ma@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-22armv8: Secure Boot: Modify boot_a_script definitionVinitha V Pillai
esbc_validate command will not be executed if “load” command for its header fails and will further execute the source command for bootscript, without its validation and boot process continues. To halt the boot process in case secure boot header is not loaded successfully, esbc_validate command is invoked separately after “load” command. The secure boot validation of the bootscript header will fail (if header is not loaded) and halts the boot process, which prevent source command from execution. Signed-off-by: Vinitha V Pillai <vinitha.pillai@nxp.com> Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-22board: fsl: lx2160ardb: invert AQR107 pins polarityFlorin Chiculita
AQR107 PHYs interrupt pins are active-low, while the GIC expects a level-high signal. Signed-off-by: Florin Chiculita <florinlaurentiu.chiculita@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-22armv8: ls1028aqds: Add support of LS1028AQDSYuantian Tang
LS1028AQDS Development System is a high-performance computing, evaluation, and development platform that supports LS1028A QorIQ Architecture processor. Signed-off-by: Sudhanshu Gupta <sudhanshu.gupta@nxp.com> Signed-off-by: Rai Harninder <harninder.rai@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com> Signed-off-by: Tang yuantian <andy.tang@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-22armv8: ls1028ardb: Add support for LS1028ARDBYuantian Tang
LS1028A is an ARMv8 implementation. LS1028ARDB is an evaluation platform that supports the LS1028A family SoCs. This patch add basic support of the platform. Signed-off-by: Sudhanshu Gupta <sudhanshu.gupta@nxp.com> Signed-off-by: Rai Harninder <harninder.rai@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com> Signed-off-by: Tang Yuantian <andy.tang@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-21Merge git://git.denx.de/u-boot-mpc83xxTom Rini
- Update MPC83xx platform support to current best practices, etc.
2019-05-21Merge tag 'video-for-2019.07-rc3' of git://git.denx.de/u-boot-videoTom Rini
- update for using splashfile instead of location->name when loading the splash image from a FIT - updates for loading internal and external splash data from FIT - DM_GPIO/DM_VIDEO migration for mx53 cx9020 board - fix boot issue on mx6sabresd board after DM_VIDEO migration - increase the max preallocated framebuffer BPP to 32 in ipuv3 driver to prepare for configurations with higher color depth - allow to use vidconsole_put_string() in board code for text output on LCD displays
2019-05-21mpc83xx: Add gazerbeam boardDirk Eibach
The gdsys gazerbeam board is based on a Freescale MPC8308 SOC. It boots from NOR-Flash, kernel and rootfs are stored on SD-Card. On board peripherals include: - 2x 10/100 Mbit/s Ethernet (optional) Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21gdsys: Introduce GDSYS_LEGACY_DRIVERSMario Six
Future gdsys boards will switch from the legacy drivers in board/gdsys/common to DM-based drivers. Define a Kconfig option that disables the legacy drivers. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21gdsys: mpc8308: Migrate SYS_FPGA{0, 1}_{BASE, SIZE} to KconfigMario Six
Move CONFIG_SYS_FPGA0_BASE, CONFIG_SYS_FPGA0_SIZE, CONFIG_SYS_FPGA1_BASE, and CONFIG_SYS_FPGA1_SIZE to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21gdsys: Post ppc4xx removal cleanupMario Six
The ppc4xx architecture was removed, and with it several old gdsys 44x boards, but some "debris" from these purged boards was left over. This patch removes these remnants (mostly entries in Makefiles, some now superfluous data structures and some now obsolete config variables from the whitelist). Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21keymile: Factor out common includes againMario Six
Not that the Kconfig conversion of a lot of variables is done, we can factor out the common include files for the keymile boards again (which now contain hardly any #ifdef logic at all). Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21keymile: Remove CONFIG_SYS_APP{1, 2}_{BASE, SIZE}Mario Six
CONFIG_SYS_APP1_BASE, CONFIG_SYS_APP2_BASE, CONFIG_SYS_APP1_SIZE, and CONFIG_SYS_APP2_SIZE are no longer used in the keymile config files (they were used for setting values, which were converted to Kconfig earlier in the series). Remove them from the configs and the whitelist. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Get rid of CONFIG_SYS_LBC_*Mario Six
Except for one counter example, CONFIG_SYS_LBC_LBCR always has a value of either 0x00040000 or 0x00000000. CONFIG_SYS_LBC_MRTPR always has the value 0x20000000. CONFIG_SYS_LBC_LSDMR_{1,2,4,5} are not set for any mpc83xx board. CONFIG_SYS_LBC_LSRT is set by one board (to 0x32000000). To simplify the configuration files, hardcode the setting of these values for mpc83xx. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Get rid of CONFIG_SYS_DDR_SDRAM_BASEMario Six
CONFIG_SYS_DDR_SDRAM_BASE is set to the same value as CONFIG_SYS_SDRAM_BASE on all existing boards. Just use CONFIG_SYS_SDRAM_BASE instead. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Get rid of CONFIG_SYS_DDR_BASEMario Six
CONFIG_SYS_DDR_BASE is specific to mpc83xx an is always set to the same value as CONFIG_SYS_SDRAM_BASE. Just use CONFIG_SYS_SDRAM_BASE instead. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate CONFIG_LCRR_* to KconfigMario Six
Migrate the CONFIG_LCRR_* settings to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate SPCR to KconfigMario Six
Migrate the SPCR setting to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate arbiter config to KconfigMario Six
Migrate the arbiter configuration to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc8308: Migrate system io config to KconfigMario Six
Migrate the system IO configuration setting to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate CONFIG_SYS_IMMR to KconfigMario Six
Migrate CONFIG_SYS_IMMR to Kconfig for MPC83xx. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate HID config to KconfigMario Six
Mirate the HID configuration settings to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Remove last CONFIG_MPC83xxMario Six
Remove the last instances of the CONFIG_MPC83xx symbol. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate CONFIG_SYS_{BR, OR}*_PRELIM to KconfigMario Six
Migrate the BR/OR settings to Kconfig. These must be known at compile time, so cannot be configured via DT. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21sbc8349: Remove SDRAM functionalityMario Six
The MPC8349EMDS configuration was the basis for the sbc8349, so it also contains its SDRAM option. Since * the SDRAM has to be soldered onto the board, * the sbc8349 never used the support, and * the support never worked (see previous patch fixing it), we can assume that the support on the sbc8349 is an artifact created by copying the MPC8349EMDS config wholesome. Hence, instead of creating a separate sbc8349 config that supports SDRAM, we can remove the SDRAM option for this board. Should it be needed in the future, it can be copied from the new MPC8349EMDS_SDRAM board. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Simplify BR,OR linesMario Six
Re-format all BR,OR #define lines into single lines. This makes them harder to read, but accessible to semi-automatic replacement. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Normalize BR/OR option linesMario Six
All BR/OR option lines should have the same layout to make them easier to migrate to Kconfig. This includes using the same option macros everywhere. The normalize the lines, * replace function macros with their results, and * replace hardcoded hex values with standard macros Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate LBLAW_* to KconfigMario Six
The LBLAW_* values determine the window configuration of the memory controller. Hence, they must be known at compile time, and cannot be implemented in the DT mechanism. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate BATS config to KconfigMario Six
The BATs (block address translation registers) determine the initial memory window mappings. Hence, they must be known at compile time and cannot be implemented in the DT mechanism. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21powerpc: Migrate HIGH_BATS to KconfigMario Six
Migrate the CONFIG_HIGH_BATS variable to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Kconfig: Migrate HRCW to KconfigMario Six
The HRCW (hardware reset configuration word) is a constant that must be hard-coded into the boot loader image. So, it must be available at compile time, and cannot be migrated to the DT mechanism, but has to be kept in Kconfig. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Get rid of CONFIG_83XX_CLKINMario Six
MPC83xx uses CONFIG_83XX_CLKIN instead of CONFIG_SYS_CLK_FREQ to set the system clock. To migrate the architecture, we can replace CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ. To do this * replace all occurrences of CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ * set CONFIG_SYS_CLK_FREQ to the old value of CONFIG_83XX_CLKIN in all MPC83xx config files Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Replace CONFIG_83XX_CLKIN in calculationsMario Six
CONFIG_SYS_CLK_FREQ is the standard way to set the system clock frequency. On MPC83xx, CONFIG_83XX_CLKIN is used for this purpose. Hence, the obvious way is to replace CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ. A few MPC83xx boards use the CONFIG_83XX_CLKIN variable for computing CONFIG_SYS_NS16550_CLK. This makes it harder to replace CONFIG_83XX_CLKIN. But the value of the multiplicator can be read from the SPMR register. Hence, replace the static calculations with a call to a new get_bus_freq function, as other architectures do. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate legacy PCI options to KconfigMario Six
The MPC83xx include files contain some settings of the PCI subsystem. Migrate these to Kconfig until a proper DM PCI driver exists. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21MPC837XERDB: Remove CONFIG_MPC837XERDBMario Six
CONFIG_MPC837XERDB is unused, and TARGET_MPC837XERDB could replace it. Hence, get rid of CONFIG_MPC837XERDB. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21MPC837XEMDS: Remove CONFIG_MPC837XEMDSMario Six
CONFIG_MPC837XEMDS is unused, and TARGET_MPC837XEMDS could replace it. Hence, get rid of CONFIG_MPC837XEMDS. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21MPC8315ERDB: Remove CONFIG_MPC8315ERDBMario Six
CONFIG_MPC8315ERDB is unused, and TARGET_MPC8315ERDB could replace it. Hence, get rid of CONFIG_MPC8315ERDB. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21MPC8313ERDB: Remove CONFIG_MPC8313ERDBMario Six
CONFIG_MPC8313ERDB is unused, and TARGET_MPC8313ERDB_NAND/TARGET_MPC8313ERDB_NOR Kconfig could replace it. Hence, get rid of CONFIG_MPC8313ERDB. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21strider: Migrate to CONFIG_TARGET_STRIDERMario Six
Use the proper CONFIG_TARGET_STRIDER Kconfig option to replace the CONFIG_STRIDER ad-hoc config option. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21hrcon: Migrate to CONFIG_TARGET_HRCONMario Six
Use the proper CONFIG_TARGET_HRCON Kconfig option to replace the CONFIG_HRCON ad-hoc config option. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21MPC8349ITX: Migrate to CONFIG_TARGET_MPC8349ITXMario Six
Use the proper CONFIG_TARGET_MPC8349ITX Kconfig option to replace the CONFIG_MPC8349ITX ad-hoc config option. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21MPC832XEMDS: Migrate to CONFIG_TARGET_MPC832XEMDSMario Six
Use the proper CONFIG_TARGET_MPC832XEMDS Kconfig option to replace the CONFIG_MPC832XEMDS ad-hoc config option. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21ve8313: Merge BR/OR settingsMario Six
The ve8313 has the option of either configuring the eLBC (enhanced local system bus) such that * NOR flash is the first memory bank, and NAND flash is the second memory bank, or * NAND flash is the first memory bank, and NOR flash is the second memory bank, by using CONFIG_SYS_NOR_{BR,OR}_PRELIM and CONFIG_SYS_NAND_{BR,OR}_PRELIM for defining CONFIG_SYS_{BR,OR}{0,1}_PRELIM. After Kconfig migration, replacing some lines in the defconfig will have the same effect. Hence, we will not create distinct ve8313_{NOR,NAND} configs for such a small change. Instead, fix the current default (NOR first, NAND second), and unroll the CONFIG_SYS_NAND_{BR,OR}_PRELIM options. This will ease the Kconfig migration Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc8315erdb: Merge BR/OR settingsMario Six
The mpc8315erdb has the option of either configuring the eLBC (enhanced local system bus) such that * NOR flash is the first memory bank, and NAND flash is the second memory bank, or * NAND flash is the first memory bank, and NOR flash is the second memory bank, by using CONFIG_SYS_NOR_{BR,OR}_PRELIM and CONFIG_SYS_NAND_{BR,OR}_PRELIM for defining CONFIG_SYS_{BR,OR}{0,1}_PRELIM. After Kconfig migration, replacing some lines in the defconfig will have the same effect. Hence, we will not create distinct ve8313_{NOR,NAND} configs for such a small change. Instead, fix the current default (NOR first, NAND second), and unroll the CONFIG_SYS_NAND_{BR,OR}_PRELIM options. This will ease the Kconfig migration. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Make distinct MPC8349EMDS_SDRAM boardMario Six
The MPC8349EMDS config file contains config options to enable SDRAM support. To keep this ability after the Kconfig migration, create a new MPC8349EMDS_SDRAM board that enables the SDRAM support and remove the SDRAM support from the original board. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-20mpc83xx: Make distinct caddy2 configMario Six
vme8349.h contains two separate boards: The vme8349 itself, and the caddy2 board. The caddy2 board is chosen by setting certain config variables. Create a proper config file for the caddy2 board to make Kconfig migration easier. Furthermore, simplify the vme8349 and caddy2 configs by keeping only the options necessary for each board. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-20vme8349: Migrate to CONFIG_TARGET_VME8349Mario Six
CONFIG_TARGET_VME8349 can replace CONFIG_VME8349. Hence, replace CONFIG_VME8349 with CONFIG_TARGET_VME8349, and remove CONFIG_VME8349. Signed-off-by: Mario Six <mario.six@gdsys.cc>
