Xilinx is introducing Versal, an adaptive compute acceleration platform
(ACAP), built on 7nm FinFET process technology. Versal ACAPs combine
Scalar Processing Engines, Adaptable Hardware Engines, and Intelligent
Engines with leading-edge memory and interfacing technologies to deliver
powerful heterogeneous acceleration for any application. The Versal AI
Core series has five devices, offering 128 to 400 AI Engines. The series
includes dual-core Arm Cortex™-A72 application processors, dual-core Arm
Cortex-R5 real-time processors, 256KB of on-chip memory with ECC, more
than 1,900 DSP engines optimized for high-precision floating point with
low latency.
The patch is adding necessary infrastructure in place without enabling
platform which is done in separate patch.
Till now we have had cases where we had one phy device per dpmac.
Now, with the upcoming products (LX2160AQDS), we have cases, where there
are sometimes two phy devices for one dpmac. One phy for TX lanes and
one phy for RX lanes. to handle such cases, add the support for multiple
phys in ethernet driver. The ethernet link is up if all the phy devices
connected to one dpmac report link up. also the link capabilities are
limited by the weakest phy device.
i.e. say if there are two phys for one dpmac. one operates at 10G without
autoneg and other operate at 1G with autoneg. Then the ethernet interface
will operate at 1G without autoneg.
Signed-off-by: Pankaj Bansal <pankaj.bansal@nxp.com>
The phydev structure is present in both ldpaa_eth_priv and
wriop_dpmac_info. the phydev in wriop_dpmac_info is not being used
As the phydev is created based on phy_addr and bus members of
wriop_dpmac_info, it is appropriate to keep phydev in wriop_dpmac_info.
Also phy_regs is not being used, therefore remove it
Test improvements to tidy up output and drop duplicate tests
Sandbox SPL/TPL support
Various dm-related improvements
This adds platform code for the Khadas VIM2 board based on a
Meson GXM (S912) SoC with the Meson GXM configuration.
This initial submission supports UART, MMC/SDCard and Ethernet.
USB is partially supported.
All the code is from Neil Armstrong! I just rebased the code, do
some cleanup and tested on my board.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Signed-off-by: Loic Devulder <ldevulder@suse.de>
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
Make it possible to add TCP versions of the same, while reusing
IP portions. This patch should not change any behavior.
Signed-off-by: Duncan Hare <DH@Synoia.com>
Peter originally sent a fix, but it breaks a number of other things.
This addresses the original reported issue in a different way.
That report was:
> U-Boot has 1 common buffer to send Ethernet frames, pointed to by
> net_tx_packet. When sending to an IP address without knowing the MAC
> address, U-Boot makes an ARP request (using the arp_tx_packet buffer)
> to find out the MAC address of the IP addressr. When a matching ARP
> reply is received, U-Boot continues sending the frame stored in the
> net_tx_packet buffer.
> However, in the mean time, if U-Boot needs to send out any network
> packets (e.g. replying ping packets or ARP requests for its own IP
> address etc.), it will use the net_tx_packet buffer to prepare the
> new packet. Thus this buffer is no longer the original packet meant
> to be transmitted after the ARP reply. The original packet will be
> lost.
This instead uses the ARP tx buffer to send async replies in the case
where we are actively waiting for an ARP reply.
Reported-by: Tran Tien Dat <peter.trantiendat@gmail.com>
Tested-by: Bin Meng <bmeng.cn@gmail.com>
This single-sources the state of the ARP.
NXP SoCs like LX2160A can support new ethernet modes
which are 25G_AUI(25G), XLAUI(40G), CAUI2(50G)
and CAUI4(100G)
Add corresponding macros definitions in phy_interface.h
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
The DP83867 has a muxing option for the CLK_OUT pin. It is possible
to set CLK_OUT for different channels.
Create a binding to select a specific clock for CLK_OUT pin.
Based on commit 9708fb630d19 ("net: phy: dp83867: Add binding for
the CLK_OUT pin muxing option") of mainline linux kernel.
Signed-off-by: Janine Hagemann <j.hagemann@phytec.de>
There are VLAN related macros defined in include/linux/if_vlan.h
in Linux kernel, as well as some kernel useful structures and inline
functions. Instead of a complete import from kernel, let's add these
VLAN macros to U-Boot's include/linux/if_ether.h.
There are plenty of existing drivers that have macros like ETH_ALEN
defined in their own source files. Now that we imported the kernel's
if_ether.h to U-Boot we can reduce some duplication.
This imports include/uapi/linux/if_ether.h from Linux kernel v4.17.
It can be very helpful When porting Linux ethernet driver to U-Boot.
Note it is not exactly the same as the kernel one, as checkpatch
issues are fixed.
This patch add SPL DM support for da8xxevm boards
with SPL serial, SPI drivers supported via platdata.
Cc: Adam Ford <aford173@gmail.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Tested-by: Adam Ford <aford173@gmail.com> #da850evm
Davanci spi driver has DM support already, this patch
add support for platdata so-that SPL can use it for
low foot-print.
Currently there are two ethernet drivers (mvneta.c and mvpp2.c) that
has netdev_### (eg: netdev_dbg) log macros defined in its own driver
file. This adds these log macros in a common place linux/compat.h.
This syncs U-Boot's include/linux/mdio.h with Linux kernel v4.17
include/uapi/linux/mdio.h.
This syncs U-Boot's include/linux/mii.h with Linux kernel v4.17
include/uapi/linux/mii.h.
While we are here, this also fixes some style issues.
Add a little more information to one comment and update the guard comment
to be more accurate.
Reviewed-by: Anatolij Gustschin <agust@denx.de>
We have a method to return the last reset as a string for humans, but not
a method that allows it to be used programmatically. Add a new method that
returns the last reset as an enum.
Some comments are incorrect or missing pieces. Fix these and use logging
to print the error.
At present ctags emits lines with unmatched quotes which means that the
output file is invalid. This is with exuberant-ctags version 5.9~svn201103
but I also see it with plain ctags. I am not sure that it is a bug though.
Make a few minor changes in the source code to fix this problem.
At present the panel can be turned on but not off, and the brightness
cannot be controlled at run-time. Add a new API function to both the panel
and backlight uclasses to handle this. Enhance the PWM backlight driver
to deal with custom levels properly and allow the backlight to be turned
on and off.
Update the test to cover thes new features.
Allow selection of which EC image to hash.
This file has changed quite a bit in the last 5 years as the capabilities
of the ECs have grown. Sync it up with the copy in coreboot commit
b9141f2215.
The only change is the addition of EC_VBNV_BLOCK_SIZE_V2. This is needed
because U-Boot uses the new v2 vboot API and this is not currently fully
supported by Chromium OS firmware.
The current name conflicts with the Chrome OS verified boot library, which
prevents it being built. That library uses a string whereas U-Boot uses a
64-bit hex value. Rename this in U-Boot.
Add a string.h header for libraries that expect this to be available, now
that U-Boot's version has moved to include/linux.
At present some of the log categories are missing comments. Add them.
These are needed for the 2018 version of Chromium OS vboot. Add an
implementation for TPM v1, with v2 to come later.
All driver-model operation should return an error code. Adjust this
function to do so also.
This function is not used in U-Boot now. Remove it along with its 'memory'
version.
Rather than returning what is effectively an internal data structure,
return the cros EC device itself.
At present we pass around a private pointer to specify the cros_ec device.
With driver model it makes more sense to pass the device. Update the code
to do this.
Move this option to Kconfig and tidy up the two boards which use it.
At present ofnode_read_fmap_entry() reads a flash map entry in a format
which is not supported by binman. To allow use to use binman-format
descriptions, update this function.
Also add a simple test.
Some devices have children and want to press an existing inactive child
into service when needed. Add a function to help with this.
Quite a few functions do not actually modify the device that is passed in.
Update the function signatures to reflect that.
There is no reason why this feature should not be supported for uclass-
private data. Update the code accordingly.
At present sandbox sets non-blocking I/O as soon as any input is read
from the terminal. However it does not restore the previous state on
exit. Fix this and drop the old os_read_no_block() function.
This means that we always enable blocking I/O in sandbox (if input is a
terminal) whereas previously it would only happen on the first call to
tstc() or getc(). However, the difference is likely not important.
This driver was originally written against Chromium OS circa 2012. A few
new features have been added. Enhance the TPM driver to match. This mostly
includes a few new messages and properly modelling whether a particular
'space' is present or not.
Use an enum for command values instead of open-coding them. This removes
the need for comments. Also make sure the driver returns proper error
numbers instead of -1.
At present there are many situations where sandbox syncs the display to
the SDL frame buffer. This is a very expensive operation but is only
needed every now and then. Update video_sync() so that we can specify
whether this operation is really needed.
At present this flag is not used on other architectures. It could also
be used for reducing writeback-cache flushes but the benefit of that would
need to be investigated.
Add logging to aid debugging features in these drivers. Also drop some
code in sandbox_spi_xfer() which is not used.
For debugging it is sometimes useful to write out data for inspection
using an external tool. Add a function which can write this data to a
given file.
At present files are not truncated on writing. This is a useful feature.
Add support for this.
At present to output a log message you need something like:
log(UCLASS_SPI, LOCL_INFO, "message1");
log(UCLASS_SPI, LOCL_INFO, "message2");
but many files use the same category throughout. Also it is helpful to
shorten the length of log names, providing helpers for common logging
levels. Add some macros so that it is possible to do:
(top of file, before #includes)
#define LOG_CATEGORY UCLASS_SPI
(later in the file)
log_info("message1");
log_debug("message2");
log_err("message3");
This macro should have two parameters, not one. Fix it so that it
correctly resolves to _ret when logging is disabled.
On my Ubuntu 18.04.1 machine two driver-model bus tests have started
failing recently. The problem appears to be that the DATA region of the
executable is protected. This does not seem correct, but perhaps there
is a reason.
To work around it, unprotect the regions in these tests before accessing
them.
