path: root/include
2012-10-15serial: bfin: Flip the jtag serial console to CONFIG_SERIAL_MULTIMarek Vasut
Rework the emulation of serial console via JTAG from simple ad-hoc implementation of serial port routines to CONFIG_SERIAL_MULTI and enable CONFIG_SERIAL_MULTI unconditionally for blackfin. In order for the JTAG serial console to take precedence over all other serial ports available in system, implement override for default_serial_console call returning this JTAG serial console. This brings in a bit of a growth of size, but eventually will allow us to unconditionally enable CONFIG_SERIAL_MULTI throughout the whole U-Boot and maintain only one serial subsystem. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-15serial: zoom2: Remove zoom2 serial prototypes from serial.hMarek Vasut
Remove the prototypes for zoom2_serial_deviceN from serial.h . This can't be done right away, as they are referenced from the zoom2 config file. Therefore, adjust the code so the config file only specifies number of the port. Then, replace the simple return in default_serial_console() with a switch across possible values, which returns the zoom2_serial_deviceN . With such adjustment in place, the exported prototypes in serial.h can be safely removed. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-15serial: bfin: Adjust serial_register_bfin_uart()Marek Vasut
Rename the serial_register_bfin_uart() to bfin_initialize_serial() to be consistent with the rest of the naming. Next, remove it's prototype from serial.h and properly insert it into serial.c as the rest of the serial initialization functions. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-15serial: bfin: Remove the bfin_serialN_device exports from serial.hMarek Vasut
Remove the exports from serial.h as they are only used in the blackfin serial driver. Furthermore, they are only used for registration, which is handled already inside that driver and default_serial_port() call, which is also handled in that driver. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-15serial: ns16550: Move serial registration from serial_initialize()Marek Vasut
Move the registration of eserialN_device ports from default serial_initialize() into driver specific function called from serial_initialize(). This slims down the serial_initialize() call to a bare tracker of all possible serial port registration routines in U-Boot. The newly implemented ns16550_serial_initialize() function, which is implemented inside of the ns16550 serial driver allows encapsulation of eserialN_device within the ns16550 serial driver itself. Also, remove the exports of eserialN_device from include/serial.h as they are no longer needed. This is simply because the implementation of default_serial_console() is wrapped into the ns16550 serial driver and the default console is picked by CONFIG_SERIAL<N> macro in config file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Michal Simek <monstr@monstr.eu>
2012-10-15serial: mpc512x: Move serial registration from serial_initialize()Marek Vasut
Move the registration of serialN_device ports from default serial_initialize() into driver specific function called from serial_initialize(). This slims down the serial_initialize() call to a bare tracker of all possible serial port registration routines in U-Boot. The newly implemented mpc512x_serial_initialize() function, which is implemented inside of the mpc512x serial driver allows encapsulation of serialN_device within the mpc512x serial driver itself. Also, remove the exports of serialN_device from include/serial.h as they are no longer needed. This is simply because the implementation of default_serial_console() is wrapped into the mpx512x serial driver and the default console is picked by CONFIG_SERIAL<N> macro in config file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de>
2012-10-15serial: microblaze: Move serial registration from serial_initialize()Marek Vasut
Move the registration of xuartlite_serialN_device ports from default serial_initialize() into driver specific function called from serial_initialize(). This slims down the serial_initialize() call to a bare tracker of all possible serial port registration routines in U-Boot. The newly implemented xuartlite_serial_initialize() function, which is implemented inside of the serial_xuartlite driver allows encapsulation of xuartlite_serialN_device within the serial_xuartlite driver itself. Also, remove the exports of xuartlite_serialN_device from include/serial.h as they are no longer needed. This is simply because the implementation of default_serial_console() is wrapped into the serial_xuartlite driver and the default console is picked by CONFIG_SERIAL<N> macro in config file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Michal Simek <monstr@monstr.eu>
2012-10-15serial: zynq: Move serial registration from serial_initialize()Tom Rini
Move the registration of zynq_serialN_device ports from default serial_initialize() into driver specific function called from serial_initialize(). This slims down the serial_initialize() call to a bare tracker of all possible serial port registration routines in U-Boot. The newly implemented zynq_serial_initialize() function, which is implemented inside of the serial_zynq driver allows encapsulation of zynq_serialN_device within the serial_zynq driver itself. Also, remove the exports of zynq_serialN_device from include/serial.h as they are no longer needed. This is simply because the implementation of default_serial_console() is wrapped into the serial_zynq driver and the default console is picked by CONFIG_SERIAL<N> macro in config file. Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15serial: s5p: Move serial registration from serial_initialize()Marek Vasut
Move the registration of s5p_serialN_device ports from default serial_initialize() into driver specific function called from serial_initialize(). This slims down the serial_initialize() call to a bare tracker of all possible serial port registration routines in U-Boot. The newly implemented s5p_serial_initialize() function, which is implemented inside of the serial_s5p driver allows encapsulation of s5p_serialN_device within the serial_s5p driver itself. Also, remove the exports of s5p_serialN_device from include/serial.h as they are no longer needed. This is simply because the implementation of default_serial_console() is wrapped into the serial_s5p driver and the default console is picked by CONFIG_SERIAL<N> macro in config file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Minkyu Kang <mk7.kang@samsung.com>
2012-10-15serial: pxa: Move serial registration from serial_initialize()Marek Vasut
Move the registration of serial_XXuart ports from default serial_initialize() into driver specific function called from serial_initialize(). This slims down the serial_initialize() call to a bare tracker of all possible serial port registration routines in U-Boot. The newly implemented pxa_serial_initialize() function, which is implemented inside of the serial_pxa driver allows encapsulation of serial_XXuart within the serial_pxa driver itself. Also, remove the exports of serial_XXuart from include/serial.h as they are no longer needed. This is simply because the implementation of default_serial_console() is wrapped into the serial_pxa driver and the default console is picked by CONFIG_CONS_IDX macro in config file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-15serial: s3c24xx: Move serial registration from serial_initialize()Marek Vasut
Move the registration of s3c24xx_serialN_device ports from default serial_initialize() into driver specific function called from serial_initialize(). This slims down the serial_initialize() call to a bare tracker of all possible serial port registration routines in U-Boot. The newly implemented s3c24xx_serial_initialize() function, which is implemented inside of the serial_s3c24xx driver allows encapsulation of s3c24xx_serialN_device within the serial_s3c24xx driver itself. Also, remove the exports of s3c24xx_serialN_device from include/serial.h as they are no longer needed. This is simply because the implementation of default_serial_console() is wrapped into the serial_s3c24xx driver and the default console is picked by CONFIG_SERIAL<N> macro in config file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: C Nauman <cnauman@diagraph.com>
2012-10-15serial: mpc512x: Properly define CONFIG_SYS_PSC3 in config filesMarek Vasut
Some of the boards using the mpc512x serial driver didn't properly define which PSC console to use. This caused breakage when building with CONFIG_SERIAL_MULTI enabled. Fix this by defining the default PSC console. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de>
2012-10-15serial: pxa: Make use of default_serial_console in serial_pxaMarek Vasut
Make use of the newly implemented weak default_serial_console in the serial_pxa driver. This removes all reimplementations of this function from board files. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-15serial: Rename .init() and .uninit() in serial_deviceMarek Vasut
Rename .init() to .start() and .uninit() to .stop() in struct serial_device. This allows aligning struct serial_device with closer to struct stdio_dev. The real goal here is to allow these two structures to converge together and eventually make one to be a superset of the other. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15serial: Coding style cleanup of struct serial_deviceMarek Vasut
Do a simple cleanup of the struct serial_device and align it with current coding style. Checkpatch now reports no errors. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-15COMMON: Use __stringify() instead of rest of implementationsMarek Vasut
Fix up the rest of implementations of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2012-10-15COMMON: Use __stringify() instead of MK_STR()Marek Vasut
Kill multiple occurances and redeclaration of MK_STR in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15COMMON: Use __stringify() instead of xstr()Marek Vasut
Kill multiple occurances and redeclaration of xstr in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2012-10-15COMMON: Add __stringify() functionMarek Vasut
Copied from Linux kernel: commit 8f7c2c37319a81ef4c2bfdec67b1ccd5744d97e4 Date: Wed Apr 8 16:58:57 2009 +0800 Pull in the __stringify() macro from Linux kernel. This macro is usually used to convert numbers to strings at preprocessor level, yet it is not limited only to that. This is useful as it allows higher usage of puts() in favour of printf(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2012-10-15gth2: Remove this platformTom Rini
After taking with the former maintainer, delete this platform. The patch is from the former maintainer. Signed-off-by: Tom Rini <trini@ti.com>
2012-10-12m28: Properly configure the SPI flash chipselectMarek Vasut
The SPI flash is not properly detected by plain "sf probe" due to it being located on different bus and different chipselect. Fix this problem. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com>
2012-10-08ide: Correct IDE_BUS(dev) macroLuka Perkov
The IDE_BUS(dev) macro was previously doing dev >> 1. This however is a mis-match of the usage in common/cmd_ide.c and would cause boards with multiple ports / devices to not correctly detect all devices. For more details please see: http://lists.denx.de/pipermail/u-boot/2012-April/122525.html [Tom Rini: Reword commit message only] Tested-by: Luka Perkov <uboot@lukaperkov.net> Signed-off-by: Simon Baatz <gmbnomis@gmail.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-08ml507: Fix Xilinx uartlite driver hangRommel Custodio
The default configuration for ml507 will generate a hang() in the Xilinx uartlite driver. userial_ports[] in drivers/serial/serial_xuartlite.c does not get initialized properly. CONFIG_SERIAL_BASE is unused. XILINX_UARTLITE_BASEADDR is used instead. Signed-off-by: Rommel Custodio <sessyargc+uboot@gmail.com>
2012-10-05MPC85xx: remove support for TQM85xx boardsWolfgang Denk
Due to grown code sizes the TQM85xx boards don't build any more with some older tool chains (like ELDK 4.2). As these boards have long reached EOL it seems a waste of effort trying to fix them. The vendor has agreed to drop support for them, too. So let's get rid of them. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> cc: Kim Phillips <kim.phillips@freescale.com> Acked-by: Stefan Roese <sr@denx.de>
2012-10-04Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-10-04ARM: Add Altera SOCFPGA Cyclone5Dinh Nguyen
Add minimal support for Altera's SOCFPGA Cyclone 5 hardware. Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Signed-off-by: Chin Liang See <clsee@altera.com> Signed-off-by: Pavel Machek <pavel@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Tom Trini <trini@ti.com> Cc: Wolfgang Denx <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefan Roese <sr@denx.de> ---- v8: Remove no_return attribute for reset_cpu Based on v2012.10-rc2
2012-10-04xilinx: Add new Zynq boardMichal Simek
Add support for Xilinx Zynq board. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Marek Vasut <marex@denx.de> CC: Joe Hershberger <joe.hershberger@gmail.com>
2012-10-04serial: Add Zynq serial driverMichal Simek
The driver is used on Xilinx Zynq platform. Signed-off-by: Michal Simek <monstr@monstr.eu> CC: Joe Hershberger <joe.hershberger@gmail.com> CC: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2012-10-04ARM: Add X600 board support (SPEAr600 based)Stefan Roese
This patch adds support for the X600 SPEAr600 based board. Its also the first SPEAr600 board that uses the newly introduced SPEAr600 SPL support. Xloader is not necessary any more. By using the new "u-boot.spr" make target, one image will generated containing both, U-Boot SPL (with mkimage header as needed by the SPEAr BootROM, and the main U-Boot with mkimage header. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Amit Virdi <amit.virdi@st.com> Cc: Vipin Kumar <vipin.kumar@st.com>
2012-10-03ext4: Rename block group descriptor table from gd to bgdSimon Glass
On x86 machines gd is unfortunately a #define, so we should avoid using gd for anything. This patch changes uses of gd to bgd so that ext4fs can be used on x86. A better fix would be to remove the #define in x86, but I'm not sure how to do that. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-03Merge remote-tracking branch 'u-boot-marvell/master'Albert ARIBAUD
2012-10-03km_kirkwood: enable MV88E6352_SWITCH support for kmnusaValentin Longchamp
This is required to configure the external 88e6352 switch on nusa. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Prafulla Wadaskar <Prafulla@marvell.com>
2012-10-03edminiv2: increase malloc len to 256KAlbert ARIBAUD
Malloc len of 128K caused a warning from ehci_hcd asking for more. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2012-10-03kirkwood: add support for Iomega iConnect boardLuka Perkov
Add support for new board iConnect from Iomega. More information about the device can be found here: http://go.iomega.com/en/products/network-storage-desktop/wireless-data-station/network-hard-drive-iconnect/?partner=4735 Signed-off-by: Luka Perkov <uboot@lukaperkov.net> Tested-by: Wojciech Dubowik <wojciech.dubowik@neratec.com> Tested-by: Tim Fletcher <tim@night-shade.org.uk>
2012-10-03ARM: add support for d2 Network v2Simon Guinot
This patch adds support for the LaCie board d2 Network v2 which share a lot of hardware caracteristics with the 2Big Network v2. - CPU: Marvell 88F6281 1200Mhz - SDRAM memory: 256MB DDR2 400Mhz - 2 SATA ports: internal and eSATA - Gigabit ethernet: PHY Marvell 88E1116R - Flash memory: SPI NOR 512KB (Macronix MX25L4005A) - i2c EEPROM: 512 bytes (24C04 type) - 2 USB2 ports: host and host/device - 1 push button - 1 power switch - 1 SATA LED (bi-color, blue and red) Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
2012-10-03ARM: add support for Network Space v2 Lite and MiniSimon Guinot
This patch adds support for the LaCie boards Network Space v2 (Lite and Mini). This two boards are derived from the Network Space v2 and a lot of hardware caracteristics are shared. - CPU: Marvell 88F6192 800Mhz - SDRAM memory: 128MB DDR2 200Mhz - 1 SATA port: internal - Gigabit ethernet: PHY Marvell 88E1318 - Flash memory: SPI NOR 512KB (Macronix MX25L4005A) - i2c EEPROM: 512 bytes (24C04 type) - 2 USB2 ports (Lite only): host and host/device - 1 push button - 1 SATA LED (bi-color, blue and red) Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
2012-10-03lacie_kw: add support for EFI partitionsSimon Guinot
Defines CONFIG_EFI_PARTITION for LaCie boards. Additionally this patch defines CONFIG_DOS_PARTITION. Note that this definition is implicit in mv_common.h when CONFIG_CMD_USB is enabled. Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
2012-10-03ARM : Add support for MINI2440 (s3c2440).Gabriel Huau
Support of the MINI2440 board from FriendlyARM from an old version of u-boot : http://repo.or.cz/r/u-boot-openmoko/mini2440.git Currently, supporting only boot from NOR. Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr>
2012-10-03rmobile: armadillo-800eva: Remove CONFIG_SYS_NO_L2CACHENobuhiro Iwamatsu
armadillo-800eva needs this config. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03rmobile: armadillo-800eva: Add Support NFS and BOOTZ commandNobuhiro Iwamatsu
2012-10-03rmobile: armadillo-800eva: Add Support CONFIG_OF_LIBFDTNobuhiro Iwamatsu
2012-10-03arm: rmobile: Add support for ATMARK-TECHNO Armadillo-800EVA boardHideyuki Sano
The Armadillo-800EVA board has Renesas R-Mobile R8A7740, 512MB DDR3-SDRAM, Ethernet, and more. This patch supports the following functions: - 512MB DDR3-SDRAM - Serial console (SCIF) - Ethernet MAC(MII) & PHY(SMSC) Signed-off-by: Hideyuki Sano <hideyuki.sano.dn@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: kzm9g: Add CONFIG_GLOBAL_TIMER to board config fileNobuhiro Iwamatsu
kzm9g board use global timer. But by commit 813ffda31, timer function of rmobile was changed that global timer might be used, when CONFIG_GLOBAL_TIMER was defined. This add CONFIG_GLOBAL_TIMER to board config file. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: Add support TMU base timer functionNobuhiro Iwamatsu
Some rmobile SoC has TMU base timer function. This supports TMU. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: kzm9g: remove unrelated configNobuhiro Iwamatsu
Remove CONFIG_ARM_CORTEXA9. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: kzm9g: Add LIBFDT supportNobuhiro Iwamatsu
2012-10-03arm: rmobile: kzm9g: remove unrelated configTetsuyuki Kobayashi
Remove CONFIG_INTEGRATOR and CONFIG_ARCH_CINTEGRATOR. These are not for kzm9g. Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: kzm9g: add NFS_TIMEOUT in config fileTetsuyuki Kobayashi
Set NFS_TIMEOUT to 10,000 msec. Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: kzm9g: Fix CONFIG_BAUDRATE settingTetsuyuki Kobayashi
The value of CONFIG_BAUDRATE is treated as string and put as initial value of environment variable. If it begin with '(', it is wrongly parsed to 0 in number. So I removed '(' and ')'. Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: kzm9g: change prompt to board specificTetsuyuki Kobayashi
Change U-Boot prompt to board specific one. Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
