This enables the device tree library on the Integrator platforms
so we can pass a device tree when booting.
As this board has NAND and supports YAFFS2, add CONFIG_MD_NAND_YAFFS
Cc: David Müller <d.mueller@elsoft.ch>
Acked-by: David Müller <d.mueller@elsoft.ch>
drivers/video/exynos_fb.c
This board is from a u-boot point of view a mixture between kmnusa and
a standard km_kirkwood board. We have our u-boot environment in the spi
NOR flash, but we have a direct connection between the kirkwood and the
piggy. A FPGA is connected via the PCIe interface. So we only have to
select the specific features in the board setup.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
Switch from 1-bit ecc to 4-bit ecc.
commit 9660e442 cosmetic: s/BOARD_LATE_INIT/CONFIG_BOARD_LATE_INIT
removes BOARD_LATE_INIT and uses CONFIG_BOARD_LATE_INIT instead.
Therefore we have to use this define.
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
The conversion of mx31pdk to SPL NAND fixed the boot issue, but we start seeing
resets in loop, which prevents us from reaching the U-boot prompt.
Until the proper fix can be identified, disable watchdog, so that mx31pdk
can be functional again.
Following the removal of the smdk6400 board, the s3c64xx SoC becomes unused, so
remove associated code. It will still be possible to restore it later from the
Git history if necessary.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
The migration of boards from Makefile to boards.cfg was due for v2012.03, but
smdk6400 did not follow, and it does not build, so move it to scrapyard. It will
still be possible to restore it from the Git history before fixing it.
Commit e05e5de7fae5bec79617e113916dac6631251156 made the 2 1st parameters of
ARM's relocate_code() useless since it moved the code handling them to crt0.S.
So, drop these parameters.
This also fixes support for mx31pdk and tx25, which had been broken by commit
e05e5de7fae5bec79617e113916dac6631251156.
Acked-by: Scott Wood <scottwood@freescale.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Change CONFIG_SPL_PAD_TO from a link address to an image offset since this is
more handy and closer to the purpose of this config.
Automatically define CONFIG_SPL_PAD_TO to CONFIG_SPL_MAX_SIZE (or 0 without
CONFIG_SPL_MAX_SIZE).
Test that CONFIG_SPL_PAD_TO >= CONFIG_SPL_MAX_SIZE if CONFIG_SPL_PAD_TO is
non-zero.
Commit e05e5de7fae5bec79617e113916dac6631251156 made ARM's relocate_code()
return to its caller, but it did not update its declaration accordingly.
Fixing this function declaration fixes dropped C code following calls to
relocate_code().
Add support for the Samsung K9LAG08U0M NAND Flash (2-GiB MLC NAND Flash, 2-kiB
pages, 256-kiB blocks, 30-ns R/W cycles, 1 CS) on mx53ard.
eNFC_CLK_ROOT is set up with a cycle time of 37.5 ns (400 MHz / 3 / 5) for this
board, which satisfies the 30-ns NF R/W cycle requirement.
Add some abstraction to NFC definitions so that some parts of the current code
can also be used for future i.MX5 code.
Clean up a few things by the way.
Allow the user to specify two UBI volumes to use for the environment
UBI is a better place for the environment on NAND devices because it
handles wear-leveling and bad blocks.
Gluebi is needed in Linux to access the env as an MTD partition.
Part, Read, and Write functionality that will be used by env_ubi.
The function get_timer() should return time in ms and CONFIG_SYS_HZ
should be set to 1000 by default. Fix both of these items.
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
The current u-boot binary needs more than 128KB of flash space and so
move the u-boot environment from an offset of 128KB to 256KB in flash
to ensure the enviroment does not overlap with u-boot.
In the current u-boot, the device pin multiplexing and clock
initialisation needs to be early during the boot process and before
board_init() is called. U-boot is currently crashing on this board
because this is not being done early enough. Therefore, add a s_init()
function for the omap5912-osk board to do this.
Also fix the stack pointer so that it is pointing to the end of the
internal RAM and not the beginning as this was also causing the device
to crash.
This has a 2MiB erase block size eMMC, so make sure we align on that for
best possible performance.
- Add CONFIG_DFU_NAND, CONFIG_DFU_MMC
- Set dfu_alt_info_nand, dfu_alt_info_emmc and dfu_alt_info_mmc to show
working examples for those cases.
- Increase CONFIG_SYS_MAXARGS due to hush parsing bugs that would
otherwise disallow 'setenv dfu_alt_info ${dfu_alt_info_nand}'.
- Enable CONFIG_FAT_WRITE to allow updating on MMC
Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
drivers/usb/gadget/composite.c requires that this is defined early.
Acked-by: Tom Rini <trini@ti.com>
Support for NAND storage devices to work with the DFU framework.
We make these two functions take a size_t pointer to how much space
was used on NAND to read or write the buffer (when reads/writes happen)
so that bad blocks can be accounted for. We also make them take an
loff_t limit on how much data can be read or written. This means that
we can now catch the case of when writing to a partition would exceed
the partition size due to bad blocks. To do this we also need to make
check_skip_len count not just complete blocks used but partial ones as
well. All callers of nand_(read|write)_skip_bad are adjusted to call
these with the most sensible limits available.
The changes were started by Pantelis and finished by Tom.
Previously we didn't support upload/download larger than available
memory. This is pretty bad when you have to update your root filesystem
for example.
This patch removes that limitation (and the crashes when you transfered
any file larger than 4MB) by making raw image writes be done in chunks
and making file maximum size be configurable.
The sequence number is a 16 bit counter; make sure we handle rollover
correctly. This fixes the wrong transfers for large (> 256MB) images.
Also utilize a variable to handle initialization, so that we don't rely
on just the counter sent by the host.
Increase size of DMA buffer from 4MiB to 8MiB. This is necessary due to
uImage size increase.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Cc: Sricharan R <r.sricharan@ti.com>
The omap5_uevm platform has eMMC, and it makes sense to say that our
default env storage shall reside there. Other platforms may not, so
move this choice to the EVM config. In addition, we should provide some
way to partition the flash for later usage, so take advantage of the GPT
partition table support code and allow that to be setup with some
reasonable defaults.
So with OMAP added to multi platform kernel,
the uImage no more contains a valid load address.
With the uboot already supporting zImage,
change the default boot command to bootz
instead.
Acked-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Sricharan R <r.sricharan@ti.com>
Tested-by: Nishanth Menon <nm@ti.com>
Now with kernel moving to all device tree, the default
boot command is changed to pass the device tree blob.
Also, adding the findfdt command to get the dt-blob
based on the board.
Thanks to Tom Rini <trini@ti.com> for suggesting this.
For production systems it is better to use script images since
they are protected by checksums and carry valuable information
like name and timestamp. Also, you can't validate the content
passed to env import.
But for development, it is easier to use the env import command and
plain text files instead of script-images.
Since both OMAP5evm/uevm boards are used primarily for development,
we allow U-Boot to load env var from a text file in case that an
boot.scr script-image is not present.
The variable uenvcmd (if existent) will be executed (using run) after
uEnv.txt was loaded. If uenvcmd doesn't exist the default boot sequence
will be started.
Inspired by commit: d70f54808dfa83b574e1239c3eccbcf3317343e1
(omap4: allow the use of a plain text env file instead boot scripts)
Signed-off-by: Nishanth Menon <nm@ti.com>
Tested-by: Sricharan R <r.sricharan@ti.com>
While booting with dt blob, if fdt_high is not set to
0xffffffff, the dt blob gets relocated to a high ram address,
which the kernel is not able to use without HIGHMEM.
So set it to 0xffffffff to avoid the issue.
The omap5-uevm is the reference board name for OMAP5 soc
based platform. So rename it accordingly.
Enable device-tree support for the omap2420-h4 board.
The omap2420-h4 board is using a RAM based address as the linker
location for code. This is causing several problems when attempting
to run the latest u-boot code base on this board from flash. Update
the default linker location for code to be in NOR flash. Please note
that OMAP maps the NOR flash to address 0x08000000 by default and so
use this as the default address for the NOR flash.
Also remove legacy code that attempts to calculate where in flash the
sdata structure, that holds the memory interface configuration data,
is located. By changing the default linker location for code to flash
this is no longer necessary.
Cc: Tom Rini <trini@ti.com>
Cc: Thomas Weber <weber@corscience.de>
Cc: Ilya Yanok <ilya.yanok@cogentembedded.com>
Cc: Scott Wood <scottwood@freescale.com>
Flush UART3 xmit on enable if TEMT is broken
On some OMAP3 devices when UART3 is configured for boot mode before SPL starts
only THRE bit is set. We have to empty the transmitter before initialization
starts. This patch avoids the use of CONFIG_SYS_NS16550_BROKEN_TEMT.
Signed-off-by: Manfred Huber <man.huber@arcor.de>
Tested-by: Javier Martinez Canillas <javier@dowhile0.org>
Tested-by: Andreas Bießmann <andreas.devel@googlemail.com>
On TI AM335x devices, MUSB has bulk split/combine feature enabled
in the ConfigData register, but the current MUSB driver does not
support it yet. Therefore, disable the feature for now, until the
driver adds the support.
One usecase which is broken because of this feature is that Ether
gadget stops working in Fullspeed mode (by un-defining
CONFIG_USB_GADGET_DUALSPEED)
After desabled this feature, MUSB driver send packets in proper size
(no more than 64 bytes) in Fullspeed mode.
This has been validated with Ether gadget in Fullspeed mode on AM335x
EVM.
Signed-off-by: Bin Liu <b-liu@ti.com>
Apparently, CONFIG_SYS_HZ must be 1000. Change this, and fix the timer
driver to conform to this.
Have the timer implementation export a custom API get_timer_us() for use
by the BCM2835 MMC API, which needs us resolution for a HW workaround.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
CONFIG_SYS_FSL_USDHC_NUM is not used for wandboard.
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
