finish remaning CFG_ID_EEPROM in CONFIG_ID_EEPROM
start in commit ad8f8687b78c3e917b173f038926695383c55555
Also set up the port pins for using I2C.
- add function fit_all_image_check_hashes() that verifies if all
hashes of all images in the FIT are valid
- improve output of fit_image_check_hashes() when the hash check fails
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
Pantelis Antoniou stated:
AFAIK, it is still used but the products using PPC are long gone.
Nuke it plz (from orbit).
So remove it since it cleans up a usage of env_get_char outside of
the environment code.
Signed-off-by: Andreas Engel <andreas.engel@ericsson.com>
Attempt to bring i386 / sc520 inline with master
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
This patch adds Lime GDC support together with support for the PWM
backlight control through the w83782d chip. The reset pin of the
latter is attached to GPIO, so we need to reset it in
early_board_init_r.
- Update the local bus ranges in the FDT for Linux for the various
devices connected to the local bus via chip-select.
- Set the LCRR_DBYP bit in the LCRR for local bus frequencies
lower than 66 MHz and uses I/O accessor functions consequently.
- UPM data update.
- Update of default environment and configuration. Use I2C multibus
as we do have two I2C buses. Also enable sdram and ext2 commands.
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
Signed-off-by: Detlev Zundel <dzu@denx.de>
The new sys_eeprom.c supports both the old CCID EEPROM format and the new NXID
format, and so it obsoletes board/freescale/common/cds_eeprom.c. Freescale
86xx boards already use sys_eeprom.c, so this patch migrates the remaining
Freescale 85xx boards to use it as well. cds_eeprom.c is deleted.
Makefile
missing doc_probe() prototype.
This patch moves some 4xx specific prototypes out of include common.h
to a ppc4xx specific header.
This patch add FDT support and command line editing capabilities
for CPCI405 and CPCI405AB boards.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Since this define is only used on one board that was never really in
production, removing this compile time option doesn't hurt and makes
the code more readable.
Added new CONFIG_DISABLE_CONSOLE define and GD_FLG_DISABLE_CONSOLE.
When CONFIG_DISABLE_CONSOLE is defined, setting
GD_FLG_DISABLE_CONSOLE disables all console input and output.
Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
Some of multi-function USB controllers (e.g. ISP1562) allow root hub
resetting only via EHCI registers. So, this patch adds the
corresponding kind of reset to OHCI's hc_reset() if the newly
introduced CONFIG_PCI_EHCI_DEVNO option is set (e.g. for Socrates
board).
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Acked-by: Markus Klotzbuecher <mk@denx.de>
This patch adds GPCS, SGMII and M88E1112 PHY support
for the AMCC PPC460GT/EX processors.
Signed-off-by: Victor Gallardo <vgallardo@amcc.com>
Signed-off-by: Adam Graham <agraham@amcc.com>
This patch provides an unificated way of handling xilinx v5 ppc440 boards.
It unificates 3 different things:
1) Source code
A new board called ppc440-generic has been created. This board includes
a generic tlb initialization (Maps the whole memory into virtual) and
defines board_pre_init, checkboard, initdram and get_sys_info weakly,
so, they can be replaced by specific functions.
If a new board needs to redefine any of the previous functions
(specific initialization) it can create a new directory with the
specific initializations needed. (see the example ml507 board).
2) Configuration file
Common configurations are located under configs/xilinx-ppc440.h, this
header file interpretes the xparameters file generated by EDK and
configurates u-boot in correspondence. Example: if there is a Temac,
allows CMD_CONFIG_NET
Specific configuration are located under specific configuration file.
3) Makefile
Some work has been done in order to not duplicate work in the Main
Makefile. Please see the attached code.
In order to support new boards they can be implemented in the next way:
a) Simple Generic Board (90% of the time)
Using EDK generates a new xparameters.h file, replace
ppc440-generic/xparameters.h and run make xilinx-ppc440-generic_config
&& make
b) Simple Boards with special u-boot parameters (9 % of the time)
Create a new file under configs for it (use ml507.h as example) and
change your paramaters. Create a new Makefile paragraph and compile
c) Complex boards (1% of the time)
Create a new folder for the board, like the ml507
Finally, it adds support for the Avnet FX30T Evaluation board, following
the new generic structure:
Cheap board by Avnet for evaluating the Virtex5 FX technology.
This patch adds support for:
- UartLite
- 16MB Flash
- 64MB RAM
Prior using U-boot in this board, read carefully the ERRATA by Avnet
to solve some memory initialization issues.
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
Record the Arbiter Event Register values and optionally display them.
The Arbiter Event Register can record the type and effective address of
an arbiter error, even through an HRESET. This patch stores the values in
the global data structure.
Display of the Arbiter Event registers immediately after the RSR value
can be enabled with defines. The Arbiter values will only be displayed
if an arbiter event has occured since the last Power On Reset, and either
of the following defines exist:
#define CONFIG_DISPLAY_AER_BRIEF - display only the arbiter address and
and type register values
#define CONFIG_DISPLAY_AER_FULL - display and interpret the arbiter
event register values
Address Only transactions are one of the trapped events that can register
as an arbiter event. They occur with some cache manipulation instructions
if the HID0_ABE (Address Broadcast Enable) is set and the memory region
has the MEMORY_COHERENCE WIMG bit set. Setting:
#define CONFIG_MASK_AER_AO - prevents the arbiter from recording address
only events, so that it can still capture
other real problems.
Signed-off-by: Nick Spence <nick.spence@freescale.com>
board/esd/dasa_sim/dasa_sim.c
- remove PCI code
- add command line editing
- minor cleanup
Signed-off-by: Matthias Fuchs <mf@esd.eu>
Wrap long lines etc.
This patch enables the PCI-OHCI controller on PLU405 board.
Also the default CPU frequency is updated to 266 MHz and
command line editing is enabled.
Affected boards:
db64360
db64460
katmai
taihu
taishan
yucca
cpc45
cpu87
eXalion
elppc
debris
kvme080
mpc8315erdb
integratorap
ixdp425
oxc
pm826
pm828
pm854
pm856
ppmc7xx
sc3
sc520_spunk
sorcery
tqm8272
tqm85xx
utx8245
Removed initialization of the driver from net/eth.c
Also, wrapped contents of pci_eth_init() by CONFIG_PCI.
Affected boards:
cu824
bab7xx
adciop
dasa_sim
mousse
mpc8540eval
musenki
mvblue
pcippc2/pcippc6
sbc8240
stxssa
Affected boards:
ap1000
mvbc_p
PM854
Affected boards:
purple
Removed initialization of controller from net/eth.c
