Allow i.MX6Q Sabre SD to load the kernel and dtb via SPL in Falcon mode.
Based on the Falcon mode code for MX6 Gateworks Ventana board.
Signed-off-by: Diego Dorta <diego.dorta@nxp.com>
Selecting the proper options to enable the build of the HAB tools.
Note, this support is disabled by default, one will have to select
the SECURE_BOOT configuration through menuconfig to enable it.
See doc/README.mxc_hab for more details.
Also remove duplicate options from board config headers.
Cc: Stefan Agner <stefan.agner@toradex.com>
Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com>
Move FDT_FIXUP_PARTITIONS to Kconfig and cleanup existing
uses.
Move SYS_OS_BASE to Kconfig and cleanup existing
uses.
[trini: Also migrate a4m2k]
Move SPL_OS_BOOT to Kconfig and cleanup existing
uses.
The fdt_path_offset() function is not inlined in upstream libfdt. Adjust
U-Boot's version to match.
The signature for this macro has changed. Bring in the upstream version and
adjust U-Boot's usages to suit.
Update to drivers/power/pmic/palmas.c:
Signed-off-by: Keerthy <j-keerthy@ti.com>
Change-Id: I6cc9021339bfe686f9df21d61a1095ca2b3776e8
These have now landed upstream. The naming is different and in one case the
function signature has changed. Update the code to match.
This applies the following upstream commits by
Thierry Reding <treding@nvidia.com> :
604e61e fdt: Add functions to retrieve strings
8702bd1 fdt: Add a function to get the index of a string
2218387 fdt: Add a function to count strings
This includes small changes to the following functions, from upstream
commit 6d1832c:
- fdt_get_max_phandle() (upstream commit 84e0e134)
- fdt_node_check_compatible (upstream commit 53bf130b)
- fdt_setprop_inplace_namelen_partial() to remove useless brackets and
use idx instead of index
- _fdt_resize_property() to use idx instead of index
- _fdt_splice() (upstream commit d4c7c25c)
It also includes various typo fixes in libfdt.h
Sometimes devicetree nodes and or properties are added out of the u-boot
console, maybe through some script or manual interaction.
The devicetree as loaded or embedded is quite small, so the devicetree
has to be resized to take up those new nodes/properties.
In original the devicetree was only extended by effective
4 * add_mem_rsv.
With this commit we can add an argument to the "fdt resize" command,
which takes the extrasize to be added.
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
source selection
cpsw driver supports only selection of phy mode in control module
but control module has more setting like RGMII ID mode selection,
RMII clock source selection. So ported to cpsw-phy-sel driver
from kernel to u-boot.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
In AM335x GP EVM, Atheros 8031 phy is used, enable the driver as
AM335x SoC RGMII delay mode has to be enabled in phy as mentioned
in the silicon errata Advisory 1.0.10
include/configs/ls1021aqds.h
include/configs/ls1021atwr.h
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
Legacy video driver macros are not needed. Clean them up.
This converts coreboot to use DM framebuffer driver.
vbe_setup_video_priv() might be useful to other drivers.
At present only chromebook boards are converted to DM video. Other
x86 boards are still using the legacy cfb_console driver. This
switches to use DM version drivers.
Move crosec commands from drivers/misc/cros_ec.c to
cmd/cros_ec.c
Signed-off-by: Moritz Fischer <moritz.fischer@ettus.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Miao Yan <yanmiaobest@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Cc: Nishanth Menon <nm@ti.com>
Cc: u-boot@lists.denx.de
Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
Add support to bind the regulators/child nodes with the pmic.
Also adds the pmic i2c based read/write funtions to access pmic
registers.
The ctrl reg contains bit fields to enable and disable regulators,
and volt_reg has the bit fields to configure the voltage values.
The registers are frequently accessed hence make them part
of dm_regulator_uclass_platdata structure.
Add support for gpio regulators. As of now this driver caters
to gpio regulators with one gpio. Supports setting voltage values to gpio
regulators and retrieving the values.
We don't have a way of adjusting these at present so it is best to refuse to
export these functions. This can be implemented later if the API is required.
Add this so that we can support 64-bit relocation on x86.
This is used in some link scripts, so add a declaration for it.
Update the common configuration so that it works correctly when
CONFIG_DM_VIDEO is enabled. This involves dropping the legacy CONFIG_VIDEO
option and changing the stdio device from "vga" to "vidconsole".
Provide a function to run the Vesa BIOS for a given PCI device and obtain
the resulting configuration (e.g. display size) for use by the video
uclass. This makes it easier to write a video driver that uses vesa and
supports driver model.
It is useful in debug() statements to display the name of the uclass for a
device. Add a simple function to provide this.
We have list_first_entry() but in some cases it is useful to find the last
item added to the list. Add a macro for this.
With this addition, the eMMC device available on the congatec and DFI
BayTrail SoM is detected correctly.
The Tegra 2 aka T20 is not host PC capable. Therefore gate the define
CONFIG_CI_UDC_HAS_HOSTPC in tegra-common-usb-gadget.h in case of
CONFIG_TEGRA20.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Some arguments don't need to pass to dwmci_setup_cfg.
They are already included in dwmci_host structure.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
The of_xlate() callback needs to know fdtdec_phandle_args is struct.
Otherwise, the following warning is displayed.
include/reset-uclass.h:40:11: warning: 'struct fdtdec_phandle_args'
declared inside parameter list
struct fdtdec_phandle_args *args);
include/reset-uclass.h:40:11: warning: its scope is only this
definition or declaration, which is probably not what you want
This is an on-board Ethernet device. It has no point if the Micro
Support Card is not available.
NOR flash devices are seldom used on UniPhier platforms these days.
The only use case I see is the Micro Support Card is connected.
Otherwise, define CONFIG_SYS_NO_FLASH to disable NOR FLASH.
Synology DS109 is based on MV88F6281. The code
is based on Dreamplug code with modificatons
from Synologys open source repository.
Signed-off-by: Walter Schweizer <swwa@users.sourceforge.net>
