This patch removes CONFIG_SYS_DSPI_XX options from
include/configs "m68k" .h board files, since CTAR
registers are now set with default values in the cf_spi
driver initialization, and configurable by devicetree.
Note, these options cannot be totally removed from the
whitelist, since still used from boards using fsl_dspi.c
(mostly arm-based boards).
Signed-off-by: Angelo Dureghello <angelo@sysam.it>
Converting to driver model and removes non-dm code.
Various DM fixes
Addition of ofnode_get_addr_size_index()
commit 58c3e62040be ("armv8: lx2160ardb : Add support for LX2160ARDB
platform") brought a new boards support with redundancy in the config.h.
One of them is CONFIG_CMDLINE_EDITING which is removed by this change.
Cc: Priyanka Jain <priyanka.jain@nxp.com>
Cc: Peng Ma <peng.ma@nxp.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
esbc_validate command will not be executed if “load” command for its
header fails and will further execute the source command for bootscript,
without its validation and boot process continues.
To halt the boot process in case secure boot header is not loaded
successfully, esbc_validate command is invoked separately after “load”
command. The secure boot validation of the bootscript header will fail
(if header is not loaded) and halts the boot process, which prevent source
command from execution.
Signed-off-by: Vinitha V Pillai <vinitha.pillai@nxp.com>
Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com>
AQR107 PHYs interrupt pins are active-low, while the GIC expects a
level-high signal.
Signed-off-by: Florin Chiculita <florinlaurentiu.chiculita@nxp.com>
LS1028AQDS Development System is a high-performance
computing, evaluation, and development platform that supports
LS1028A QorIQ Architecture processor.
Signed-off-by: Sudhanshu Gupta <sudhanshu.gupta@nxp.com>
Signed-off-by: Rai Harninder <harninder.rai@nxp.com>
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com>
Signed-off-by: Tang yuantian <andy.tang@nxp.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
LS1028A is an ARMv8 implementation. LS1028ARDB is an evaluation
platform that supports the LS1028A family SoCs. This patch add basic
support of the platform.
Signed-off-by: Tang Yuantian <andy.tang@nxp.com>
It was returning an int, which doesn't work if the u32 it is reading,
or the default value, will overflow a signed int.
While it could be made to work, when using a C standard/compiler where
casting negative signed values to unsigned has a defined behavior,
combined with careful casting, it seems obvious one is meant to use
ofnode_read_s32_default() with signed values.
Signed-off-by: Trent Piepho <tpiepho@impinj.com>
Add ofnode_get_addr_size_index function to fetch the address
and size of the reg space based on index.
Signed-off-by: Keerthy <j-keerthy@ti.com>
U-Boot already defines the {upper,lower}_32_bits() macros that have the
same purpose. Use the existing macros instead of defining new APIs.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Some libraries build by U-Boot may include stdint.h. This is not used by
U-Boot itself and causes conflicts with the types defined in
linux/types.h. To work around this, add an empty file with this name so
that it will be used in preference to the compiler version.
- Update MPC83xx platform support to current best practices, etc.
- update for using splashfile instead of location->name
when loading the splash image from a FIT
- updates for loading internal and external splash data from FIT
- DM_GPIO/DM_VIDEO migration for mx53 cx9020 board
- fix boot issue on mx6sabresd board after DM_VIDEO migration
- increase the max preallocated framebuffer BPP to 32 in ipuv3
driver to prepare for configurations with higher color depth
- allow to use vidconsole_put_string() in board code for text
output on LCD displays
The gdsys gazerbeam board is based on a Freescale MPC8308 SOC.
It boots from NOR-Flash, kernel and rootfs are stored on
SD-Card.
On board peripherals include:
- 2x 10/100 Mbit/s Ethernet (optional)
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Future gdsys boards will switch from the legacy drivers in board/gdsys/common
to DM-based drivers.
Define a Kconfig option that disables the legacy drivers.
Move CONFIG_SYS_FPGA0_BASE, CONFIG_SYS_FPGA0_SIZE, CONFIG_SYS_FPGA1_BASE, and
CONFIG_SYS_FPGA1_SIZE to Kconfig.
The ppc4xx architecture was removed, and with it several old gdsys 44x
boards, but some "debris" from these purged boards was left over.
This patch removes these remnants (mostly entries in Makefiles, some now
superfluous data structures and some now obsolete config variables from
the whitelist).
Not that the Kconfig conversion of a lot of variables is done, we can
factor out the common include files for the keymile boards again (which
now contain hardly any #ifdef logic at all).
CONFIG_SYS_APP1_BASE, CONFIG_SYS_APP2_BASE, CONFIG_SYS_APP1_SIZE, and
CONFIG_SYS_APP2_SIZE are no longer used in the keymile config files
(they were used for setting values, which were converted to Kconfig
earlier in the series).
Remove them from the configs and the whitelist.
Except for one counter example, CONFIG_SYS_LBC_LBCR always has a value
of either 0x00040000 or 0x00000000.
CONFIG_SYS_LBC_MRTPR always has the value 0x20000000.
CONFIG_SYS_LBC_LSDMR_{1,2,4,5} are not set for any mpc83xx board.
CONFIG_SYS_LBC_LSRT is set by one board (to 0x32000000).
To simplify the configuration files, hardcode the setting of these
values for mpc83xx.
CONFIG_SYS_DDR_SDRAM_BASE is set to the same value as
CONFIG_SYS_SDRAM_BASE on all existing boards. Just use
CONFIG_SYS_SDRAM_BASE instead.
CONFIG_SYS_DDR_BASE is specific to mpc83xx an is always set to the same
value as CONFIG_SYS_SDRAM_BASE. Just use CONFIG_SYS_SDRAM_BASE instead.
Migrate the CONFIG_LCRR_* settings to Kconfig.
Migrate the SPCR setting to Kconfig.
Migrate the arbiter configuration to Kconfig.
Migrate the system IO configuration setting to Kconfig.
Migrate CONFIG_SYS_IMMR to Kconfig for MPC83xx.
Mirate the HID configuration settings to Kconfig.
Remove the last instances of the CONFIG_MPC83xx symbol.
Migrate the BR/OR settings to Kconfig. These must be known at compile
time, so cannot be configured via DT.
Configuration of this crucial variable should still be somewhat
comfortable. Hence, make its fields configurable in Kconfig, and
assemble the final value from these.
The MPC8349EMDS configuration was the basis for the sbc8349, so it also
contains its SDRAM option.
Since
* the SDRAM has to be soldered onto the board,
* the sbc8349 never used the support, and
* the support never worked (see previous patch fixing it),
we can assume that the support on the sbc8349 is an artifact created by
copying the MPC8349EMDS config wholesome.
Hence, instead of creating a separate sbc8349 config that supports
SDRAM, we can remove the SDRAM option for this board.
Should it be needed in the future, it can be copied from the new
MPC8349EMDS_SDRAM board.
Re-format all BR,OR #define lines into single lines. This makes them
harder to read, but accessible to semi-automatic replacement.
All BR/OR option lines should have the same layout to make them easier
to migrate to Kconfig. This includes using the same option macros
everywhere.
The normalize the lines,
* replace function macros with their results, and
* replace hardcoded hex values with standard macros
The LBLAW_* values determine the window configuration of the memory
controller. Hence, they must be known at compile time, and cannot be
implemented in the DT mechanism.
The BATs (block address translation registers) determine the initial
memory window mappings. Hence, they must be known at compile time and
cannot be implemented in the DT mechanism.
Migrate the CONFIG_HIGH_BATS variable to Kconfig.
The HRCW (hardware reset configuration word) is a constant that must be
hard-coded into the boot loader image. So, it must be available at
compile time, and cannot be migrated to the DT mechanism, but has to be
kept in Kconfig.
MPC83xx uses CONFIG_83XX_CLKIN instead of CONFIG_SYS_CLK_FREQ to set the
system clock. To migrate the architecture, we can replace
CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ.
To do this
* replace all occurrences of CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ
* set CONFIG_SYS_CLK_FREQ to the old value of CONFIG_83XX_CLKIN in all
MPC83xx config files
CONFIG_SYS_CLK_FREQ is the standard way to set the system clock
frequency. On MPC83xx, CONFIG_83XX_CLKIN is used for this purpose.
Hence, the obvious way is to replace CONFIG_83XX_CLKIN with
A few MPC83xx boards use the CONFIG_83XX_CLKIN variable for computing
CONFIG_SYS_NS16550_CLK. This makes it harder to replace
CONFIG_83XX_CLKIN.
But the value of the multiplicator can be read from the SPMR register.
Hence, replace the static calculations with a call to a new get_bus_freq
function, as other architectures do.
The MPC83xx include files contain some settings of the PCI subsystem.
Migrate these to Kconfig until a proper DM PCI driver exists.
CONFIG_MPC837XERDB is unused, and TARGET_MPC837XERDB could replace it.
Hence, get rid of CONFIG_MPC837XERDB.
CONFIG_MPC837XEMDS is unused, and TARGET_MPC837XEMDS could replace it.
Hence, get rid of CONFIG_MPC837XEMDS.
CONFIG_MPC8315ERDB is unused, and TARGET_MPC8315ERDB could replace it.
Hence, get rid of CONFIG_MPC8315ERDB.
CONFIG_MPC8313ERDB is unused, and
TARGET_MPC8313ERDB_NAND/TARGET_MPC8313ERDB_NOR Kconfig could replace it.
Hence, get rid of CONFIG_MPC8313ERDB.
Use the proper CONFIG_TARGET_STRIDER Kconfig option to replace the
CONFIG_STRIDER ad-hoc config option.
Use the proper CONFIG_TARGET_HRCON Kconfig option to replace
the CONFIG_HRCON ad-hoc config option.
Use the proper CONFIG_TARGET_MPC8349ITX Kconfig option to replace the
CONFIG_MPC8349ITX ad-hoc config option.
Use the proper CONFIG_TARGET_MPC832XEMDS Kconfig option to replace the
CONFIG_MPC832XEMDS ad-hoc config option.
The ve8313 has the option of either configuring the eLBC (enhanced local system bus) such that
* NOR flash is the first memory bank, and NAND flash is the second memory bank, or
* NAND flash is the first memory bank, and NOR flash is the second memory bank,
by using CONFIG_SYS_NOR_{BR,OR}_PRELIM and
CONFIG_SYS_NAND_{BR,OR}_PRELIM for defining
CONFIG_SYS_{BR,OR}{0,1}_PRELIM.
After Kconfig migration, replacing some lines in the defconfig will have
the same effect.
Hence, we will not create distinct ve8313_{NOR,NAND} configs for such a
small change.
Instead, fix the current default (NOR first, NAND second), and unroll
the CONFIG_SYS_NAND_{BR,OR}_PRELIM options. This will ease the Kconfig
migration
