CONFIG_ROCKCHIP_USB2_PHY
CONFIG_OMAP_USB_PHY
CONFIG_TWL4030_USB
CONFIG_DAVINCI_SPI
CONFIG_USB_MUSB_HCD
CONFIG_USB_MUSB_UDC
CONFIG_USB_DAVINCI
CONFIG_USB_OMAP3
CONFIG_USB_DA8XX
CONFIG_USB_AM35X
CONFIG_USB_MUSB_OMAP2PLUS
CONFIG_USB_MUSB_AM35X
CONFIG_USB_MUSB_DSPS
CONFIG_USB_MUSB_PIO_ONLY
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Sync with Linux commit 30a7acd573899fd8b("Linux 4.15-rc6")
to use enum pin_config_param.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
%s/falback/fallback/g
Now the u-boot spi image is greater than 0x90000, increase the same in
env during spi erase.
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
The following config symbols are only defined once and never referenced
anywhere else:
CONFIG_CYRUS
CONFIG_IDS8313
CONFIG_MPC8308_P1M
CONFIG_MPC8308RDB
CONFIG_MPC8349EMDS
CONFIG_MPC8349ITXGP
CONFIG_SBC8349
CONFIG_SBC8548
CONFIG_SBC8641D
CONFIG_TQM834X
CONFIG_VE8313
CONFIG_XPEDITE5140
CONFIG_XPEDITE5200
CONFIG_XPEDITE550X
Most of them are config symbols named after the respective boards which
seems to have been a standard practice at some point.
Acked-by: Mario Six <mario.six@gdsys.cc>
anywhere else:
CONFIG_AMCORE
CONFIG_ASTRO5373L
CONFIG_M52277EVB
CONFIG_M5253DEMO
CONFIG_M5253EVBE
CONFIG_M5275EVB
CONFIG_M54418TWR
CONFIG_STMARK2
Seems to be again one of those CONFIG_ symbols named after a board, with
nothing referencing it.
Last users of the following macros (for n = 0..7) were removed in
commit 5b8e76c35ec312a ("powerpc, 8xx: remove support for 8xx"):
CONFIG_SYS_PCMCIA_PBRn
CONFIG_SYS_PCMCIA_PORn
This commit adds UBIFS_NAND to BOOT_TARGET_DEVICES. This will
allow the kernel zImage to be loaded from '/boot/zImage' in UBIFS
(ubi0:rootfs).
Additionally update the *_MMC devices to also load kernel image from
the MMC 0:2 EXT4 file system.
DISTRO_DEFAULTS Setup
[primary] Check MMC 0:1 for /extlinux/extlinux.conf and boot
[fallback 1] Check MMC 0:2 /boot/zImage and run mmcbootz
[fallback 2] Check MMC 0:2 /boot/uImage and run mmcboot
[fallback 3] Check NAND UBIFS /boot/zImage and run nandbootubifs
[fallback 4] Check NAND partitions and run nandboot
The following "extlinux.conf" can be used to load images in the
top-level of the MMC 0:1 FAT partition.
[MMC(0:1)/extlinux/extlinux.conf]
---8<-------------------------------------------------------------------
default omap3-evm
label omap3-evm
kernel /zImage
fdt /omap3-evm.dtb
append console=ttyO0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
There is an #ifdef and #endif with nothing in between. This patch simply
removes this dead/useless code.
This commit updates the configuration files needed to support OF_CONTROL
on the OMAP3 BeagleBoard(s).
Select dtb name for am574x-idk and dra76x evm with acd package.
I'm working on a v2 patch to add support for a board named pdu001. Its
Linux DTS file uses the include file added by this patch. To keep Linux
and U-Boot DTS files in sync U-Boot requires a copy of this file,
although there is no driver for NXP's PCA9532 i2c LED driver chip (yet).
Signed-off-by: Felix Brack <fb@ltec.ch>
Added support for K2G EVM with FlipChip SoC of which
ARM/DDR3 runs at 1GHz/1066 MT/s. The patch is also
backward compatible with old revision EVM and EVM
with WireBond SoC. Their ARM/DDR3 run at 600MHz/800 MT/s.
The new SoC supports 2 different speeds at 1GHz and 600MHz.
Modyfied the CPU Name to show which SoC is used in the EVM.
Modified the DDR3 configuration to reflect New SoC supports
2 different CPU and DDR3 speeds, 1GHz/1066MT and 600MHz/800MT.
Added new inline function board_it_k2g_g1() for the new FlipChip 1GHz,
and set the u-boot env variable board_name accordingly.
Modified findfdt script in u-boot environment variable to include new k2g board type.
Signed-off-by: Rex Chang <rchang@ti.com>
Now that we have multi dtb enabled in u-boot allocate
128K space for u-boot.
Even though in production uImage usually is quite small as
it contains just Linux kernel image during development it might
be pretty convenient to have root-FS built into the same image.
That makes uImage much larger but given on our dev platforms we have
quite a lot of DDR (> 512 MiB) we may afford loading huge uImages.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Update default AXI, TUN, ARC clock set options:
instead of changing only IDIV divider settings adjust also domain PLL
settings.
Add support of TUN_ROM and TUN_PWM clocks (subclocks of TUNN_PLL)
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Sata is equipped on ls1012a and can be a boot source. Add sata boot
support as an option if available.
Signed-off-by: Tang Yuantian <andy.tang@nxp.com>
Sata is equipped on ls1046a and can be a boot source. Add sata boot
The DT spec demands a unit-address in a node name to match the "reg"
property in that node. Newer dtc versions will throw warnings if this is
not the case.
Fix all occurences in the tree where node names were mentioned in
comments, to not give bad examples to the reader.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Signed-off-by: Rob Clark <robdclark@gmail.com>
Similar to CONFIG_OF_BOARD, but in this case the fdt is still built by
u-boot build. This allows the board to patch the fdt, etc.
In the specific case of dragonboard 410c, we pass the u-boot generated
fdt to the previous stage of bootloader (by embedding it in the
u-boot.img that is loaded by lk/aboot), which patches the fdt and passes
it back to u-boot.
[trini: Update board_fdt_blob_setup #if check]
the kernel fails to boot when it goes over the limit.
Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
This commit adds support for 96Boards Dragonboard820C.
The board is based on APQ8086 Qualcomm Soc, complying with the
96Boards specification.
Features
- 4x Kyro CPU (64 bit) up to 2.15GHz
- USB2.0
- USB3.0
- ISP
- Qualcomm Hexagon DSP
- SD 3.0 (UHS-I)
- UFS 2.0
- Qualcomm Adreno 530 GPU
- GPS
- BT 4.2
- Wi-Fi 2.4GHz, 5GHz (802.11ac)
- PCIe 2.0
- MIPI-CSI, MIPI-DSI
- I2S
U-Boot boots chained from LK (LK implements the fastboot protocol) in
64-bit mode.
For detailed build instructions see readme.txt in the board directory.
LS1012A-2G5RDB belongs to LS1012A family with features 2 2.5G SGMII
PFE MAC, SATA, USB 2.0/3.0, WiFi DDR, eMMC, QuadSPI, UART.
Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com>
This adds SH_ETHER to drivers/net/Kconfig and convert to Kconfig.
Add a minimalistic Broadcom BCM53xx (roboswitch) switch driver similar
to the Marvell MV88E617x. This takes care of configuring the minimum
amount out of the switch hardware such that each user visible port
(configurable) and the CPU port can forward packets between each other
while preserving isolation with other ports.
This is useful for e.g: the Lamobo R1 board featuring a Broadcom
BCM53125 switch.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Request that all environment variables containing hard-coded address be
calculated at boot time instead.
Signed-off-by: Tom Warren <twarren@nvidia.com>
On this platform, there may be up to 1024 unusable chunks of memory.
Increase CONFIG_NR_DRAM_BANKS so that U-Boot can remember all the banks
required to represent such fragmented memory.
Enable CONFIG_SYS_INIT_SP_BSS_OFFSET for all 64-bit Tegra boards. Place
the stack/... 512KiB from the end of the U-Boot binary. This should be
plenty to accommodate the current DTBs (max 64 KiB), early malloc region
(6KiB), stack usage, and plenty of slack, while still not placing it too
far away from the U-Boot binary.
No 64-bit Tegra uses SPL. Remove various unused definitions from config
headers.
Some distributions like Fedora expect U-Boot to select a proper
devicetree. Since there are several variants of the cm-fx6 module
featuring different SoC variants and the module can be paired with
several baseboards, it is not viable to hardcode a filename.
Instead, follow the lead of other i.MX6 based devices and try to
determine the devicetree to use with the help of the board name
and the SoC variant exported by the board code, before calling the
distro bootcommand.
For now, only for the Utilite Pro a proper devicetree filename is
known but further variants of the Utilite Computer or other devices
based on the cm-fx6 module may be added in the future.
Signed-off-by: Christopher Spinrath <christopher.spinrath@rwth-aachen.de>
Like many other i.MX6 based boards, there are multiple variants of
the cm-fx6 module featuring different SoC variants. Furthermore, the
module can be paired with multiple baseboards.
At the same time modern distribution like Fedora require U-Boot to
select a proper devicetree which depends on the SoC variant and the
baseboard.
Thus, export the SoC variant and the actual board to the environment
following the conventions of other i.MX6 devices (e.g. the NXP boards)
such that the environment can select a devicetree file to load.
For now, we only know for sure that the cm-fx6 module and the SB-fx6m
baseboard amount to a Utilite Computer variant (depending on the SoC).
Further combinations may be added in the future; e.g. CompuLab's
evaluation board once someone can verify the identification string
stored in its eeprom.
Reviewed-by: Stefano Babic <sbabic@denx.de>
To support QSPI DM driver
- Add spi0 alias for qspi node. Which is used for bus number 0.
- Modify the n25q256a@0 compatible property to "spi-flash".
- Modify spi4 (gpio_spi) node to spi5
- Define DM SPI/QSPI related config to enable QSPI
