Fix setsdupdate by adding missing 'usb start' command.
While at it also add USB start to setethupdate as doing it twice won't
hurt (e.g. it returns immediately only 'usb reset' does a full rescan).
Enable OF system setup to add hardware revision and serial number
information to the device-tree in case a mainline Linux kernel with any
such is booted.
While at it default back to the regular 8 MB DFU data buffer size.
Enable optional raw initrd support to allow boot using an initrd.
Use ft_system_setup to set Toradex specific device-tree properties.
At first, this is only the serial-number, which is using a property
which is about to be standardized in the binding documentation of
the Linux kernel.
This uses the tools/logos/toradex.bmp instead of the default
tux logo and places it centered on screen.
While at it group the display releated variables together.
Swap the order of the Toradex factory configuration block location in
respect to the U-Boot environment. This to again be in-line with
mainline.
Move the Toradex factory configuration block to a 3 MB offset.
Add consoleblank=0 to disable console blanking by default. To use
initramfs without the need of creating a U-Boot image using mkimage,
enable CONFIG_SUPPORT_RAW_INITRD too.
Some functionality is repetitve accross the boards. This creates
a common place for U-Boot functions which need to be implemented
similarly for all Toradex modules.
use
make colibri_imx6_defconfig
Use for the industrial temperature range rated modules:
make apalis_imx6_it_defconfig
Use for the commercial temperature range rated modules:
make apalis_imx6_defconfig
Cleanup various whitespaces throughout its configuration file.
Fix setupdate handling.
While at it also fix using asix_mac rather than igb_mac on Colibri T30.
Migrate Colibri T20 to U-Boot 2015.04.
Add I2C support in order to subsequently allow disabling the PMIC sleep
mode on low supply voltage.
Add LCD display support defaulting to VESA VGA resolution. Different
resolutions configurable via device-tree.
Also, the kernel argument has been renamed (to fec.macaddr) and uses
a different format (0x00,0x2d...). The FEC ethernet address is assigned
through device tree nowadays. Hence remove the old argument "fec_mac"
without replacement.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Add environment variables for default framebuffer support using a
default VGA mode. Also remove memargs, since we use memory size to
reserve the framebuffer which does not get overwritten by the
Linux kernel. See related commit: 1d7518ec3a ("video: dcu: fix
framebuffer to the end of memory")
Fix the framebuffer location to the very end of the available memory.
This allows to remove the area from available memory for the kernel,
which in turn allows to display the splash screen through the while
Linux kernel boot process.
Ideas has been taken from the sunxi display driver, e.g.
20779ec3a5 ("sunxi: video: Dynamically reserve framebuffer memory")
The Vybrid SoC family has the same display controller unit (DCU)
like the LS1021A SoC. This patch adds platform data, pinmux defines
and clock control to enable the driver for Vybrid based boards too.
Implement boot mode for Vybrid SoC. Boot mode selection works much
like the i.MX6 implementation. Provide a standard set of boot modes
for the two eSDHC instances and use the reserved mode to jump into
SoC's recovery mechanism, the serial downloader.
Display model information even if config block is missing.
While at it fix an indentation issue, update copyright period and fix
abbreviated setenv commands.
Migrate Apalis/Colibri T30 to U-Boot 2015.04.
Allow for optional custom USB gadget manufacturer/product/vendor
IDs/strings to be specified.
Migrating our BSPs towards mainline U-Boot I noticed it suddenly booting
slower. With mainline Linux I noticed about a 1 to 2 second increase
while booting downstream L4T takes 10 to 15 seconds longer!
This reverts commit 858530a8c0a7ce7e573e513934804a00d6676813.
drivers/serial/Makefile
(cherry picked from commit 752aae30a791326581efafbb761c0cebaba8d3ea)
drivers/serial/serial_tegra.c
include/configs/tegra-common.h
Add default environment variable allowing update of the on-board flash
using USB mass storage in addition to SD card.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
[merged with SD-card update script]
Add writebcb command which creates a NAND Boot Configuration Block
(BCB) at the beginning of the active flash device. The BCB stores
the information for the SoC internal boot ROM where the application
with a valid IVT header can be found on the NAND device. The first
two argument of the command need an offset of the NAND device where
the primary and secondary application can be found.
Typically, U-Boot is the application which gets loaded by the boot
ROM. Hence, the offset address need to be the address where U-Boot
(u-boot.imx along with a 0x400 long prefix) is stored on the device.
At least one location is mandatory.
Currently only the FCB (Firmware Configuration Block) is written to
the device. The DBBT (Discovered Bad Block Table) is optional and
not created by writebcb currently.
This adds initial support for Colibri VF50/VF61 based on Freescale
Vybrid SoC.
- CPU clocked at 396/500 MHz
- DDR3 at 396MHz
- for VF50, use PLL2 as memory clock (synchronous mode)
- for VF61, use PLL1 as memory clock (asynchronous mode)
- Console on UART0 (Colibri UART_A)
- Ethernet on FEC1
- PLL5 based RMII clocking (E.g. No external crystal)
- UART_A and UART_C I/O muxing
- Boot from NAND by default
- USB host and client support
Tested on Colibri VF50/VF61 booting using serial loader over UART.
Signed-off-by: Stefan Agner <stefan@agner.ch>
This changes enable ONFI detection. The Read ID command now allows
one address byte which is needed for ONFI detection. To read the
ONFI parameter page, the NAND_CMD_PARAM need to be supported. The
CMD code enables one command and one address byte along with reading
data from flash using R/B#, as specified by ONFI.
This commit allows users to enable/disable the Freescale NFC
controller found in systems like Vybrid (VF610), MPC5125, MCF54418
or Kinetis K70 via Kconfig with more detailed help docs.
This consolidates the flash settings for the Integrator
and activates the new ARM flash image support for them
so images can be loaded by name from flash.
This modifies the vexpress64 Juno configuration so that
it will by default load and boot a kernel and a device tree
from the images stored in the NOR flash. When we are
at it, also define the proper command line for the Juno and
indicate that the USB stick (/dev/sda1) is the default
root file system.
Work_92105 from Work Microwave is an LPC3250-
based board with the following features:
- 64MB or 128MB SDR DRAM
- 1 GB SLC NAND, managed through MLC controller.
- Ethernet
- Ethernet + PHY SMSC8710
- I2C:
- EEPROM (24M01-compatible)
- RTC (DS1374-compatible)
- Temperature sensor (DS620)
- DACs (2 x MAX518)
- SPI (through SSP interface)
- Port expander MAX6957
- LCD display (HD44780-compatible), controlled
through the port expander and DACs
This board has SPL support, and uses the LPC32XX boot
image format.
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
This allows to clean up the config a good deal and also converts
pandora to Generic Board.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Remove obsolete email address from MAINTAINERS.
There're 2 versions of motherboards that could be used in ARC SDP.
The only important difference for U-Boot is different NAND IC in use:
[1] v2 board (we used to support up until now) sports MT29F4G08ABADAWP
while
[2] v3 board sports MT29F4G16ABADAWP
They are almost the same except data bus width 8-bit in [1] and 16-bit
in [2]. And for proper support of 16-bit data bus we have to pass
NAND_BUSWIDTH_16 option to NAND driver core - which we do now knowing
board type we're running on.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Add support for Inverse Path USB armory board, an open source
flash-drive sized computer based on Freescale i.MX53 SoC.
http://inversepath.com/usbarmory
Signed-off-by: Andrej Rosano <andrej@inversepath.com>
Cc: Chris Kuethe <chris.kuethe@gmail.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Vagrant Cascadian <vagrant@debian.org>
Tested-By: Vagrant Cascadian <vagrant@debian.org>
Tested-by: Chris Kuethe <chris.kuethe@gmail.com>
Since commit 32df39c741788e ("mx5: fix get_reset_cause") we have the following
boot messages on a mx53qsb:
U-Boot 2015.04-rc5-00029-gd68df02 (Apr 06 2015 - 11:15:39)
CPU: Freescale i.MX53 rev2.1 at 800 MHz
Reset cause: POR
Board: MX53 LOCO
I2C: ready
DRAM: 1 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
In: serial
Out: serial
Err: serial
CPU: Freescale i.MX53 rev2.1 at 1000 MHz
Reset cause: unknown reset
Net: FEC [PRIME]
The CPU and Reset cause lines appear twice.
Initially mx53 boots at 800MHz, then at a later point the PMIC is configured via
I2C to raise the CPU voltage so that it can run at 1GHz.
To avoid such misleading double printings, disable printing cpu info for now.
Acked-by: Jason Liu <r64343@freescale.com>
After this change it is possible to boot trats2 device with Image.itb,
which facilitates automated testing, since only one file is necessary.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
