The environment variable fdtfile is used in include/config_distro_bootcmd.h
hence we should make sure it is set by default.
Rather than using NXP proprietary boot script transition to using
proper distroboot one.
FDT relocation disabled seems to cause issues when using TorizonCore,
probably related to ramdisk.
Distro boot scripts require scriptaddr. Make sure it is defined to
a sensible address for both Apalis iMX8 as well as Colibri iMX8X.
Change default device tree to the regular one now that parallel RGB is
working.
The current loading address for the ramdisk images overlaps with
reserved memory for the decoder_boot section of the device tree (see
fsl-imx8qxp.dtsi). This generates a kernel panic early in the boot
process when trying to access that memory region.
Signed-off-by: Ming Liu <liu.ming50@gmail.com>
Do not undef CMD config defines which are set by Kconfig. This
allows to enable those commands using Kconfig.
Fix ramdisk relocation address to work accross all our use cases.
a sensible address.
When booting U-Boot in recovery mode the default boot command for
automatic boots is substituted by bootcmd_mfg. For tezi we want this
command to source the boot script inside the boot container that the uuu
utility loads. The precise load address of this script is the one used
in the mkimage_imx8 utility to generate the boot container.
NOTE: this change affects both tezi U-Boot as well as BSP U-Boot. Since
currently only tezi is supporting recovery mode, this shouldn't be a
problem. Otherwise, consider adding preprocessor safeguards.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Tezi uses Distro Boot by default. Enable it and modify the appropriate
environment.
By default bootm can load kernels of up to 5MB. Our universal kernels in
imx8 are much larger than this, even when compressed. Since recovery
tezi needs to load from memory, allow for larger sizes to be loaded by
bootm.
fsl-imx8qm.dtsi). This generates a kernel panic early in the boot
Fused modules boot from eMMC rather than SD card.
Clean-up board file.
Clean-up configuration moving some stuff from include header file to
Kconfig defconfig.
Adjust copyright/licensing headers e.g. universally using SPDX license
identifier.
Fix Ethernet functionality. The FEC clock on i.MX 8X really has an
additional by 2 divider plus our design requires the ENET0_RCLK50M_OUT
on the ENET0_RGMII_TXC pin to be turned on for the Micrel PHY.
As long as the parallel RGB interface bring-up is not completed default
to dsihdmi device tree instead.
Kconfig defconfig.
identifier.
(cherry picked from commit eb0ed0e4283385700db1e5080d78f9a2684f98a5)
(cherry picked from commit 3a5cc1cf85b8e22da78d794a2d71c03490f500b6)
(cherry picked from commit 6557f1c6c8f5c5e6a5585459ab77e3d994ffff81)
(cherry picked from commit 6efbcb8cd6740e60fc53f9033d60cc27f62b3c74)
(cherry picked from commit 969f430f983d602afd83b6dd75b299e51463eae9)
(cherry picked from commit 2963361493e0f3df76f3a25202a56a76e69fd63f)
Initial board support for Colibri iMX8QXP using a copy of Apalis iMX8.
(cherry picked from commit 62f0f03e1acb4bb6b0fcca8d4e9bd4d2df04ad33)
(cherry picked from commit be14c3ea1850e2614883c86b62fd1c3a1828eac2)
U-Boot in the current 4.9.123 form freezes when initalizing HSIO.
(cherry picked from commit 68a2be9b6247eaf5ac577082d8d5c0c930d37132)
(cherry picked from commit e819b0c2d5790ce7b0c2bfc0501eb6e79e98db16)
Current samples are strapped to boot from SD card by default. Also
make sure that the default U-Boot environment boots from SD card.
(cherry picked from commit 67cf06ee02ba39a93fbfd4ed2e82509ec86ba53e)
(cherry picked from commit 82ffe3f0c08c9c4f8e988e1402dc814b71e3be92)
(cherry picked from commit 1d7c4df41d20cb2447a6512de42475f8d754c905)
(cherry picked from commit bfaf217291cbe34381ce5d5e9a63a700d211c48d)
Add Toradex config block support for i.MX8QM.
(cherry picked from commit 18426b50681e6cd64ab5977f0ba84efd3f7c4495)
(cherry picked from commit c6d0e1042170d273a5b5434abe867213155d5582)
(cherry picked from commit ae31e946da33510a352795de09aa1c0ea9fc8280)
(cherry picked from commit 0798437c661ef3ca11f84fb45b4cce5b7ac145d9)
Add default memory layout and networking options typically used
on Toradex modules.
(cherry picked from commit 261060112cc55c25e672f6b73374d2a80e00a2e4)
(cherry picked from commit 26db8b3fd1ad8bac8921f0ac11cb29364dc1bbaf)
(cherry picked from commit 3bf49ccc73b2685eb965bcd61907bcffab3f3fd3)
(cherry picked from commit f6cbf3f9c591646cd1f89b86d7dd5c7902269df8)
Use USDHC1 which is eMMC to store U-Boot environment and as default
root device for Linux.
(cherry picked from commit 65b8faac518e90ba1b53013e4639e2cd41e6bf2f)
(cherry picked from commit 5b235d487dea79976597368d2edac64c1b468e4c)
(cherry picked from commit f7bc9e4e18a15e44bc0a06afe0abaddb03f4e9c0)
(cherry picked from commit a90ba0b545e88c0182ee0c9033020d952fd54aff)
Extend bootcmd to also load the HDMI firmware through hdp
command.
(cherry picked from commit 41ef3986ae21dc6fcc4355ab53ccc809d80d361e)
(cherry picked from commit 94d78f51638f4ab3519b845c4fbffe92865cc5b3)
(cherry picked from commit cad9542ed852cee3d3dd0b6c25a36a0de6f22c29)
(cherry picked from commit 331fc0f28dc6b3a4938c66a5788041e527eabc8b)
(cherry picked from commit 04e7012224b6971972cb76415980c835a2ba9654)
(cherry picked from commit 0759efaef277ff5e0583a4808593a36d7de0353d)
(cherry picked from commit 6ceb16bf22088785c53d751328347f0b6579fafe)
(cherry picked from commit c5844221c59cda20f645ae83352944ffa570c3f1)
NXP LPUART1 is used as Apalis UART1, which is the main console
on our Linux BSP.
(cherry picked from commit 360629c1fd6187de19d0f50feb85c725995e49cc)
(cherry picked from commit 63030dac6afc51d17b04d23ce41af4788f03717e)
(cherry picked from commit 7bbe1708e0cebf3432c234ea74f8d6fb632a023b)
(cherry picked from commit d58fa8f3247edc18bdbf716fa9a45bcf5fce9cb8)
Make sure that all pins connected to the Micrel KSZ9031 PHY
are muxed. Properly reset the PHY after all muxing has been
applied. This makes sure that strapping is not overwritten by
the SoC default mux (particularly it makes sure that CLK125_NDO
is not driven low during reset).
Make sure to not use CONFIG_DM_ETH as it seems to break ETH
support as is.
(cherry picked from commit f0a1ceb6f5e2ab3b3618190541b1e7a9fd4c1e4a)
(cherry picked from commit 8f6405070189a8744c2f6a9d9a6e041554fb9046)
(cherry picked from commit 6f24c637fd7725a27249d6a950f587134f30b97c)
(cherry picked from commit 1b3c97e1eb50a56066820596a6b1b83da465af7f)
The Apalis iMX8 module does not have PCA9557 GPIO controllers
on the module.
(cherry picked from commit c80b3bfbe693d5a8851129f4878d0cd3a7325d13)
(cherry picked from commit 898ae105703cd0019a542bc0a17649339c934fa6)
(cherry picked from commit 69d385444efa79d2909f772c4a4b404d1bd7274d)
(cherry picked from commit 0f5887d5b80f8535a7f422b73d7a0bf4a4e445af)
Initial board support for Apalis iMX8 using a copy of NXP
iMX8QM ARM2 LPDDR4 board.
(cherry picked from commit 68e401998ba0654292b7914b85433d8453202ec8)
(cherry picked from commit 6b9234fa1f5889f0eeecc6147afffbc859933c99)
(cherry picked from commit 0b7feded806717b4292615373ed6c018324b8ef5)
arch/arm/cpu/armv8/imx8/Kconfig, file moved
(cherry picked from commit 393dd8dd4061833fcc3cfd85886d49160b515ce0)
Sometimes we need to set random rpmb key which is invisible
except for the device.
Generate the random key with hwcrypto interface and support
fastboot command "fastboot oem set-rpmb-random-key" to set it.
Test: build and boot on imx8q.
Change-Id: I44e1b6b091366d8ffceb1159fc65c17610ce5243
Signed-off-by: Ji Luo <ji.luo@nxp.com>
Add new hwcrypto command to support rng generation with CAAM.
Test: rng generated on imx8qxp_mek.
Change-Id: I756f3e99423f0f9dfc2bcd30117a3f96e9f5f2f7
Open configs to enable trusty for imx8mm_evk and also
add new config imx8mm_evk_android_trusty_defconfig based
on imx8mm_evk_android_defconfig.
Test: Trusty starts ok.
Change-Id: Iaea90de21f886ed23082a5e8e8d2fa7fb139a9cb
It's "Copyright" instead of "opyright".
Change-Id: I4e66ea402e06ee03b5268d1d70c95e066ad35fd0
