New QorIQ p1020 based board support from Arcturus Networks Inc.
http://www.arcturusnetworks.com/products/ucp1020/
Signed-off-by: Michael Durrant <mdurrant@arcturusnetworks.com>
Signed-off-by: Oleksandr G Zhadan <oleks@arcturusnetworks.com>
[York Sun: remove patman tags from commit message]
Reviewed-by: York Sun <yorksun@freescale.com>
Enable eSDHC peripheral clock support. u-boot and linux will
use SD clock generated by peripheral clock instead of platform
clock.
Signed-off-by: Yangbo Lu <yangbo.lu@freescale.com>
Cc: York Sun <yorksun@freescale.com>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
The SD clock could be generated by platform clock or peripheral
clock for some platforms. This patch adds peripheral clock
support for T1024/T1040/T2080. To enable it, define
CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK.
Enable eSDHC adapter card type identification and this will do
some corresponding operations and set 'adapter-type' property
for device tree according SDHC Card ID.
Add adapter card type identification support by reading
FPGA STAT_PRES1 register SDHC Card ID[0:2] bits. To use this function,
define CONFIG_FSL_ESDHC_ADAPTER_IDENT.
[York Sun: resolve conflicts in README.fsl-esdhc]
T1023RDB is a Freescale Reference Design Board that hosts the T1023 SoC.
T1023RDB board Overview
- T1023 SoC integrating two 64-bit e5500 cores up to 1.4GHz
- CoreNet fabric supporting coherent and noncoherent transactions with
prioritization and bandwidth allocation
- Memory: 2GB Micron MT40A512M8HX unbuffered 32-bit fixed DDR4 without ECC
- Accelerator: DPAA components consist of FMan, BMan, QMan, DCE and SEC
- Ethernet interfaces:
- one 1G RGMII port on-board(RTL8211F PHY)
- one 1G SGMII port on-board(RTL8211F PHY)
- one 2.5G SGMII port on-board(AQR105 PHY)
- PCIe: Two Mini-PCIe connectors on-board.
- SerDes: 4 lanes up to 10.3125GHz
- NOR: 128MB S29GL01GS110TFIV10 Spansion NOR Flash
- NAND: 512MB S34MS04G200BFI000 Spansion NAND Flash
- eSPI: 64MB S25FL512SAGMFI010 Spansion SPI flash.
- USB: one Type-A USB 2.0 port with internal PHY
- eSDHC: support SD/MMC card and eMMC on-board
- 256Kbit M24256 I2C EEPROM
- RTC: Real-time clock DS1339 on I2C bus
- UART: one serial port on-board with RJ45 connector
- Debugging: JTAG/COP for T1023 debugging
As well updated T1024RDB to add T1023RDB.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
[York Sun: fix defconfig files]
T2080QDS PEX1/Slot#1 will down-train from x4 to x2,
with SRDS_PRTCL_S1 = 0x66 and SRDS_PRTCL_S2 = 0x15.
Soft reset PCIe can fix this issue.
Signed-off-by: Zhao Qiang <B45475@freescale.com>
This patch adds SD boot support for T4240RDB board. SPL
framework is used. PBL initializes the internal RAM and
copies SPL to it. Then SPL initializes DDR using SPD and
copies u-boot from SD card to DDR, finally SPL transfers
control to u-boot.
Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com>
[York Sun: Fix T4240RDB_SDCARD_defcofig]
Add a delay of 1 microsecond before issuing soft reset to the
controller to let ongoing ULPI transaction complete.
This prevents corruption of ULPI Function Control Register which
eventually prevents phy clock from entering to low power mode
Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com>
T4240 SoC has been available for a long time. Emulator support
is no longer needed.
Signed-off-by: York Sun <yorksun@freescale.com>
Move arch/arm/cpu/armv7/zynq/* -> arch/arm/mach-zynq/*
Enable SDHCI0 for zynqmp.
Add empty gpio.h because of sdhci requirement.
Provide an option to write filesystem independend commands.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Added the SPI driver support for ZynqMP
The controller is same as zynq SPI controller
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Enable the i2c driver for ZynqMP
Also enable the eeprom for read and writes
to eeprom on ZynqMP
ZynqMP uses the same i2c controller as in Zynq
Add support for loading sw for R5 with enabling for zynqmp.
Define the mmu table till 2MB granularity
enable dcaches for zynqmp.
The PicoZed is a System-on-Module board which is marketed as part of
the ZedBoard/MicroZed/etc. collection. It includes a Zynq-7000
processor.
This patch adds support that covers all the variants of the PicoZed
including the SKUs with Z7010/Z7020 and Z7015/Z7030 Zynq chips. This
patch set however only covers support for the System-on-Module and does
not cover any extra components that are available on carrier boards
(except those that are fanned out of the module itself).
More information on this board, its variants and available carrier
boards is available at: http://zedboard.org/product/picozed
Signed-off-by: Nathan Rossi <nathan.rossi@xilinx.com>
Enable GPIO driver and GPIO commands.
Add a new member 'flags' in struct spi_flash to store the flash flags
during spi_flash_validate_params().
Instead of hardcoding the 'fdtfile' variable, let's detect the SoC and
board variant on the fly and change the dtb name.
Based on the scheme done on am335x board.
Tested-By: Vagrant Cascadian <vagrant@debian.org>
README file suggests to use 'fdtfile' for the dtb file name and
'fdt_addr_r' for the dtb address in RAM, so do as suggested.
This patch adds esdhc support for ls2085a.
Enable NAND boot support using SPL framework. To boot from
NAND, either use DIP switches on board, or "qixis_reset nand"
command. Details of forming NAND image can be found in README.
[York Sun: Remove +S from defconfig after commit 252ed872]
This adds NAND boot support for LS2085AQDS, using SPL framework.
IFC has two register pages.Till IFC version 1.4 each
register page is 4KB each.But IFC ver 2.0 register page
size is 64KB each.IFC regiters structure is break into
two viz FCM and RUNTIME.FCM(Flash control machine) registers
are defined in PAGE0 and controls IFC generic functionality.
RUNTIME registers are defined in PAGE1 and controls NAND and
GPCM funcinality.
FCM and RUNTIME structures defination is common for IFC
version 1.4 and 2.0.
Signed-off-by: Jaiprakash Singh <b44839@freescale.com>
Add support of ethernet:
- eth.c: mapping lane to slot for (0x2A, 0x07)
- ls2085a.c: To enable/disable dpmac and get link type
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
Enable USB support on Toradex Colibri Vybrid Modules.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
This adds initial support for Colibri VF50/VF61 based on Freescale
Vybrid SoC.
- CPU clocked at 396/500 MHz
- DDR3 at 396MHz
- for VF50, use PLL2 as memory clock (synchronous mode)
- for VF61, use PLL1 as memory clock (asynchronous mode)
- Console on UART0 (Colibri UART_A)
- Ethernet on FEC1
- PLL5 based RMII clocking (E.g. No external crystal)
- UART_A and UART_C I/O muxing
- Boot from NAND by default
Tested on Colibri VF50/VF61 booting using serial loader over UART.
Acked-by: Stefan Agner <stefan@agner.ch>
Add architecture-specific u-boot.lds and remove all board-specific
u-boot.lds.
All the .text customization that was board-specific have been
moved inside the related include/configs, inside a
LDS_BOARD_TEXT define.
Signed-off-by: Angelo Dureghello <angelo@sysam.it>
Implemented fb_set_reboot_flag() for OMAP5 to set
an environment variable 'dofastboot' when reboot-bootloader called.
This environment variable will be checked in boot command and fastboot
will be called if the variable is set.
If the bootcmd env variable of OMAP5 common is overwritten with board-specific
command, then these changes will not apply.
This was originally intended for DRA7 platform, but now applies to all OMAP5.
Ref:
http://git.omapzoom.org/?p=repo/u-boot.git;a=commit;h=19da2e436e9806259cf1f4988b9e046ab256bf2c
Signed-off-by: Angela Stegmaier <angelabaker@ti.com>
Signed-off-by: Dileep Katta <dileep.katta@linaro.org>
[trini: Make it check for !CONFIG_ENV_IS_NOWHERE as we can't saveenv()
in that case]
- Fastboot is enable by default for DRA7XX
- This is based on following patch modified accordingly
http://git.omapzoom.org/?p=repo/u-boot.git;a=commit;h=b2e04f92b5d91c708b6fd6b79d2266966ac51f4b
1. The bits 11..10 for mfp driver strength is only valid for
aspen and old xscale family, for newer Marvell chip, this range
has been moved to 12..11.
2. add sleep bit support
Signed-off-by: Xiang Wang <wangx@marvell.com>
[robh: rebase to current mainline]
Signed-off-by: Rob Herring <robh@kernel.org>
Signed-off-by: Peter Howard <phoward@gme.net.au>
[trini: Add config file, update for ..._ether_addr() -> ..._ethaddr() rename]
The LS2085ARDB is a evaluation platform that supports LS2085A
family SoCs. This patch add sbasic support for the platform.
Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
The LS2085AQDS is an evaluatoin platform that supports the LS2085A
family SoCs. This patch add basic support of the platform.
Wire rate IO Processor (WRIOP) provide support of receive and transmit
ethernet frames from the ethernet MAC. Here Each WRIOP block supports
upto 64 DPMACs.
Create a house keeping data structure to support upto 16 DPMACs and
store external phy related information.
The memac for PHY management on little endian SoCs is similar on big
endian SoCs, so we modify the driver by using I/O accessor function to
handle the endianness, so the driver can be reused on little endian
SoCs, we introduce CONFIG_SYS_MEMAC_LITTLE_ENDIAN for little endian
SoCs, if the CONFIG_SYS_MEMAC_LITTLE_ENDIAN is defined, the I/O access
is little endian, if not, the I/O access is big endian. Move fsl_memac.h
out of powerpc include.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Changed MC firmware loading to comply with the new MC boot architecture.
Flush D-cache hierarchy after loading MC images. Add environment
variables "mcboottimeout" for MC boot timeout in milliseconds,
"mcmemsize" for MC DRAM block size. Check MC boot status before calling
flib functions.
Signed-off-by: J. German Rivera <German.Rivera@freescale.com>
Add support of SerDes framework for Layerscape Architecture.
- Add support of 2 SerDes block
- Add SerDes protocol parsing and detection
- Create table of SerDes protocol supported by LS2085A
Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com>
The timer clock is system clock divided by 4, not fixed 12MHz.
This is common to the SoC, not board specific. Primary core is
fixed when u-boot still runs in board_f. Secondary cores are
fixed by reading a variable set by u-boot.
CC: Mark Rutland <mark.rutland@arm.com>
ls2085a_common.h contains hard-coded information for NOR/NAND flash,
I2C, DDR, etc. These are platform specific. Move them out of common
header file and placed into respective board header files.
Move TEXTBASE to 1MB offset to fit NOR flash with up to 1MB sector
size.
Enable command auto complete. Update prompt symbol. Set fdt_high to
0xa0000000 because Linux requires that the fdt be 8-byte aligned
and below 512 MiB. Besides ensuring compliance with the 512 MiB
limit, this avoids problems with the dtb being misaligned within
the FIT image.
Change the MC FW, MC DPL and Debug server NOR addresses in compliance
with the NOR flash layouts for 128MB flash.
Add PCIe macros. Enable "loadb" command. Disable debug server.
Enable workaround for erratum A008511.
Stop reset on panic for postmortem debugging.
This erratum only applies to general purpose DDR controllers in LS2.
It shouldn't be applied to DP-DDR controller. Check DDRC versoin number
before applying workaround.
Add/update registers for DDR4, including DQ mappings. Allow raw timing
method used for all controllers. Update mode_9 register to 0x500 for
improved stability. Check DDR controller version number individually
in case a SoC has multiple DDR controllers of different versions.
Increase read-write turnaround for DDR4 high speeds.
