The keystone2 evm can boot from USB partition with FAT32 FS, so
enable generic load command and fatload command usage.
Acked-by: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
Reviewed-by: Tom Rini <trini@ti.com>
The Multicore Software Development Kit (MCSDK) provides foundational
software for TI KeyStone II device platforms. It's supposed to be used
with uboot, and it's convenient to have the same names for images, so
correct environment image names according to the last MCSDK3.
Currently to customize env for various ks2 boards, individual
variables such as NAME_FS etc are defined and included in the
common config.h to define CONFIG_EXTRA_ENV_SETTINGS. This
doesn't scale well if a variable is not applicable on a
specific board. Using this scheme, we have to define variables
with empty value and it's ugly. Instead, to allow board specific
customization of default env variable, define a common
CONFIG_EXTRA_ENV_KS2_SETTINGS for all common variables and define
board specific variables in individual board specific config.h
using CONFIG_EXTRA_ENV_KS2_BOARD_SETTINGS. Use the common and board
specific variables to define CONFIG_EXTRA_ENV_SETTINGS. This way
more variables can be added in future for individual boards
without affecting the other config.h files.
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
To allow out of box demo, change default boot mode to ubi
boot now that NAND is functional in latest EVMs.
The UBI volume name has to be prefixed with "ubi:".
since it is now in ti_armv7_common.h
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
Cc: Tom Rini <trini@ti.com>
This patch adds network support code and enables keystone_net
driver usage for k2l_evm evaluation board.
Signed-off-by: Hao Zhang <hzhang@ti.com>
Keystone2 Lamar SoC uses the same keystone SerDes driver.
All Keystone2 EVM boards currently use SerDes driver, so move
CONFIG_TI_KEYSTONE_SERDES to common configuration file.
Signed-off-by: Dileep Katta <dileep.katta@linaro.org>
[trini: Rework so that am335x_evm_usbspl still builds]
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
Add a driver for the designware serial UART used on sunxi. This just
redirects to the normal ns16550 driver.
Add a stdout-path to the device tree so that the correct UART is chosen.
This adds driver model support to the sunxi GPIO driver, using the device
tree to trigger binding of the driver. The driver will still operate
without driver model too.
For now we won't want to mess with the existing configurations. Create a
new one which will enable device tree and driver model. Note that this
brings the device tree binary into u-boot-sunxi-with-spl.bin.
These are from Linux 3.17-rc7 (commit fe82dcec). U-Boot only uses a small
portion of these, but we may as well have something to look forward to.
The total compiled size is about 25KB.
Acked-by: Hans de Goede <hdegoede@redhat.com>
Mostly automatic with:
sed -i -e 's/CONFIG_\(SUN[45678]I\)/CONFIG_MACH_\1/g' $(git grep -l CONFIG_SUN[45678]I)
followed by removing the relevant #defines from include/configs/sun?i.h by
hand.
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
While at it, sort them.
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
Add new Kconfig option to let the user select the targets
endianess. Each target have to select SUPPORTS_BIG_ENDIAN
and/or SUPPORTS_LITTLE_ENDIAN to indicate which endianess
is supported.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
[1] arch/arm/include/asm/arch-at91/at91_shdwn.h
The top9000 was the last board to use this header file.
It was removed by commit d58a9451e733 (ppc/arm: zap EMK boards).
[2] board/matrix_vision/common/*
Some Matrix Vision boards were dropped by commit e7a565638a7a
(powerpc: mpc83xx: remove board support for MERGERBOX and MVBLM7)
and commit af55e35d3389
(powerpc: mpc5xxx: remove board support for MVBC_P and MVSMR).
Since then these files have been unused.
[3] include/usb/omap1510_udc.h
The omap5912osk was the last board to use this header file.
It was removed by commit 62d636aa2ac2
(omap: remove omap5912osk board support).
Acked-By: Wolfgang Denk <wd@denx.de>
This enables the VMMC2 LDO, which powers the MMC2 device.
When the device starts from MMC2, this has already been enabled by the BootROM,
but when starting from peripheral boot (USB, UART), it is not the case.
Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
The code density of x86_64 is not wonderful. Increase the maximum boot
size and adjust the load address to cope.
This converts all TQM8xx boards (MPC8xx based) to generic board.
In preparation for the SoCFPGA support of the designware I2C driver,
convert this driver to the common CONFIG_SYS_I2C framework.
This patch converts all users of this driver, this is:
- ST spearxxx boards
- AXS101 (ARC700 platform)
I couldn't test this patch on those boards. Only compile tested for all
spear boards. And tested on SoCFPGA.
Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
Tested-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Vipin Kumar <vk.vipin@gmail.com>
Cc: Jeroen Hofstee <jeroen@myspectrum.nl>
This patch just converts the function prototypes used throughout
this driver to match those of the i2c framework. There is so far
no functional change. This patch does not do the deeper integration
of the framework bits.
This is a bit odd in that we are permitted to boot images for either, even
though they are separate architectures.
Display the type of CPU (x86 or x86_64) when starting up.
The following bard configurations have been without active maintenance
for a long time, and the board maintainer agrees to have them removed:
MPC5200: TOP5200, MINI5200, EVAL5200
MPC860: TOP860
at91sam9xeXXX: top9000eval_xe, top9000su_xe
Cc: Reinhard Meyer <reinhard.meyer@emk-elektronik.de>
[trini: Add missing Kconfig removals]
This patch adds support for i211 as well as unprogrammed aka tools only
i210/i211 chip support.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
This config is required by Odroid, and could be also useful for the other
boards.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Some boards still use xstr(). Replace remaining occurrences
of xstr() by commonly used __stringify().
- switch to GENERIC_BOARD
- fix env support from eeprom
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Enable EXT support in SPL for OMAP4 boards.
Build tested for duovero, omap4_sdp4430 and omap4_panda.
Run time tested on omap4_panda.
Add EXT filesystem support to SPL.
[trini: Fix a warning and checkpatch problems]
Rename some defines containing FAT in their name to be filesystem generic:
MMCSD_MODE_FAT => MMCSD_MODE_FS
CONFIG_SPL_FAT_LOAD_ARGS_NAME => CONFIG_SPL_FS_LOAD_ARGS_NAME
CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME => CONFIG_SPL_FS_LOAD_PAYLOAD_NAME
CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION => CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION
Use inttypes.h and uint64_t to correct the code so that it will not issue
warnings on 64-bit machines where 'uint64_t' is 'unsigned long'.
Unfortunately 'unsigned long long' and 'uint64_t' are not necessarily
compatible on 64-bit machines. Use the correct typedef instead of
writing the supposed type out in full.
inttypes.h defines format specifiers for printf which work with data types of
particular sizes. stdlib.h is currently just a passthrough to malloc.h which
has declarations of the various *alloc functions.
Add the required #define to common.h so that these printf format specifiers
will be made available.
Signed-off-by: Gabe Black <gabeblack@google.com>
Reviewed-by: Gabe Black <gabeblack@chromium.org>
Tested-by: Gabe Black <gabeblack@chromium.org>
Reviewed-by: Bill Richardson <wfrichar@google.com>
(Replaced with a GPL version from glibc)
There's a definition in stdint.h (provided by gcc) which will be more correct
if available.
Define CONFIG_USE_STDINT to use this feature, or USE_STDINT=1 on the 'make'
commmand.
This adjusts the settings for x86 and sandbox, with both have 64-bit options.
Rewritten to be an option, since stdint.h is often available only in glibc.
Changed to preserve a clear boundary between stdint and non-stdint
The run command treats each argument an an environment variable. It gets the
value of each variable and executes it as a command. If an environment
variable contains a newline and the hush cli is used, it is supposed to
execute each line one after the other.
Normally a newline signals to hush to exit - this is used in normal command
line entry - after a command is entered we want to return to allow the user
to enter the next one. But environment variables obviously need to execute
to completion.
Add a special case for the execution of environment variables which
continues when a newline is seen, and add a few tests to check this
behaviour.
Note: it's not impossible that this may cause regressions in other areas.
I can't think of a case but with any change of behaviour with limited test
coverage there is always a risk. From what I can tell this behaviour has
been around since at least U-Boot 2011.03, although this pre-dates sandbox
and I have not tested it on real hardware.
Reported-by: Wolfgang Denk <wd@denx.de>
This board is old and is using CONFIG_I2C_X, which is wrong.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
