- Update style of 86xx CPU information on boot to more closely
match 85xx boards
- Fix detection of 8641/8641D
- Use strmhz() to display frequencies
- Display L1 information
- Display L2 cache size
- Fixed CPU/SVR version output
== Before ==
Freescale PowerPC
CPU:
Core: E600 Core 0, Version: 0.2, (0x80040202)
System: Unknown, Version: 2.1, (0x80900121)
Clocks: CPU:1066 MHz, MPX: 533 MHz, DDR: 266 MHz, LBC: 133 MHz
L2: Enabled
Board: X-ES XPedite5170 3U VPX SBC
== After ==
CPU: 8641D, Version: 2.1, (0x80900121)
Core: E600 Core 0, Version: 2.2, (0x80040202)
Clock Configuration:
CPU:1066.667 MHz, MPX:533.333 MHz
DDR:266.667 MHz (533.333 MT/s data rate), LBC:133.333 MHz
L1: D-cache 32 KB enabled
I-cache 32 KB enabled
L2: 512 KB enabled
Update the 86xx reset sequence to try executing a board-specific reset
function. If the board-specific reset is not implemented or does not
succeed, then assert #HRESET_REQ. Using #HRESET_REQ is a more standard
reset procedure than the previous method and allows all board
peripherals to be reset if needed.
Added various p2020 processor specific details:
* SVR for p2020, p2020E
* immap updates for LAWs and DDR on p2020
* LAW defines related to p2020
Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
Signed-off-by: Travis Wheatley <Travis.Wheatley@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
When we introduced the 36-bit config of the MPC8572DS board we had the
wrong PCI MEM bus address map. Additionally, the change to the address
map exposes a small issue in our dummy read on the ULI bus. We need
to use the new mapping functions to handle that read properly in the
36-bit config.
Previously we only allowed power-of-two memory sizes and didnt
handle >2G of memory. Now we will map up to CONFIG_MAX_MEM_MAPPED
and should properly handle any size that we can make in the TLBs
we have available to us
The Blackfin i2c driver has been rewritten thus the special ifdefs in the
common code are no longer needed.
With actual u-boot compiling the mgcoge port fails, because
since commit ba705b5b1a97b47388ed48858bef6bf7b6bfcd56 it is
necessary to define CONFIG_NET_MULTI.
Seems to me the mgcoge port is the only actual existing 8260
port who uses CONFIG_ETHER_ON_SCC, so no other 8260 port needed
to be fixed.
The criteria of the AMCC SDRAM Controller DDR autocalibration
U-Boot code is to pick the largest passing write/read/compare
window that also has the smallest SDRAM_RDCC.[RDSS] Read Sample
Cycle Select value.
On some Kilauea boards the DDR autocalibration algorithm can
find a large passing write/read/compare window with a small
SDRAM_RDCC.[RDSS] aggressive value of Read Sample Cycle Select
value "T1 Sample".
This SDRAM_RDCC.[RDSS] Read Sample Cycle Select value of
"T1 Sample" proves to be to aggressive when later on U-Boot
relocates into DDR memory and executes.
The memory traces on the Kilauea board are short so on some
Kilauea boards the SDRAM_RDCC.[RDSS] Read Sample Cycle Select
value of "T1 Sample" shows up as a potentially valid value for
the DDR autocalibratiion algorithm.
The fix is to define a weak default function which provides
the minimum SDRAM_RDCC.[RDSS] Read Sample Cycle Select value
to accept for DDR autocalibration. The default will be the
"T2 Sample" value. A board developer who has a well defined
board and chooses to be more aggressive can always provide
their own board specific string function with the more
aggressive "T1 Sample" value or stick with the default
minimum SDRAM_RDCC.[RDSS] value of "T2".
Also put in a autocalibration loop fix for case where current
write/read/compare passing window size is the same as a prior
window size, then in this case choose the write/read/compare
result that has the associated smallest RDCC T-Sample value.
Signed-off-by: Adam Graham <agraham@amcc.com>
CONFIG_SDRAM_PPC4xx_IBM_DDR2 is not set when include/asm-ppc/config.h is
included. So for katmai, CONFIG_MAX_MEM_MAPPED will get set to 256MB.
It makes perfect sense to set CONFIG_MAX_MEM_MAPPED to 2GB for all PPC4xx
boards right now.
At some point an intentional double space at the end of the sentence
got changed into a tab in the GPL header line:
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
This patch fixes the damage.
Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
If on your board is more than one flash, you must know
the size of every single flash, for example, for updating
the DTS before booting Linux. So make this function
flash_get_info() extern, and you can have all info
about your flashes.
Added new CONFIG options for the three type of MAC-PHY interconnect and
applied them all relevant board config files
Moved CONFIG_MAX_MEM_MAPPED to the asm/config.h so its kept consistent
between the two current users (lib_ppc/board.c, 44x SPD DDR2).
We have common defines that we duplicate in various ways. Having an
arch specific config.h gives us a common location for those defines.
Eventually we should be able to replace this when we have proper
Kconfig support.
Now that the rest of u-boot can support it, change the PCI bus
address of the PCI MEM regions from 0x80000000 to 0xc0000000,
and use the same bus address for both PCI1 and PCI2. This will
maximize the amount of PCI address space left over to map RAM
on systems with large amounts of memory.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Clean up PCI mapping concepts in the 8641 config - rename _BASE
to _BUS, as it's actually a PCI bus address, separate virtual
and physical addresses into _VIRT and _PHYS, and use each
appopriately.
If CONFIG_ADDR_MAP is enabled, update the address map
whenever we write a bat.
The BAT fields are architected; there's no need for these to be in
cpu-specific files. Drop the duplication and move these to
include/asm-ppc/mmu.h. Also, remove the BL_xxx defines that were only
used by the alaska board, and switch to using the BATU_BL_xxx defines
used by all the other boards. The BL_ defines previously in use
had to be shifted into the proper position for use, which was inefficient.
It is no longer always true that the pci bus address can be
used as the virtual address for pci accesses. pci_map_bar()
is created to return the virtual address for a pci region.
If the VA and PA of the flash aren't the same, the banks list
should be initialized to hold the physical address. Correct this.
This patch adds support for Dave/DENX QongEVB-LITE i.MX31-based board.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Driver for Dave DNET ethernet controller (used on Dave/DENX
QongEVB-LITE board).
Acked-by: Ben Warren <biggerbadderben@gmail.com>
The PCI_REGION_MEMORY and PCI_REGION_MEM are a bit to similar and
can be confusing when reading the code.
Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY to clarify its used
for system memory mapping purposes.
Added definitions for i.MX31 processor GPIO registers.
Enable NAND_UNLOCK option for unlocking nand for
erase/write operations
Signed-off-by: Nishanth Menon <nm@ti.com>
Add missing GPIO registers address definition for Coldfire M5271.
Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
Cleanup for M5271EVB:
Added clarification on the use of CONFIG_SYS_CLOCK.
Modified to use u-boot's HUSH parser.
Cleanup on environment settings.
Removed compiler warning by defining CONFIG_SYS_CS0_*
Dependencies:
Added the use of CONFIG_SYS_MCF_SYNCR for clock multiplier.
This depends on a patch to include/asm-m68k/m5271.h
that defines the multiplier and divider ratios.
Removed the definition of CONFIG_SYS_FECI2C.
This depends on a patch that removes the use of it in
cpu/mcf52x2/cpu_init.c
M5271 dynamic clock multiplier. It is currently fixed at 100MHz.
Allow the board header file to set their own multiplier and divider.
Added the #define for the multiplier and divider to the cpu header file.
Move the default SPI CS that we boot from into common code so that it can
be used in other SPI drivers and environment settings.
include/flash.h was commented to say that the address in
flash_info->start was a physical address. However, from u-boot's
point of view, and looking at most flash code, it makes more
sense for this to be a virtual address. So I corrected the
comment to indicate that this was a virtual address.
The only flash driver that was actually treating the address
as physical was the mtd/cfi_flash driver. However, this code
was using it inconsistently as it actually directly dereferenced
the "start" element, while it used map_physmem to get a
virtual address in other places. I changed this driver so
that the code which initializes the info->start field calls
map_physmem to get a virtual address, eliminating the need for
further map_physmem calls. The code is now consistent.
The *only* place a physical address should be used is when defining the
flash banks list that is used to initialize the flash_info struct,
usually found in the board config file.
Update the anomaly lists to match latest anomaly sheets.
Original patch from Ralph Kondziella
plus clean up by Wolfgang Denk
plus changes by John Rigby
use ips clock not lpc
port forward to current u-boot release
Signed-off-by: Ralph Kondziella <rk@argos-messtechnik.de>
Signed-off-by: John Rigby <jrigby@freescale.com>
IIM (IC Identification Module) is the fusebox for the mpc5121.
Use #define CONFIG_IIM to turn on the clock for this module
use #define CONFIG_CMD_FUSE to add fusebox commands.
Fusebox commands include the ability to read
the status, read the register cache, override the register cache,
program the fuses and sense them.
Signed-off-by: Martha Marx <mmarx@silicontkx.com>
Make inclusion of FSL logo optional and
turn it off by default.
Regression since merge window after 2009.01
Signed-off-by: Remy Bohmer <linux@bohmer.net>
This is a port of the Linux Blackfin on-chip SDH driver to U-Boot.
Signed-off-by: Cliff Cai <cliff.cai@analog.com>
Knowing the booting source of the part is useful, especially when the part
can switch dynamically between sources.
Set the default CONFIG_ENV_SPI_CS value to match the SPI CS that is used by
the Blackfin on-chip bootrom to boot out of SPI flash.
