Rather than the caller negating our progress numbers to indicate an
error has occurred, which seems hacky, add a function to indicate this.
At present boot_stage_progress() is called with various magic numbers. The
new bootstage.h header will be used to turn these into symbolic names
throughout the code.
The intent is not that these numbers are passed to Linux. In fact by using
an enum to track them we should eventually be able to remove the explict
numbers and just have the stages count up from 0.
A few subsystems are using the same define "NAMESIZE". This has been
working so far because they define it to the same number. However, I
want to change the size of eth_device's NAMESIZE, so rather than tweak
the define names, simply drop references to it. Almost no one does,
and the handful that do can easily be changed to a sizeof().
This patch adds support for the esd CPCI-HD/2 board to u-boot for CPCI-CPU/750.
As the primary devices on the CPCI-HD/2 board are connected to device 1 and 3,
the device must be swapped.
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd.eu>
* 'master' of git://git.denx.de/u-boot-avr32:
atmel_mci.h: remove outdated register macros
doc/git-mailrc: add <me> to avr32 alias
ATMEL: remove old atmel_mci driver
ATMEL: use generic mmc framework
* 'sandbox' of git://git.denx.de/u-boot-blackfin:
sandbox: mark os_exit as noreturn
sandbox: add getopt support
sandbox: allow processing before main loop
sandbox: add concept of sandbox state
sandbox: disable fortification
sandbox: u-boot.lds: tweak style
sandbox: add get_{tbclk,ticks}
sandbox: enable GPIO driver
sandbox: gpio: add basic driver for simulating GPIOs
sandbox: add flags for open() call
sandbox: config: enable fdt and snprintf() options
sandbox: fdt: add support for CONFIG_OF_CONTROL
sandbox: add lseek helper
sandbox: add ifdef protection to os.h
sandbox: add required header to os.c
sandbox: sort header files in os.c
New gen_atmel_mci driver does not use the outated register access macros. Since
the old atmel_mci driver is deleted these macros are no longer necessary.
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
gen_atmel_mci works on AVR32 as well, so no need to use the legacy
mmc driver. This also has the nice side effect of being able to use
SDHC cards an those boards.
Signed-off-by: Sven Schnelle <svens@stackframe.org>
This adds simple command-line parsing to sandbox. The idea is that it
sets up the state with options provided, and this state can then be
queried later, as needed.
New flags are declared with the SB_CMDLINE_OPT_SHORT helper macro,
pointers are automatically gathered up in a special section, and
then the core code takes care of gathering them up and processing
at runtime. This way there is no central place where we have to
store a list of flags with ifdefs.
Enable the new GPIO driver for sandbox.
This provides a way for callers to create files for writing. The flags
are translated at runtime, for the ones we support.
Enable fdt code and safe snprintf() options for sandbox.
Follow up patches want to be able to seek fd's.
The generalised calculation of the serial bit rate reg also applies
to sh7264, it was just the clock speed that was set incorrectly.
Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com>
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
We currently have the same code in hush.c and main.c. This brings the
code into one place.
As an added feature, if the command function returns CMD_RET_USAGE then
cmd_process() will print a usage message for the command before
returning the standard failure code of 1.
ARM code size increases about 32 bytes with this clean-up.
We should aim for a single point of entry to the commands, whichever
parser is used.
Boards can select either the 'built-in' parser or the hush parser. We
should not call builtin_run_command() if we are using the hush parser.
We use run_command() instead, since it knows how to call the correct
parser.
This is a more sensible name, so rename it.
The current run_command() is only one of the parsing options - the other
is hush. We should not call run_command() when the hush parser is being
used. So we rename this function to better explain its purpose.
It really isn't clear why this is here and there is no comment, so
drop it.
Signed-off-by: Thomas Weber <weber@corscience.de>
Fixing build regressions for the Integrator I get find that a few
boards try to work around the missing declaration of
pciauto_config_init() by declaring it in the local scope. This
does not make sense when the sibling functions are in <pci.h>
so move the function to the header, ridding the build error
in the Integrator and getting rid of the local declarations
here and there.
Reported-by: Wolfgang Denk <wd@denx.de>
This moves keyboard polling logic from USB HCD drivers into USB
keyboard driver. Remove usb_event_poll() as keyboard polling was
the only user of this API. With this patch USB keyboard works with
EHCI controllers again. Tested on a tegra2 seaboard.
Signed-off-by: Allen Martin <amartin@nvidia.com>
Fix the crash when running several times usb_init() with a USB ethernet
device plugged.
Signed-off-by: Vincent Palatin <vpalatin@chromium.org>
Tested-by: Wolfgang Grandegger <wg@denx.de>
Cc: Remy Bohmer <linux@bohmer.net>
* 'master' of git://git.denx.de/u-boot-nand-flash:
cmd_nand.c: Fix 'nand dump' after latest MTD resync
mtd/nand:Fix wrong usage of is_blank() in fsl_ifc_run_command
mtd/nand: Fix IFC driver to support 2K NAND page
nand: reinstate lazy bad block scanning
Revert "nand: make 1-bit software ECC configurable"
commit 2a8e0fc8b3dc31a3c571e439fbf04b882c8986be ("nand: Merge changes
from Linux nand driver") accidentally reverted commit
13f0fd94e3cae6f8a0d9fba5d367e311edc8ebde ("NAND: Scan bad blocks
lazily.").
Reinstate the change, as amended by commit
ff49ea8977b56916edd5b1766d9939010e30b181 ("NAND: Mark the BBT as scanned
prior to calling scan_bbt.").
This reverts commit 4fee6c2f295f932b8febdc7ce8731ba045695fa5.
It breaks boards that currently rely on soft-ecc, as pointed out here:
http://patchwork.ozlabs.org/patch/140872/
The reverted patch should be resubmitted with documentation, and with the
CONFIG_MTD_ECC_SOFT selected from every board that needs it. We could
start by looking at what NAND driver the board selects, and whether
that driver ever asks for soft ECC.
Add PREBOOT, SILENT_CONSOLE and DEVICE_NULLDEV for release
build. Fixed bug in CONFIG_SYS_HUSH_PARSER define.
Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
The video setup for the Epson display is provided. Addtionally
some extra info is displayed next to the Linux logo.
Make get_cpu_rev() publicly available (added to sys_proto.h).
size of environment must match erasable block size in the flash.
Define CONFIG_PHY_MICREL, and
minimize the tx clock delay.
There is an issue with 1000 baseTx mode on early revs
of the SabreLite boards. The center tap pin 9 of the mag RJ45
USB combo was connected to the 3.3 filtered supply. Letting
this pin float solved the problem. Symptoms of the problem
were packets with many extra zeroes tacked on the end, and random
bit flips causing a high rate of CRC errors. 10/100 baseTx worked
fine on all revs. To disable 1000 baseTx for these boards, simply
define the environment variable disable_giga. ie.
setenv disable_giga 1
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
Add the gigabit phy KSZ9021.
Also, add function ksz9021_phy_extended_write
/_read for access to the phys extended registers.
The environment variable "disable_giga"
can be used to disable 1000baseTx.
The Integrator/CP config file was very outdated and gives a
non functional U-Boot. So:
- Set the CONFIG_ARCH_CINTEGRATOR arch flag correctly
- Add proper core module configuration options
- Skip cluttered command lista and just include
<config_cmd_default.h>
- Kill off #if 0 network section and insert some example
configuration that simply just boots from the network
using TFTP if available.
- Delete flash control registers that have no business
in this config file. These are already moved down to
board/armltd/integrator/integrator-sc.h
The PCI support for the Integrator AP has apparently never
been finished and I strongly suspect that it has never worked,
so let's fix it. This is a list of the more or less
un-splittable changes done in this driver rewrite:
- Replace the register definitions stashed into the config
file (!) with a copy if the register file from the Linux
kernels arch/arm/include/asm/hardware/pci_v3.h
- Delete the unreadable gigantic macros that perform the
config accesses and replace them with copyedited code from
Linux arch/arm/mach-integrator/pci_v3.c
- Rewrite the rest of the setup code to use the
v3_[read|write][lwb]() accessors.
- Enable PCI by default in the AP board configuration.
- Fix checkpatch warnings and make code more conformant.
Tested-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Detlev Zundel <dzu@denx.de>
CC: Stefano Babic <sbabic@denx.de>
davinci_dm6467Tevm
In commit 2d575e46859dd9127a9cec731ace77523e6ea2ab a separate header
file was introduced for the DM6467T EVM, include/configs/davinci_dm6467Tevm.h.
The substantial difference between the davinci_dm6467evm and the
davinci_dm6467Tevm configuration is a single bit in the hardware revision
that is passed to the Linux kernel and davinci_dm6467evm has
REFCLK_FREQ = 27000000 where as davinci_dm6467Tevm.h has a
REFCLK_FREQ = 33000000.
This patch removes include/configs/davinci_dm6467Tevm.h. Instead the
include/configs/davinci_dm6467evm.h configuration is used for DM6467T EVMs and
renamed CFG_REFCLK_FREQ to CONFIG_REFCLK_FREQ and CONFIG_REFCLK_FREQ is defined
in boards.cfg.
Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
Cc: Tom Rini <trini@ti.com>
Because the tricorder uses the CONFIG_OMAP_HSMMC the
initialization command is mmc rescan and not mmc init.
The default settings store the persistent environment on SD card
and not serial flash (SPI NOR).
To use SPI NOR to save the environment instead of SD card, edit
include/configs/mx6qsabrelite.h and
- undefine CONFIG_ENV_IS_IN_MMC
- define CONFIG_ENV_IS_IN_SPI_FLASH
The SPI driver can take as chip select the controller's chip selects
as well as an external GPIO. The LSB byte has the value of the internal
chip select, the highest (thought as 16-bit value) contains the GPIO
number.
The GPIO used on Sabre Lite is GP3:19 == 83.
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
Acked-by: Jason Liu <jason.hui@linaro.org>
Tested-by: Jason Liu <jason.hui@linaro.org>
This patch adds SPI support for the MX28EVK. Support for
an optionally installed SPI flash is also added. An example
configuration for redundant envrionment from SPI flash is also
added but disabled by default.
This patch has been tested on a MX28EVK Rev. D with an installed
SST25VF032B 32Mbit SPI flash.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
This patch enables USB host support on the MX28EVK board.
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
This patch adds support for the MX28 internal RTC
and enables u-boot's date command.
Signed-off-by: Stephan Linz <linz@li-pro.net>
* 'master' of git://git.denx.de/u-boot-mmc:
mmc: make mmc_send_status() more reliable
mmc: fix card busy polling
Tegra: mmc: Fixed handling of interrupts in timeouts.
omap_hsmmc: Wait for CMDI to be clear
