It is very common in the debug stage to test U-Boot loading a linux
kernel. The commands to boot linux kernel with ramdisk and nfs as the
root are common to all x86 targets, so it makes sense to add them as
the U-Boot default environment in x86-common.h.
Acked-by: Simon Glass <sjg@chroimum.org>
Saving U-Boot's environment in SPI flash on Intel Galileo board.
Acked-by: Simon Glass <sg@chromium.org>
Saving U-Boot's environment in SPI flash on Intel CrownBay board.
Intel Crown Bay board has one ethernet port connected from Intel
Topcliff PCH. Enable it in the board configuration.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Add a new driver for the Gigabit Ethernet MAC found on Intel Topcliff
Platform Controller Hub. Tested under 10/100 half/full duplex and 1000
full duplex modes using ping and tftpboot commands.
Some ethernet drivers use their own version of ethernet FCS length
macro which is really common. We define ETH_FCS_LEN in net.h and
replace those custom versions in various places.
Intel Quark SoC integrates two 10/100 ethernet controllers which can
be connected to an external RMII PHY. The MAC IP is from Designware.
Enable this support with the existing U-Boot Designware MAC driver
so that the ethernet port on Intel Galileo board can be used.
Add the description that how the compatible property is involved in
the fdtdec_get_pci_bdf() documentation.
To remove the ifdef conditional of CONFIG_SKIP_LOWLEVEL_INIT,
add late_lowlevel_init.S to U-Boot proper.
There is no good reason to have the 0x1000 gap between
CONFIG_SYS_INIT_SP_ADDR and CONFIG_SYS_TEXT_BASE.
The Boot ROM of UniPhier platform only loads 64KB image. We should
always make sure that SPL memory footprint is less than that.
Ifdef conditionals for CONFIG options are not Kconfig-friendly.
Instead, define CONFIG_SPL_STACK to prepare for Kconfig moves.
Enable CONFIG_SPL_DM and CONFIG_SPL_SERIAL_SUPPORT, which provide
Driver Model UART support on SPL.
CONFIG_SYS_SPL_MALLOC_{START,SIZE} should be dropped because simple
malloc is preferred on SPL. Dlmalloc requires some static variables
on .data section that is not available yet for NOR boot mode etc.
Do not reset board on panic, which allows us to not link reset_cpu()
into SPL.
As the u-boot-spl.lds is used only for armv7 SoCs (includes
sama5d3 and sama5d4), so move it to armv7 directory.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
As the u-boot-spl.lds is moved to <arch/arm/mach-at91> directory.
So, correct the path for sama5d4 related boards.
Add a mmc default config, which will save the environment in a FAT file
(uboot.env) of MMC.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
This patch enable the MCI support for at91sam9rlek board.
[rebase on ToT]
Update the nand flash offset mapping, default nand bootcmand and
bootargs to align with linux4sam.org.
Acked-by: Bo Shen <voice.shen@atmel.com>
Boards that haven't been converted to GENERIC_BOARD does
*not* mean they should be removed.
This has not been converted to Generic Board, so should be removed.
(See doc/README.generic-board for details.)
Cc: Larry Johnson <lrj@acm.org>
Cc: Eric Millbrandt <emillbrandt@dekaresearch.com>
They have not been converted to Generic Board, so should be removed.
Cc: Erik Theisen <etheisen@mindspring.com>
Cc: Stephen Williams <steve@icarus.com>
We don't want that CONSOLE is redirected to LCD upon init, we rather prefer
that console is still on the serial line.
Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
Signed-off-by: Hannes Petermaier <hannes.petermaier@br-automation.com>
Panasonic's System LSI products, UniPhier SoC family, have been
transferred to Socionext Inc.
This should make it more clear why there appear to be C pre-processor
symbols in the file that contain mixed case. They're really error
messages.
Suggested-by: Simon Glass <sjg@chromium.org>
When Beagle X15 is connected to Gigabit switch, it takes
more time to finish auto-negotiation than on a 10/100 switch.
The default 4 second limit times-out more often than not. This is
observed when testing with a D-Link DGS-1008A desktop switch.
Increase the auto-negotiation time-out for Beagle-X15 to handle
this case.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
RX51 has a secure logic which uses different parameters compared to
traditional implementation. So, make the generic secure acr write
over-ride-able by board file and refactor rx51 code to use this.
While at it, enable the OMAP3 specific errata code for 454179, 430973,
621766.
Signed-off-by: Nishanth Menon <nm@ti.com>
Enable the OMAP3 specific errata code for 454179, 430973, 621766
and while at it, remove legacy non-revision checked errata logic.
Tested-by: Matt Porter <mporter@konsulko.com>
This patch enables the workaround for ARM errata 798870 for OMAP5 /
DRA7 which says "If back-to-back speculative cache line fills (fill
A and fill B) are issued from the L1 data cache of a CPU to the
L2 cache, the second request (fill B) is then cancelled, and the
second request would have detected a hazard against a recent write or
eviction (write B) to the same cache line as fill B then the L2 logic
might deadlock."
An l2auxctlr accessor implementation for OMAP5 and DRA7 is introduced
here as well.
Signed-off-by: Praveen Rao <prao@ti.com>
Signed-off-by: Angela Stegmaier <angelabaker@ti.com>
This is in preperation of using generic cross OMAP code.
The purpose of this build target is to do SPL over USB RNDIS. We remove
YMODEM, MMC and NAND (and re-set ENV to be built-in) as when those are needed
we can use the other build targets. This brings us well under size limit again.
Since commit ad8aae82b20ac6a ("mx6sabre: Enable User Mass Storage") SPL target
does not boot anymore due to the increased spl image size.
Only enable USB Mass Storage for the non-SPL target.
Warp has a DDR eMMC, so enable CONFIG_SYS_FSL_ESDHC_HAS_DDR_MODE for better
performance:
reading zImage
5790288 bytes read in 117 ms (47.2 MiB/s)
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
CONFIG_SYS_FSL_ESDHC_HAS_DDR_MODE should be selected only by boards that really
have a DDR-capable eMMC, so remove this option from common code to avoid
regressions.
Reported-by: Stefan Roese <sr@denx.de>
Reviewed-by: Volodymyr Riazantsev <volodymyr.riazantsev@globallogic.com>
Tested-by: Stefan Roese <sr@denx.de>
By not defining CONFIG_SYS_PROMPT, the standard "=>" prompt is used, so remove
its definition.
Replace "mmc open/close" with "mmc dev" in mx6sabre_common.h as those commands
were removed with this commit: 614b2bf1c9bf80dbad24f5e5ce1d115bf24a831d
cmd_mmc.c: Drop open/close mmc sub-commands
Signed-off-by: Maxin B. John <maxin.john@enea.com>
Device Firmware Upgrade (DFU) is a very convenient mechanism to upgrade U-boot
on the eMMC.
Add support for it.
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into
the console and hitting enter afterwards, causes a hang in the system because
CONFIG_SYS_PBSIZE is not capable of storing the extra characters of the error
message:
"Unknown command '' - try 'help'".
Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve
this problem.
message:
this problem.
Cc: Otavio Salvador <otavio@ossystems.com.br>
message:
this problem.
Cc: Eric Nelson <eric.nelson@boundarydevices.com>
message:
this problem.
message:
this problem.
