path: root/include
2016-03-14libfdt: Add a function to write a property placeholderSimon Glass
The existing function to add a new property to a tree being built requires that the entire contents of the new property be passed in. For some applications it is more convenient to be able to add the property contents later, perhaps by reading from a file. This avoids double-buffering of the contents. Add a new function to support this and adust the existing fdt_property() to use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-11exynos5: common: Enable CONFIG_USB_ETHER_RTL8152 ethernet supportAnand Moon
Enable CONFIG_USB_ETHER_RTL8152 support for Odroid XU4 which has support for RTL8153-CG gigabit Ethernet adapter, connected over USB 3.0. commit 9dc8ba19c50fc0b1623c654bcfe6caa903a4c36c added support for Realtek 8152/8153 driver. Signed-off-by: Anand Moon <linux.amoon@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2016-03-08malloc: use hidden visibilityStephen Warren
When running sandbox, the following phases occur, each with different malloc implementations or behaviors: 1) Dynamic linker execution, using the dynamic linker's own malloc() implementation. This is fully functional. 2) After U-Boot's malloc symbol has been hooked into the GOT, but before any U-Boot code has run. This phase is entirely non-functional, since U-Boot's gd symbol is NULL and U-Boot's initf_malloc() and mem_malloc_init() have not been called. At least on Ubuntu Xenial, the dynamic linker does make both malloc() and free() calls during this phase. Currently these free() calls crash since they dereference gd, which is NULL. U-Boot itself makes no use of malloc() during this phase. 3) U-Boot execution after gd is set and initf_malloc() has been called. This is fully functional, albeit via a very simple malloc() implementation. 4) U-Boot execution after mem_malloc_init() has been called. This is fully functional with a complete malloc() implementation. Furthermore, if code that called malloc() during phase 1 calls free() in phase 3 or later, it is likely that heap corruption will occur, since U-Boot's malloc implementation will assume the pointer is part of its own heap, although it isn't. I have not actively observed this happening. To prevent phase 2 from happening, this patch makes all of U-Boot's malloc library public symbols have hidden visibility. This prevents them from being hooked into the GOT, so only code in the U-Boot binary itself actually calls them; any other code will call into the standard C library malloc(). This also avoids the "furthermore" issue mentioned above. I have seen references to this GCC pragma in blog posts from 2008, and RHEL5's ancient gcc appears to accept it fine, so I believe it's quite safe to use it without checking gcc version. Cc: Rabin Vincent <rabin@rab.in> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-08OMAP3: am3517_evm: Add NAND MTD partitions with UBI/UBIFS supportDerald D. Woods
- Add required UBI/UBIFS config definitions - Add reasonable MTD partition layout - Remove JFFS2 config definitions - Drop some CFI verbage and definitions - Make comment 'one-liners' truly one line - Improve readability and content arrangement Signed-off-by: Derald D. Woods <woods.technical@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-08OMAP3: am3517_evm: Use BCH8 ECC for NANDDerald D. Woods
Select 8-bit BCH ecc-scheme with s/w based error correction - OMAP_ECC_BCH8_CODE_HW_DETECTION_SW Signed-off-by: Derald D. Woods <woods.technical@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-02mx53ard: Move to booting zImageFabio Estevam
Move to booting a zImage kernel by default to align with the other i.MX boards. While at it, adjust the fdt_addr so that we can boot a standard mainline kernel. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-02-29arm: dra7xx: Define Android partition tableSam Protsenko
"fastboot oem format" command reuses "gpt write" command, which in turn requires correct partitions defined in $partitions variable. This patch adds such definition of Android partitions for DRA7XX EVM board. By default $partitions variable contains Linux partition table. In order to prepare Android environment one can run next commands from U-Boot shell: => env set partitions $partitions_android => env save After those operations one can go to fastboot mode and perform "fastboot oem format" to create Android partition table. While at it, enable CONFIG_RANDOM_UUID to spare user from providing UUIDs for each partition manually. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-29sniper: Various minor cleanups, missing Kconfig configs and reorganisationPaul Kocialkowski
This introduces some minor cleanups, regarding aspects such as board name, code and headers organization as well as deprecated and missing config options. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-29amcc-common.h: Disable CONFIG_SYS_LONGHELPTom Rini
There are a number of AMCC platforms which are close to, or with some toolchains exceeding, the size constraints. Disable CONFIG_SYS_LONGHELP to get us room to build with again. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-29compiler*.h: sync include/linux/compiler*.h with Linux 4.5-rc6Tom Rini
Copy these from Linux v4.5-rc6 tag. This is needed so that we can keep up with newer gcc versions. Note that we don't have the uapi/ hierarchy from the kernel so continue to use <linux/types.h> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-29Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2016-02-29Revert "dm: ns16550: Add support for reg-offset property"Tom Rini
This reverts commit d9a3bec682f9756621615f4306718a356a3230e3. While this is a correct change to do long term it unfortunately breaks a number of platforms that are using pdata and not named struct members so they are getting all of their data after 'base' incorrect. Acked-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-29ARM: uniphier: default to environment in eMMCMasahiro Yamada
Of the several boot devices supported, it looks like the eMMC is the most commonly used. Enable CONFIG_ENV_IS_IN_MMC by default. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-29ARM: uniphier: add emmcupdate commandMasahiro Yamada
The Boot ROM expects the boot image (SPL) in the Boot Partition 1. So, updating images involves the hardware partition switch. It might be a bit advanced for some users. To be user-friendly, this commit adds a useful command to update the images; just put SPL and U-Boot proper into the public directory of the TFTP server and execute "run emmcupdate" from the command line. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-29ARM: uniphier: add eMMC boot supportMasahiro Yamada
Export device nodes needed for eMMC boot (eMMC node, pinctrl, and clock) to the SPL DTB. CONFIG_SUPPORT_EMMC_BOOT is also necessary to use "mmc partconf" command. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-29ARM: uniphier: enable UniPhier SD/MMC host driverMasahiro Yamada
Enable the driver in all UniPhier defconfig files and add some needed defines to the common files. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-26Merge git://git.denx.de/u-boot-dmTom Rini
2016-02-26powerpc/t208xqds: fix esdhc peripheral clock supportYangbo Lu
The patch that enabled eSDHC peripheral clock support had an obvious error as below. This patch is used to fix it. +#define define CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK Fixes: 3285e6cbcc1b ("powerpc/t2080qds: enable eSDHC peripheral clock support") Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-02-26timer: Provide an early timerSimon Glass
In some cases the timer must be accessible before driver model is active. Examples include when using CONFIG_TRACE to trace U-Boot's execution before driver model is set up. Enable this option to use an early timer. These functions must be supported by your timer driver: timer_early_get_count() and timer_early_get_rate(). Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-26image: Correct the OS location code to work on sandboxSimon Glass
A recent change broke the 'bootm' command on sandbox. The root cause is using a pointer as an address. Conversion from pointer to address needs to use map_to_sysmem() so that sandbox can do the right thing. The problem was pre-existing but uncovered by a recent commit. Fix this. Also move fit_get_end() to the C file to avoid needing to include mapmem.h (and thus asm/io.h) everywhere. Fixes: 1fec3c5d (common/image.c: Make boot_get_ramdisk() perform a check for Android images) Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-26ARM: rpi: increase CONFIG_SYS_MAXARGSStephen Warren
This allows all the hush tests implemented in test/py to pass, under qemu at least. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-25ARM: zynq: zynqmp: Enable DCC serial driver by defaultMichal Simek
Compile DCC serial driver by default. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-02-24Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
2016-02-24Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2016-02-24Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2016-02-24rpi: always scroll by 10 linesLubomir Rintel
Scrolling the simple framebuffer is really slow in Raspberry Pi to the point it delays the boot by a second or two and makes longer output inconvenient to follow (printenv, md). Signed-off-by: Lubomir Rintel <lkundrak@v3.sk> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2016-02-24arm: am437x: cm-t43: bring back BOOTDELAY featureNikita Kiryanov
Commit 755324 (configs: Use config_distro_defaults.h in ti_armv7_common.h) made ti_armv7_common.h include config_distro_defaults.h. This breaks the bootdelay feature in cm_t43 because now the - #include ti_armv7_common.h (#define CONFIG_BOOTDELAY 1) - #undef CONFIG_BOOTDELAY - #include config_distro_defaults.h (#define CONFIG_BOOTDELAY 2) dance in cm_t43.h is no longer valid and in fact leads to CONFIG_BOOTDELAY not being defined. Adapt the config file to the new inclusion hierarchy. Cc: Tom Rini <trini@konsulko.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24arm: am437x: cm-t43: update parameters for raw mmc bootNikita Kiryanov
Update U-Boot offset and size for raw mmc boot. Cc: Tom Rini <trini@konsulko.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24arm: am437x: cm-t43: set MPU and CORE voltages on bootNikita Kiryanov
During boot, U-Boot raises the CPU frequency but the CORE and MPU regulators are not updated. This is not a problem in cold boot since the default values that the pmic outputs are correct, but if Linux were to switch the module to a low power OPP, the new voltage values will be retained after a reboot and the module will likely hang once U-Boot raises the CPU frequency back up. Set both CORE and MPU regulators to to 1.1V on boot. Cc: Tom Rini <trini@konsulko.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24pmic: tps65218: add useful functions and definesNikita Kiryanov
Add the following functions: tps65218_reg_read() for accessing redisters tps65218_toggle_fseal() for toggling the fseal bit tps65218_lock_fsea() for locking the fseal bit to 1 Add the following defines: All status register bits Cc: Tom Rini <trini@konsulko.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24arm: am437x: cm-t43: support all available SPI flash chipsNikita Kiryanov
Add full support for SPI flash chips to future-proof U-Boot for cm-t43. Cc: Tom Rini <trini@konsulko.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24arm: am437x: cm-t43: migrate CONFIG_DM_SERIAL to config fileNikita Kiryanov
Move CONFIG_DM_SERIAL to cm_t43_defconfig. This forces us to update the CONFIG_SYS_NS16550_REG_SIZE value for SPL. Cc: Tom Rini <trini@konsulko.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24arm: am437x: cm-t43: fix cm-t43 bootNikita Kiryanov
spl_board_init() is necessary for boot. Remove the #undef that keeps it out of the boot sequence. Cc: Tom Rini <trini@konsulko.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24board/BuR/kwb: cosmetic changesHannes Schmelzer
- fixup typo - fixup identation Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24board/BuR: split bur_am335x_common.h into am335x-specific and BuR common partsHannes Schmelzer
bur_am335x_common.h today holds all common configuration which is shared over all B&R boards. In future we want to bring up boards which are not based on AM335x only but we still want to have common configuration over all B&R boards independent from their architecture. To prepare this we introduce a new file "bur_cfg_common.h", where we move all common things, which are not architecture specific, from bur_am335x_common.h. On B&R am335x boards we include from now: #include <configs/bur_cfg_common.h> #include <configs/bur_am335x_common.h> On other B&R boards, we include only #include <configs/bur_cfg_common.h> Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24board/BuR: move everything possible from board's headerfile to KConfigHannes Schmelzer
We drop everything possible things from board headerfiles and replace this functionality with responsible settings in Kconfig (_defconfig). Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24board/BuR: drop ETH-support in SPL-StageHannes Schmelzer
During very early prototype-phase we did boot the AM335x boards initially from CPSW-EMAC. Now we don't need this feature anymore. So we drop it to save MLO-space and having therefore a more quickly boot. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24OMAP3SOM BOARD: Auto detect Logic PD ModelsAdam Ford
Logic PD makes four different system on modules. This patch will auto detect the board type and identify the corresponding device tree image. V2: Added 'default:' case to switch statement Since board_late_init() is defined as int, we now return 0 Signed-off-by: Derald Woods <woods.technical@gmail.com> Signed-off-by: Adam Ford <aford173@gmail.com>
2016-02-24stm32: add support for stm32f7 & stm32f746 discovery boardVikas Manocha
This patch adds support for stm32f7 family & stm32f746 board. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2016-02-24stm32x7: add support for stm32x7 serial driverVikas Manocha
This patch adds support for stm32f7 family usart peripheral. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-24arm: socfpga: Add missing CONFIG_BUILD_TARGETMarek Vasut
Add the missing CONFIG_BUILD_TARGET to get u-boot-with-spl.sfp built automatically upon running make in the source tree. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Chin Liang See <clsee@altera.com> Cc: Denis Bakhvalov <denis.bakhvalov@nokia.com>
2016-02-24implement Fastboot via USB OTG on bcm28155_ap boardsSteve Rae
Don't understand how it happened, but this change got applied twice! Therefore, removing the duplicated items. Signed-off-by: Steve Rae <srae@broadcom.com>
2016-02-24dfu: odroid xu3: Define DFU_MANIFEST_POLL_TIMEOUT to handle large files ↵Lukasz Majewski
transmission and storage As tested on the Odroid XU3, large files to be stored on the file system require considerable time to be physically written to the medium. The default 300 ms is not enough to store large file (e.g. 26 MiB). To fix this situation the DFU_MANIFEST_POLL_TIMEOUT has been defined. It is used to cease the communication with dfu-util and allow the target board to store the data on file system. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2016-02-24dfu: usb: f_dfu: Set deferred call for dfu_flush() functionLukasz Majewski
This patch fixes situation when one would like to write large file into medium with the file system (fat, ext4, etc). This change sets file size limitation to the DFU internal buffer size. Since u-boot is not supporting interrupts and seek on file systems, it becomes challenging to store large file appropriately. To reproduce this error - create large file (around 26 MiB) and sent it to the target board. Lets examine the flow of USB transactions: 0. DFU uses EP0 with 64B MPS [Max Packet Size] 1. Send file - OUT (PC->target) - dat_26MiB.img is sent with 4096 B transactions 2. Get status - OUT (PC->target) - wait for DFU_STATE_dfuDNLOAD_IDLE (0x05) sent from target board - IN transaction (target->PC) 3. The whole file content is sent to target - OUT (PC->target) with ZLP [Zero Length Packet] Now the interesting part starts: 4. OUT (PC->target) Setup transaction (request to share DFU state) 5. IN (target->PC) - reply the current DFU state - In the UDC driver the req->completion (with dfu_flush) is called after successful IN transfer. - The dfu_flush() (called from req->completion callback) saves the whole file at once (u-boot doesn't support seek on fs). Such operation takes considerable time. When the file is large - e.g. 26MiB - this time may be more than 5 seconds. 6. OUT (PC->target) - ZLP, is send in the same time when dfu_flush() writes data to eMMC memory. The dfu-util application has hard coded timeout on USB transaction completion set to 5 seconds (it uses libusb calls). When the file to store is large (e.g. 26 MiB) the time needed to write it may excess the dfu-util timeout and following error message will be displayed: "unable to read DFU status" on the HOST PC console. This change is supposed to leverage DFU's part responsible for storing files on file systems. Other DFU operations - i.e. raw/partition write to NAND and eMMC should work as before. The only functional change is the error reporting. When dfu_flush() fails the u-boot prompt will exit with error information and dfu-util application exits afterwards as well. Test HW: - Odroid XU3 (Exynos5433) - test with large file - Trats (Exynos4210) - test for regression - eMMC, raw, Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Reported-by: Alex Gdalevich <agdalevich@axion-biosystems.com> Tested-by: Stephen Warren <swarren@nvidia.com> Tested-by: Heiko Schocher <hs@denx.de>
2016-02-24board: ls1043ardb: Add micro QE support for ls1043ardbZhao Qiang
Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-02-24armv8/ls1043aqds: Add USB support for ls1043aqdsQianyu Gong
Add USB XHCI support for ls1043qds board. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-02-24fm: fdt: Move fman ucode fixup to driver codeQianyu Gong
Not only powerpc/mpc85xx but also Freescale Layerscape platforms will use fdt_fixup_fman_firmware() to insert Fman ucode blob into the device tree. So move the function to Fman driver code. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-02-24qe: move drivers/qe/qe.h to include/fsl_qe.hQianyu Gong
As the QE firmware struct is shared with Fman, move the header file out of drivers/qe/. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-02-24armv8: ls2080: Update bootcmd env variablePrabhakar Kushwaha
Before Linux boot DPL must be deployed to DPAA2 interface. So update bootcmd env variable to make sure DPL deployment before Linux boot. Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
