Cc: Joe Hershberger <joe.hershberger@gmail.com>
Added its mask, too, for intra-file consistency.
This allows us to act like a serial device: we get tab chars and CTRL+C
and respond appropriately.
So that sdhci host would tell in the driver that the mmc current
attributes.
Signed-off-by: Lei Wen <leiwen@marvell.com>
If CONFIG_MMC_SDHCI_IO_ACCESSORS is defined, the following warning would
shows up:
include/sdhci.h:224: warning: 'struct sdhci_host' declared inside
parameter list
include/sdhci.h:224: warning: its scope is only this definition or
declaration, which is probably not what you want
include/sdhci.h:225: warning: 'struct sdhci_host' declared inside
parameter list
include/sdhci.h:226: warning: 'struct sdhci_host' declared inside
parameter list
include/sdhci.h:227: warning: 'struct sdhci_host' declared inside
parameter list
include/sdhci.h:228: warning: 'struct sdhci_host' declared inside
parameter list
include/sdhci.h:229: warning: 'struct sdhci_host' declared inside
parameter list
Previous magic number is hard to parse its meaning, change it to
respective macro definition
Acked-by: WOlfgang Denk <wd@denx.de>
* 'master' of git://git.denx.de/u-boot-arm:
ARM: Add Calxeda Highbank platform
dkb: make mmc command as default enabled
Marvell: dkb: add mmc support
ARM: pantheon: add mmc definition
davinci: remove config.mk file from the sources
ARM:AM33XX: Add support for TI AM335X EVM
ARM:AM33XX: Added timer support
ARM:AM33XX: Add emif/ddr support
ARM:AM33XX: Add clock definitions
ARM:AM33XX: Added support for AM33xx
omap3/emif4: fix registers definition
davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUM
davinci: emac: add support for more than 1 PHYs
davinci: emac: add new features to autonegotiate for EMAC
da850evm: Move LPSC configuration to board_early_init_f()
omap4_panda: Build in cmd_gpio support on panda
omap: Don't use gpio_free to change direction to input
mmc: omap: Allow OMAP_HSMMC[23]_BASE to be unset
OMAP3: overo : Add environment variable optargs to bootargs
OMAP3: overo: Move ethernet CS4 configuration to execute based on board id
OMAP3: overo : Use ttyO2 instead of ttyS2.
da830: add support for NAND boot mode
dm36x: revert cache disable patch
dm644X: revert cache disable patch
devkit8000: Add malloc space
omap: spl: fix build break due to changes in FAT
OMAP3 SPL: Provide weak omap_rev_string
omap: beagle: Use ubifs instead of jffs2 for nand boot
omap: overo: Disable pull-ups on camera PCLK, HS and VS signals
omap: overo: Configure mux for gpio10
SPL: Add DMA library
omap3: Add interface for omap3 DMA
omap3: Add DMA register accessors
omap3: Add Base register for DMA
arm, davinci: add missing LSPC define for MMC/SD1
U-Boot/SPL: omap4: Make ddr pre-calculated timings as default.
DaVinci: correct MDSTAT.STATE mask
omap4: splitting padconfs into common, 4430 and 4460
omap4: adding revision detection for 4460 ES1.1
omap4: replacing OMAP4_CONTROL with OMAP4430_CONTROL
gplug: fixed build error as a result of code cleanup patch
kirkwood_spi: add dummy spi_init()
gpio: mvmfp: reduce include platform file
ARM: orion5x: reduce dependence of including platform file
serial: reduce include platform file for marvell chip
ARM: kirkwood: reduce dependence of including platform file
ARM: armada100: reduce dependence of including platform file
ARM: pantheon: reduce dependence of including platform file
Armada100: Add env storage support for Marvell gplugD
Armada100: Add SPI flash support for Marvell gplugD
Armada100: Add SPI support for Marvell gplugD
SPI: Add SPI driver support for Marvell Armada100
dreamplug: initial board support.
imx: fix coding style
misc: pmic: drop old Freescale's pmic driver
MX31: mx31pdk: use new pmic driver
MX31: mx31ads: use new pmic driver
MX31: mx31_litekit: use new pmic driver
MX5: mx53evk: use new pmic driver
MX5: mx51evk: use new pmic driver
MX35: mx35pdk: use new pmic driver
misc: pmic: addI2C support to pmic_fsl driver
misc: pmic: use I2C_SET_BUS in pmic I2C
MX5: efikamx/efikasb: use new pmic driver
MX3: qong: use new pmic driver
RTC: Switch mc13783 to generic pmic code
MX5: vision2: use new pmic driver
misc: pmic: Freescale PMIC switches to generic PMIC driver
misc:pmic:samsung Enable PMIC driver at GONI target
misc:pmic:max8998 MAX8998 support at a new PMIC driver.
misc:pmic:core New generic PMIC driver
mx31pdk: Remove unneeded config
mx31: provide readable WEIM CS accessor
MX51: vision2: Set global macros
I2C: Add i2c_get/set_speed() to mxc_i2c.c
ARM: Update mach-types
devkit8000: Add config to enable SPL MMC boot
devkit8000: protect board_mmc_init
arm, post: add missing post_time_ms for arm
cosmetic, post: Codingstyle cleanup
arm, logbuffer: make it compileclean
tegra2: Enable MMC for Seaboard
tegra2: Add more pinmux functions
tegra2: Rename PIN_ to PINGRP_
tegra2: Add more clock functions
tegra2: Clean up board code a little
tegra2: Rename CLOCK_PLL_ID to CLOCK_ID
* 'master' of git://git.denx.de/u-boot-microblaze:
microblaze: Fix strict-aliasing rules for in_be32
microblaze: Wire up axi_ethernet driver initialization
The current implementation of debug doesn't play well with GCC4.6.
This implementation also fixes GCC4.6 complaints about unused variables
while maintaining code size.
Also, drop the debugX() as that's not used anywhere anymore.
lcd.c: In function 'lcd_setmem':
lcd.c:446:2: warning: format '%d' expects type 'int', but argument 2 has type
'u_long'
lcd.c:446:2: warning: format '%d' expects type 'int', but argument 3 has type
'u_long'
Cc: Mike Frysinger <vapier@gentoo.org>
interrupts.c: In function 'interrupt_init_cpu':
interrupts.c:37: warning: implicit declaration of function 'GTREGREAD'
interrupts.c:37: error: 'LOW_INTERRUPT_CAUSE_REGISTER' undeclared (first use in
this function)
interrupts.c:37: error: (Each undeclared identifier is reported only once
interrupts.c:37: error: for each function it appears in.)
interrupts.c:37: error: 'HIGH_INTERRUPT_CAUSE_REGISTER' undeclared (first use in
this function)
interrupts.c:40: error: 'ETHERNET0_INTERRUPT_CAUSE_REGISTER' undeclared (first
use in this function)
interrupts.c:40: error: 'ETHERNET1_INTERRUPT_CAUSE_REGISTER' undeclared (first
interrupts.c:40: error: 'ETHERNET2_INTERRUPT_CAUSE_REGISTER' undeclared (first
interrupts.c:44: error: 'ETHERNET0_INTERRUPT_MASK_REGISTER' undeclared (first
interrupts.c:44: error: 'ETHERNET1_INTERRUPT_MASK_REGISTER' undeclared (first
interrupts.c:44: error: 'ETHERNET2_INTERRUPT_MASK_REGISTER' undeclared (first
cmd_date.c: In function ‘do_date’:
cmd_date.c:50:6: warning: variable ‘old_bus’ set but not used
[-Wunused-but-set-variable]
This renames BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT.
Along the way it removes some leftover
#define BOARD_LATE_INIT 1
and adds some basic documentation for board specific
callbacks in README.
Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
Commit 476af29 broke this check when the ifdef lists we consolidated.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
The rarp code includes another instance of the auto_load logic, so call
what is now net_auto_load() instead.
This also fixes an incorrect call to TftpStart() which was never seen
since apparently no boards enable rarp.
Add basic support for Calxeda Highbank platform. Only minimal support with
serial and SATA are included.
Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
This patch adds basic support for booting the board.
This patch adds support for the UART necessary to
get to the u-boot prompt.
Signed-off-by: Chandan Nath <chandan.nath@ti.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
remove macro CONFIG_EMAC_MDIO_PHY_NUM and depending macro EMAC_MDIO_PHY_NUM
as they are no longer needed with the support for more than 1 PHYs in davinci
emac driver.
Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
Since commit f1d2b313c9eb6808d30c16a9eb5251240452a56c the serial
port of the da850evm is accessed before the UART2 peripheral of
the SoC is powered on in the function board_init() in
board/davinci/da8xxevm/da850evm.c.
When u-boot is used in conjunction with the UBL (user boot loader, see
doc/README.davinci) on this board, the UART2 peripheral is already
turned on by UBL at the time u-boot is started. Hence, the wrong
initialization sequence is not noticed by most users. However, if UBL is not
used, u-boot must power on the peripheral before using it.
This patch adds a board_early_init_f() function for the LPSC
configuration to the da850evm board configuration.
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Cc: Ben Gardiner <bengardiner@nanometrics.ca>
Enable the gpio command
This allows the user can easily add extra kernel arguments. Very helpful
for reserving memory for the DSP without rewriting the entire kernel
argument line.
Signed-off-by: Philip Balister <philip@opensdr.com>
Tested-by: Steve Sakoman <steve@sakoman.com>
Starting with kernel 2.6.37, the serial ports on the OMAP3 are called
ttyOX, not ttySX.
Add support for enabling NAND boot mode in configuration file and
add correspanding pinmux support, nand initialize function in board file.
The size required for environment variables not more than 10KB
the CONFIG_ENV_SIZE is set to 10KB from (512 << 10).
Acked-by: Nick Thompson <nick.thompson@ge.com>
Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
revert commit 98c19aff9524e1d0dd6bf39bf7bde5644f121feb as the
disabling of cache need not be done explicitly. Subsequent
patches to new cache management framework has fixed it.
EMAC issue with cache coherency still exists when cahces are
enabled.
revert commit 913a39e9aa4d935948d41cd727d53f5878414a77 as the
enabled.
With malloc support being a new requirement for all ARM SPL
implementations, define a small area for use on devkit8000.
Cc: Frederik Kriewitz <frederik@kriewitz.eu>
