Move coreboot-x86 over to driver model for PCI.
Enable PCI options so that sandbox can be used for testing this bus with
driver model.
Since sandbox does not have real devices (unless it borrows those from the
host) it must use emulations. Provide a uclass which permits PCI operations
to be passed through to an emulation device.
Add a uclass for PCI controllers and a generic one for PCI devices. Adjust
the 'pci' command and the existing PCI support to work with this new uclass.
Keep most of the compatibility code in a separate file so that it can be
removed one day.
TODO: Add more header file comments to the new parts of pci.h
Driver model will share many functions with the existing PCI implementation.
Move these into their own file to avoid duplication and confusion.
Some uclasses want to set up a device before it is probed. Add a method
for this.
An example is with PCI, where a PCI uclass wants to set up its private
data for later use. This allows the device's uclass() method to make calls
whcih use that data (for example, read PCI memory regions from device
tree, set up bus numbers).
Add a convenience function to access the private data that a uclass stores
for each of its devices. Convert over most existing uses for consistency
and to provide an example for others.
This function returns -ENOENT when the property is missing (which the caller
might forgive) and also when the property is present but incorrectly
formatted (which many callers would like to report).
Update the error return value to allow these different situations to be
distinguished.
Since driver model is set up after arch_cpu_init(), that function cannot
use drivers. Add a new arch_cpu_init_dm() function which is called
immediately after driver model is ready, and can reference devices.
This can be used to probe essential devices for the CPU.
This function is missing a prototype but is more widey useful. Add it.
Support running U-Boot as a coreboot payload. Tested peripherals include:
- Video (HDMI and DisplayPort)
- SATA disk
- Gigabit Ethernet
- SPI flash
USB3 does not work. This may be a problem with the USB3 PCI driver or
something in the USB3 stack and has not been investigated So far this is
disabled. The SD card slot also does not work.
For video, coreboot will need to run the OPROM to set this up.
With this board, bare support (running without coreboot) is not available
as yet.
Since Chromebooks mostly have similar configuration, put it in a common
file.
Add some new device IDs used by this haswell-based chipset.
Sunxi platforms come with at least 3 TWI (I2C) controllers and some platforms
even have up to 5. This adds support for every controller on each supported
platform, which is especially useful when using expansion ports on single-board-
computers.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
Acked-by: Hans de Goede <hdegoede@redhat.com>
Orion5x, Kirkwood and Armada XP platforms come with a single TWSI (I2C) MVTWSI
controller. However, other platforms using MVTWSI may come with more: this is
the case on Allwinner (sunxi) platforms, where up to 4 controllers can be found
on the same chip.
Acked-by: Heiko Schocher <hs@denx.de>
This converts the VBUS detection and enable logic to GPIO instead of separate
axp functions and checks that have to be used aside usual GPIO functions.
Since we support multiple dwc3 controllers to be existent at the same
time, in order to handle the interrupts of a particular dwc3 controller
usb_gadget_handle_interrutps should take controller index as an
argument.
Hence the API of usb_gadget_handle_interrupts is modified to take
controller index as an argument and made the corresponding changes to all
the usb_gadget_handle_interrupts calls.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
Enabled dwc3, dwc3-omap and PHY for dwc3 are enabled. Also enabled
support for DFU.
support for DFU.
Added a single driver for both USB2 PHY programming and USB3 PHY
programming.
USB3 PHY is taken from drivers/phy/phy-ti-pipe3.c in linux kernel.
commit 56042e : phy: ti-pipe3: Fix suspend/resume and module reload.
USB2 PHY is taken from drivers/phy/phy-omap-usb2.c in linux kernel.
commit eb82a3 : phy: omap-usb2: Balance pm_runtime_enable() on probe
failure and remove.
Added an API to check for interrupt status. This API is generally
called from board file to check for interrupt status.
Added support for multiple dwc3 omap controllers. This gives uboot
the capability to control multiple dwc3 omap controllers.
Removed probe and remove that are specific to linux and replaced it with
uboot init and uboot exit. These functions will be invoked from boardfile.
This will change once we have dwc3-omap driver adapted to use the uboot
driver model.
Added a structure to populate dwc3 omap platform data. The board file should
populate these platform data before invoking dwc3 omap driver.
This will be removed once dwc3-omap driver is adapted to use the driver model.
*) Changed the included header files to that used in u-boot.
*) Removed extcon_* APIs
*) Removed regulator_* APIs
*) Fixed other misc warnings
*) Added dwc3-omap.h to include the definitions of UTMI modes.
Since interrupt support is not present in u-boot, added an
API to handle the interrupts in dwc3 core. This API can be
polled to handle the interrupts.
Added support for multiple dwc3 controllers. This gives uboot
the capability to control multiple dwc3 controllers.
Added a structure to populate dwc3 core platform data. The board file should
populate these platform data before invoking dwc3 driver.
This will be removed once we have dwc3 driver adapted to use the driver model.
error
Added USB_GADGET_DELAYED_STATUS to avoid the following compilation error.
error: ‘USB_GADGET_DELAYED_STATUS’ undeclared (first use in this function)
while compiling dwc3/ep0.c
While this is been added only to avoid compilation error, the complete fix
should be something like the one added in linux kernel. The complete fix
will be ported once we have the composite driver in u-boot look similar to
the one in linux kernel.
commit 1b9ba000177ee47bcc5b44c7c34e48e735f5f9b1
Author: Roger Quadros <roger.quadros@nokia.com>
Date: Mon May 9 13:08:06 2011 +0300
usb: gadget: composite: Allow function drivers to pause control transfers
Did a bunch of things to get dwc3/gadget.c compile in u-boot without
build errors and warnings
*) Used dma_alloc_coherent and dma_free_coherent APIs of u-boot
*) removed sg support
*) remove jiffies and used a simple while loop
*) removed irq support and added a function to call these interrupt handler.
Changed the header files included in core.h and io.h to the u-boot header
files so that these files can be included in other dwc3 source files and
be compiled in uboot. Also added otg.h which has the defines for dr_mode.
Made changes in gadget.h that is required after adding udc-core.c
except changes that might break other platforms.
On some SoCs, DMA-capable peripherals see a different address space to
the CPU's physical address space. Create an API to allow platform-agnostic
drivers to convert between the two address spaces when programming DMA
operations.
This API will exist on all platforms, but will have a dummy implementation
when this feature is not required. Other platforms will enable
CONFIG_PHYS_TO_BUS and provide the required implementation.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
This patch converts USB protocol headers to use explicitly sized
fields like the rest of the code
Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com>
Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com>
This consolidates the flash settings for the Integrator
and activates the new ARM flash image support for them
so images can be loaded by name from flash.
This modifies the vexpress64 Juno configuration so that
it will by default load and boot a kernel and a device tree
from the images stored in the NOR flash. When we are
at it, also define the proper command line for the Juno and
indicate that the USB stick (/dev/sda1) is the default
root file system.
Work_92105 from Work Microwave is an LPC3250-
based board with the following features:
- 64MB or 128MB SDR DRAM
- 1 GB SLC NAND, managed through MLC controller.
- Ethernet
- Ethernet + PHY SMSC8710
- I2C:
- EEPROM (24M01-compatible)
- RTC (DS1374-compatible)
- Temperature sensor (DS620)
- DACs (2 x MAX518)
- SPI (through SSP interface)
- Port expander MAX6957
- LCD display (HD44780-compatible), controlled
through the port expander and DACs
This board has SPL support, and uses the LPC32XX boot
image format.
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
This allows to clean up the config a good deal and also converts
pandora to Generic Board.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Remove obsolete email address from MAINTAINERS.
There're 2 versions of motherboards that could be used in ARC SDP.
The only important difference for U-Boot is different NAND IC in use:
[1] v2 board (we used to support up until now) sports MT29F4G08ABADAWP
while
[2] v3 board sports MT29F4G16ABADAWP
They are almost the same except data bus width 8-bit in [1] and 16-bit
in [2]. And for proper support of 16-bit data bus we have to pass
NAND_BUSWIDTH_16 option to NAND driver core - which we do now knowing
board type we're running on.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Add support for Inverse Path USB armory board, an open source
flash-drive sized computer based on Freescale i.MX53 SoC.
http://inversepath.com/usbarmory
Signed-off-by: Andrej Rosano <andrej@inversepath.com>
Cc: Chris Kuethe <chris.kuethe@gmail.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Vagrant Cascadian <vagrant@debian.org>
Tested-By: Vagrant Cascadian <vagrant@debian.org>
Tested-by: Chris Kuethe <chris.kuethe@gmail.com>
