This makes it easier to include this header from other headers.
This function should also be part of the GPIO API, so add it.
Update Makefile change for LIBS -> LIBS-y change.
Makefile
This patch fixes the build error for MCF537x. As the NANDFLASH_SIZE is
redefined in boards.cfg, it is needed to rename NANDFLASH_SIZE into
CONFIG_NANDFLASH_SIZE in include/configs/M5373EVB.h.
Signed-off-by: Alison Wang <b18965@freescale.com>
Add support for the onboard eSDHC MMC controller. The hardware on the
MPC8308RDB has the following errata:
- ESDHC111: manual asynchronous CMD12 is broken
- DMA is broken (PIO works)
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
[added include fsl_esdhc header to prevent implicit declarations of
fsl_esdhc_mmc_init() and fdt_fixup_esdhc()]
This is very useful on a modern system.
The SPI pins are routed to header J8 for testing SPI functionality. A
Spansion flash has been wired up and tested on this header.
This patch breaks support for the second TSEC interface, since the GPIO
pin used as a chip select is pinmuxed with some of the TSEC pins.
Change the syntax (user API) for "env default":
-f: override write-once variables
var... : accept individual variable(s)
-a: all (resetting the whole env is NOT the default behavior)
Enable variable checking and make changes effective by
enabling do_apply argument to himport_r().
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
Change hashtable so that a callback function will decide whether a
variable can be overwritten, and possibly apply the changes.
So add a new field to struct hsearch_data:
o "apply" callback function to check whether a variable can be
overwritten, and possibly immediately apply the changes;
when NULL, no check is performed.
And a new argument to himport_r():
o "do_apply": whether to call the apply callback function
NOTE: This patch does not change the current behavior.
Add 2 new arguments to himport_r():
o "nvars", "vars": number and list of variables to take into account
(0 means ALL)
NOTE: This patch does not change the current behaviour.
The logic of checking special parameters (e.g. baudrate, stdin, stdout,
for a valid value and/or whether can be overwritten) and applying the
new value to the running system is now all within a single function
env_check_apply() which can be called whenever changes are made
to the environment, no matter if by set, default or import.
With this patch env_check_apply() is only called by "env set",
retaining previous behavior.
This board is the only board that still sticks to OneNAND IPL.
Remove this board, since we have SPL around for a while and
OneNAND is well supported in the SPL framework. The board can
be revived if necessary.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Tom Rini <trini@ti.com>
Use the same IP revisions as in Linux in order to make the comparison more
clear.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Cc: Scott Wood <scottwood@freescale.com>
There is no reason to have board configs to select the NFC IP revision. Just let
the driver detect it. BTW, remove broken NFC IP revision configs from board
config files.
On the NFC IP 1.1, the 32-bit ecc_status_result value comes from 2
consecutive 16-bit registers. This patch reads all the fields of this value,
which makes a difference for 4-kiB NF pages.
This patches fixes the TODO to use same register definitions in mtd mxc_nand and
nand_spl fsl nfc drivers.
This is based on Linux kernel -next:
commit 14f44abf1dafc20ba42ce8616a8fc8fbd1b3712b
Author: Brian Norris <computersforpeace@gmail.com>
Date: Fri Jul 13 09:28:24 2012 -0700
mtd: nand: allow NAND_NO_SUBPAGE_WRITE to be set from driver
The NAND_CHIPOPTIONS_MSK has limited utility and is causing real bugs. It
silently masks off at least one flag that might be set by the driver
(NAND_NO_SUBPAGE_WRITE). This breaks the GPMI NAND driver and possibly
others.
Really, as long as driver writers exercise a small amount of care with
NAND_* options, this mask is not necessary at all; it was only here to
prevent certain options from accidentally being set by the driver. But the
original thought turns out to be a bad idea occasionally. Thus, kill it.
Note, this patch fixes some major gpmi-nand breakage.
Cc: Brian Norris <computersforpeace@gmail.com>
Cc: Eric Nelson <eric.nelson@boundarydevices.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Micron NAND flash (e.g. MT29F4G08ABADAH4) BLOCK LOCK READ STATUS is not
the same as others. Instead of bit 1 being lock, it is #lock_tight.
To make the driver support either format, ignore bit 1 and use only
bit 0 and bit 2.
NAND_CMD_ constants for lock/unlock should be in the header
Missed in previous cleanup.
NAND unlock command allows an invert bit to be set to unlock all but
the selected page range.
[scottwood@freescale.com: updated docs and added comment about invert bit]
The environment has been based on mx53loco and m28evk but keeping the
possibility to easy change the default console device as Freescale and
mainline kernels differ on the device name.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
This commit enables multibus handling at Samsung's Trats development board.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Heiko Schocher <hs@denx.de>
Support for multiple soft I2C buses.
Multibus I2C support is achieved by defining get_multi_{sda|scl}_pin
functions to switch between multiple "soft" I2C buses.
Common definition of I2C_X I2C buses is provided at <i2c.h>.
TEST HW:
Samsung's Exynos4210 evt.0.1 - Trats development board
This patch is derived from an older patch provided by atmel in its
buildroot-avr32-v3.0.0.tar.bz2
cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Fix CONFIG_SYS_HZ usage in board config.
Do not use hardcoded value. Use CONFIG_SYS_HZ instead.
Separate static configuration to single block.
enable serial multi for Microblaze.
Acked-by: Stephan Linz <linz@li-pro.net>
Convert TEGRA20_ defines to either TEGRA_ or NV_PA_ where appropriate.
Convert tegra20_ source file and function names to tegra_, also.
Upcoming Tegra30 port will use common code/defines/names where possible.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Add support for SD card and change the default
environment due to increased u-boot size.
unused macro CONFIG_DISCOVER_PHY
Signed-off-by: Ashok Kumar Reddy <ashokkourla2000@gmail.com>
When I set up Tegra's config files to put the environment into eMMC, I
assumed that CONFIG_ENV_OFFSET was a linearized address relative to the
start of the eMMC device, and spanning HW partitions boot0, boot1,
general* and the user area in order. However, it turns out that the
offset is actually relative to the beginning of the user area. Hence,
the environment block ended up in a different location to expected and
documented.
Set CONFIG_SYS_MMC_ENV_PART=2 (boot1) to solve this, and adjust
CONFIG_ENV_OFFSET to be relative to the start of boot1, not the entire
eMMC.
Some eMMC devices contain boot partitions, but do not set the PART_SUPPORT
bit in EXT_CSD_PARTITIONING_SUPPORT. Allow partition selection on such
devices, by enabling partition switching when EXT_CSD_BOOT_MULT is set.
Note that the Linux kernel enables access to boot partitions solely based
on the value of EXT_CSD_BOOT_MULT; EXT_CSD_PARTITIONING_SUPPORT only
influences access to "general" partitions.
eMMC devices affected by this issue exist on various NVIDIA Tegra
platforms (and presumably many others too), such as Harmony (plug-in eMMC),
Seaboard, Springbank, and Whistler (plug-in eMMC).
This commit enables NAND support on the Tamonten Evaluation Carrier and
adds the corresponding device tree nodes. Furthermore, the U-Boot
environment can now be stored in NAND.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
This enables NAND support for the Seaboard.
A device tree is used to configure the NAND, including memory
timings and block/pages sizes.
If this node is not present or is disabled, then NAND will not
be initialized.
Signed-off-by: Jim Lin <jilin@nvidia.com>
The NAND layer needs to use cache-aligned buffers by default. Towards this
goal. align the default buffers and their members according to the minimum
DMA alignment defined for the architecture.
Acked-by: Scott Wood <scottwood@freescale.com>
Define default SoC input clock frequencies for i.MX31 in order to get rid of
duplicated definitions.
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Helmut Raiger <helmut.raiger@hale.at>
