include/asm-microblaze/microblaze_intc.h
include/linux/stat.h
FSL_Has_data is connected to INTC.
MPC5200B systems are incorrectly reported as MPC5200 in U-Boot start-up
message. Use PVR to distinguish between the two variants, and print proper CPU
information.
Signed-off-by: Grzegorz Wianecki <grzegorz.wianecki@gmail.com>
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
The AMCC Secquoia board has been changed in a new revision from using a
33.000 MHz clock to a 33.333 MHz system clock. A bit in the CPLD
indicates the difference. This patch reads that bit and uses the correct
clock speed for the board. This code is backward compatable will all
prior boards. All prior boards will be read as 33.000.
Signed-off-by: Jeffrey Mann <mannj@embeddedplanet.com>
Enable hush shell, environment in flash rather in EEPROM,
more user-friendly default environment, etc.
The simple EEPROM environment can be selected easily in the board
config file.
Signed-off-by Dan Malek, <dan@embeddedalley.com>
* Cleaned up the CDS PCI Config Tables and added NULL entries to
the end
* Fixed PCIe LAWBAR assignemt to use the cpu-relative address
* Fixed 85xx PCI code to assign powar region sizes based on the
config values (rather than hard-coding them)
* Fixed the 8548 CDS PCI2 IO to once again have 0 as the base address
Signed-off-by: Andy Fleming <afleming@freescale.com>
This included some changes to common files:
* Add 8568 processor SVR to various places
* Add support for setting the qe bus-frequency value in the dts
* Add the 8568MDS target to the Makefile
Signed-off-by: James Yang <James.Yang@freescale.com>
* Add support to the Makefile
* Add 8544 configuration support to the tsec driver
* Add 8544 SVR numbers to processor.h
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
The other pagesz constants use one letter to specify order of
magnitude. Also change the one reference to it in mpc8548cds/init.S
The PCI I/O space mapping for Freescale MPC8540ADS board was broken by commit
52c7a68b8d587ebcf5a6b051b58b3d3ffa377ddc which failed to update the #define's
describing the local address window used for the PCI I/O space accesses -- fix
this and carry over the necessary changes into the MPC8560ADS code since the
PCI I/O space mapping was also broken for this board (by the earlier commit
087454609e47295443af793a282cddcd91a5f49c). Add the comments clarifying how
the PCI I/O space must be mapped to all the MPC85xx board config. headers.
board/mpc8540ads/init.S | 4 ++--
board/mpc8560ads/init.S | 4 ++--
include/configs/MPC8540ADS.h | 5 ++---
include/configs/MPC8541CDS.h | 2 +-
include/configs/MPC8548CDS.h | 2 +-
include/configs/MPC8560ADS.h | 8 ++++----
6 files changed, 12 insertions(+), 13 deletions(-)
This patch disables MPC8548CDS 2T_TIMING for DDR by default.
Signed-off-by:Ebony Zhu <ebony.zhu@freescale.com>
Enable PCI function and add PEX & rapidio memory map on MPC8548CDS
board.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Signed-off-by: Detlev Zundel <dzu@denx.de>
G2 core reference manual says decrementer and time base
are decreasing/increasing once every 4 bus clock cycles.
Lets fix it, so time in Linux won't run twice as fast
Signed-off-by: Domen Puncer <domen.puncer@telargo.com>
Previous versions used full wait states for the chip select #1 which
is connected to the Xilinix SystemACE controller on the AMCC Katmai
evaluation board. This leads to really slow access and therefore low
performance. This patch now sets up the chip select a lot faster
resulting in much better read/write performance of the Linux driver.
Now 405EZ ports also show upon bootup from which boot device
they are configured to boot:
U-Boot 1.2.0-gd3832e8f-dirty (Apr 18 2007 - 07:47:05)
CPU: AMCC PowerPC 405EZ Rev. A at 199.999 MHz (PLB=133, OPB=66, EBC=66 MHz)
Bootstrap Option E - Boot ROM Location EBC (32 bits)
16 kB I-Cache 16 kB D-Cache
Board: Acadia - AMCC PPC405EZ Evaluation Board
Set up the portmux for the MMC interface and enable the MMC driver
along with support for DOS partitions, ext2 and FAT filesystems.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Driver for the Atmel MCI controller (MMC interface) for AT32AP CPUs.
The AT91 ARM-based CPUs use basically the same hardware, so it should
be possible to share this driver, but no effort has been made so far.
Hardware documentation can be found in the AT32AP7000 data sheet,
which can be downloaded from
http://www.atmel.com/dyn/products/datasheets.asp?family_id=682
Implement functions for configuring the mmci pins, as well as
functions for getting the clock rate of the mmci controller.
Implement MACB initialization for AVR32 and ATSTK1000, and turn
everything on, including the MACB driver.
Implement functions for configuring the macb0 and macb1 pins, as
well as functions for getting the clock rate of the various
busses the macb ethernet controllers are connected to.
