path: root/include
2012-01-13stdio: fix stack memory corruptionVincent Palatin
When copying the device name, the temporary target variable was twice smaller than the copy size. Create a define to ensure this won't break again. Signed-off-by: Vincent Palatin <vpalatin@chromium.org> BUG=chrome-os-partner:7188 chrome-os-partner:7430 chrome-os-partner:7432 chrome-os-partner:7559 TEST=On lumpy with usb keyboard configured, run in recovery mode, insert a bad key, press tab, remove the key, press tab. The recovery info are displayed properly. Change-Id: Ia9e765555d2f4efba81b8c389be2778cf2b92db0 Reviewed-on: https://gerrit.chromium.org/gerrit/14185 Commit-Ready: Vincent Palatin <vpalatin@chromium.org> Tested-by: Vincent Palatin <vpalatin@chromium.org> Reviewed-by: Stefan Reinauer <reinauer@chromium.org>
2012-01-11CHROMIUM: x86: Add entry in ACPI NVS table for the ME hashDuncan Laurie
BUG=chromium-os:24151 TEST=verify ME hash in the OS Change-Id: I752bdb9e7fedc3a25772ba33b00d981b9e3db4b0 Signed-off-by: Duncan Laurie <dlaurie@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/13994 Reviewed-by: Stefan Reinauer <reinauer@chromium.org>
2012-01-06Fix u-boot on x86Stefan Reinauer
This fixes the breakage introduced by https://gerrit.chromium.org/gerrit/#change,13371 BUG=none TEST=emerge-stumpy chromeos-u-boot does not fail anymore Signed-off-by: Stefan Reinauer <reinauer@google.com> Change-Id: If969ea2aab6a29d6c22053a63ef1b155d3fb42fa Reviewed-on: https://gerrit.chromium.org/gerrit/13842 Reviewed-by: David Hendricks <dhendrix@chromium.org> Tested-by: Stefan Reinauer <reinauer@chromium.org> Commit-Ready: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Duncan Laurie <dlaurie@chromium.org>
2012-01-05Track lcd wait time using bootstageSimon Glass
The intent is for LCD init to happen such that we never need to call udelay(). Add tracking that this is indeed the case, and report it with the boot time report. BUG=chromium-os:22938 TEST=build and boot on Kaen Change-Id: I78e458a6b878a4237e4e059525bae4fa47844ed9 Reviewed-on: https://gerrit.chromium.org/gerrit/13377 Commit-Ready: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2012-01-05Add bootstage timing to TPM operationsSimon Glass
Records the total time taken by TPM operations for display as part of the bootstage report. BUG=chromium-os:22938 TEST=build and boot on Kaen Change-Id: I7ce6efa3c2bb90858d17ab6613724e6ae73d918b Reviewed-on: https://gerrit.chromium.org/gerrit/13371 Commit-Ready: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2012-01-05Add bootstage accumulationSimon Glass
This adds a new type of boot timer, which records the time taken by an operation, rather than marking the instant when it occurred. This is useful to track the amount of time spent in a repeating activity during boot. To use this, call bootstage_start() at the start of the activity, then bootstage_accum() at the end, to add this segment of time to the total. You can call them (start first, then accum) as many times as you like. BUG=chromium-os:22938 TEST=build and boot on Kaen Change-Id: I3f1b536dc140c91a4a780188f6974dc37780f4f0 Reviewed-on: https://gerrit.chromium.org/gerrit/13370 Commit-Ready: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2012-01-05Add option to tftp kernel then boot from eMMCSimon Glass
The mmc0_tftpboot option reads a kernel using TFTP but then boots from eMMC. This allows kernel development without resorting to NFS root (which changes some parts of the boot process). BUG=chromium-os:22938 TEST=build and boot on Kaen Change-Id: I23c0890f76dc63dde128d7137d8891341761c884 Reviewed-on: https://gerrit.chromium.org/gerrit/13280 Commit-Ready: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2012-01-05CHROMIUM: config: Skip LCD final init for secure bootSimon Glass
The vboot command makes sure that the LCD init is completed so we don't need this in board_late_init(). Overall the LCD init optimization reduces boot time by about 150ms. BUG=chromium-os:22938 TEST=build and boot on Kaen Change-Id: Idcefb81108d0499bb208f8b3d90df65ca4cb6349 Reviewed-on: https://gerrit.chromium.org/gerrit/13206 Commit-Ready: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2012-01-05tegra: config: Enable BOARD_LATE_INIT to complete LCD initSimon Glass
LCD final init is now kept in board_late_init(), so we need to enable this feature in the config. BUG=chromium-os:22938 TEST=build and boot on Kaen Change-Id: Ib895c2768359439349714805cea6ff636c2307b3 Reviewed-on: https://gerrit.chromium.org/gerrit/13214 Commit-Ready: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2012-01-05usb: increase timeout on the control endpointVincent Palatin
Some USB keys are very slow at answering the initial GET_DESCRIPTOR or SET_ADDRESS request. I have encountered a couple of USB keys which take respectively 140ms and 230ms to send back their data packet on such a request, and thus fail with the current code. According to the USB2.0 standard 9.2.6.4, the device should answer the standard device requests (e.g. GET_DESCRIPTOR or SET_ADDRESS) in less than 500ms, so let's increase the control endpoint timeout to that value. Signed-off-by: Vincent Palatin <vpalatin@chromium.org> BUG=chrome-os-partner:7344 chrome-os-partner:7345 TEST=boot a recovery image from the 2 previously non working keys. (Lexar JUMPDRIVE TwistTurn LJDTT32GASBNA and USB M316 Aquarium Tutle) Change-Id: I00ffb11810ac538bae4622ecba7edd2388d592b2 Reviewed-on: https://gerrit.chromium.org/gerrit/13716 Reviewed-by: Stefan Reinauer <reinauer@chromium.org> Tested-by: Vincent Palatin <vpalatin@chromium.org> Commit-Ready: Vincent Palatin <vpalatin@chromium.org>
2012-01-04Do not use CONTROL_EP method of getting USB keyboard eventsPatrick Georgi
The GetReport request isn't implemented in all keyboards, so use interrupt transfers instead. BUG=chrome-os-partner:5752 TEST=Use USB keyboard in u-boot (recovery mode) Change-Id: Ided3289ef86ee9899813582c9f137526399ad2f8 Signed-off-by: Patrick Georgi <patrick@georgi-clan.de> Reviewed-on: https://gerrit.chromium.org/gerrit/13491 Reviewed-by: Vincent Palatin <vpalatin@chromium.org> Commit-Ready: Vincent Palatin <vpalatin@chromium.org> Tested-by: Vincent Palatin <vpalatin@chromium.org>
2011-12-21CHROMIUM: config: delay console init until after relocationSimon Glass
Turning on this option saves about 20ms boot time. BUG=chromium-os:22938 TEST=build and boot on Kaen Change-Id: I06ec0ae0da4afc208ca7952dfa42e725f5a67d4c Reviewed-on: https://gerrit.chromium.org/gerrit/13208 Commit-Ready: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-12-21Add CONFIG_DELAY_CONSOLE to delay console initSimon Glass
This option delays console initialization until after relocation. This can save time if this init is relatively expensive, since after relocation the CPU is often running much faster. This option should be used in conjunction with CONFIG_PRE_CONSOLE_BUFFER to ensure that all console output is buffered until the console is ready for it. This saves about 30ms boot time. BUG=chromium-os:22938 TEST=build and boot on Kaen Change-Id: I3a774b418d45e7be9338f9942df445c2c2baa528 Reviewed-on: https://gerrit.chromium.org/gerrit/13207 Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Reviewed-by: Tom Wai-Hong Tam <waihong@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Commit-Ready: Simon Glass <sjg@chromium.org>
2011-12-20Security: Make sure not to overflow the in memory version of the GBBGabe Black
This is a revised version of this patch which fixes an ARM bug. This change plumbs the size of the GBB specified in the device tree to the functions that read it from the flash into memory, and adds checks to those functions to make sure they don't spill out of the in memory GBB. From a security standpoint this is a largely theoretical problem since the GBB is in the read only portion of flash and if that can be modified the machine is totally compromised, but it's possible somehow an attacker could force vboot to read the GBB from the wrong place. From a practical perspective it's not a bad idea to check this to avoid accidental memory corruption. BUG=chromium-os:24223 TEST=Built and booted on Lumpy. Built for Kaen. Change-Id: I90d23fd6e055db595af12b1bd63d9932cbffe7ae Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: https://gerrit.chromium.org/gerrit/13279 Tested-by: Simon Glass <sjg@chromium.org> Reviewed-by: Gabe Black <gabeblack@chromium.org>
2011-12-20Revert "Security: Make sure not to overflow the in memory version of the GBB"Simon Glass
This breaks recovery mode on Kaen - the bitmaps are not displayed. This reverts commit e1153e1f56ebebff188f3693e534f10bd68e6f07 Change-Id: I300ae39382dc1960bb0375ad660a88b65181edc9 Reviewed-on: https://gerrit.chromium.org/gerrit/13274 Reviewed-by: Gabe Black (Do Not Use) <gabeblack@google.com> Commit-Ready: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-12-20USB: add device connection/disconnection detectionVincent Palatin
Provide a function to detect USB device insertion/removal in order to avoid having to do USB enumeration in a tight loop when trying to detect peripheral hotplugging. Signed-off-by: Vincent Palatin <vpalatin@chromium.org> BUG=chrome-os-partner:5752 chrome-os-partner:6344 TEST=on Lumpy, insert and remove a USB key in recovery mode. Change-Id: I18dc97d54cd909acea754fd9b3a4b7f4fc3219ec Reviewed-on: https://gerrit.chromium.org/gerrit/13249 Reviewed-by: Stefan Reinauer <reinauer@chromium.org> Tested-by: Stefan Reinauer <reinauer@chromium.org>
2011-12-20Add a new boot stage to time relocationSimon Glass
Relocation takes about 40ms of the boot time, so add a timer to track it. BUG=chromium-os:22938 TEST=build and boot on Kaen Change-Id: If936bc8ff9a23f6dd885f60e845a597ac7edad97 Reviewed-on: https://gerrit.chromium.org/gerrit/13203 Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Commit-Ready: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
This change plumbs the size of the GBB specified in the device tree to the functions that read it from the flash into memory, and adds checks to those functions to make sure they don't spill out of the in memory GBB. From a security standpoint this is a largely theoretical problem since the GBB is in the read only portion of flash and if that can be modified the machine is totally compromised, but it's possible somehow an attacker could force vboot to read the GBB from the wrong place. From a practical perspective it's not a bad idea to check this to avoid accidental memory corruption. BUG=chromium-os:24223 TEST=Built and booted on Lumpy. Built for Kaen. Change-Id: I4f33552f9d27321e73659520b08be52d775a6a9b Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: https://gerrit.chromium.org/gerrit/13228 Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Reviewed-by: Stefan Reinauer <reinauer@chromium.org> Tested-by: Gabe Black <gabeblack@chromium.org>
2011-12-16Add beep for x86 chormeos.Dylan Reid
Implement the VbExBeep function so that the DEV screen can beep. Much of this code was coppied from coreboot. BUG=chrome-os-partner:7114 TEST=manual, check that Stumpy beeps on DEV screen timeout and when booting from USB with dev_boot_usb=0. Change-Id: Icd4eabb0b10cc3d226db71e6a2b52d3ed7eb25ef Signed-off-by: Dylan Reid <dgreid@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/13110 Reviewed-by: Stefan Reinauer <reinauer@chromium.org>
2011-12-16For ChromeOS systems, don't show coreboot as BIOS vendor/versionStefan Reinauer
Instead, once we know which firmware we are actually running on, copy the FWID to the BIOS version in the SMBIOS table. BUG=chrome-os-partner:6827 TEST=Boot Stumpy, go to chrome://settings/about and see Google_Stumpy.... show up as "Firmware" Signed-off-by: Stefan Reinauer <reinauer@google.com> Also needs https://gerrit-int.chromium.org/#change,9288 Change-Id: I2e16a2fdb7fb835b0a0fbf08462d8a98b3cfe208 Reviewed-on: https://gerrit.chromium.org/gerrit/13098 Tested-by: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Duncan Laurie <dlaurie@chromium.org>
2011-12-15Don't use bogus gbb address when booting up rewriteable firmware.Vadim Bendebury
https://gerrit.chromium.org/gerrit/11152 introduced a bug where the gbb pointer used during rewriteable firmware boot is bogus. The pointer is retrieved from the 'chromeos-config' section of the device tree, but on x86 platform this memory area is never initialized. The fix is to make sure that the proper gbb address in the CPU address space is used before gbb contents are accessed. What it boils down to is that when CONFIG_HARDWARE_MAPPED_SPI is set, gbb address should be determined before setup_gbb_and_cdata() is called. To accomplish that fdt_decode_twostop_fmap() is being modified to retrieve the flash base address among other things. Calling this function before setup_gbb_and_cdata() allows to assign the gbb pointer before it is used. `google-binary-block' is not yet being removed from the cromeos-config section of the device tree as this could break some tests. BUG=chromium-os:22528 BUG=chrome-os-partner:7155 TEST=manual . build a new firmware image and program it on a Lumpy . verify that the device comes up as expected . modify the firmware to use read/write path as suggested by hungte@ cd ~/trunk/src/platform/vboot_reference/scripts/image_signing ./resign_firmwarefd.sh /build/lumpy/firmware/image.bin \ /build/lumpy/firmware/new_image.bin \ ../../tests/devkeys/firmware_data_key.vbprivk \ ../../tests/devkeys/firmware.keyblock \ ../../tests/devkeys/firmware_data_key.vbprivk \ ../../tests/devkeys/firmware.keyblock \ ../../tests/devkeys/kernel_subkey.vbpubk \ 1 0 . put new_image.bin into a lumpy flashrom . reboot the device . observe it come up, printing on the console 'vboot_twostop: jump to readwrite main firmware at 0x1110000, size 0xdffc0' along the way Change-Id: Ieeaadafdf31ee6199a6f1fce0b9684dd494a7602 Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/12969 Reviewed-by: Simon Glass <sjg@chromium.org>
2011-12-14Tegra3: Cardhu: Fix Cardhu buildTom Warren
BUG=chromium-os:23496 TEST=built and booted Cardhu to cmd prompt; USB, MMC, SPI all work. This build is to allow developers that don't have a Waluigi to still contribute to porting/upstreaming T30 U-Boot code/patches. Signed-off-by: Tom Warren <twarren@nvidia.com> Change-Id: I5978cbe33bfc9329f420c32eb5ca97b9b302029c Reviewed-on: https://gerrit.chromium.org/gerrit/12932 Reviewed-by: Simon Glass <sjg@chromium.org>
2011-12-13arm: Tegra3: enable USB supportTom Warren
BUG=chromium-os:23496 TEST=build and boot Waluigi T30. Usb detects devices OK. usb tree, usb part, ext2ls usb and ext2load usb work as expected. Signed-off-by: Tom Warren <twarren@nvidia.com> Change-Id: I40910e0c770bb33171ad9c8b4e5a6baaaac4a7df Reviewed-on: https://gerrit.chromium.org/gerrit/12392 Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Commit-Ready: Simon Glass <sjg@chromium.org>
2011-12-12CHROMIUM: Make config names consistentChe-Liang Chiou
In making config names consistent, this commit renames configs following the "chromeos_${BOARD}" naming convention. The old config names are kept before portage overlays are set to the new config names to prevent builders from break. They will be removed in next commit. BUG=chromium-os:23869 TEST=Run script snippet below successfully >>>> for BOARD in lumpy \ stumpy \ tegra2_aebl \ tegra2_arthur \ tegra2_asymptote \ tegra2_dev-board \ tegra2_dev-board-opengl \ tegra2_kaen \ tegra2_seaboard \ tegra2_wario \ waluigi \ x86-alex \ x86-alex_he \ x86-mario \ x86-mario64 do ebuild-${BOARD} /path/to/chromeos-u-boot-9999.ebuild configure done <<<< Change-Id: I984bea648f6d8384facce9771a7a5de3b169108c Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/12671 Reviewed-by: Simon Glass <sjg@chromium.org>
2011-12-12tegra: Remove CONFIG_SYS_PLLP_BASE_IS_408MHZSimon Glass
This setting is now in the fdt, so remove the CONFIG item. BUG=chromium-os:23496 TEST=build and boot on Seaboard, T33, Kaen Change-Id: I336a6cc2140c725fdda85330efe617f82f205a90 Reviewed-on: https://gerrit.chromium.org/gerrit/12250 Commit-Ready: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-12-08Make u-boot use the new PCHVadim Bendebury
New device ID range is included to allow the SPI driver to use the Panther Point based controller and a new device ID is checked when attaching the AHCI controller. BUG=chrome-os-partner:7112 TEST=manual After this change the top of the tree ChromeOS can be booted on IVB reworked Stumpy platforms. Change-Id: Ia41c17b58337cde2d041990b3d1c9da37c0cd92c Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/12606
2011-12-08config: coreboot: enable USB keyboardVincent Palatin
Enable the compilation of USB keyboard driver code and the associated polling code to detect keypress with the EHCI controller. BUG=chrome-os-partner:5752 TEST=tested on Stumpy and Lumpy, with and without usb-keyboard set in the device tree, check Ctrl+U, Ctrl+D and space are working as expected. Signed-off-by: Vincent Palatin <vpalatin@chromium.org> Change-Id: I424758ad6a30d01b5858ddaff6e4494a40e79f83 Reviewed-on: https://gerrit.chromium.org/gerrit/12582 Commit-Ready: Vincent Palatin <vpalatin@chromium.org> Tested-by: Vincent Palatin <vpalatin@chromium.org> Reviewed-by: Vincent Palatin <vpalatin@chromium.org>
2011-12-08fdt: Add function to read boolean propertyVincent Palatin
Signed-off-by: Vincent Palatin <vpalatin@chromium.org> BUG=chrome-os-partner:5752 TEST=on Lumpy, test Ctrl+D behavior with and without usb-keyboard set in the device tree. Change-Id: I7bb2f6ea18f5edadea93f9e5d23ed49ed57a3b23 Reviewed-on: https://gerrit.chromium.org/gerrit/12589 Commit-Ready: Vincent Palatin <vpalatin@chromium.org> Tested-by: Vincent Palatin <vpalatin@chromium.org> Reviewed-by: Vincent Palatin <vpalatin@chromium.org>
2011-12-07tegra: config: Remove unused CONFIG itemsSimon Glass
We don't need the default serial clock now, since we try with both options. BUG=chromium-os:23496 TEST=build and boot on Seaboard, T33, Kaen Change-Id: I68a80174e10b299c46742d36291d839ea9fa6d7c Reviewed-on: https://gerrit.chromium.org/gerrit/12249 Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Commit-Ready: Simon Glass <sjg@chromium.org>
2011-12-07tegra: fdt: add USB VBUS gpio calls to fdt_decode_usbTom Warren
BUG=chromium-os:23496 TEST=built Seaboard and Waluigi OK Signed-off-by: Tom Warren <twarren@nvidia.com> Change-Id: I9045f77032038435180b68c9a7f79c3f0cca1989 Reviewed-on: https://gerrit.chromium.org/gerrit/12391 Commit-Ready: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2011-11-30fdt: Add function to read a clock rate from fdtSimon Glass
This reads the frequency of a named clock from the fdt. BUG=chromium-os:23496 TEST=build and boot on Seaboard, T33, Kaen Change-Id: Ib35bf7ef749f51862644218b1015057ca4e25203 Reviewed-on: https://gerrit.chromium.org/gerrit/12243 Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Commit-Ready: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-11-22Revert "Remove NAND support to reduce code size"Simon Glass
This reverts commit fab63e9aacc49a3d224df47b6d0e23dc6b73de40. Change-Id: I4ce3622871374baa7da19263cbe38603b4f9e356 Reviewed-on: https://gerrit.chromium.org/gerrit/11943 Reviewed-by: Doug Anderson <dianders@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Commit-Ready: Simon Glass <sjg@chromium.org>
2011-11-18Tidy up fdt_decode_alloc_region() to make alloc separateSimon Glass
Move the malloc() out of fdt_decode_alloc_region() and rename it accordingly. This makes the code somewhat cleaner and allows us to print a sensible error message. BUG=chromium-os:17062 TEST=build and boot on Kaen Change-Id: I8edc8809baa42578e74c5e42cf47494b31b774e7 Reviewed-on: https://gerrit.chromium.org/gerrit/11878 Commit-Ready: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-11-17Remove NAND support to reduce code sizeSimon Glass
Perhaps due to a toolchain change or the recent TFTP changes, U-Boot no longer fits in the space available. This removes NAND support to give us time to expand the space and/or fix the toolchain. TBR=U-Boot suddenly grew for no immediately obvious reason, quick fix. http://build.chromium.org/p/chromiumos/builders/tegra2%20seaboard%20full/builds/924/steps/cbuildbot/logs/stdio TEST=build U-Boot and see that it is about 40KB smaller. Change-Id: Iec02cc4da57cac7e79355714000f3e5d31c326c4 Reviewed-on: https://gerrit.chromium.org/gerrit/11895 Reviewed-by: Yasuhiro Matsuda <mazda@chromium.org> Commit-Ready: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-11-17UPSTREAM: tftpput: add save_addr and save_size global variablesSimon Glass
We need something akin to load_addr to handle saving data. Signed-off-by: Simon Glass <sjg@chromium.org> (cherry picked from commit 1aec244acf9daf0d4dad80fe86b2c2b7404251d6) Change-Id: I56c586abb3e075f0ab422c833637a3160d7e2a5f Reviewed-on: https://gerrit.chromium.org/gerrit/11800 Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-11-17BACKPORT: net: tftpput: Support selecting get/put for tftpSimon Glass
TftpStart should support starting either a get or a put. (cherry-picked from 58f317d) Change-Id: Ic221520a1c7cb00536a42d3ab531efbcaba35bf6 Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/11799
2011-11-17BACKPORT: net: tftpput: Rename TFTP to TFTPGETSimon Glass
This is a better name for this protocol. Also remove the typedef to keep checkpatch happy, and move zeroing of NetBootFileXferSize a little earlier since TFTPPUT will need to change this. (cherry-picked from e4bf0c5) Change-Id: I90d03045de0231553a693f7119bdcc67a908e3c9 Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/11796
2011-11-17UPSTREAM: net: tftpput: Add support for receiving ICMP packetsSimon Glass
ICMP packets can tell you when there is no server at the other end. It is useful for tftp to figure this out, so that a quick error can be displayed, rather than pointlessly retrying. This adds an ICMP packet handler to the net interface. Signed-off-by: Simon Glass <sjg@chromium.org> (cherry picked from commit 4793ee6522f10a3d108de7e47adbcf5f15eb3f46) Change-Id: I02bbd41b3852b92b06210db160a06c62f5bf414f Reviewed-on: https://gerrit.chromium.org/gerrit/11795 Commit-Ready: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-11-16BACKPORT: Add setenv_ulong() and setenv_addr()Simon Glass
It seems we put numbers and addresses into environment variables a lot. We should have some functions to do this. (cherry picked from commit d67f10c) Change-Id: I922e72a7db872f26774459a6dc074a80016ef904 Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/11792 Reviewed-by: Doug Anderson <dianders@chromium.org>
2011-11-16UPSTREAM: Move simple_itoa to vsprintfSimon Glass
This function is generally useful and shouldn't hide away in hush. It has been moved as is. Signed-off-by: Simon Glass <sjg@chromium.org> (cherry picked from commit 3cce8a5496452285e1828984ad3945417205cfc3) Change-Id: I014f58e901e6b035b5eeb694c62e6e881a7b75c2 Reviewed-on: https://gerrit.chromium.org/gerrit/11791 Reviewed-by: Doug Anderson <dianders@chromium.org> Commit-Ready: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-11-15tegra: enable SPI on Cardhu and WaluigiChe-Liang Chiou
BUG=chromium-os:21033 TEST=run `sf erase, write` and `sf read` on Waluigi verify the data it reads from SPI flash matches that it writes to Change-Id: Ibeefd3183e4fa367d68d0035a818e1c166e6d59d Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/11473 Commit-Ready: Che-Liang Chiou <clchiou@chromium.org> Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Tested-by: Che-Liang Chiou <clchiou@chromium.org>
2011-11-15tegra: spi: add SFLASH and SLINK driversChe-Liang Chiou
BUG=chromium-os:21033 TEST=run `sf erase, write` and then `sf read` on seaboard verify the data it reads from SPI flash matches that it writes to Change-Id: I1b04afa4b54738cd93be29b70f428bdc3e6b234f Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/11472 Commit-Ready: Che-Liang Chiou <clchiou@chromium.org> Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Tested-by: Che-Liang Chiou <clchiou@chromium.org>
2011-11-13spi: rename tegra2_spi to tegra_spi in prep for tegra3Che-Liang Chiou
BUG=chromium-os:21033 TEST=build seaboard successfully Change-Id: Idbfbdbf0bdb1070f4a2b5f8205c1caff6ef0c811 Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/11471 Reviewed-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2011-11-04Introduce ability to use hardware SPI mapping for read accesses.Vadim Bendebury
On X86 systems the hardware maps the bootprom SPI flash chip into the top of memory address range. This could be used for accessing all information in the SPI flash. The vboot-reference code requires access to FMAP sections containing cryptographic information, and as of today, u-boot reads the whole sections, which are 64 KB in size, even though the actual areas accessed by vboot-reference are much smaller. A much faster way of accessing this information would be just passing around pointers to the appropriate memory areas. This would eliminate one copy, and also would make sure that only the areas actually accessed get fetched from SPI flash. This patch provides this ability trying to keep code changes to a minimum. New feature is enabled by defining CONFIG_HARDWARE_MAPPED_SPI. The firmware storage API for file reads changes when the new configuration option is set: a pointer to pointer to buffer is passed to the read_spi() function instead of a pointer to buffer. When the new feature is enabled the read_spi() function sets the pointer value to point to the requested data instead of copying the data into the buffer. A new data type is introduced (read_buf_type), which is set to be a (void *) if the new feature is not enabled, or (void **) otherwise. This type is used as the buffer pointer in the spi_read() function. Code allocating/freeing buffers used to keep data read from SPI flash is now conditionally compiled. Call sites for the spi_read() function are modified to adjust the buffer pointer parameter (pass the address of the parameter instead of the parameter, when the new feature is enabled). gbb field access functions can be aliased to gbb_init(), as they all in fact do the same - read a certain section of the gbb area. This change does not benefit the ARM implementations, and makes the code more complicated that it should be. Some u-boot rearchitecture along with vboot_reference API enhancements could address this. A tracking issue (http://code.google.com/p/chromium-os/issues/detail?id=22528) has been opened for that. BUG=chrome-os-partner:6585, chromium-os:22528 TEST=manual . build a new stumpy firmware image . boot the stumpy, observe it start up chromeos. . assess the boot timing using the cbmem.py utility (this modification shaves in excess of 100ms off the boot time). . disable the new feature, build a stumpy image, observe that is still boots chromeOs. . run emerge-terga2_kaen chromeos-u-boot to confirem that ARM version builds cleanly. Change-Id: I4e6ab530d24f5771b5a86a48d3f3135101b469a6 Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/11152
2011-11-03CHROMIUM: config: Config options to allow us to boot a kernelDoug Anderson
With this set of config options we can now boot the kernel. With the kernel I have, it doesn't work yet, but at least it prints out some messages to the UART. BUG=chromium-os:21540 TEST=If I have a reasonable kernel in MMC1, I see that it can boot quite a ways into the kernel w/ autoboot. Change-Id: I5918fff3d48f2ff9f2bac9261c84e08e60a1560a Signed-off-by: Doug Anderson <dianders@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/10675
2011-10-28CHROMIUM: waluigi: config: Turn on MMC for waluigi.Doug Anderson
BUG=chromium-os:21540 TEST=Able to use mmc. Change-Id: I1d566f08f9dd115b5be1a05ffa0ff07b508e0cee Signed-off-by: Doug Anderson <dianders@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/10663
2011-10-28Remove generic MMC support from the coreboot configGabe Black
The MMC reader looks like a USB device, so we don't need to support generic MMC devices directly. BUG=chrome-os-partner:6585 TEST=Built and booted on Stumpy. Change-Id: Id5729cd9d51e0c4cb2570b9b452f96bd23764b85 Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: https://gerrit.chromium.org/gerrit/10755 Commit-Ready: Gabe Black <gabeblack@chromium.org> Reviewed-by: Gabe Black <gabeblack@chromium.org> Tested-by: Gabe Black <gabeblack@chromium.org>
2011-10-28Add a high level option to the coreboot config to control network supportGabe Black
We aren't currently planning to have network support in production firmware. If we need it at some point, we can easily turn that support back on. BUG=chrome-os-partner:6585 TEST=Built and booted on Stumpy Change-Id: Iad265bb2bbae5360135eaa8577cc6dfde95045f9 Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: https://gerrit.chromium.org/gerrit/10754 Commit-Ready: Gabe Black <gabeblack@chromium.org> Reviewed-by: Gabe Black <gabeblack@chromium.org> Tested-by: Gabe Black <gabeblack@chromium.org>
2011-10-28Add a high level option to the coreboot config to control IDE supportGabe Black
Disable it by default since we're using the SCSI interface now. Being able to turn IDE back on later might be necessary if we haven't gotten AHCI support working on a new platform yet. BUG=chrome-os-partner:6585 TEST=Built and booted on Stumpy. Change-Id: I07e80dc2673529f3f2ec52431e1c0958511539b0 Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: https://gerrit.chromium.org/gerrit/10753 Commit-Ready: Gabe Black <gabeblack@chromium.org> Reviewed-by: Gabe Black <gabeblack@chromium.org> Tested-by: Gabe Black <gabeblack@chromium.org>
2011-10-28Refactor the coreboot config to separate out command line optionsGabe Black
Also disable those options. This way they can be enabled when needed, but when you aren't expecting to use the command line (most of the time) they can be excluded to reduce u-boot's size and load time. BUG=chrome-os-partner:6585 TEST=Built and booted on Stumpy. Change-Id: I7ea0f02a1aa3537fa4282822bbc0d4976c2b1383 Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: https://gerrit.chromium.org/gerrit/10752 Commit-Ready: Gabe Black <gabeblack@chromium.org> Reviewed-by: Gabe Black <gabeblack@chromium.org> Tested-by: Gabe Black <gabeblack@chromium.org>
