Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
FSL DIU (including DVI and LVDS) support
save the environment variable to eSDHC/eSPI
Reset the eSDHC controller first before initialize the eSDHC controller.
Including boot from eSDHC and eSPI.
This patch is from MPC8536, and fixed some hunk failed error.
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com>
Singed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
eSPI support for p1022ds
The max clock of MMC is 52MHz, and the clock mask is wrong.
Therefore, fixed them.
Signed-off-by: Jerry Huang <Changm-Ming.Huang@freescale.com>
Auto CMD12 command support for P1022DS eSDHC driver.
1. Modified the tsec_mdio structure to include the new regs
2. Modified the MDIO_BASE_ADDR so that it will handle both
older version and new version of etsec.
Signed-off-by: Sandeep Kumar <Sandeep.Kumar@freescale.com>
Moved the mdio regs out of the tsec structure,and
provided different offsets for tsec base and mdio
base so that provision for etsec2.0 can be provided.
This patch helps in providing the support for etsec2.0
In etsec2.0, the MDIO register space and the etsec reg
space are different.
Also, moved the TSEC_BASE_ADDR and MDIO_BASE_ADDR definitons into
platform specific files.
In Rev 1.0 of P1022, in the esdhc Host Capabilities register
the 1.8V bit is set; it should not be. So we exclude this
setting in the driver.
Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
On P1022, the data snoop bit (in the sata ip) is at bit 28.
Account for this. Additionally, change the mode to enterprise mode
since on reset, it is in legacy mode.
This patch adds support for P1022DS to u-boot. The following items
have been tested - DDR (spd-based), I2C, Flash, Vetsec1, 2, DIU,
PEX 1,2,3.
Neither the MVBLUE nor its underlying architecture implement the
do_irqinfo() function which is required when CONFIG_CMD_IRQ is defined.
This change fixes the following MVBLUE compiler error:
-> ./MAKEALL MVBLUE
Configuring for MVBLUE board...
common/libcommon.a(cmd_irq.o):(.u_boot_cmd+0x24): undefined reference to `do_irqinfo'
make: *** [u-boot] Error 1
Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
The support for this was silently dropped by a configuration
split during the merge of the imx27lite board support in commit
864aa034f3a0e10ce710e8bbda171df3cab59414 (cmd_mtdparts: Move to common
handling of FLASH devices via MTD layer).
Signed-off-by: Detlev Zundel <dzu@denx.de>
We are using generic implementation of ffs. This should
be part of Simon's commit 0413cfecea350000eab5e591a0965c3e3ee0ff00
Here is warning message which this patch removes.
In file included from /tmp/u-boot-microblaze/include/common.h:38,
from cmd_mtdparts.c:87:
/tmp/u-boot-microblaze/include/linux/bitops.h:123:1: warning: "ffs" redefined
In file included from /tmp/u-boot-microblaze/include/linux/bitops.h:110,
/tmp/u-boot-microblaze/include/asm/bitops.h:269:1:
warning: this is the location of the previous definition
A typo caused the stack and malloc regions to overlap, which prevented
mem_malloc_init() from returning. This commit makes the memory layout match
the example described in include/configs/microblaze-generic.h
Signed-off-by: Graeme Smecher <graeme.smecher@mail.mcgill.ca>
A bunch of the 85xx boards have this cruft in them - it's not used
anywhere. Delete it.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Signed-off-by: Remy Bohmer <linux@bohmer.net>
This patch adds a default bootargs "fbmem" value to the
CONFIG_BOOTARGS string for the MIMC200 board.
Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
This patch fixes an ugly behavior of the IL712 magnetic couplers
as used on PLU405. These parts will remember their last state
over a power cycle which might cause unwanted behavior.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This patch is in preparation for the upcoming PLU405 board fix.
Both lpd7a400 and lpd7a404 failed to compile because they had
CONFIG_SMC_USE_IOFUNCS defined:
examples/standalone/smc91111_eeprom.c:388: undefined reference to `SMC_outw'
Also removed an orphaned paren in lpd7a404.h
This patch fixes a problem only seen very occasionally on Canyonlands.
The NOR flash interface (CFI driver) doesn't work reliably in all cases.
Erasing and/or programming sometimes doesn't work. Sometimes with
an error message, like "flash not erased" when trying to program an
area that should have just been erased. And sometimes without any error
messages. As mentioned above, this problem was only seen rarely and with
some PLL configuration (CPU speed, EBC speed).
Now I spotted this problem a few times, when running my Canyonlands with
the following setup (chip_config):
1000-nor - NOR CPU:1000 PLB: 200 OPB: 100 EBC: 100
Changing the EBC configuration to not release the bus into high
impedance state inbetween the transfers (ATC, DTC and CTC bits set to 1
in EBC0_CFG) seems to fix this problem. I haven't seen any failure
anymore with this patch applied.
Cc: David Mitchell <dmitchell@amcc.com>
Cc: Jeff Mann <MannJ@embeddedplanet.com>
The asm-arm/unaligned.h includes linux/unaligned/access_ok.h
This file is unsafe to be used on ARM, since it does an unaligned memory
accesses which fails on ARM.
Lookin at Linux the basic difference seems to be the header
"include/asm-arm/unaligned.h". The Linux version of "unaligned.h"
does *not* include "access_ok.h" at all. It includes "le_byteshift.h"
and "be_byteshift.h" instead.
include/asm-arm/unaligned.h | 3 -
include/linux/unaligned/be_byteshift.h | 70 +++++++++++++++++++++++++++++++++
include/linux/unaligned/le_byteshift.h | 70 +++++++++++++++++++++++++++++++++
3 files changed, 142 insertions(+), 1 deletion(-)
create mode 100644 include/linux/unaligned/be_byteshift.h
create mode 100644 include/linux/unaligned/le_byteshift.h
commit 70ed869e broke fsl pcie end-point initialization.
Returning 0 is not correct. The function must return the first free
bus number for the next controller.
fsl_pci_init() must still be called and a bus allocated even if the
controller is an end-point.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Acked-by: Vivek Mahajan <vivek.mahajan@freescale.com>
This reverts commit 70ed869ea5f6b1d13d7b140c83ec0dcd8a127ddc.
There isn't any need to modify the API for fsl_pci_init_port to pass the
status of host/agent(end-point) status. We can determine that
internally to fsl_pci_init_port. Revert the patch that makes the API
change.
The comment for the BR0_PRELIM port size initialization incorrectly
stated 32 bit, while it's actually 16 bit. The code is correct.
Reported-by: Guenter Koellner <guenter.koellner@nsn.com>
The patch fixes a compilation warning by defining
CONFIG_SYS_64BIT_VSPRINTF in the config file
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Extend bootdelay to 10 seconds. Set boot retry time to 120 seconds and use
reset to retry. Define default bootcommand and bootargs for production.
Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com>
Currently the CFI driver issues both AMD and Intel reset commands.
This is because the driver doesn't know yet which chips are connected.
This dual reset seems to cause problems with the M29W128G chips as
reported by Richard Retanubun. This patch now introduces a weak default
function for the CFI reset command, still with both resets. This can
be overridden by a board specific version if necessary.
Cc: Richard Retanubun <RichardRetanubun@ruggedcom.com>
The editenv command can be used to edit an environment variable.
Editing an environment variable is useful when one wants to tweak an
existing variable, for example fix a typo or change the baudrate in the
'bootargs' environment variable.
Breaks building on many boards, and no really clean fix available yet.
This reverts commit 6dab6add2d8ee80905234b326abc3de11be1d178.
Simply add some defines, and adjust TLBe setup to include some
space for eLBC NAND.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
eSDHC is mutually exlusive with UART0 (in 4-bits mode) and I2C2
(in 1-bit mode). When eSDHC is used, we should switch u-boot console to
UART1, and make the proper device-tree fixups.
Because of an erratum in prototype boards it is impossible to use eSDHC
without disabling UART0 (which makes it quite easy to 'brick' the board
by simply issung 'setenv hwconfig esdhc', and not able to interact with
U-Boot anylonger).
So, but default we assume that the board is a prototype, which is a most
safe assumption. There is no way to determine board revision from a
register, so we use hwconfig.
This change has 3 goals:
- Have secondary cores be released into spin loops at their 'true'
address in SDRAM. Previously, secondary cores were put into spin
loops in the 0xfffffxxx address range which required that boot page
translation was always enabled while cores were in their spin loops.
- Allow the TLB window that the primary core uses to access the
secondary cores boot page to be placed at any address. Previously, a
TLB window at 0xfffff000 was always used to access the seconary cores'
boot page. This TLB address requirement overlapped with other
peripherals on some boards (eg XPedite5370). By default, the boot
page TLB will still use the 0xfffffxxx address range, but this can be
overridden on a board-by-board basis by defining a custom
CONFIG_BPTR_VIRT_ADDR. Note that the TLB used to map the boot page
remains in use while U-Boot executes. Previously it was only
temporarily used, then restored to its initial value.
- Allow Boot Page Translation to be disabled on bootup. Previously,
Boot Page Translation was always left enabled after secondary cores
were brought out of reset. This caused the 0xfffffxxx address range
to somewhat "magically" be translated to an address in SDRAM. Some
boards may not want this oddity in their memory map, so defining
CONFIG_MPC8xxx_DISABLE_BPTR will turn off Boot Page Translation after
the secondary cores are initialized.
These changes are only applicable to 85xx boards with CONFIG_MP defined.
Originally written by Jason Jin and Mingkai Hu for mpc8536.
When QorIQ based board is configured as a PCIe agent, then unlock/enable
inbound PCI configuration cycles and init a 4K inbound memory window;
so that a PCIe host can access the PCIe agents SDRAM at address 0x0
* Supported in fsl_pci_init_port() after adding pcie_ep as a param
* Revamped copyright in drivers/pci/fsl_pci_init.c
* Mods in 85xx based board specific pci init after this change
Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com>
