The definitons of the variable services are adjusted:
- use efi_uintn_t instead of unsigned long
- use u16 * instead of s16 * for Unicode strings
- correct definition of QueryVariableInfo
- rename efi_get_next_variable to efi_get_next_variable_name
Xilinx changes for v2018.07 second pull
zynqmp:
- Show reset reason
- Remove emulation platform
- Update pmufw version
- Simplify mmc bootmode
- Remove dc2 useless configuration file
- Cleanup mini config
- Defconfig syncup
- zcu100, zcu104 and zcu111 dts fixes
xilinx:
- Use live-tree functions in some drivers
- Add support for Avnet Minized and Antminer S9
fpga:
- Add secure bitstream loading support
mmc:
- Add hs200 mode support
usb xhci:
- Header fix
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
This patch adds support for loading secure bitstreams on ZynqMP
platforms. The secure bitstream images has to be generated using
Xilinx bootgen tool.
Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com>
This patch adds support to load secure bitstreams(authenticated or
encrypted or both). As of now, this feature is added and tested only
for xilinx bitstreams and the secure bitstream was generated using
xilinx bootgen tool, but the command is defined in more generic way.
Command example to load authenticated and device key
encrypted bitstream is as follows
"fpga loads 0 100000 2000000 0 1"
Add support for the R8A77990 Ebisu board.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Add clock tables for R8A77990 E3 SoC .
Enable MTD partitioning support on Gen2 boards with SPI NORs.
Here we do a couple of minor fixes like:
- Move .ivt section to the very beginning of the image
by default which allows us to use that image put right
at reset vector (usually 0x0)
- Improve relocation fix-up which became required once
we moved .ivt and understood a problem with existing implementation
where we relied on a particular placement of sections.
Now we don't care about placement because we just explicitly
check for .text and in case of ARCompact .ivt sections
- Re-implemnt do_reset() such that it calls reset_cpu() which
could implmented for a particular board
And hte most important part we introduce support for yet another
devboard from Synopsys - EMDK.
Synopsys DesignWare ARC EM Development Kit (ARC EMDK) is
an FPGA-based development platform from Synopsys aimed to speed-up
development of software for ARC EM cores and entire subsystems based on
ARC EM like Data Fusion, Secure and Sensor & Control subsystems.
U-Boot is supposed to be used as a primary bootloader on EMDK allowing
users to easily load and start their application from micro-SD card.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
This adds the following commits from upstream:
aadd0b65c987 checks: centralize printing of property names in failure messages
88960e398907 checks: centralize printing of node path in check_msg
f1879e1a50eb Add limited read-only support for older (V2 and V3) device tree to libfdt.
37dea76e9700 srcpos: drop special handling of tab
65893da4aee0 libfdt: overlay: Add missing license
962a45ca034d Avoid installing pylibfdt when dependencies are missing
cd6ea1b2bea6 Makefile: Split INSTALL out into INSTALL_{PROGRAM,LIB,DATA,SCRIPT}
51b3a16338df Makefile.tests: Add LIBDL make(1) variable for portability sake
333d533a8f4d Attempt to auto-detect stat(1) being used if not given proper invocation
e54388015af1 dtc: Bump version to v1.4.6
a1fe86f380cb fdtoverlay: Switch from using alloca to malloc
c8d5472de3ff tests: Improve compatibility with other platforms
c81d389a10cc checks: add chosen node checks
e671852042a7 checks: add aliases node checks
d0c44ebe3f42 checks: check for #{size,address}-cells without child nodes
18a3d84bb802 checks: add string list check for *-names properties
8fe94fd6f19f checks: add string list check
6c5730819604 checks: add a string check for 'label' property
a384191eba09 checks: fix sound-dai phandle with arg property check
b260c4f610c0 Fix ambiguous grammar for devicetree rule
fe667e382bac tests: Add some basic tests for the pci_bridge checks
7975f6422260 Fix widespread incorrect use of strneq(), replace with new strprefixeq()
fca296445eab Add strstarts() helper function
cc392f089007 tests: Check non-matching cases for fdt_node_check_compatible()
bba26a5291c8 livetree: avoid assertion of orphan phandles with overlays
c8f8194d76cc implement strnlen for systems that need it
c8b38f65fdec libfdt: Remove leading underscores from identifiers
3b62fdaebfe5 Remove leading underscores from identifiers
2d45d1c5c65e Replace FDT_VERSION() with stringify()
2e6fe5a107b5 Fix some errors in comments
b0ae9e4b0ceb tests: Correct warning in sw_tree1.c
Commit c8b38f65fdec upstream ("libfdt: Remove leading underscores from
identifiers") changed the multiple inclusion define protection, so the
kernel's libfdt_env.h needs the corresponding update.
Signed-off-by: Rob Herring <robh@kernel.org>
[ Linux commit: 9130ba884640328bb78aaa4840e5ddf06ccafb1c ]
[erosca: - Fixup conflicts in include/linux/libfdt_env.h caused by v2018.03-rc4
commit b08c8c487083 ("libfdt: move headers to <linux/libfdt.h>
and <linux/libfdt_env.h>")
- Fix build errors in lib/libfdt/fdt_ro.c, tools/libfdt/fdt_rw.c by:
- s/_fdt_mem_rsv/fdt_mem_rsv_/
- s/_fdt_offset_ptr/fdt_offset_ptr_/
- s/_fdt_check_node_offset/fdt_check_node_offset_/
- s/_fdt_check_prop_offset/fdt_check_prop_offset_/
- s/_fdt_find_add_string/fdt_find_add_string_/]
Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com>
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
This is control board on Bitmain Antminer S9.
There are 3 board variables with 256MB, 512MB and 1024MB DDR.
DDR memory is automatically detected with using get_with using
get_ram_size().
Bitmain is using 16MB space for FPGA which is handled via
reserved-memory. Also U-Boot is allocating 16B for storing bootcounts.
Watchdog is started but never service in U-Boot.
SPL MMC is working. SPL NAND is not working because it is not supported
as of now.
Signed-off-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
CMD_UNZIP is already disabled via Kconfig.
There is no reason to keep empty config file in the tree that's why
remove it.
Introduce 'oem format' which matches the USB implementation, guard this
with CONFIG_FASTBOOT_CMD_OEM_FORMAT so that you can configure it out.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Merge UDP fastboot support from AOSP:
https://android.googlesource.com/platform/external/u-boot/+/android-o-mr1-iot-preview-8
Signed-off-by: Alex Deymo <deymo@google.com>
Signed-off-by: Jocelyn Bohr <bohr@google.com>
Add fs_get_type_name so we can get the current filesystem type.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Rename fb_mmc_flash_write/fb_mmc_erase/fb_nand_flash_write/fb_nand_erase to
fastboot_... as they form a public interface
Move FASTBOOT_VERSION to include/fastboot.h so when we merge the UDP code
we only have one definition.
Rename fb_set_reboot_flag to fastboot_set_reboot_flag so it matches
all other fastboot code in the global name space. Fix the guards around
them so that they're dependent on FASTBOOT, not just USB_FUNCTION_FASTBOOT.
Move the weak implementation of fastboot_set_reboot_flag to fb_common.c
so we can call it from non-USB fastboot code.
Add drivers/fastboot/fb_common.c, where fastboot_okay/fail are implemented
so we can call them from a non-USB implementation.
Introduce fastboot_response which takes varargs parameters so we can
use it to generate formatted response strings. Refactor fastboot_okay/fail
to use it.
Add the response string as a parameter to fastboot_okay/fail, instead
of modifying a global, to match the contract expected by the AOSP
U-Boot code.
Android documentation defines the recommended image format for storing
DTB/DTBO files in a single dtbo.img image. This patch includes the
latest header file with the struct definitions for this format from
AOSP.
The header was adapted to U-Boot's coding style and the function
declarations were removed.
[trini: Change SDPX tag location]
This was being used by some Marvell boards to enable some file system
related features (many of which have already been moved to Kconfig).
Make the future migration of the final 2 or 3 config options easier by
expanding #define CONFIG_SYS_MVFS into the options that it enables and
remove CONFIG_SYS_MVFS.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
Enable cfi flash driver and setup flash
parameters to support parallel nor flash
which type is JS28F00A-M29EWH.
Verification:
Size detection, data read, erase and write are all ok.
Signed-off-by: Rick Chen <rick@andestech.com>
Signed-off-by: Rick Chen <rickchen36@gmail.com>
Cc: Greentime Hu <green.hu@gmail.com>
Rename
nx25 as ax25
ae250 as ae350
nx25-ae250 as ax25-ae350
including filename, variable, string and definition.
Distro boot allows for a common boot path on systems that allow distributions
to easily boot from a default configuration.
This patch enables distro boot for the nx25-ae250. Hopefully this can serve
as a good example for new boards, so they enable it as well.
While we don't have UEFI naming conventions for RISC-V file paths yet,
we need to search for something. So let's copy the removable file paths
from the RISC-V edk2 port.
Also add the official VCI strings that contain the standardized RISC-V
architecture ID fields.
We were using our EFI_CACHELINE_SIZE define only in the runtime service
code, but left the image loader to use plain CONFIG_SYS_CACHELINE_SIZE.
This patch moves EFI_CACHELINE_SIZE into efi_loader.h and converts
the image loader to use it.
mv-common.h and mv-plug-common.h still had comments delimiting sections
of configuration options that have all been moved to Kconfig by previous
treewide efforts. Remove the redundant comment sections.
The last option guarded by this ifdef was removed in commit 68d534201733
("sf: Move SPI flash drivers to defconfig"). Remove the now empty
ifdef/endif block and the associated comment.
Import the dts files from Linux 4.17 and enable CONFIG_OF_CONTROL.
Add FIT data-position & data-offset property support for bootm,
which were already supported in SPL.
Signed-off-by: Kelvin Cheung <keguang.zhang@gmail.com>
Implements serial setparity ops to allow uart parity change.
It allows to select ODD, EVEN or NONE parity.
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
- adds reading FMC swap setting from DTB to SDRAM driver
- sets FMC swap for stm32f429-disco board
- changes ram start address to 0x90000000
Signed-off-by: Radoslaw Pietrzyk <radoslaw.pietrzyk@gmail.com>
Acked-by: Patrice Chotard <patrice.chotard@st.com>
This patch adds pinmux and pinctrl driver for TLMM
subsystem in snapdragon chipsets.
Currently, supporting only 8016, but implementation is
generic and 8096 can be added easily.
Driver is using the generic dt-bindings and doesn't
introduce any new bindings (yet).
Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
Add a doc comment for pciauto_region_allocate().
Currently, if we happen to allocate an address requiring 64 bits to a
device only supporting 32-bit BARs, the address eventually gets silently
truncated to 32 bits. Avoid this by adding a new flag to
pciauto_region_allocate() to bail out in such situations.
Add support for the TPM2_PCR_SetAuthPolicy and
TPM2_PCR_SetAuthValue commands.
Change the command file and the help accordingly.
Note: These commands could not be tested because the TPMs available
do not support them, however they could be useful for someone else.
The user is warned by the command help.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Add support for the TPM2_HierarchyChangeAuth command.
Add support for the TPM2_DictionaryAttackParameters and
TPM2_DictionaryAttackLockReset commands.
Add support for the TPM2_GetCapability command.
Add support for the TPM2_PCR_Read command.
Add support for the TPM2_PCR_Extend command.
