This adds support for the AT91SAM9G20-EK board in the mainline U-Boot.
Signed-off-by: Justin Waters <justin.waters@timesys.com>
The AT91RM9200-EK board is very similar to the AT91RM9200-DK board. This
adds support for it against the mainline u-boot.
Set the MQ Read Passing & MCIF Cycle limits to the recommended by AMCC
values. This fixes the occasional 440SPe hard locking issues when the 440SPe's
dedicated DMA engines are used (e.g. by the h/w accelerated RAID driver).
Previously the appropriate initialization had been made in Linux, by the
ppc440spe ADMA driver, which is wrong because modifying the MQ configuration
registers after normal operation has begun is not supported and could
have unpredictable results.
Comment from Stefan: This patch doesn't change the resulting value of the
MQ registers. It explicitly sets/clears all bits to the desired state which
better documents the resulting register value instead of relying on pre-set
default values.
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
The MPC8544 RM incorrect shows the SEC_CFG bit in PORDEVSR2 as being
bit 26, instead it should be bit 28. This caused in incorrect
interpretation of the i2c_clk which is the same as the SEC clk on
MPC8544. The SEC clk is controlled by cfg_sec_freq that is reported
in PORDEVSR2.
Currently this is not creating any problem. But it will result
in compilation error when used as below.
printf("CFG_SDRAM_CFG2 - %08x\n", CFG_SDRAM_CFG2);
Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com>
continuation of the theme based on git grep "^#define CFG_.*;$" include/
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Commit 445a7b38308eb05b41de74165b20855db58c7ee5 introduced the following
compile warnings:
cmd_i2c.c:112: warning: missing braces around initializer
cmd_i2c.c:112: warning: (near initialization for 'i2c_no_probes[0]')
Switch to the standard CFG_HZ=1000 value, while at it, minor white-space
cleanup, remove CFG_CLKS_IN_HZ from config-headers. Tested on mx31ads,
provides 2% or 0.4% precision depending on the
CONFIG_MX31_TIMER_HIGH_PRECISION flag. Measured with stop-watch on 100s
boot-delay.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
The ID EEPROM on MPC8572DS board locates on I2C bus 1. Its the storage for
system information like mac addresses etc. This patch enables it.
MPC8572DS has two i2c buses. This patch moves the DDR SPD_EEPROM to i2c bus 1
according to the board spec, and adds the 2nd i2c bus offset.
On 8536DS board, When the DDR clk is set async mode(SW3[6:8] != 111),
The display is still sync mode DDR freq. This patch try to fix
this. The display DDR freq is now the actual freq in both
sync and async mode.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Oops, screwed up the function name in the documenting comment for this
function. Trivial correction in this patch.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Acked-by: Gerald Van Baren <vanbaren@cideas.com>
Kumar has already added alias expansion to fdt_path_offset().
However, in some circumstances it may be convenient for the user of
libfdt to explicitly get the string expansion of an alias. This patch
adds a function to do this, fdt_get_alias(), and uses it to implement
fdt_path_offset().
Using Gcc 4.3 detected this problem:
../dtc/libfdt/fdt.c: In function 'fdt_next_tag':
../dtc/libfdt/fdt.c:82: error: assuming signed overflow does not
occur when assuming that (X + c) < X is always false
To fix the problem, treat the offset as an unsigned int.
The problem report and proposed fix were provided
by Steve Papacharalambous <stevep@freescale.com>.
bootdelay set to -1 'permanently' disables autobooting, even if
bootcmd is specified. Change to a positive value to allow
autobooting when a bootcmd is set.
Reported-by: Coray Tate <Coray.Tate@freescale.com>
Cc: Scott Wood <scottwood@freescale.com>
Fixed typo from CONIFG_MPC837X to CONFIG_MPC837X
the operating system may leave flash in a h/w locked state after writing.
This allows u-boot to continue to write flash by enabling h/w unlocking
by default.
A few Spartan-3 definitions erroneously use Spartan-3E size
constants. This patch fixes them.
Signed-off-by: Laurent Pinchart <laurentp@cse-semaphore.com>
Running mtest command on socrates without specifying
an address range crashes the board. This patch changes
default mtest address range to prevent this behavior.
Commit be0bd8234b9777ecd63c4c686f72af070d886517
changed SPD EEPROM address to 0x51 and DDR SDRAM
detection stopped working. Change this address
back to 0x50.
After switching to using the CFI flash driver, the correct remapping
of the flash banks was forgotten.
Also, some boards were not adapted, and the old legacy flash driver
was not removed yet.
Signed-off-by: Detlev Zundel <dzu@denx.de>
Commit 2a1a2cb6 didnt remove the dummy mem reservation in fdt_chosen,
and this stopped Linux from booting with a Ramdisk. This patch fixes
this, by deleting the useless dummy mem reservation.
When booting with a Ramdisk, a fix offset FDT_RAMDISK_OVERHEAD is now
added to of_size, so we dont need anymore a dummy mem reservation.
I measured the value of FDT_RAMDISK_OVERHEAD on a MPC8270 based
system (=0x44 bytes) and rounded it up to 0x80).
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com>
This patch fixes a problem introdiced with patch
bbeff30c [ppc4xx: Remove superfluous dram_init() call or replace it by
initdram()].
The boards affected are:
- PCI405
- PPChameleonEVB
- quad100hd
- taihu
- zeus
omap730.h
- Correct Invalid #define of MPUTIM_PTV_MASK for
omap1510 & omap730 register definition
MPUTIM_PTV_MASK is defined as
#define MPUTIM_PTV_MASK (0x7<<PTV_BIT)
while it should have been
#define MPUTIM_PTV_MASK (0x7<<MPUTIM_PTV_BIT)
- Below Patch corrects the same
Signed-off-by: Gururaja Hebbar <gururajakr@sanyo.co.in>
The i.MX31 has three SPI buses and each bus has several chip selects
and the MC13783 chip can be connected to any of these. The current
RTC driver for MC13783 is hardcoded for CSPI2/SS2.
This patch makes make MC13783 SPI bus and chip select configurable
via CONFIG_MC13783_SPI_BUS and CONFIG_MC13783_SPI_CS.
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
add CMD_DATA_SIZE macro to enable it
