path: root/include
2007-04-14AVR32: Enable networkingHaavard Skinnemoen
Implement MACB initialization for AVR32 and ATSTK1000, and turn everything on, including the MACB driver. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Add clk and gpio infrastructure for macb0 and macb1Haavard Skinnemoen
Implement functions for configuring the macb0 and macb1 pins, as well as functions for getting the clock rate of the various busses the macb ethernet controllers are connected to. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14Import <linux/mii.h> from the Linux kernelHaavard Skinnemoen
Instead of creating yet another set of MII register definitions in the macb driver, here's a complete set of definitions for everyone to use. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Include more commands for ATSTK1000Haavard Skinnemoen
Include the imi, imls and jffs commands sets by default on ATSTK1000. Also define CONFIG_BOOTARGS to something more useful, define CONFIG_BOOTCOMMAND and enable autoboot by default. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Provide a definition of struct statHaavard Skinnemoen
Copy the definition of struct stat from the Linux kernel. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Use initdram() instead of board_init_memories()Haavard Skinnemoen
Conform to the "standard" interface and use initdram() instead of board_init_memories() on AVR32. This enables us to get rid of the sdram_size member of the global_data struct as well. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Relocate u-boot to SDRAMHaavard Skinnemoen
Relocate the u-boot image into SDRAM like everyone else does. This means that we can handle much larger .data and .bss than we used to. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Resource management rewriteHaavard Skinnemoen
Rewrite the resource management code (i.e. I/O memory, clock gating, gpio) so it doesn't depend on any global state. This is necessary because this code is heavily used before relocation to RAM, so we can't write to any global variables. As an added bonus, this makes u-boot's memory footprint a bit smaller, although some functionality has been left out; all clocks are enabled all the time, and there's no checking for gpio line conflicts. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Clean up memory-map.h for at32ap7000Haavard Skinnemoen
Convert spaces to tabs (must have missed this one last time around), sort the entries by address and group them together by bus connectivity. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-11Update for SC3 boardWolfgang Denk
* Make IDE timeout configurable through ide_reset_timeout variable. * Use Newline as "password" string * Use just a single partition in NAND flash
2007-04-04Merge with /home/wd/git/u-boot/custodian/u-boot-ppc4xxWolfgang Denk
2007-04-04Minor coding style cleanup.Wolfgang Denk
2007-04-04Merge with /home/wd/git/u-boot/custodian/u-boot-microblazeWolfgang Denk
2007-04-04Minor cleanup.Wolfgang Denk
2007-03-31Add a flattened device tree (fdt) command (2 of 2)Gerald Van Baren
Modifications to the existing code to support the new fdt command.
2007-03-31libfdt: Enhanced and published fdt_next_tag()Gerald Van Baren
Enhanced the formerly private function _fdt_next_tag() to allow stepping through the tree, used to produce a human-readable dump, and made it part of the published interface. Also added some comments.
2007-03-31libfdt: Customizations for use by u-boot.Gerald Van Baren
Changes to David Gibson's original source to fit into u-boot's environment. No functionality changes.
2007-03-31libfdt: Import libfdt source (1 of 2)Gerald Van Baren
This adds the applicable libfdt source files (unmodified) and a README to explain where the source came from.
2007-03-31Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-03-31ppc4xx: Change Yucca config file to support ECCStefan Roese
With the updated 44x DDR2 driver the Yucca board now supports ECC generation and checking. Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-30[CLEAN] Remove inefficient Suzaku codeMichal Simek
2007-03-29Merge with /home/wd/git/u-boot/custodian/u-boot-mpc86xxWolfgang Denk
2007-03-28Merge some AMCC make targets to keep the top-level Makefile smallerStefan Roese
2007-03-26Support for XUPV2P boardMichal Simek
Reset support BSP autoconfig support
2007-03-24Merge with /home/stefan/git/u-boot/acadiaStefan Roese
2007-03-24[PATCH] Add 4xx GPIO functionsStefan Roese
This patch adds some 4xx GPIO functions. It also moves some of the common code and defines into a common 4xx GPIO header file. Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-24[PATCH] Small Sequoia cleanupStefan Roese
2007-03-24[PATCH] Clean up 40EZ/Acadia supportStefan Roese
This patch cleans up all the open issue of the preliminary Acadia support. Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-22Set Rev 2.x 86xx PIC in mixed mode.Haiying Wang
Prevent false interrupt from hanging Linux as MSR[EE] is set to enable interrupts by changing the PIC out of the default pass through mode into mixed mode. Signed-off-by: Haiying Wang <haiying.wang@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-03-22Add flash cmd function to 8641HPCN rambootJason Jin
Also fixes some commmand for 8641 HPCN ramboot case. Signed-off-by: Jason Jin <jason.jin@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-03-22Merge with /home/wd/git/u-boot/custodian/u-boot-blackfinWolfgang Denk
2007-03-21Merge with /home/wd/git/u-boot/custodian/u-boot-ppc4xxWolfgang Denk
2007-03-21ppc4xx: Fix file mode of include/configs/acadia.hStefan Roese
2007-03-21Merge with /home/stefan/git/u-boot/acadiaStefan Roese
2007-03-21[PATCH] Add AMCC Acadia (405EZ) eval board supportStefan Roese
This patch adds support for the new AMCC Acadia eval board. Please note that this Acadia/405EZ support is still in a beta stage. Still lot's of cleanup needed but we need a preliminary release now. Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-21[PATCH] Add AMCC PPC405EZ supportStefan Roese
This patch adds support for the new AMCC 405EZ PPC. It is in preparation for the AMCC Acadia board support. Please note that this Acadia/405EZ support is still in a beta stage. Still lot's of cleanup needed but we need a preliminary release now. Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-20Merge http://www.denx.de/git/u-bootAubrey Li
2007-03-20[Blackfin][PATCH] Add BF561 EZKIT board supportAubrey Li
2007-03-19Merge http://www.denx.de/git/u-bootAubrey Li
2007-03-19[PATCH] Add flash chip M29W320ET/B supportAubrey Li
2007-03-19[Blackfin][PATCH] Add BF537 stamp board supportAubrey Li
2007-03-16Merge with /home/wd/git/u-boot/custodian/u-boot-ppc4xxWolfgang Denk
2007-03-16[PATCH] Use dynamic SDRAM TLB setup on AMCC Ebony eval boardStefan Roese
Define CONFIG_PROG_SDRAM_TLB so that the TLB entries for the DDR memory are dynamically programmed matching the total size of the equipped memory (DIMM modules). Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-14[PATCH] renamed environment variable 'addcon' to 'addcons' for PCI405Matthias Fuchs
boards in terms of unification. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-03-13Make SC3 board build with 'make O='; use 'addcons' consistentlyWolfgang Denk
(SC3 and Jupiter used to use 'addcon' instead). Signed-off-by: Wolfgang Denk wd@denx.de
2007-03-13Merge with /home/hs/jupiter/u-bootWolfgang Denk
2007-03-13[PATCH] update board config for jupiter Board:Heiko Schocher
added Hush Shell, CONFIG_CMDLINE_EDITING, CFG_ENV_ADDR_REDUND activated Signed-off-by: Heiko Schocher <hs@denx.de>
2007-03-12[Blackfin][PATCH] minor cleanupAubrey Li
2007-03-12[Blackfin][PATCH] code cleanupAubrey Li
2007-03-11[Microblaze][PATCH]Michal Simek
timer support interrupt controller support flash support ethernet support cache support board information support env support booting image support adding support for Xilinx ML401
