path: root/include
2017-09-03include/configs: remove numerous CONFIG_SYS_BARGSIZE definitionsThomas Petazzoni
This commit removes definitions of CONFIG_SYS_BARGSIZE defined to be equal to CONFIG_SYS_CBSIZE in numerous configuration files. We remove such definitions in two situations: - CONFIG_SYS_CBSIZE is otherwise not defined in the board configuration file, which means the default value of CONFIG_SYS_CBSIZE == 256 applies. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common/image.c) is suitable, as it is larger. - CONFIG_SYS_CBSIZE is defined in the board configuration file, but to a value equal or less than 512. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common.image.c) is suitable, as it is equal or larger. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove default values of CONFIG_SYS_BARGSIZEThomas Petazzoni
CONFIG_SYS_BARGSIZE is already defined to 512 in common/image.c when not defined. Therefore, there is no point in having board configuration files define it to 512. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/config_fallbacks.h: add default for CONFIG_SYS_MAXARGSThomas Petazzoni
CONFIG_SYS_MAXARGS contains the maximum number of arguments accepted by U-Boot commands. Since the vast majority of the platforms define it to 16, it makes sense to have a default definition to 16, which will allow to remove this definition from a significant number of platforms. It will allow to remove the default definition from 216 platform .h files, leaving only 56 platforms with non-default values (15, 24, 32, 48, 64, 96, 128 or 256). Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/config_fallbacks.h: change fallback for CONFIG_SYS_PBSIZEThomas Petazzoni
Most of the platforms are using CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16 as their value for CONFIG_SYS_PBSIZE, so let's adopt this for the fallback value of CONFIG_SYS_PBSIZE. This will allow us to drop an explicit definition of CONFIG_SYS_PBSIZE from a large number of platforms. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove CONFIG_SYS_CBSIZE when the default value is usedThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Drop <config.h> from stih410-b2260.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-03include/config_fallbacks.h: add default for CONFIG_SYS_CBSIZEThomas Petazzoni
CONFIG_SYS_CBSIZE contains the buffer size for input for the console. The vast majority of platforms define them to some reasonable value (256, 512 or 1024 bytes), and it is quite annoying to repeat this definition for all platforms while it isn't really HW-related. Therefore, let's provide a sane fallback value in config_fallbacks.h, so that platforms can rely on it instead of having to explicitly define it. We use 1024 when KGDB is enabled, and 256 otherwise, which is what the majority of the platforms are doing. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03part: efi: make gpt_fill_pte take the device descriptorMaxime Ripard
The gpt_fill_pte will need to access the device block size. Let's pass the device descriptor as an argument. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-02Merge git://git.denx.de/u-boot-x86Tom Rini
2017-09-02Kconfig: Add EEPROM options to Kconfig when I2C_EEPROM is setAdam Ford
Add the following options to drivers/misc/Kconfig: SYS_I2C_EEPROM_ADDR SYS_I2C_EEPROM_BUS SYS_EEPROM_SIZE SYS_EEPROM_PAGE_WRITE_BITS SYS_EEPROM_PAGE_WRITE_DELAY_MS SYS_I2C_EEPROM_ADDR_LEN SYS_I2C_EEPROM_ADDR_OVERFLOW This does not migrate any boards, but provides a foundations for those who want/need these options Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Migrate uniphier] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-02x86: theadorable-x86-common: Remove "ip=dhcp" from default environmentStefan Roese
Without ethernet cable plugged, "ip=dhcp" leads to a complete hangup in Linux booting and the system does not boot into userland at all. Since its not required to have an active network connection on these board, lets remove this statement from the default environment. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-02omap3_logic: Move CONFIG_SYS_NAND_U_BOOT_OFFS to KconfigAdam Ford
Manually enable SYS_NAND_U_BOOT_LOCATIONS. Set CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 and remove it from header Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-01Convert CONFIG_BCH to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_BCH Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-01Convert CONFIG_SPL_OMAP3_ID_NAND to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SPL_OMAP3_ID_NAND Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-01Convert CONFIG_SYS_I2C_BUS_MAX to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_I2C_BUS_MAX Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> [trini: Fix AM43XX drop AM44XX] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-01Configs: Migrate I2C_BUS_MAX to CONFIG_SYS_I2C_BUS_MAXAdam Ford
For consistency with other platforms and in preparation of Kconfig migration, let's change Several TI platforms that use I2C_BUS_MAX to CONFIG_SYS_I2C_BUS_MAX Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-01Kconfig: Migrate all of cmd/fastboot/Kconfig to defconfigsTom Rini
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's not strictly part of fastboot. - Add some defaults for the fastboot buffer location and size - Migrate all options listed in cmd/fastboot/Kconfig - Cleanup the README Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-01Merge git://git.denx.de/u-boot-sunxiTom Rini
2017-09-01sunxi: Fix CONFIG_SUNXI_GMAC referencesDave Prue
SUNXI_GMAC was still used to configure the code where as the same has been renamed and moved to Kconfig in below commit "sunxi: Move SUNXI_GMAC to Kconfig" (sha1: 4d43d065db3262f9a9918ba72457bf36dfb8e0bb) Signed-off-by: Dave Prue <dave@prue.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Mark Kettenis <kettenis@openbsd.org> Tested-by: Mark Kettenis <kettenis@openbsd.org> [Tweek commit message, config_whitelist.txt, build-whitelist.sh] Signed-off-by: Jagan Teki <jagan@openedev.com>
2017-09-01Merge git://git.denx.de/u-boot-imxTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: configs/imx6qdl_icore_mmc_defconfig configs/imx6qdl_icore_rqs_defconfig
2017-09-01Merge git://git.denx.de/u-boot-uniphierTom Rini
- add {ofnode,dev}_read_resource_byname - provide DT probe hook to Denali NAND driver - update clk/reset driver - update DT - misc cleanups
2017-08-30i.MX6Q: icorem6: Add falcon modeJagan Teki
Add Falcon mode support in Engicam i.CoreM6 board. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-08-30ARM: uniphier: remove unneeded NAND config optionsMasahiro Yamada
CONFIG_NAND_DENALI select's CONFIG_SYS_NAND_SELF_INIT, so the NAND initialization process is driven by the driver itself. CONFIG_SYS_NAND_MAX_CHIPS and CONFIG_SYS_NAND_BASE are unused. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-08-29ofnode: add {ofnode, dev}_read_resource_byname()Masahiro Yamada
Linux supports platform_get_resource_byname() to look up a resource by name. We want a similar helper. It is useful when a device node has named register regions. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-28nvme: Adjust the 'nvme' command to use blk_common_cmd()Bin Meng
Instead of having separate code in the 'nvme' command, adjust it to use the common function. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-26Merge git://git.denx.de/u-boot-x86Tom Rini
2017-08-26Merge git://www.denx.de/git/u-boot-cfi-flashTom Rini
2017-08-26igep00x0: merge igep0020 and igep0030 defconfigs to igep00x0_defconfigPau Pajuelo
Update igep00x0 code with the following features: - Add board and revision detection for the boards: - IGEP0020-RF - IGEP0020-RC - IGEP0030-RG - IGEP0030-RE - Merge IGEP0020 and IGEP0030 mux tables - Add suport to use GPIO_126, GPIO_127 and GPIO_129 - board_name and board_rev environment variables display board and revision informations - Move dtb name selection from code to boot script Signed-off-by: Pau Pajuelo <ppajuel@gmail.com> Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Tested-by: Pau Pajuelo <ppajuel@gmail.com>
2017-08-26arm: omap: Define command for booting Android from eMMCSemen Protsenko
If SD card is present -- try to boot from it first. If no -- try to boot Android from eMMC. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2017-08-24serial: serial-uclass: Add generic serial RX buffer supportStefan Roese
Pasting longer lines into the U-Boot console prompt sometimes leads to characters missing. One problem here is the small 16-byte FIFO of the legacy NS16550 UART, e.g. on x86 platforms. This patch now introduces a Kconfig option to enable RX buffer support for all DM based serial drivers. With this option enabled, I was able paste really long lines into the U-Boot console, without any characters missing. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-24Revert "serial: ns16550: Add RX interrupt buffer support"Stefan Roese
This reverts commit 6822cf3ec7c8768b8727573b8f4b2cb3d870b881. As Bin Meng has tested and pointed out, we don't need the RX interrupt for the RX buffer support at all. Just reading all available characters into a buffer is sufficient to solve the problem with the dropped characters upon long lines pasted into the U-Boot prompt. Since this RX buffer support can be implemented in a generic way, without any device specifica (e.g. for the ns16550), I'll post a new patch with a new serial RX buffer support for DM, which all DM based serial drivers can use. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-24vbe: Drop vbe_get_video_info()Bin Meng
With DM video, this is not used any more. Drop it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-23usb: gadget: add SDP driverStefan Agner
Add SDP (Serial Downloader Protocol) implementation for U-Boot. The protocol is used in NXP SoC's boot ROM and allows to download program images. Beside that, it can also be used to read/write registers and download complete Device Configuration Data (DCD) sets. This basic implementation supports downloading images with the imx header format reading and writing registers. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Łukasz Majewski <lukma@denx.de>
2017-08-23imx: move imximage header to common locationStefan Agner
Move the imximage.h header file to a common location so we can make use of it from U-Boot too. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Łukasz Majewski <lukma@denx.de>
2017-08-22mtd: cfi: staticize functionsMarek Vasut
Staticize a few functions and variables which are no longer exposed. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2017-08-21Merge git://git.denx.de/u-boot-usbTom Rini
2017-08-21usb: ehci: Convert CONFIG_USB_EHCI_PCI to KconfigBin Meng
This converts CONFIG_USB_EHCI_PCI to a Kconfig option, and updates all boards that use it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-20ARM: uniphier: remove sLD3 SoC supportMasahiro Yamada
This SoC is too old. It is difficult to maintain any longer. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-08-18Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
EFI Fixes for 2017.09: - Fix GOP w/o display - Fix LocateHandle - Fix exit return value truncation - Fix missing EFIAPI in efi_locate_handle (for x86)
2017-08-18Merge branch 'master' of git://git.denx.de/u-boot-mmcTom Rini
2017-08-18efi_loader: do not cast return value in EFI_EXITxypron.glpk@gmx.de
UEFI API functions have different return types. Some return a value of type EFI_STATUS other don't. We therefore should not cast the return value of EFI_EXIT to another type than the expression passed to EFI_EXIT. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-08-18m68k: add board stmark2, mcf5441x basedAngelo Dureghello
Sysam stmark2 board is a generic and fully (hw and sw) open board, with a mcf54415 Coldfire CPU, 128MB of DDR2, 16MB of SPI flash and SD card as non volatile memories, and a wifi module included on-board. The board is actually used mainly for Coldfire custodian testing activity related to the mcf5441x Coldfire family. For further information please see: http://sysam.it/cff_stmark2.html Signed-off-by: Angelo Dureghello <angelo@sysam.it> --- Changes in v2: - remove CMD_REGINFO - add board information in commit message
2017-08-18m68k: mcf5445x: move early ddr init as board-specificAngelo Dureghello
For certain boot types and sbf, for V4 cpu's, an early ddr/sdram init is required. This patch moves this ddr/sdram early initalization away from start.S (to be board related). Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2017-08-17cmd: mmc: add mmc partconf read capabilityAngelo Dureghello
This patch allows to show the EXT_CSD[179] partition_config register info, just by specifying the dev param: U-Boot> mmc partconf 0 EXT_CSD[179], PARTITION_CONFIG: BOOT_ACK: 0x0 BOOT_PARTITION_ENABLE: 0x0 PARTITION_ACCESS: 0x0 Signed-off-by: Angelo Dureghello <angelo@sysam.it> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2017-08-17dm: mmc: Drop CONFIG_DM_MMC_OPSSimon Glass
All boards which use DM_MMC have now been converted to use DM_MMC_OPS. Drop the option and good riddance. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-17dm: sata: dwc_ahsata: Add support for driver modelSimon Glass
Update this driver to support driver model. This involves implementing the AHCI operations and reusing existing common code. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-17dm: sata: Update the AHCI uclass to support operationsSimon Glass
At present the AHCI uclass is just a shell and we still use the global functions to access SATA. Fix this by adding operations to the uclass. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-17dm: sata: Support driver model with the 'sata' commandSimon Glass
Update this command to support driver model. This has a different way of starting and stopping SATA. Signed-off-by: Simon Glass <sjg@chromium.org>
