Add CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG support and enable it to set
'board_rev' and 'board_name' envs.
'board_rev' can be used in scripts to determine what board we are running on
and 'board_name' for pretty printing.
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
For current U-Boot to initialize status LEDs via status_led_init(), it
is required to have both CONFIG_STATUS_LED and STATUS_LED_BOOT defined.
This may be a particular concern with GPIO LEDs, where __led_init() is
required to correctly set up the GPIO (gpio_request and
gpio_direction_output). Without STATUS_LED_BOOT the initialization isn't
called, which could leave the user with a non-functional "led" command -
due to the fact that the LED routines in gpio_led.c use gpio_set_value()
just fine, but the GPIO never got set up properly in the first place.
I think having CONFIG_STATUS_LED is sufficient to justify a
corresponding call to status_led_init(), even with no STATUS_LED_BOOT
defined. To do so, common/board_r.c needs call that routine, so it now
is exposed via status_led.h.
Signed-off-by: Bernhard Nortmann <bernhard.nortmann@web.de>
[trini: Add dummy __led_init to pca9551_led.c]
Convert altera_tse to driver model and phylib.
As we use device tree to control u-boot now, the generic
board can be removed.
Convert altera sysid to driver model with misc uclass.
Acked-by: Chin Liang See <clsee@altera.com>
Implement a Miscellaneous uclass with generic read or
write operations. This class is used only for those
do not fit other more general classes.
Both altera_jtag_serial_initialize() and
altera_serial_initialize() are no longer used after
they are converted to driver model.
Convert altera timer to driver model.
Implement a Timer uclass to work with lib/time.c.
Convert altera_pio to driver model.
Convert altera_uart to driver model.
Convert altera_jtag_uart to driver model.
Move the timer code from interrupts.c into timer.c . Eliminate the
installation of timer interrupt handler, which is no longer used.
Zap almost all of the ad-hoc timer code from interrupts.c and
use the code in lib/time.c instead.
As altera_pio_init() uses BSS, it should be moved to
board_early_init_r().
This patch moves command line configuration from board header
file to board defconfig in the way of Kconfig. The change passed
savedefconfig.
This fixes warnings such as : "CONFIG_SYS_HUSH_PARSER" redefined,
when "Use hush shell" is selected with menuconfig, etc.
Since spl doesn't support DM currently, do not define DM_MMC
for spl build.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
asdfsadf
Import various DT files for am4372, an43xx pinctrl and
am437x-gp-evm from Linux Kernel v4.2
Add config file for this board, enable DM, DM_GPIO, DM_SERIAL
and DM_MMC.
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
for spl build.
Tested on am437x gp evm and am437x sk evm
for spl build.
Add config file for k2g
Signed-off-by: Vitaly Andrianov <vitalya@ti.com>
Add clock information for Galileo
Import k2hk specific DT files from Linux Kernel and enable
OF_CONTROL, DM, DM_SERIAL.
If CONFIG_SYS_MALLOC_F_LEN is enabled, the stack is moved down to the
specified size to make the malloc function available before relocation.
But on keystone platforms SYS_SPL_MALLOC is immediately preceding stack,
which is causing an overlap with this config enabled.
So leave a gap between malloc space and stack space.
Tested on J6Eco EVM
Tested on Pandaboard
Many System on Chip(SoC) solutions are complex with multiple processors
on the same die dedicated to either general purpose of specialized
functions. Many examples do exist in today's SoCs from various vendors.
Typical examples are micro controllers such as an ARM M3/M0 doing a
offload of specific function such as event integration or power
management or controlling camera etc.
Traditionally, the responsibility of loading up such a processor with a
firmware and communication has been with a High Level Operating
System(HLOS) such as Linux. However, there exists classes of products
where Linux would need to expect services from such a processor or the
delay of Linux and operating system being able to load up such a
firmware is unacceptable.
To address these needs, we need some minimal capability to load such a
system and ensure it is started prior to an Operating System(Linux or
any other) is started up.
NOTE: This is NOT meant to be a solve-all solution, instead, it tries to
address certain class of SoCs and products that need such a solution.
A very simple model is introduced here as part of the initial support
that supports microcontrollers with internal memory (no MMU, no
execution from external memory, or specific image format needs). This
basic framework can then (hopefully) be extensible to other complex SoC
processor support as need be.
Signed-off-by: Nishanth Menon <nm@ti.com>
adopt cpsw driver to device driver model
Since usb ether gadget doesn't have support for driver model, so
not defining usb ether gadget when ethernet driver model is
defined.
Add support for distro bootcmds and network booting while retaining
backwards compatibility with the current "legacy" setup. With these
changes the default boot sequence becomes:
* SD card (standard distro boot)
* SD card (legacy boot)
* EMMC (standard distro boot)
* EMMC (legacy boot)
* Nand (legacy boot)
* PXE (standard distro boot)
* DHCP (standard distro boot)
The older boot scripts have some overlap with what the distro
bootcommands to however i've left them unchanged to prevent introduction
of subtle bugs.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Add mandatory address variables for loading scripts and pxe configuration as
per README.distro
Hush has an oddity where using ${var} causes var to resolved in the the global
address space (iotw the environment) first and only afterwards will the local
variable space be searched.
This causes odd side-effects when iterating over the boot partitions
using ${bootpart} if the environment also has a bootpart variable (e.g. for
the various TI boards). Fix this by using the hopefully more unique
${distro_bootpart} instead of ${bootpart}.
Advantech SOM-6896 is a Broadwell U based COM Express Compact Module
Type 6. This patch adds support for it as a coreboot payload.
On board SATA and SPI are functional. On board Ethernet isn't functional
but since it's optional and ties up a PCIe x4 that is otherwise brought
out, this isn't a concern at the moment. USB doesn't work since the
xHCI driver appears to be broken.
Signed-off-by: George McCollister <george.mccollister@gmail.com>
It is useful to see a message from the debug UART early during boot so that
you know things are working. Add an option to enable this. The message will
be displayed as soon as debug_uart_init() is called.
Some boards need to set things up before the debug UART can be used. On
these boards a call to debug_uart_init() is insufficient. When this option
is enabled, the function board_debug_uart_init() will be called when
debug_uart_init() is called. You can put any code here that is needed to
set up the UART ready for use, such as set pin multiplexing or enable
clocks.
We want to be able to add other common code to this function. So change the
driver's version to have an underscore before it, just like
_debug_uart_putc(). Define debug_uart_init() to call this version.
Update all drivers to this new method.
Add Wildcat Point AHCI and LPC PCI IDs which are present on Broadwell U
based (and possibly other) boards.
E820 is critical to the kernel as it provides system memory map
information. Pass it to an x86 VxWorks kernel.
Tested-by: Jian Luo <jian.luo4@boschrexroth.de>
So far VxWorks bootline can be contructed from various environment
variables, but when these variables do not exist we get these from
corresponding config macros. This is not helpful as it requires
rebuilding U-Boot, and to make sure these config macros take effect
we should not have these environment variables. This is a little
bit complex and confusing.
Now we change the logic to always contruct the bootline from
environments (the only single source), by adding two new variables
"bootdev" and "othbootargs", and adding some comments about network
related settings mentioning they are optional. The doc about the
bootline handling is also updated.
Tested-by: Hannes Schmelzer <oe5hpm@oevsv.at>
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards.
CONFIG_HOSTNAME is an environment varible, so that quotation mark
is not needed.
Add a Kconfig option to disable the Integrated Graphics Device (IGD)
so that it does not show in the PCI configuration space as a VGA
disaplay controller. This gives a chance for U-Boot to run PCI/PCIe
based graphics card's VGA BIOS and use that for the graphics console.
GENMASK is used to create a contiguous bitmask([hi:lo]).
This patch is a copy from Linux, with below commit details
"bitops: Fix shift overflow in GENMASK macros"
(sha1: 00b4d9a14125f1e51874def2b9de6092e007412d)
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Signed-off-by: Jagan Teki <jteki@openedev.com>
Since it's a copy from Linux, this patch moved all
BIT definitions to top so-that it looks same as Linux file.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
This patch enables DM_SERIAL for all ARCH_MVEBU boards (AXP & A38x).
Cc: Luka Perkov <luka.perkov@sartura.hr>
This patch enables DM_USB on the Marvell AXP / A38x eval boards.
When running on the AXP I sometimes noticed a strange behavior. As some
characters are not echoed on the U-Boot prompt. Not disabling the
lowlevel_init code, especially calling cpu_init_cp15() in the main
U-Boot seems to solve this issue.
