Make the driver model I2C API available always, even if driver model
is not enabled. This allows for a 'soft' switch-over, where drivers can
use the new structures in code which is compiled but not yet used. This
makes migration easier in some cases.
Fix up the existing drivers which define their own 'struct i2c_msg'.
Acked-by: Heiko Schocher <hs@denx.de>
As with i2c_read() and i2c_write(), add a dm_ prefix to the driver model
versions of these functions to avoid conflicts.
Drop the old checksum functions in favour of the new ones.
This comes from the device tree or a call to get_uart_clock().
Switch to generic board so that this board will not be broken/removed.
Move these options to Kconfig and remove them from the CONFIG files.
Many CONFIG options have an unnecessary value of 1. CONFIG_440 is set in
the various board config files. Also simplify the CONFIG_440 check in
config.mk
The recent changes to config_distro_bootcmd.h require CONFIG_CMD_PART to be
defined, as the default bootcmd not uses the "part" command.
This fixes sunxi boards not booting with v2015.04-rc1.
Add linux/compiler-gcc5/h from the kernel sources at:
commit 5631b8fba640a4ab2f8a954f63a603fa34eda96b
Author: Steven Noonan <steven@uplinklabs.net>
Date: Sat Oct 25 15:09:42 2014 -0700
compiler/gcc4+: Remove inaccurate comment about 'asm goto' miscompiles
include/splash.h
lcd_logo() currently performs tasks well beyond just displaying the logo.
It has code which displays splash image, it has logic which determines
when the different display features are displayed, and it is coupled with
the lcd console because it holds the responsibility of returning the
lcd console base address.
Make lcd_logo() just about the logo by:
* Moving splash image display code into a dedicated function
* Moving the logic regarding when various features are displayed to
lcd_clear() (which is arguably not the correct name for housing such
code either, but it is currently the most fitting location code wise)
* Move the responsibility of setting the console base address to
lcd_clear() too.
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Tested-by: Bo Shen <voice.shen@atmel.com>
Tested-by: Josh Wu <josh.wu@atmel.com>
Cc: Bo Shen <voice.shen@atmel.com>
We now have api functions that can support compiling simplefb code as its own
module. Since this code is not part of the display functionality, extract it
to its own file.
Raspberry Pi is updated to accommodate the changes.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
This cleanup mostly focuses on removing unnecessary whitespace and comments
which are superfluous and/or do not conform to the coding style.
configuration_get_cmap() is multiple platform-specific functions stuffed into
one function. Split it into multiple versions, and move each version to the
appropriate driver to reduce the #ifdef complexity.
common/lcd code is full of platform-specific code and definitions, which
ideally should reside with the respective driver code. Take a step towards that
goal by moving platform-specific structs from lcd.h to their own header files.
The structs for the generic case (the #else for all the platform-specific
cases) is retained in lcd.h as the default case.
Add more pfuze register offset.
And switch mode definition.
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
"#define PFUZE100_SW1ABC_SETP(x) ((x - 3000) / 250)"
This macro is for configuring SW1A/B/C Output Voltage easily.
This patch has some parts connected together:
- Use _gd in bss section which is automatically cleared
Location at SPL_MALLOC_END wasn't cleared at all
- Use MALLOC_F_LEN(early alloc) instead of FULL MALLOC
(mem_malloc_init is not called at all)
- Simplify malloc and stack init.
At the end of SPL addr is malloc area and below is stack
Create space for dm_init where calloc is called
and malloc_base has to be initialized.
Compile code with -fPIC to get GOT. Do not build SPL
with fPIC because it increasing SPL size for nothing.
Simplify SPL NOR init.
Following SPARK ARC now has SYS_MONITOR_BASE setup via Kconfig.
This makes "include/configs/*.h" cleaner and more flexible.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Common arch_early_init_r() is used in "arc/lib/cpu.c" for all ARC boards
so there's no sense in separate per-board definitions.
Currently there's nothing related to really low-level init on ARC so
CONFIG_SKIP_LOWLEVEL_INIT definition makes no sense.
There're no other options for ARC except "generic board" so ther's no
point to define CONFIG_SYS_GENERIC_BOARD per board.
We now have it set fo all ARC boards.
This change allows to keep board description clean and minimalistic.
This is especially helpful if one board may house different CPUs with
different features.
It is applicable to both FPGA-based boards or those that have CPUs
mounted on interchnagable daughter-boards.
different features.
Now we may select a particular version of ARC700:
* ARC750D or
* ARC770D
It allows more flexible (or more fine tuned) configuration of U-Boot.
Before that change we relied on minimal configuration but now we may
use specific features of each CPU.
Moreover allows us to escape manual selection of options that
exist in both CPUs but may have say different version like MMUv2 in
ARC750D vs MMUv3 in ARC770D.
With switch to Kconfig we only need very board-specific descriptions in
include/configs.
CPU selection is performed with either defconfig or manually via
menuconfig.
remove MACH_TYPE definitions in config file, as they come from
the defconfig.
enable WDT for the taurus board.
This patch will save U-Boot environment as a file: uboot.env, in FAT partition
instead of saving it in raw sector of MMC card.
This make us easier to manage the environment file.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Acked-by: Bo Shen <voice.shen@atmel.com>
instead of in raw sector of MMC card.
Current the MMC support will enable MCI port A, Which is only exist
for 2mmc board.
So by default we need to disable MMC (port A) support. And only enable
it for 2mmc board. Otherwise, dataflash won't work in at91sam9260ek board
as MMC has confliction with Dataflash in the CLK pin.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
The sama5d4ek support boot up from NAND flash, SD/MMC card and
also the SPI flash.
There are two typos in the comment block in bootstage.h, fix them.
Intel Galileo board has a microSD slot which is routed from Quark SoC
SDIO controller. Enable SD/MMC support so that we can use an SD card.
Add pci ids for Intel Quark SoC.
Add standard dt-bindings macros to be used by Intel Quark MRC node.
Add COMPAT_INTEL_QRK_MRC and "intel,quark-mrc" so that fdtdec can
decode Intel Quark MRC node.
New board/intel/galileo board directory with minimum codes, plus
board dts, defconfig and configuration files.
CONFIG_SATA_INTEL is not referenced anywhere, so remove it.
