R-mobile SoC (at least SH73A0) has extension bits to store 8th bit of iccl and icch.
This patch add support for the extentin bits.
Acked-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
Since commit 50d4a707f0 (mx5/6: Define default SoC input clock frequencies)
we can use the default clock values.
The CSI PODF bit-field used by the previous code for the i.MX31 CCM PDR0
register is actually composed of two bit-fields: one pre-divider and one
post-divider. This patch fixes the CCM access macros and the code using them
accordingly.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
The mx6qsabreauto console is different than mx6qsabresd so the console
configuration is now set in the board file.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Define default SoC input clock frequencies for i.MX5/6 in order to get rid of
duplicated definitions.
Cc: Jason Liu <r64343@freescale.com>
Cc: Matt Sealey <matt@genesi-usa.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
mx6qsabreauto is a board based on mx6q SoC with the following features:
- 2GB of DDR3
- 2 USB ports
- 1 HDMI output port
- SPI NOR
- 2 LVDS LCD ports
- Gigabit Ethernet
- Camera
- eMMC and SD card slot
- Multichannel Audio
- CAN
- SATA
- NAND
- PCIE
- Video Input
Add very basic support for it.
Add a common mx6 config file that can be shared between some mx6 boards.
mx6qsabresd has a AR8031 Gigabit PHY.
Add support for it.
Also increase CONFIG_SYS_MALLOC_LEN so that FEC buffer allocation does not fail.
Tested on 1Gbp and 100Mbps networks.
Suggested-by: Kim Phillips <kim.phillips@freescale.com>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
mx6qsabresd is a board based on mx6q SoC with the following features:
- 1GB of DDR3
- 1 USB OTG port
- SPI NOR
- LVDS panel
- Gigabit Ethernet
- Camera Connector
- Audio
This is extremely likely to be used from the boot.scr that Tegra's default
bootcmd locates and executes.
Signed-off-by: Tom Warren <twarren@nvidia.com>
The move is pretty straight-forward. ap20.h and tegra20.h were renamed to ap.h and tegra.h.
Some files remain in arch-tegra20 but 'include' a file in 'arch-tegra' with #defines & structs
that will be common between T20 and T30 HW. HW-specific #defines, etc. stay in the 'arch-tegra20'
'root' file.
All boards build OK w/MAKEALL -s tegra20. Checkpatch.pl runs clean. Seaboard works OK.
Medcom is the marketing name for an older, PXA-based version of the same
device. In order to avoid confusion, rename the Tegra-based version to
the new marketing name.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Some keyboards will not need a key ghosting filter, so make this feature
optional.
It is inconvenient to have to specify the keyboard repeat and delay at
init time if it is not yet available, so move this into a separate
function.
Some drivers will want to do this when their keyboard init routine
is actually called.
- block_dev_desc_t says that block_(read|write) take lbaint_t for blkcnt
not ulong.
- We also move the extern of sata_dev_desc into <sata.h>
- Remove now duplicate declarations from driver-specific headers.
Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
not ulong
PXA25x gadget implements common function usb_disconnect().
This patch adds this function prototype into usb.h for boards using it.
Signed-off-by: Lukasz Dalek <luk0104@gmail.com>
Allows for easy configuration of the VBUS indicator related ULPI
config bits.
Also move the external indicator setup from ulpi_set_vbus() to
the new function.
Signed-off-by: Lucas Stach <dev@lynxeye.de>
Carry an index in the lowlevel usb functions to make specify the
respective usb controller.
Also pass through an controller struct from lowlevel_init to the
creation of the root usb device of this controller.
As the board seems to be unmaintained for some time, lets remove
the support in mainline completely.
Cc: James MacAulay <james.macaulay@amirix.com>
Cc: Peter De Schrijver <p2@mind.be>
Since the IOP480 (PPC401/3 variant from PLX) is only used on 2
boards that are not actively maintained, lets remove support
for it completely. This way the ppc4xx code will get a bit cleaner.
Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Remove the parts depending either on disabled CONFIG_SERIAL_MULTI
or ifdefs around CONFIG_SERIAL_MULTI parts since CONFIG_SERIAL_MULTI
is now enabled by default.
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Tom Rini <trini@ti.com>
Cc: Stefan Roese <sr@denx.de>
Remove any notion of CONFIG_SERIAL_MULTI from board config files.
Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless
to specify this config option in the board config files. Therefore
remove it.
Rework the emulation of serial console via JTAG from simple ad-hoc
implementation of serial port routines to CONFIG_SERIAL_MULTI and
enable CONFIG_SERIAL_MULTI unconditionally for blackfin.
In order for the JTAG serial console to take precedence over all
other serial ports available in system, implement override for
default_serial_console call returning this JTAG serial console.
This brings in a bit of a growth of size, but eventually will allow
us to unconditionally enable CONFIG_SERIAL_MULTI throughout the whole
U-Boot and maintain only one serial subsystem.
Cc: Mike Frysinger <vapier@gentoo.org>
Remove the prototypes for zoom2_serial_deviceN from serial.h . This
can't be done right away, as they are referenced from the zoom2
config file. Therefore, adjust the code so the config file only
specifies number of the port. Then, replace the simple return in
default_serial_console() with a switch across possible values, which
returns the zoom2_serial_deviceN . With such adjustment in place,
the exported prototypes in serial.h can be safely removed.
Rename the serial_register_bfin_uart() to bfin_initialize_serial()
to be consistent with the rest of the naming. Next, remove it's
prototype from serial.h and properly insert it into serial.c as
the rest of the serial initialization functions.
Remove the exports from serial.h as they are only used in the blackfin
serial driver. Furthermore, they are only used for registration, which
is handled already inside that driver and default_serial_port() call,
which is also handled in that driver.
Move the registration of eserialN_device ports from default
serial_initialize() into driver specific function called from
serial_initialize(). This slims down the serial_initialize() call
to a bare tracker of all possible serial port registration routines
in U-Boot.
The newly implemented ns16550_serial_initialize() function, which is
implemented inside of the ns16550 serial driver allows encapsulation
of eserialN_device within the ns16550 serial driver itself.
Also, remove the exports of eserialN_device from include/serial.h
as they are no longer needed. This is simply because the implementation of
default_serial_console() is wrapped into the ns16550 serial driver and
the default console is picked by CONFIG_SERIAL<N> macro in config file.
Move the registration of serialN_device ports from default
in U-Boot.
The newly implemented mpc512x_serial_initialize() function, which is
implemented inside of the mpc512x serial driver allows encapsulation
of serialN_device within the mpc512x serial driver itself.
Also, remove the exports of serialN_device from include/serial.h
default_serial_console() is wrapped into the mpx512x serial driver and
Move the registration of xuartlite_serialN_device ports from
default serial_initialize() into driver specific function called from
in U-Boot.
The newly implemented xuartlite_serial_initialize() function, which is
implemented inside of the serial_xuartlite driver allows encapsulation
of xuartlite_serialN_device within the serial_xuartlite driver itself.
Also, remove the exports of xuartlite_serialN_device from include/serial.h
default_serial_console() is wrapped into the serial_xuartlite driver and
Move the registration of zynq_serialN_device ports from default
in U-Boot.
The newly implemented zynq_serial_initialize() function, which is
implemented inside of the serial_zynq driver allows encapsulation
of zynq_serialN_device within the serial_zynq driver itself.
Also, remove the exports of zynq_serialN_device from include/serial.h
default_serial_console() is wrapped into the serial_zynq driver and
Move the registration of s5p_serialN_device ports from default
in U-Boot.
The newly implemented s5p_serial_initialize() function, which is
implemented inside of the serial_s5p driver allows encapsulation
of s5p_serialN_device within the serial_s5p driver itself.
Also, remove the exports of s5p_serialN_device from include/serial.h
default_serial_console() is wrapped into the serial_s5p driver and
Move the registration of serial_XXuart ports from default
in U-Boot.
The newly implemented pxa_serial_initialize() function, which is
implemented inside of the serial_pxa driver allows encapsulation
of serial_XXuart within the serial_pxa driver itself.
Also, remove the exports of serial_XXuart from include/serial.h
default_serial_console() is wrapped into the serial_pxa driver and
the default console is picked by CONFIG_CONS_IDX macro in config file.
Move the registration of s3c24xx_serialN_device ports from
in U-Boot.
The newly implemented s3c24xx_serial_initialize() function, which is
implemented inside of the serial_s3c24xx driver allows encapsulation
of s3c24xx_serialN_device within the serial_s3c24xx driver itself.
Also, remove the exports of s3c24xx_serialN_device from include/serial.h
default_serial_console() is wrapped into the serial_s3c24xx driver and
Cc: C Nauman <cnauman@diagraph.com>
Some of the boards using the mpc512x serial driver didn't properly
define which PSC console to use. This caused breakage when building
with CONFIG_SERIAL_MULTI enabled. Fix this by defining the default
PSC console.
Make use of the newly implemented weak default_serial_console in
the serial_pxa driver. This removes all reimplementations of this
function from board files.
Rename .init() to .start() and .uninit() to .stop() in struct
serial_device. This allows aligning struct serial_device with
closer to struct stdio_dev. The real goal here is to allow
these two structures to converge together and eventually make
one to be a superset of the other.
Do a simple cleanup of the struct serial_device and align it with
current coding style. Checkpatch now reports no errors.
Fix up the rest of implementations of __stringify().
Kill multiple occurances and redeclaration of MK_STR
in favor of __stringify().
Kill multiple occurances and redeclaration of xstr in favor of __stringify().
Copied from Linux kernel:
commit 8f7c2c37319a81ef4c2bfdec67b1ccd5744d97e4
Date: Wed Apr 8 16:58:57 2009 +0800
Pull in the __stringify() macro from Linux kernel. This macro is usually used to
convert numbers to strings at preprocessor level, yet it is not limited only to
that. This is useful as it allows higher usage of puts() in favour of printf().
After taking with the former maintainer, delete this platform. The
patch is from the former maintainer.
The SPI flash is not properly detected by plain "sf probe" due to
it being located on different bus and different chipselect. Fix
this problem.
The IDE_BUS(dev) macro was previously doing dev >> 1. This however is a
mis-match of the usage in common/cmd_ide.c and would cause boards with
multiple ports / devices to not correctly detect all devices. For more
details please see:
http://lists.denx.de/pipermail/u-boot/2012-April/122525.html
[Tom Rini: Reword commit message only]
Tested-by: Luka Perkov <uboot@lukaperkov.net>
Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
The default configuration for ml507 will generate a hang() in the
Xilinx uartlite driver.
userial_ports[] in drivers/serial/serial_xuartlite.c does not get
initialized properly. CONFIG_SERIAL_BASE is unused.
XILINX_UARTLITE_BASEADDR is used instead.
Signed-off-by: Rommel Custodio <sessyargc+uboot@gmail.com>
Due to grown code sizes the TQM85xx boards don't build any more with
some older tool chains (like ELDK 4.2). As these boards have long
reached EOL it seems a waste of effort trying to fix them. The vendor
has agreed to drop support for them, too. So let's get rid of them.
cc: Kim Phillips <kim.phillips@freescale.com>
