path: root/include
2013-07-19arm:trats:fix: Correction of loaddtb environment variable.Łukasz Majewski
Missing space for loaddtb command has been added. When missing, ext4load fails with wrong number of passed parameters. Acked-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2013-07-16mpc85xx: Add gdsys ControlCenter Digital boardDirk Eibach
The gdsys ControlCenter Digital board is based on a Freescale P1022 QorIQ SOC. It boots from SPI-Flash but can be configured to boot from SD-card for factory programming and testing. On board peripherals include: - 2x GbE - Lattice ECP3 FPGA connected via PCIe - mSATA RAID1 - USB host - DisplayPort video output - Atmel TPM Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-16tpm: add AUTH1 cmds for LoadKey2 and GetPubKeyReinhard Pfau
Extend the tpm library with support for single authorized (AUTH1) commands as specified in the TCG Main Specification 1.2. (The internally used helper functions are implemented in a way that they could also be used for double authorized commands if someone needs it.) Provide enums with the return codes from the TCG Main specification. For now only a single OIAP session is supported. OIAP authorized version of the commands TPM_LoadKey2 and TPM_GetPubKey are provided. Both features are available using the 'tpm' command, too. Authorized commands are enabled with CONFIG_TPM_AUTH_SESSIONS. (Note that this also requires CONFIG_SHA1 to be enabled.) Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc> Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Acked-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-15Fix ext2/ext4 filesystem accesses beyond 2TiBFrederic Leroy
With CONFIG_SYS_64BIT_LBA, lbaint_t gets defined as a 64-bit type, which is required to represent block numbers for storage devices that exceed 2TiB (the block size usually is 512B), e.g. recent hard drives We now use lbaint_t for partition offset to reflect the lbaint_t change, and access partitions beyond or crossing the 2.1TiB limit. This required changes to signature of ext4fs_devread(), and type of all variables relatives to block sector. ext2/ext4 fs uses logical block represented by a 32 bit value. Logical block is a multiple of device block sector. To avoid overflow problem when calling ext4fs_devread(), we need to cast the sector parameter. Signed-off-by: Frédéric Leroy <fredo@starox.org>
2013-07-15Revert "MIPS: Jz4740: Add qi_lb60 board support"Tom Rini
The files board/qi/qi_lb60/qi_lb60.c and include/configs/qi_lb60.h were licensed under the GPL v3 or later, and not v2 or later. As this is incompatible with the project, revert this board support until the responsible parties are available to re-license (if so desired) under GPL v2. Signed-off-by: Tom Rini <trini@ti.com>
2013-07-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and serial. Conflicts: arch/arm/dts/exynos5250.dtsi Signed-off-by: Tom Rini <trini@ti.com>
2013-07-12bootm: Use selected configuration for ramdisk and fdtSimon Glass
If a specific configuraion is selected by the bootm command, e.g. with 'bootm 84000000#recoveryconf' we must honour this for not just the kernel, but also the ramdisk and FDT. In the conversion to using a common fit_image_load() function for loading images from FITs (commits a51ec63 and 53f375f) this feature was lost. Reinstate it by passing the selected configuration back from fit_image_load() to boot_get_kernel(), then use this configuration (which is stored in images->fit_uname_cfg) in both boot_get_ramdisk() and boot_get_fdt(). Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-12Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-07-12mx53ard: Change default environment to cope with OE changesOtavio Salvador
OpenEmbedded has change partitioning layout of generated image so it does not raise warnings during the boot regarding unkown partition being used for U-Boot. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-12mx51evk: Change default environment to cope with OE changesOtavio Salvador
OpenEmbedded has change partitioning layout of generated image so it does not raise warnings during the boot regarding unkown partition being used for U-Boot. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2013-07-12wandboard: Change default environment to cope with OE changesOtavio Salvador
2013-07-12mx6slevk: Change default environment to cope with OE changesOtavio Salvador
2013-07-12mx6qsabrelite: Change default environment to cope with OE changesOtavio Salvador
2013-07-12mx53loco: Change default environment to cope with OE changesOtavio Salvador
OpenEmbedded has change partitioning layout of generated image so it does not raise warnings during the boot regarding unkown partition being used for U-Boot. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Jason Liu <r64343@freescale.com>
2013-07-12m28evk: add trimffs to nand commandMarek Vasut
this is usefull when writing an UBI image which contains and UBIFS volume (check README.nand and UBI FAQ for more details) Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2013-07-11ARM: tegra: enable LCD panel on VentanaStephen Warren
Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-07-11ARM: tegra: enable LCD panel on HarmonyStephen Warren
2013-07-11Tegra: Config: Enable Tegra30/Tegra114 USB functionJim Lin
Add USB EHCI, storage and network support. Tested on Tegra30 Cardhu, and Tegra114 Dalmore platforms. All works well. Signed-off-by: Jim Lin <jilin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-07-11ARM: Tegra: USB: EHCI: Add support for Tegra30/Tegra114Jim Lin
Tegra30 and Tegra114 are compatible except PLL parameters. Tested on Tegra30 Cardhu, and Tegra114 Dalmore platforms. All works well. Signed-off-by: Jim Lin <jilin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-07-10Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-07-10bootm: Clean up bootz_setup() functionSimon Glass
This function has no prototype in the headers and passes void * around, thus requiring several casts. Tidy this up. - Add new patch to clean up bootz_setup() function Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-10Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2013-07-08video: consolidate splash screen alignment codeAnatolij Gustschin
Code for checking "splashpos" environment variable is duplicated in drivers, move it to the common function. Call this function also in the bmp display command to consider "splashpos" settings. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-07-05arm:trats: Increase malloc pool size (for DFU ext4 transfers)Łukasz Majewski
Commit: dfu: make data buffer size configurable SHA1: 89a72b2e0e141042c9109185e02d39b2107ffc62 replaced statically allocated buffers with one allocated with memalign. Malloc pool size of 1MiB was too small, since we needed bigger buffer to transfer for example uImage. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05EXYNOS: Move files from board/samsung to arch/armRajeshwari Shinde
This patch performs the following: 1) Convert the assembly code for memory and clock initialization to C code. 2) Move the memory and clock init codes from board/samsung to arch/arm 3) Creat a common lowlevel_init file across Exynos4 and Exynos5. Converted the common lowlevel_init from assembly to C-code 4) Made spl_boot.c and tzpc_init.c common for both exynos4 and exynos5. 5) Enable CONFIG_SKIP_LOWLEVEL_INIT as stack pointer initialisation is already done in _main. 6) exynos-uboot-spl.lds made common across SMDKV310, Origen and SMDK5250. TEST: Tested SD-MMC boot on SMDK5250 and Origen. Tested USB and SPI boot on SMDK5250 Compile tested for SMDKV310. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05EXYNOS4210: Configure GPIO for uartRajeshwari Shinde
This patch configures the gpio values for UART on Origen and SMDKV310 using pinmux Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05EXYNOS: LDS file move to commonRajeshwari Shinde
smdk5250-uboot-spl.lds is moved to common folder, so that it can be reused. It is renamed to exynos-uboot-spl.lds Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-03Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2013-07-01omap: cm_t35: Fix cm_t35 for weak splash_screen_prepareRobert Winkler
Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-07-01video: lcd: Add CONFIG_SPLASH_SCREEN_PREPARE support to CONFIG_VIDEORobert Winkler
Create splash.c/h to put the function and any future common splash screen code in. Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-07-01lcd: align bmp header when uncopmressing imagePiotr Wilczek
When compressed image is loaded, it must be decompressed to an aligned address + 2 to avoid unaligned access exception on some ARM platforms. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Anatolij Gustschin <agust@denx.de> CC: Wolfgang Denk <wd@denx.de> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-07-01Merge branch 'master' of git://git.denx.de/u-boot-nand-flashTom Rini
2013-06-30usb: fix unaligned access in device_qual()Heiko Schocher
while playing with dfu, I tapped in an unaligned access when doing on the host side a "lsusb -d [vendornr]: -v" I get on the board: GADGET DRIVER: usb_dnl_dfu data abort MAYBE you should read doc/README.arm-unaligned-accesses pc : [<8ff71db8>] lr : [<8ff75aec>] sp : 8ef40d18 ip : 00000005 fp : 00000000 r10: 00000000 r9 : 47401410 r8 : 8ef40f38 r7 : 8ef4aae8 r6 : 0000000a r5 : 8ef4ab28 r4 : 8ef4ab80 r3 : 0000000a r2 : 00000006 r1 : 00000006 r0 : 8ef4aae8 Flags: Nzcv IRQs off FIQs on Mode SVC_32 Resetting CPU ... reason is that in the "struct usb_composite_dev" the "struct usb_device_descriptor desc;" is on an odd address, and this struct gets accessed in drivers/usb/gadget/composite.c device_qual() Fix it, by align this var "struct desc" fix to an aligned address. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Samuel Egli <samuel.egli@siemens.com>
2013-06-30usb, g_dnl: make possibility to fixup the device_desc board specificHeiko Schocher
add a weak dummy function g_dnl_fixup to add the possibility to update the device_desc board specific. Used on the upcoming siemens board support, where idVendor and idProduct is stored in an eeprom. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2013-06-30dfu: make data buffer size configurableHeiko Schocher
Dfu transfer uses a buffer before writing data to the raw storage device. Make the size (in bytes) of this buffer configurable through environment variable "dfu_bufsiz". Defaut value is configurable through CONFIG_SYS_DFU_DATA_BUF_SIZE Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Tom Rini <trini@ti.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Tom Rini <trini@ti.com>
2013-06-28mkimage: Build signing only if board has CONFIG_FIT_SIGNATURESimon Glass
At present mkimage is set up to always build with image signing support. This means that the SSL libraries (e.g. libssl-dev) are always required. Adjust things so that mkimage can be built with and without image signing, controlled by the presence of CONFIG_FIT_SIGNATURE in the board config file. If CONFIG_FIT_SIGNATURE is not enabled, then mkimage will report a warning that signing is not supported. If the option is enabled, but libraries are not available, then a build error similar to this will be shown: lib/rsa/rsa-sign.c:26:25: fatal error: openssl/rsa.h: No such file or directory Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-28Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-06-28vf610twr: Remove SoC name from U-Boot promptOtavio Salvador
We've been dropping SoC name from U-Boot prompt as it increase complexity for automatic testing and makes line longer for no good reason. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Tested-by: Andy Voltz <andy.voltz@timesys.com>
2013-06-28vf610twr: Add default environment in line with other Freescale boardsOtavio Salvador
This adds a default environment which should be able to support both 3.0.15 from Timesys and upcoming 3.11. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Tested-by: Andy Voltz <andy.voltz@timesys.com>
2013-06-27am335x_evm: Add missing ';' in findfdtTom Rini
In a714321 we add a check at the end of findfdt to make sure we have updated it from undefined and if not, warn the user. This however forgot a ';' on the end of the previous last test. Signed-off-by: Tom Rini <trini@ti.com>
2013-06-26imx: nitrogen6x: Enable filesystem generic commandsRobert Winkler
2013-06-26imx: nitrogen6x: Enable raw initrdRobert Winkler
2013-06-26imx: nitrogen6x: Enable bootzRobert Winkler
2013-06-26imx: nitrogen6x: Enabled data cacheRobert Winkler
2013-06-26imx: Add support for the SabreSD shipped with i.MX6DLPierre Aubert
The SabreSD platform is available with i.MX6Q or i.MX6DL. This patch adds the support of the i.MX6DL. The config file and the board directory are renamed to remove the reference to the MX6Q. Signed-off-by: Pierre Aubert <p.aubert@staubli.com> CC: Stefano Babic <sbabic@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-06-26Fix block device accesses beyond 2TiBSascha Silbe
With CONFIG_SYS_64BIT_LBA, lbaint_t gets defined as a 64-bit type, which is required to represent block numbers for storage devices that exceed 2TiB (the block size usually is 512B), e.g. recent hard drives. For some obscure reason, the current U-Boot code uses lbaint_t for the number of blocks to read (a rather optimistic estimation of how RAM sizes will evolve), but not for the starting address. Trying to access blocks beyond the 2TiB boundary will simply wrap around and read a block within the 0..2TiB range. We now use lbaint_t for block start addresses, too. This required changes to all block drivers as the signature of block_read(), block_write() and block_erase() in block_dev_desc_t changed. Signed-off-by: Sascha Silbe <t-uboot@infra-silbe.de>
2013-06-26sandbox: config: Enable FIT signatures with RSASimon Glass
We want to sign and verify images using sandbox, so enable these options. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26image: Add support for signing of FIT configurationsSimon Glass
While signing images is useful, it does not provide complete protection against several types of attack. For example, it it possible to create a FIT with the same signed images, but with the configuration changed such that a different one is selected (mix and match attack). It is also possible to substitute a signed image from an older FIT version into a newer FIT (roll-back attack). Add support for signing of FIT configurations using the libfdt's region support. Please see doc/uImage.FIT/signature.txt for more information. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26libfdt: Add fdt_find_regions()Simon Glass
Add a function to find regions in device tree given a list of nodes to include and properties to exclude. See the header file for full documentation. Signed-off-by: Simon Glass <sjg@chromium.org>
