path: root/include
2004-12-19* Fix problems with CMC_PU2 flash driver.LABEL_2004_12_19_2240wdenk
* Adjust INKA 4x0 default settings
2004-12-19Renamed UC100 => uc100LABEL_2004_12_19_1100wdenk
2004-12-19Cleanup: avoid trigraph warning in fs/ext2/ext2fs.c; rename UC100 -> uc100wdenk
2004-12-18Add support for UC100 boardLABEL_2004_12_18_2335wdenk
2004-12-16Code cleanup.wdenk
2004-12-16esd config files updatedstroese
2004-12-16new 405ep defines addedstroese
2004-12-16new SST and EXCEL devices addstroese
2004-12-16- ext2fs support addedstroese
- Tundra universe support added
2004-12-16Coldfire MCF5249 support addedstroese
2004-12-16Tundra universe support addedstroese
2004-12-16ext2fs support addedstroese
2004-12-16Add support for INKA4X0 boardwdenk
2004-12-14Cleanup for CMC_PU2 boardwdenk
2004-12-13Fix problem introduced by previous patch.wdenk
2004-12-12Patch by Martin Krause, 27 Oct 2004:wdenk
- add support for "STK52xx" board (including PS/2 multiplexer) - add hardware detection for TQM5200
2004-11-24* Fix udelay() on AT91RM9200 for delays < 1 ms.LABEL_2004_11_25_0035wdenk
* Enable long help on CMC PU2 board; fix reset issue; increase CPU speed from 179 to 207 MHz.
2004-11-21* Update for AT91RM9200DK and CMC_PU2 boards:wdenk
- Enable booting directly from flash - fix CMC_PU2 flash driver * Fix mkimage usage message
2004-11-17Map SRAM on NC650 boardLABEL_2004_11_17_2222wdenk
2004-11-02Work around for Ethernet problems on Xaeniax boardwdenk
2004-10-28Patch by TsiChung Liew, 23 Sep 2004:wdenk
- add support for MPC8220 CPU - Add support for Alaska and Yukon boards
2004-10-24* Fix configuration for ERIC board (needs more room)wdenk
* Adjust MIPS compiler options at run-time depending on tools version ("-march=4kc -mtune=4kc -Wa,-mips_allow_branch_to_undefined" for new, "-mcpu=4kc" for old tools)
2004-10-19Add passing of the command line and memory size information to theLABEL_2004_10_20_0020wdenk
kernel on xaeniax board.
2004-10-17Code cleanup for GCC-3.3.x compilerswdenk
2004-10-11CleanupLABEL_2004_10_12_0110wdenk
2004-10-11* Enable NAND flash support for NC650 board.wdenk
* Patch by Thomas Lange 07 Oct 2004: Updated README for DBAu1x00 boards to match current status
2004-10-11* Patch by Philippe Robin, 28 Sept 2004:wdenk
Fix Flash support for Versatile. * Patch by Roger Blofeld, 16 Sep 2004: Fix timeout for DHCP command retry
2004-10-11Fix CFG_HZ problems on AT91RM9200 systemswdenk
[Remember: CFG_HZ should be 1000 on ALL systems!]
2004-10-10* Patch by Gridish Shlomi, 30 Aug 2004:wdenk
- Add support to revA version of PQ27 and PQ27E. - Reverted MPC8260ADS baudrate back to original 115200 * Patch by Hojin, 17 Sep 2004: Fix typo in cfi_flash.c * Patch by Mark Jonas, 09 September 2004: mtest's data line test (with CFG_ALT_MEMTEST set) returned a wrong error message * Patch by Mark Jonas, 31 August 2004: Added option CFG_XLB_PIPELINING to enable XLB pipelining. This improves FTP performance for MPC5200 systems. Enabled for IceCube by default.
2004-10-10* Patch by Michael Bendzick, 30 Aug 2004:wdenk
- Improve platform.S code for omap1510inn that detects whether code is running from SDRAM or not. Patch allows SDRAM to be configured if code is running out of SRAM at 0x20000000. * Patch by Frederick Klatt, 30 Aug 2004: Add support for the Wind River SBC8540/SBC8560 boards
2004-10-10* Configure SX1 board to use drivers/cfi_flash.cwdenk
* Patches by Michael Bendzick, 30 Aug 2004: - Configure omap1510inn board to use drivers/cfi_flash.c - Make drivers/cfi_flash.c protect environment and redundant environment. * Patch by Steven Scholz, 23 Jun 2004: - Add script (tools/img2brec.sh) to programm U-Boot into (Synch)Flash using the Bootstrap Mode of the MC9328MX1/L
2004-10-10Patches by Scott McNutt, 24 Aug 2004:wdenk
- Add support for Altera Nios-II processors. - Add support for Psyent PCI-5441 board. - Add support for Psyent PK1C20 board.
2004-10-10Patches by Jon Loeliger, 24 Aug 2004:wdenk
- Add support for the MPC8541 and MPC8555 CDS boards - Cleanup eth?addr handling: make dependent on CONFIG_ETH?ADDR
2004-10-10* Patch by Jon Loeliger, 24 Aug 2004:wdenk
- Fix PCI window on MPC85xx; remove unneeded PCI initialization from board_early_init_f() - Provide SW workaround for PCI initialization on 85xx CDS - Convert MPC85xxADS to use common CFI flash driver * Cleanup: avoid compiler warnings * Add CMC PU2 board to MAKEALL script
2004-10-10Patches by George G. Davis, 24 Aug 2004:wdenk
- Enable ramdisk/initrd tagged param support for omap1610h2_config - Remove static network setup defaults from mx1ads_config
2004-10-10Patch by George G. Davis, 24 Aug 2004:wdenk
- update ARM boards to use constants from mach-types.h
2004-10-10Code Cleanupwdenk
Patch by Gary Jennejohn, 04 Oct 2004: - fix I2C on at91rm9200 - add support for Ricoh RS5C372A RTC
2004-10-10* Patch by Gary Jennejohn, 01 Oct 2004:wdenk
- add support for CMC PU2 board - add support for I2C on at91rm9200 * Patch by Gary Jennejohn, 28 Sep 2004: fix baudrate handling on at91rm9200
2004-10-09Patch by Yuli Barcohen, 22 Aug 2004:wdenk
- remove ZPC.1900 board-specific flash driver; switch the port to generic CFI driver; - port clean-up
2004-10-09* Clean up tools/bmp_logo.c to not add trailing white spacewdenk
* Patch by Hinko Kocevar, 21 Aug 2004: - Group common framebuffer functions in common/lcd.c - Group common framebuffer macros and #defines in include/lcd.h - Provide calc_fbsize() for video ATAG
2004-10-09Patch by Sam Song, 21 August 2004:wdenk
- Fix a typo in README - Align "(RO)" output for "flinfo" after "protect on" - Add RESET support for RPXlite_DW board; adjust CPU:BUS frequency ratio 1:1 when core frequency less than 50MHz
2004-10-09Patches by himba, 21 Aug 2004:wdenk
- fix some "use of label at end of compound statement" warnings - Define type of LCD panel on lubbock board if CONFIG_LCD is used
2004-10-09Patch by Andreas Engel, 16 Aug 2004:wdenk
parameter type cleanup for NetSetTimeout()
2004-09-29* Patches by Sean Chang, 09 Aug 2004:wdenk
- Added support for both 8 and 16 bit mode access to System ACE CF through MPU. - Fixed missing System ACE CF device during get FAT partition info in fat_register_device function. - Enabled System ACE CF support on ML300. * Patch by Sean Chang, 09 Aug 2004: Synch defines for saveenv and do_saveenv functions so they get compiled under the same statement.
2004-09-29* Patch by Sean Chang, 9 Aug 2004:wdenk
- Added I2C support for ML300. - Added support for ML300 to read out its environment information stored on the EEPROM. - Added support to use board specific parameters as part of U-Boot's environment information. - Updated MLD files to support configuration for new features above. * Patches by Travis Sawyer, 5 Aug 2004: - Remove incorrect bridge settings for eth group 6 - Add call to setup bridge in ppc_440x_eth_initialize - Fix ppc_440x_eth_init to reset the phy only if its the first time through, otherwise, just check the phy for the autonegotiated speed/duplex. This allows the use of netconsole - only print the speed/duplex the first time the phy is reset.
2004-09-29* Patch by Shlomo Kut, 29 Mar 2004:wdenk
Add support for MKS Instruments "Quantum" board * Fix build problem with Cogent boards; avoid using <asm/byteorder.h> when using the host compiler
2004-09-28Fix problems with CDROM drive as slave device on Lite5200 IDE bus.wdenk
2004-09-28* Patch by Stephen Williams, 15 July 2004wdenk
Set the PCI class code for JSE board as part of PCI interface setup * Patch by Michael Bendzick, 15 Jul 2004: Fix problem with writes with odd sizes in drivers/cfi_flash.c when CFG_FLASH_USE_BUFFER_WRITE is set
2004-09-28* Patch by Yuli Barcohen, 13 Jul 2004:wdenk
Allow clock setting on MPC866/MPC885 series chips according to environment variable `cpuclk' * Patch by Yuli Barcohen, 20 Apr 2004: Remove unnecessary redefine of CPM_DATAONLY_SIZE for MPC826x
2004-09-28Patch by Vincent Dubey, 24 Sep 2004:wdenk
Add support for xaeniax board
