This patch fix the broken boot from NOR Flash on AT91RM9200 boards, if
CONFIG_AT91RM9200 is defined and nor preloader is used.
Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
Add cfi-mtd driver, which exports CFI flash to MTD layer.
This allows CFI flash devices to be used from MTD layer.
Building of the new driver is controlled by CONFIG_FLASH_CFI_MTD
option. Initialization is done by calling cfi_mtd_init() from
flash_init().
Signed-off-by: Piotr Ziecik <kosmo@semihalf.com>
Add interface for flash verbosity control. It allows
to disable output from low-level flash API. It is useful
when calling these low-level functions from context other
than flash commands (for example the MTD/CFI interface
implmentation).
Export flash_sector_size() function from drivers/mtd/cfi_flash.c,
so that it can be used in the upcoming cfi-mtd driver.
At least some (old ?) versions of the AT91Bootstrap do not set up the
PLLB correctly to 48 MHz in order to make USB host function correctly.
This patch sets up the PLLB to the same values Linux uses, and makes USB
work ok on the following CPUs:
- AT91CAP9
- AT91SAM9260
- AT91SAM9263
This patch also defines CONFIG_USB_STORAGE and CONFIG_CMD_FAT for all
the relevant AT91CAP9/AT91SAM9 atmel boards.
Signed-off-by: Stelian Pop <stelian@popies.net>
Introduce AT91_CPU_CLOCK and use it for displaying the CPU
speed in the LCD driver.
Also make AT91_MAIN_CLOCK and AT91_MASTER_CLOCK reflect the
corresponding board clocks.
To enable UBI on Apollon you need to uncomment the CONFIG_SYS_USE_UBI
macro.
This patch adds basic UBI (Unsorted Block Image) support to U-Boot.
It's based on the Linux UBI version and basically has a "OS"
translation wrapper that defines most Linux specific calls
(spin_lock() etc.) into no-ops. Some source code parts have been
uncommented by "#ifdef UBI_LINUX". This makes it easier to compare
this version with the Linux version and simplifies future UBI
ports/bug-fixes from the Linux version.
Since we've changed the memory map of the board, be nice and
add some checking to try to catch out-of-date .dts files. We do
this by checking the CCSRBAR location in the .dts and comparing
it to the CCSRBAR location in u-boot. If they don't match, a
warning msg is printed. This isn't foolproof, but it's simple and
will catch most of the cases where an out-of-date .dts is present,
including all of the cases where a new u-boot is used with an old
standard MPC8641 .dts file as supplied with Linux.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
This patch creates a memory map with all the devices
in 36-bit physical space, in addition to the 32-bit map.
The CCSR relocation is moved (again, sorry) to
allow for the physical address to be 36 bits - this
requires translation to be enabled. With 36-bit physical
addressing enabled, we are no longer running with VA=PA
translations. This means we have to distinguish between
the two in the config file. The existing region name is
used to indicate the virtual address, and a _PHYS variety
is created to represent the physical address.
Large physical addressing is not enabled by default.
Set CONFIG_PHYS_64BIT in the config file to turn this on.
The memory map on the 8641hpcn is modified to look more like
the 85xx boards; this is a step towards a more standardized
layout going forward. As part of this change, we now relocate
the flash.
The regions for some of the mappings were far larger than they
needed to be. I have reduced the mappings to match the
actual sizes supported by the hardware.
In addition I have removed the comments at the head
of the BAT blocks in the config file, rather than updating
them. These get horribly out of date, and it's a simple
matter to look at the defines to see what they are set to
since everything is right here in the same file.
Documentation has been changed to reflect the new map, as this
change is user visible, and affects the OS which runs post-uboot.
We define CONFIG_MONITOR_BASE_EARLY to define the initial location
of the bootpage in flash. Use this to create an early mapping
definition for the FLASH, and change the early_bats code to use this.
This change facilitates the relocation of the flash since the early
mappings are no longer tied to the final location of the flash.
Currently, that's what it is, but it's hardcoded.
There's a lot of setup and foo for the second flash
bank. The problem is, this board doesn't actually have one.
Clean this up. Also, the flash is 8M in size. Get rid
of the confusing aliased overmapping, and just map 8M.
It's currently defined twice inside in an if/else block, but
both halves set the same value. Move the define outside
the if.
Removed initialization of the driver from net/eth.c
All in-tree IBM/AMCC PPC4xx boards using the EMAC get this new CONFIG
Affected boards:
Several MPC8xx boards
Several MPC8260/MPC8272 boards
Several MPC85xx boards
This patch will move au1x00_eth_initialize from net/eth.c to cpu_eth_init
as a part of ongoing eth_initialize cleanup work. The function ret value
is also fixed as it should be negative on fail.
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
Also, removed the driver initialization from net/eth.c
AT91_BASE_EMAC is never used outside the board specific files,
so replace its usage by the board specific AT91xxx_BASE_EMAC.
This patch provides support for AFEB9260 board, a product of
OpenSource hardware and software. Some commertial projects
are made with this design. A board is basically AT91SAM9260-EK
with some modifications and different peripherals and different
parts used. Main purpose of this project is to gain experience in
hardware design.
More info: http://groups.google.com/group/arm9fpga-evolution-board
(In Russian only, sorry).
Subversion repository: svn://194.85.238.22/home/users/george/svn/arm9eb
Signed-off-by: Sergey Lapin <slapin@ossfans.org>
We put the bootpg for the secondary cpus into memory and use
BPTR to get to it. This is a step towards converting to the
ePAPR boot methodology. Also, the code is written to
deal properly with more than 4GB of RAM.
There are several items in the config file that were hardcoded
but that should really be based on other config options, since
the regions are contiguous and depend on being so. This cleans
that up a bit. Also, add BR_PHYS_ADDR() macro to convert
addresses into the proper format for BR registers.
Currently, the CCSR gets relocated while translation is
enabled, meaning we need 2 BAT translations to get to both the
old location and the new location. Also, the DEFAULT
CCSR location has a dependency on the BAT that maps the
FLASH region. Moving the relocation removes this unnecessary
dependency. This makes it easier and more intutive to
modify the board's memory map.
Swap BATs 3 and 4 on 8610 so that all 86xx boards use the same
BAT for CCSR space.
You can't actually have both, and with some coming changes to
change the memory map for the board and support 36-bit physical,
we need the extra BAT that is being consumed by having both.
I also make non-PCI configs build cleanly, for the sake of sanity.
We don't actually ever do this, remove the code so we
can stop maintaining it.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Add serial boot support
Place FEC pin assignments in cpu_init.c from platform's
mii.c
Consolidate ATA, ePORT, QSPI, FlexCan, PWM, RNG,
MDHA, SKHA, INTC, and FlexBus structures and
definitions in immap_5xxx.h to more unify modules
header files. Append DSPI support for m547x_8x.
SSI cleanup. Remove USB Host structure from immap_539.h.
Apply changes to use FlexBus structures in mcf52x2's
cpu_init.c and platform configuration files.
There were several, now there is one (two if you count the lower-case
versions).
Signed-off-by: Andy Fleming <afleming@freescale.com>
