path: root/include
2011-10-09powerpc/mpc8536ds: Save the env variables to SDcard and SPI flashXie Xiaobo
MPC8536DS offer booting from SDcard or SPI flash. This patch defined that u-boot can save the environment variables on SDcard or SPI flash when booting from the related device. The Env parameter region and linux kernel region have overlap in SPI-Flash, So change the Env param saving address. Signed-off-by: Xie Xiaobo <r63061@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-09powerpc/mpc8536ds: Add USB support for MPC8536DSFanzc
Add EHCI controller and USB command definition. Signed-off-by: Xie Xiaobo <r63061@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-09powerpc/mpc8536ds: Add eSPI support for MPC8536DSXie Xiaobo
1. The SD_DATA[4:7] signals are shared with the SPI chip selects on 8536DS, so don't set MPC85xx_PMUXCR_SD_DATA that config eSDHC data bus-width to 4-bit and enable SPI signals. 2. Add eSPI controller and SPI-FLASH definition. Signed-off-by: Xie Xiaobo <r63061@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-09powerpc/mpc8548cds: Update config filechenhui zhao
- Increase the size of malloc space. - Enable e1000 network card. - Show pci devices on startup. - Change the location of env address. - Use hwconfig to turn off ECC by default. [Kumar Gala] Fixed white space formating for CONFIG_EXTRA_ENV_SETTINGS Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-09powerpc/mpc86xx: Disable translation for BAT setupBecky Bruce
We really shouldn't be overwriting bat registers with translation enabled, especially when we're executing code using one of them for translating the current instruction stream. Instead, disable address translation while doing the final BAT setup. In order to do this, setup_bats has to move back to asm code, because we require translation to be enabled to have a stack for C code. The yucky thing about that is that the assembler doesn't like ULL so we have to switch to using HIGH/LOW pairs for physical addresses that are > 32 bits in length. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-09powerpc/mpc8641hpcn: fix SRIO BAT configBecky Bruce
There were duplicate (and conflicting) defines for the BATs used to cover SRIO. Drop the bogus set. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-09powerpc/85xx: CONFIG_ENABLE_36BIT_PHYS does not depend on CONFIG_PHYS_64BITTimur Tabi
The macro CONFIG_ENABLE_36BIT_PHYS is used to indicate that the given SOC is capable of 36-bit physical addresses, even if such large addresses are not used. On two boards, this macro was enabled only when building a 36-bit image. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-09powerpc/8xxx: Add support for interactive DDR programming interfaceYork Sun
Interactive DDR debugging provides a user interface to view and modify SPD, DIMM parameters, board options and DDR controller registers before DDR is initialized. With this feature, developers can fine-tune DDR for board bringup and other debugging without frequently having to reprogram the flash. To enable this feature, define CONFIG_FSL_DDR_INTERACTIVE in board header file and set an environment variable to activate it. Syntax: setenv ddr_interactive on After reset, U-boot prompts before initializing DDR controllers FSL DDR> The available commands are print print SPD and intermediate computed data reset reboot machine recompute reload SPD and options to default and recompute regs edit modify spd, parameter, or option compute recompute registers from current next_step to end next_step shows current next_step help this message go program the memory controller and continue with u-boot The first command should be "compute", which reads data from DIMM SPDs and board options, performs the calculation then stops before setting DDR controller. A user can use "print" and "edit" commands to view and modify anything. "Go" picks up from current step with any modification and compltes the calculation then enables the DDR controller to continue u-boot. "Recompute" does it over from fresh reading. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-09serial: uartlite: Support for SERIAL_MULTIMichal Simek
Add support for SERIAL MULTI for uartlite. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-10-09ppc: Fix DBSR_IAx defines in <bedbug/regs.h>Stefan Roese
While adding asm/cache.h to common.h for PPC targets, I got an error about multiple definitions of some DBSR_ macros. While scanning these defines, I noticed that some where defined not correctly for all PPC variants. So I removed all unused defines, and corrected the ones really used by bedbug (book-e vs. ppc40x). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2011-10-09ppc: Include <asm/cache.h> in common.hStefan Roese
This is needed for the patch "cache: add default setting for CONFIG_SYS_CACHELINE_SIZE" from Anton Staaf. As cache.h defines CONFIG_SYS_CACHELINE_SIZE for PPC targets. This will remove the following warnings/errors: include/common.h:819:2: warning: #warning CONFIG_SYS_CACHELINE_SIZE not defined, using __BIGGEST_ALIGNMENT__ cache.c:33: error: '__BIGGEST_ALIGNMENT__' undeclared (first use in this function) Signed-off-by: Stefan Roese <sr@denx.de> Cc: Anton Staaf <robotboy@chromium.org> Cc: Wolfgang Denk <wd@denx.de>
2011-10-05net: drop !NET_MULTI codeMike Frysinger
This is long over due. All but two net drivers have been converted, but those have now been dropped. The only thing left to do is actually delete all references to NET_MULTI and code that is compiled when that is not defined. So here we scrub the core code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05net: drop !NET_MULTI ns7520 driverMike Frysinger
This driver was never converted to NET_MULTI, and no board uses it. So punt it and be done. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05net: drop !NET_MULTI bcm570x/tigon3 driversMike Frysinger
These drivers have never been converted to NET_MULTI, and they are only used by one board (BMW). So drop the drivers until someone feels like rewriting them for NET_MULTI support. Rather than punting the BMW board completely, just disable net support in its board config. Seems to build fine without it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05image: push default arch values to arch headersMike Frysinger
This pushes the ugly duplicated arch ifdef lists we maintain in various image related files out to the arch headers themselves. Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Tested-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05km_arm: enable POST for these boardsValentin Longchamp
The current km_arm boards have a Power-On test jumper. When this jumper is set, this triggers some Power-On tests on the board. This patch enables the support of this jumper for starting the memory_regions test when the jumper is set. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-10-05km_arm: change CONFIG_SYS_TEXT_BASE to end of RAMValentin Longchamp
This allows to test a larger part of the RAM in the memory tests. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Cc: Heiko Schocher <hs@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-10-05POST: add new memory regions testValentin Longchamp
This test is similar to the actual POST memory test but quicker and far less complete. It checks the address and data lines and then only tests some regularly placed sub regions of the RAM. This can be useful when we want to test the RAM but we do not have enough time to run the full memory test. The POST memory test code was rearranged in order to avoid code duplication between the two tests but the memory test functionnality remains the same. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Ackey-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05POST: allow redefinition of post_word_load/storeValentin Longchamp
The predefinde post_word_load/store functions do not fit all boards, so we introduce a way to define post_word_load/store as externs in post.h that then can be defined in board specific files. This is done with the CONFIG_POST_EXTERNAL_WORD_FUNCS #define Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2011-10-04Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
* 'master' of git://git.denx.de/u-boot-nand-flash: PPC: Fix socrates NAND problem PPC: Fix fsl_upm.c by renaming nand handling functions NAND: Make page, erase, oob size available via cmd_nand mtd: eLBC NAND: remove elbc_fcm_ctrl->oob_poi NAND: Add -y option to nand scrub command NAND: Add nand read.raw and write.raw commands NAND: Really ignore bad blocks when scrubbing spl, nand: add 4bit HW ecc oob first nand_read_page function mxc_nand: fix a problem writing more than 32MB mxc_nand: fixed some typos (cosmetic) nand: increase chip_delay in mv kirkwood nand driver
2011-10-04Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mpc85xx: powerpc/p3060: Add SoC related support for P3060 platform powerpc/85xx: Add support for setting up RAID engine liodns on P5020 powerpc/85xx: Refactor some defines out of corenet_ds.h fm-eth: Add ability for board code to disable a port powerpc/mpc8548: Add workaround for erratum NMG_LBC103 powerpc/mpc8548: Add workaround for erratum NMG_DDR120 powerpc/mpc85xxcds: Fix PCI speed powerpc/mpc8548cds: Fix booting message powerpc/p4080: Add support for secure boot flow powerpc/85xx: Add Secure Boot support on P1010RDB for NOR, NAND & SPIFLASH powerpc/85xx: Add PBL & SECUREBOOT support on P3041/P5020DS boards powerpc/p2041rdb: remove watch dog related codes powerpc/p2041rdb: updated description of cpld command powerpc/p2041rdb: add more ddr frequencies support powerpc/p2041rdb: set sysclk according to status of physical switch SW1 powerpc/p2041rdb: update cpld reset command according to CPLD 2.0 powerpc/mpc8349emds: Migrate from spd_sdram to unified DDR driver powerpc/mpc83xx: Migrate from spd_sdram to unified DDR driver powerpc/mpc8xxx: Add DDR2 to unified DDR driver powerpc/mpc8xxx: Fix picos_to_mclk() and get_memory_clk_period_ps() powerpc/mpc8xxx: Add SPD EEPROM address for single controller 2 slots powerpc/mpc8xxx: Fix DDR code for empty first DIMM slot and enable DQS_en powerpc/85xx: Refactor P2041RDB to use common p_corenet files powerpc/85xx: refactor common P-Series CoreNet files for FSL boards powerpc/85xx: Enable CMD_REGINFO on corenet boards powerpc/85xx: p2041rdb - Remove unused 'execute' perm in TLB entries powerpc/85xx: Fix USB protocol definitions for P1020RDB powerpc/corenet_ds: Use separated speed tables for UDIMM and RDIMM powerpc/mpc8xxx: Move DDR RCW overriding to common code powerpc/mpc8xxx: Extend CWL table powerpc/85xx: Cleanup how SVR_MAJ() is defined on MPC8536 powerpc/85xx: Cleanup extern in corenet_ds board code powerpc/p2041rdb: Add ethernet support on P2041RDB board powerpc/85xx: Add networking support to P1023RDS powerpc/hydra: Add ethernet support on P5020/P3041 DS boards powerpc/85xx: Add FMan ethernet support to P4080DS powerpc/85xx: Add support for FMan ethernet in Independent mode powerpc/mpc8548cds: Cleanup mpc8548cds.c powerpc/mp: add support for discontiguous cores powerpc/85xx: corenet_ds - Remove unused 'execute' perm in TLB entries fdt: Add new fdt_create_phandle helper fdt: Rename fdt_create_phandle to fdt_set_phandle powerpc/85xx: Fix compile warnings/errors if CONFIG_SYS_DPAA_FMAN isn't set fsl_ifc: Add the workaround for erratum IFC A-003399(enabled on P1010) powerpc/P1010: Add workaround for erratum P1010-A003549 (related to IFC) fsl_ifc: Add the workaround for erratum IFC-A002769 (enable on P1010) powerpc/85xx: Expanding the window of CCSRBAR in AS=1 from 4k to 1M powerpc/85xx: Add NAND/NAND_SPL support to P1010RDB nand: Freescale Integrated Flash Controller NAND support powerpc/85xx: Add basic support for P1010RDB powerpc/85xx: Add support for new P102x/P2020 RDB style boards powerpc/85xx: relocate CCSR before creating the initial RAM area powerpc/85xx: introduce and document CONFIG_SYS_CCSRBAR macros powerpc/85xx: Enable internal USB UTMI PHY on p204x/p3041/p50x0 powerpc/85xx: Add ULPI and UTMI USB Phy support for P1010/P1014
2011-10-04Merge branch 'master' of git://git.denx.de/u-boot-microblazeWolfgang Denk
* 'master' of git://git.denx.de/u-boot-microblaze: microblaze: Enable FDT/FIT support microblaze: Remove address offset for uart16550 microblaze: Do not select NFS for platforms without ethernet microblaze: Clean up reset asm code microblaze: Save and restore first unused vector microblaze: Setup MB vectors if feature is enable for u-boot microblaze: Remove debug saving value
2011-10-04Revert "GCC4.6: Convert various empty macros to inline functions"Wolfgang Denk
This reverts commit 60ce53cf9f408d9ad721f8e7a87d6a564e6d5bac. The commit causes build breakage for a number of boards. This results from the fact that now the arguments of debug() actually get referenced (even if there is hope that the compiler will optimize away the debug() call). The obvious fix to that probem (change the code to always declare the referenced variables and data structures) increases the code size, and was this rejected. So it was decided to revert this commit until a better solution is found.
2011-10-03NAND: Really ignore bad blocks when scrubbingMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> [scottwood@freescale.com: use chip instead of redundant priv_nand] Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-03powerpc/85xx: Add support for setting up RAID engine liodns on P5020Kumar Gala
Add support for Job Queue/Ring LIODN for the RAID Engine on P5020. Each Job Queue/Ring combo needs one id assigned for a total of 4 (2 JQs/2 Rings per JQ). This just handles RAID Engine in non-DPAA mode. Signed-off-by: Santosh Shukla <santosh.shukla@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-03powerpc/85xx: Refactor some defines out of corenet_ds.hKumar Gala
Move some SoC/board specific defines out of corenet_ds.h and into the corresponding P3041DS/P4080DS/P5020.h. We moved CONFIG_MMC, CONFIG_PCIE3, & CONFIG_FSL_NGPIXIS because the P3060 SoC/reference board does not have these devices and it will share the same board code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-03fm-eth: Add ability for board code to disable a portKumar Gala
The SoC configuration may have more ports enabled than a given board actually can utilize. Add a routinue that allows the board code to disable a port that it knows isn't being used. fm_disable_port() needs to be called before cpu_eth_init(). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-03powerpc/p4080: Add support for secure boot flowRuchika Gupta
Pre u-boot Flow: 1. User loads the u-boot image in flash 2. PBL/Configuration word is used to create LAW for Flash at 0xc0000000 (Please note that ISBC expects all these addresses, images to be validated, entry point etc within 0 - 3.5G range) 3. ISBC validates the u-boot image, and passes control to u-boot at 0xcffffffc. Changes in u-boot: 1. Temporarily map CONFIG_SYS_MONITOR_BASE to the 1M CONFIG_SYS_PBI_FLASH_WINDOW in AS=1. (The CONFIG_SYS_PBI_FLASH_WINDOW is the address map for the flash created by PBL/configuration word within 0 - 3.5G memory range. The u-boot image at this address has been validated by ISBC code) 2. Remove TLB entries for 0 - 3.5G created by ISBC code 3. Remove the LAW entry for the CONFIG_SYS_PBI_FLASH_WINDOW created by PBL/configuration word after switch to AS = 1 Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Kuldip Giroh <kuldip.giroh@freescale.com> Acked-by: Wood Scott-B07421 <B07421@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-03powerpc/85xx: Add Secure Boot support on P1010RDB for NOR, NAND & SPIFLASHRuchika Gupta
2011-10-03powerpc/p2041rdb: set sysclk according to status of physical switch SW1Shaohui Xie
P2041RDB supports 3 sysclk frequencies, it's selected by SW1[6~8], software need to read the SW1 status to decide what the sysclk needs. SW1[8~6] : frequency 0 0 1 : 83.3MHz 0 1 0 : 100MHz others: 66.667MHz Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-03microblaze: Enable FDT/FIT supportMichal Simek
Enable FDT and FIT support. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-10-03microblaze: Remove address offset for uart16550Michal Simek
U-Boot BSP handle 0x3 offset for big endian systems. Little endian Microblaze systems don't use any offset. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-10-03microblaze: Do not select NFS for platforms without ethernetMichal Simek
Undefined network functionality for systems without ethernet and disable NFS support. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-10-01GCC4.6: Convert various empty macros to inline functionsMarek Vasut
Fix the following gcc4.6 problems: cmd_date.c: In function ‘do_date’: cmd_date.c:50:6: warning: variable ‘old_bus’ set but not used [-Wunused-but-set-variable] asix.c: In function ‘asix_init’: asix.c:317:6: warning: variable ‘rx_ctl’ set but not used [-Wunused-but-set-variable] usb.c: In function ‘usb_parse_config’: usb.c:331:17: warning: variable ‘ch’ set but not used [-Wunused-but-set-variable] usb.c: In function ‘usb_hub_port_connect_change’: usb.c:1123:29: warning: variable ‘portchange’ set but not used [-Wunused-but-set-variable] usb.c: In function ‘usb_hub_configure’: usb.c:1183:25: warning: variable ‘hubsts’ set but not used [-Wunused-but-set-variable] usb_storage.c: In function ‘usb_stor_CB_reset’: usb_storage.c:466:6: warning: variable ‘result’ set but not used [-Wunused-but-set-variable] Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2011-10-01sbc82xx: delete support for obsolete SBC8240/SBC8260Paul Gortmaker
The EST SBC8260 is over 10 years old, and the SBC8240 older than that. With the tiny amount of RAM (by today's standards), there really isn't anyone interested in running the latest U-boot on these EOL products anymore. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> CC: jon.diekema@smiths-aerospace.com
2011-10-01Add missing header for gcc3Scott McNutt
When include/linux/compiler.h is included, the associated gcc3 header is required for older build environments. Signed-off-by: Scott McNutt <smcnutt@psyent.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-01ns16550: change to allow 32 bit access to registersDave Aldridge
If CONFIG_SYS_NS16550_MEM32 is defined then 32 bit memory mapped access will be used to read/write the uart registers. This is especially useful for SoC devices that implement 16550 compatible uarts but that have peripheral access width constraints. Signed-off-by: Dave Aldridge <fovsoft@gmail.com>
2011-10-01fat: replace LINEAR_PREFETCH_SIZE with PREFETCH_BLOCKSSergei Shtylyov
Currently in do_fat_read() when reading FAT sectors, we have to divide down LINEAR_PREFETCH_SIZE by the sector size, whereas it's defined as 2 sectors worth of bytes. In order to avoid redundant multiplication/division, introduce #define PREFETCH_BLOCKS instead of #define LINEAR_PREFETCH_SIZE. Signed-off-by: Sergei Shtylyov <sshtylyov@mvista.com>
2011-10-01fat: fix crash with big sector sizeSergei Shtylyov
Apple iPod nanos have sector sizes of 2 or 4 KiB, which crashes U-Boot when it tries to read the boot sector into 512-byte buffer situated on stack. Make the FAT code indifferent to the sector size. Signed-off-by: Sergei Shtylyov <sshtylyov@mvista.com>
2011-10-01Merge branch 'post' of git://git.denx.de/u-boot-blackfinWolfgang Denk
* 'post' of git://git.denx.de/u-boot-blackfin: Blackfin: uart: implement loop callback for post Blackfin: bf537-stamp/bf548-ezkit: update POST flash block range Blackfin: post: generalize led/button tests with GPIOs Blackfin: bf537-stamp: drop uart/flash post tests Blackfin: post: drop custom test list Blackfin: bf537-stamp: convert to gpio post hotkey
2011-09-30EfikaSB: Add preliminary EfikaSB supportMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de>
2011-09-30vision2: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-09-30zmx25: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Cc: Matthias Weisser <weisserm@arcor.de> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-30mx53evk: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Jason Liu <jason.hui@linaro.org>
2011-09-30mx53ard: Place machine ID into board configFabio Estevam
2011-09-30mx53smd: Place machine ID into board configFabio Estevam
2011-09-30mx53loco: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Jason Liu <jason.hui@linaro.org>
2011-09-30mx51evk: Place machine ID into board configFabio Estevam
2011-09-30imx31_litekit: Place machine ID into board configFabio Estevam
