As this symbol can either be a fixed value or the function
get_board_ddr_clk, migration is tricky. Introduce a choice of DYNAMIC
or STATIC_DDR_CLK_FREQ. If DYNAMIC, we continue to use the board
defined get_board_ddr_clk function. If STATIC, set CONFIG_DDR_CLK_FREQ
to that value and now include/clock_legacy.h contains the function
prototype or defines get_board_ddr_clk() to that static value. Update
callers to test for DYNAMIC or STATIC.
We have a number of CONFIG symbols to express the fixed size of system
memory. For now, rename CONFIG_DDR_FIXED_SIZE to CONFIG_SYS_SDRAM_SIZE
and adjust usage to match that CONFIG_SYS_SDRAM_SIZE expects the entire
size rather than MiB.
Cc: Marek Behún <marek.behun@nic.cz>
Cc: Stefan Roese <sr@denx.de>
Acked-by: Marek Behún <marek.behun@nic.cz>
Move CONFIG_DDR_32BIT/64BIT to Kconfig as a choice for Armada XP
platforms. Make 64bit the default as this mirrors the current code.
These symbols are now either unused or were only used within the config
file to determine other logic, which could be done in a way that doesn't
further pollute the CONFIG namespace.
Rather than using CONFIG namespace for logic internal to
include/configs/astro_mcf5373l.h to select ASTRO_ID (and populate the
default environment), strip CONFIG from the various options used and
set.
Update the comment here to refer to PCI_CONFIG_ADDRESS rather than
CONFIG_ADDRESS.
This driver is currently unused. Remove.
This removes a number of spots of dead code based on symbols that start
with CONFIG_[0-9] or CONFIG_A.
This driver uses the CONFIG namespace to set the chips internal CONFIG
namespace related bits. However, CONFIG is reserved for the top-level
Kconfig based configuration system. Use CFG as the namespace here
instead to avoid pollution.
There are an assortment of hard-coded CONFIG_BOOTCOMMAND options in some
board headers. Rework these so that they do not add to the CONFIG
namespace.
Migrate CONFIG_GICV2 and CONFIG_GICV3 to Kconfig. We still have the GIC
related registers that need to be handled more cleanly but start by
moving this symbol to Kconfig.
CONFIG_I2C_SET_DEFAULT_BUS_NUM
CONFIG_I2C_DEFAULT_BUS_NUMBER
Remove the irrelevant section from the README and remove the
non-functional SPL-undef section.
- As there are no boards that use different values for speed / slave on
different buses, use a single option.
- Switch to using the common SYS_I2C_SPEED / SYS_I2C_SLAVE options.
- Introduce _HAS_ options for additional buses as only the first one is
common to all users.
- Convert all remaining symbols to Kconfig.
- Migrate SYS_I2C_SH and related defines to Kconfig
- Remove currently unused SYS_I2C_SH related defines
- Cleanup related README section.
Cc: Marek Vasut <marek.vasut+renesas@gmail.com>
CONFIG_SYS_I2C_MXC
CONFIG_SYS_I2C_MXC_I2C1
CONFIG_SYS_I2C_MXC_I2C2
CONFIG_SYS_I2C_MXC_I2C3
CONFIG_SYS_I2C_MXC_I2C4
CONFIG_SYS_I2C_SPEED
CONFIG_SYS_I2C_SLAVE
The omap24xx I2C driver uses its own CONFIG namespace for common I2C
variables. Rather than convert more of them to Kconfig, rename these to
the common I2C ones and remove the entirely unused functionality. As
part of this, we make the am335x_shc platforms consistent with their
intended speed values.
Convert SYS_I2C_EARLY_INIT to Kconfig, and make it depend on
SPL_SYS_I2C_LEGACY. Remove the weak implementation as it's either
something that needs to exist for real, or shouldn't be called.
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot
have SYS_I2C_LEGACY and DM_I2C at the same time, introduce
CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only
in SPL. Finally, for some PowerPC cases we also need
CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to
one or more symbols.
CONFIG_SYS_I2C_MVTWSI
CONFIG_SYS_I2C_SOFT
CONFIG_SYS_I2C_SOFT_SPEED
CONFIG_SYS_I2C_SOFT_SLAVE
- Rename usages of CONFIG_SYS_DEF_EEPROM_ADDR to CONFIG_SYS_I2C_EEPROM_ADDR
based on current usage.
- Convert CONFIG_SYS_I2C_EEPROM_ADDR, CONFIG_SYS_I2C_EEPROM_ADDR_LEN,
CONFIG_SYS_I2C_EEPROM_BUS, CONFIG_CONFIG_SYS_EEPROM_SIZE
CONFIG_SYS_EEPROM_PAGE_WRITE_BITS and CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS
to Kconfig. We move these symbols around a bit and add appropriate
dependencies to them. In some cases, we now add a correct default value
as well.
At this point in time, there's no systems with "U-Boot environment
exists on an EEPROM which is accessed over the I2C bus" that sets this
option. Drop it.
Finish moving this driver to Kconfig.
- Update the dependency logic for Exynos5 too
- Remove the unused CONFIG_SYS_I2C_S3C24X0_SPEED variable
- Drop CONFIG_SYS_I2C_S3C24X0_SLAVE as it's always set to 0.
- Move the internal SYS_I2C_S3C24X0_SLAVE define closer to the only user.
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
CONFIG_ID_EEPROM
The instances of CONFIG_SYS_I2C_EEPROM_ADDR on these platforms doesn't
match up with the rest of the EERPOM related defines in U-Boot. Move
these out of the CONFIG namespace rather than make complex Kconfig
logic.
Cc: Samuel Egli <samuel.egli@siemens.com>
Reviewed-by: Anatolij Gustschin <agust@denx.de>
As the code reads now, making this code path use
CONFIG_SYS_IVM_EEPROM_ADR rather than CONFIG_SYS_I2C_EEPROM_ADDR seems
to make sense as the rest of the EEPROM infrastructure isn't used on
these platforms.
Cc: Aleksandar Gerasimovski <aleksandar.gerasimovski@hitachi-powergrids.com>
Reviewed-by: Aleksandar Gerasimovski <aleksandar.gerasimovski@hitachi-powergrids.com>
The shc platforms do not make use of the rest of the EEPROM
infrastructure. Rather than make more elaborate Kconfig logic, remove
this setting from the CONFIG namespace.
This platform does not use any of the standard EEPROM functionality and
instead provides its own. Use a local namespace for the I2C related
defines to access the EEPROM.
Cc: Lukasz Majewski <lukma@denx.de>
Acked-by: Lukasz Majewski <lukma@denx.de>
This code is no longer used, remove it.
Rework the default environment a bit to not use non-standard
CONFIG_ENV_... names and similar one-off CONFIG names.
Rename CONFIG_ENV_KS2_BOARD_SETTINGS to ENV_KS2_BOARD_SETTINGS so that
it better fits with the rest of the environment addition macros.
Cc: Vitaly Andrianov <vitalya@ti.com>
Rename CONFIG_EXTRA_ENV_BOARD_SETTINGS to EXTRA_ENV_BOARD_SETTINGS in
order to not further add to the CONFIG namespace.
There are a number of DWC2 configuration options that are set in dwc2.h
and referenced in dwc2.c only. Move these out of the CONFIG_DWC2
namespace and in to the DWC2 namespace. Note that hikey was defining an
option that was already always enabled, so we can remove that hunk.
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze
Xilinx changes for v2021.10-rc3
xilinx:
- Disable CONFIG_ARCH_FIXUP_FDT_MEMORY
- Print information about cpu via soc drivers and enable DISPLAY_CPUINFO
- Wire infrastructure for DTB_RESELECT and MULTI_DTB_FIT
zynq:
- Wire single QSPI
- Use power-source instead of io-standard properties
- Enable nor on zc770-xm012
zynqmp:
- Change handling around multi_boot()
- Setup offset for u-boot.itb in spi
- Generate run time dfu_alt_info for capsule update
- Use explicit values for enums (zynqmp_firmware.h)
- Enable RTC/SHA1/BUTTON/BUTTON_GPIO command
- Disable WDT driver by default
- Bind usb/scsi via preboot because of EFI
- DT updates/fixes
- Add soc driver
- Fix SPL SPI boot mode
versal:
- Add soc driver
sdhci:
- Update tap delay programming for zynq_sdhci driver
cmd:
- Fix RTC uclass handling in date command
- Update pwm help message
- Update reset help message
watchdog:
- Fix wwdt compilation
rtc:
- Deal with seq alias in rtc uclass
- Add zynqmp RTC driver
fdt:
- Add kernel-doc for fdt_fixup_memory_banks()
Move tapdelay function calls to zynq_sdhci.c and make them static
inline. zynqmp_tap_delay.h has function prototypes for the functions
defined in tap_delays.c, which will not be needed anymore.
Remove tap_delays.c and zynqmp_tap_delay.h files.
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
Currently xilinx sdhci driver is using zynqmp_mmio_write() to set
tapdelay values and DLL resets. Continue to use this for SPL and mini
U-Boot where U-Boot will be executed at EL3 level.
Use firmware call xilinx_pm_request() using appropriate arguments to
set input/output tapdelays and also for DLL resets in regular flow(EL2).
Host driver should explicitly request DLL reset before ITAP (assert DLL)
and after OTAP (release DLL) to avoid issues in some cases. Also handle
error return where possible.
Signed-off-by: T Karthik Reddy <t.karthik.reddy@xilinx.com>
Add CONFIGs for N5X.
Signed-off-by: Siew Chin Lim <elly.siew.chin.lim@intel.com>
Add clock manager driver for N5X. Provides clock initialization
and get_rate functions.
Rename to common file name to used by all SOC64 devices and change
"_S10_" to "_SOC64_" in base_addr_soc64.h.
https://source.denx.de/u-boot/custodians/u-boot-efi
Pull request for efi-2021-10-rc3
Documentation:
* Rename Freescale to NXP
* Document structures used for the UEFI TCG2 protocol
UEFI:
* Device paths must use EfiBootServicesData
fsl-qoriq: Fixes related to env, spi, usb, crypto, configs, distro-boot
for Layerscape Boards like lx2, sl28, ls2088ardb.
powerpc: Fixes for t208xrdb revd board and cortina related configs
update for T208xRDB, T4240RDB.
Add function to apply a bitmask to an i2c register, so
that specific bits can be cleared and/or set.
Suggested-by: Simon Glass <sjg@chromium.org>
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.com>
Update boot-commands to load device-tree from
boot-device at 'fdt_addr_r' address in DDR
during distro-boot.
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
Use moveconfig.py script to convert below defines to Kconfig and move
these entries to defconfigs.
CONFIG_CORTINA_FW_ADDR
CONFIG_CORTINA_FW_LENGTH
Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
This symbol was largely migrated, except for one case. Update it.
Cc: Priyanka Jain <priyanka.jain@nxp.com>
Use enum efi_memory_type and enum_allocate_type in the definitions of the
efi_allocate_pages(), efi_allocate_pool().
In the external UEFI API leave the type as int as the UEFI specification
explicitely requires that enums use a 32bit type.
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Use the same name as in the UEFI specification to avoid confusion.
