Fix CONFIG_SYS_INIT_SP_ADDR undefined issue.
Signed-off-by: Zhong Hongbo <bocui107@gmail.com>
For example, an input of 0x80000000 should print:
2147.484 instead of -2147.-483.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
If no Flash is connected to cs1, Linux crashes, because
reg entries are not correct adapted.
Following fix is needed:
- swap base addresses in CONFIG_SYS_FLASH_BANKS_LIST, as
flash bank 1 is on chipselect 0 and flash bank 2 on
chipselect 1
- call fdt_fixup_nor_flash_size() from ft_board_setup()
cc: Wolfgang Denk <hs@denx.de>
cc: Werner Pfister <Pfister_Werner@intercontrol.de>
cc: Detlev Zundel <dzu@denx.de>
Currently, pixis_reset altbank does not work properly. This patch
uses the correct mask to boot into the alternate bank.
Signed-off-by: Matthew McClintock <msm@freescale.com>
DKB is a Development Board for PANTHEON TD/TTC(pxa920/pxa910) with
* Processor upto 806Mhz
* LPDDR1/2
* x8/x16 SLC/MLC NAND
* Footprints for eMMC & MMC x8 card
With Peripherals:
* Parallel LCD I/F
* Audio codecs (88PM8607)
* MIPI CSI-2 camera
* Marvell 88W8787 802.11n/BT module
* Marvell 2G/3G RF
* Dual analog mics & speakers, headset jack, LED, ambient
* USB2.0 HS host, OTG (mini AB)
* GPIO, GPIO expander with DIP switches for easier selection
* UART serial over USB, CIR
This patch adds basic board support with DRAM and UART functionality
Signed-off-by: Lei Wen <leiwen@marvell.com>
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
Since there are lots of difference between kirkwood and armada series,
it is better to seperate them but still keep the most common file
shared by all marvell platform in the mv-common configure file.
This patch move the kirkwood only driver definitoin in mv-common to
the <soc_name>/config.h.
This patch is tested with compilation for armada100 and guruplug.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Use board_early_init_f so that the full boot log output can be displayed.
Port USB gadget RNDIS protocol support from linux-2.6.26
(.27 gadget stack actually has composite drivers).
Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
Port struct net_device_stats and statistics collecting needed for
RNDIS protocol.
Driver originally written by NVIDIA Corporation, modified to
handle odd-length packets.
This adds support for using USB Ethernet dongles in host mode. This is just
the framework - drivers will come later. A new config option called
CONFIG_USB_HOST_ETHER can be defined in board config files to switch this
on.
The was originally written by NVIDIA and was cleaned up for release by the
Chromium authors.
Changed both to use a common timeout for URB submission, since they were using
different values and EHCI's was too short.
Also fixed EHCI to actually check if urb submission succeeded, rather than
silently continuing into the weeds.
Change-Id: I7f71499ffaa05187d8e5618db2419e1606007b82
Fix the problem which cannot build the U-boot, if we only set
the CONFIG_ENV_IS_IN_SPI_FLASH.
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
The SC520 has an inbuilt MC146818 - Enable it for the eNET board
Board EEPROM is used to read/save Ethernet MAC addresses.
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Board support for the Guntermann & Drunck DLVision-10G.
Adds support for multiple FPGAs per board for gdsys 405ep
architecture.
Adds support for dual link osd hardware for gdsys 405ep.
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
Use SPMR instead of HRCWL when calculating clocks as HCRWL
may be changed and the CPU will not pick up all changes
until there is a POR. u-boot will think SPMF has changed and get
the clocks wrong.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
This patch fix a problem for the pcie enumeration when the mpc83xx
pcie controller is connected with switch or we use both of the two
pcie controller.
Signed-off-by: Leo Liu <liucai.lfn@gmail.com>
fix codingstyle and compiler warning: 'pcie_priv' defined but not used
At the same time, fix up CPU_CLOCK_RATE to have the CONFIG_ prefix to
work with boards.cfg.
Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
disabled
Some VCT boards lacks the support of networking or USB.
Additionally that support is disabled in small image
configurations.
If CONFIG_CMD_NET should not used the CONFIG_CMD_NFS option
have to be disabled too. Otherwise the linker fails with
unresolved symbols.
If CONFIG_VCT_SMALL_IMAGE is set than CONFIG_CMD_NET and
CONFIG_CMD_USB are disabled at the end of vct.h.
This is not adequate because CONFIG_CMD_USB enables additional
options and the linker fails again with unresolved symbols.
This patch adds an early check against CONFIG_VCT_SMALL_IMAGE
so the additional options are only enabled if they are really
needed.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Using hwconfig to turn on/off ECC, without re-compiling.
Signed-off-by: York Sun <yorksun@freescale.com>
Also removed duplicate CONFIG_CMD_IRQ define.
The R0P7757LC0030RL board has SH7757, 256MB DDR3-SDRAM, SPI ROM,
Ethernet, and more.
This patch supports the following functions:
- 256MB DDR3-SDRAM
- SPI ROM
- Ethernet
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the
unnecessary config.mk file.
