CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
Add a new function to activate an existing simple frame buffer node
and add the associated reserved memory, with no-map properties.
This device tree update is only done when the video device is active
and the video buffer is used.
This patch uses '#if CONFIG_IS_ENABLED(DM_VIDEO)' because
gd->video_bottom and gd->video_top are only defined when CONFIG_DM_VIDEO
is activated.
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
Add the helper function video_is_active() to test if one video device
is active.
This function can be used in board code to execute operation
only when the display is probed / really used.
Rename the function named lcd_dt_simplefb* to fdt_simplefb* to be aligned
with the associated file name fdt_simplefb.h/fdt_simplefb.c
Reviewed-by: Matthias Brugger <mbrugger@suse.com>
CONFIG_LCD_DT_SIMPLEFB
This patch also renames this config to CONFIG_FDT_SIMPLEFB as the code in
common/lcd_simplefb.c support CONFIG_LCD and CONFIG_VIDEO.
The Micrel PHYs on known DHSOM based boards take a while to come out
of reset, increase the auto-negotiation timeout to prevent it from
timing out in case the ethernet is used right after the board was
reset.
Cc: Patrice Chotard <patrice.chotard@foss.st.com>
Cc: Patrick Delaunay <patrick.delaunay@foss.st.com>
Reviewed-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Add script to read U-Boot from SD card and write it to matching
locations in the SPI NOR, thus making the SPI NOR bootable. The
script erases the entire SPI NOR, including U-Boot environment,
to make sure the installation is clean. To retain environment
from current running U-Boot, run 'saveenv' after running the
'update_sf' script.
The USB hub on STM32MP1 DHCOM boards needs to wait a bit longer until
the USB Vbus is stable. Increase the USB power-good delay to 1 s.
This adds default-undefined STM32MP_BOARD_EXTRA_ENV variable into
stm32mp15_common.h to reduce duplication in board-specific config
files adding custom environment.
Prepare v2022.01-rc3
Add a function that returns the number of devices in a uclass. This can be
helpful in sizing an array that needs to hold a list of them.
In some cases it is useful to search just by a partial name, such as
when looking for a sibling device that has a common name substring. Add
helper functions to handle these requirements.
At present we support reading a string list a string at a time. Apart
from being inefficient, this makes it impossible to separate reading of
the devicetree into the of_to_plat() method where it belongs, since any
code which needs access to the string must read it from the devicetree.
Add a function which returns the string property as an array of pointers
to the strings, which is easily used by clients.
The details for of_property_read_string_helper() and
ofnode_read_string_index() are a little inaccurate. Fix up the comments to
avoid confusion.
This method is currently called after the platform data has been freed.
But the pre_unbind() method may wish to access this, e.g. to free some
data structures stored there.
Split the unbinding of devices into two pieces, as is done with removal.
This corrects the problem.
Also tidy a code-style issue in device_remove() while we are here.
Add the opposite of mapping, so that we can unmap and avoid running out of
address space.
This text should never change during execution, so it makes sense to
use a const char * so that it can be declared as const in the code.
Update struct cmd_tbl with a const char * pointer for 'help'.
We cannot make usage const because of the bmode command, used on mx53ppd
for example.
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Adds TEE_ERROR_SHORT_BUFFER as TEE error code. This error code is
commonly used by TEEs to inform caller that the buffer(s) it provided
is too small for the desired operation.
Cc: Jens Wiklander <jens.wiklander@linaro.org>
Reviewed-by: Jens Wiklander <jens.wiklander@linaro.org>
Signed-off-by: Etienne Carriere <etienne.carriere@linaro.org>
Define identifiers for clnt_login field in struct tee_open_session_arg
based in GlobalPlatform Device TEE IDs and on the REE_KERNEL identifier
extension from OP-TEE OS.
Correct inline comment describing API function devm_scmi_process_msg().
Certain serial SERDES protocols like 1000base-x, 2500base-x, SGMII,
USXGMII can operate either in a mode where the PHY (be it on-board or
inside an SFP module) passes the link parameters (speed, duplex, pause)
to the MAC through in-band through control words standardized by IEEE
802.3 clause 37, or in a mode where the MAC must configure (force) its
link parameters based on information obtained out-of-band (MDIO reads,
guesswork etc).
In Linux, the OF node property named "managed" is parsed by the phylink
framework, and the convention is that if a driver uses phylink, then the
presence of this property means that in-band autoneg should be enabled,
otherwise it shouldn't.
To be compatible with the OF node bindings of drivers that use phylink
in Linux, introduce parsing support for this property in U-Boot too.
Signed-off-by: Vladimir Oltean <vladimir.oltean@nxp.com>
Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
In the current DSA switch driver API, only the udevice of the switch
(belonging to UCLASS_DSA) is exposed, as well as an "int port" argument.
So drivers do not have access to the udevice of individual ports
(belonging to UCLASS_ETH), one of the reasons being that not all ports
have an associated UCLASS_ETH udevice.
However, all DSA ports have an OF node, and in some cases the driver
needs a handle to it, for all ports including the CPU port. Example: the
following Linux per-port device tree property:
managed = "in-band-status";
states whether a port should operate with clause 37 in-band autoneg
enabled or not.
This patch exposes a function which can be called by individual drivers
as needed.
This is needed for the VLAN header structure.
The Freescale TSEC can be a DSA master, and the ports of the attached
DSA switch can have different MAC addresses compared to the TSEC.
Nonetheless, the TSEC must receive the packets on behalf of those switch
ports. Therefore, implement the promiscuous mode method to allow DSA to
set this.
Note that the init_registers() function called from eth_ops :: start
overwrites this setting. There is no reason why the RCTRL register
should be zero-initialized, so just stop clearing it so that the setting
we applied in eth_ops :: set_promisc sticks.
We have implemented all what is new in UEFI specification 2.9 and relevant
for U-Boot.
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Implement the EFI_EVENT_GROUP_BEFORE_EXIT_BOOT_SERVICES event group
handling.
Add the definition of EFI_EVENT_GROUP_AFTER_READY_TO_BOOT.
Fix incorrect Sphinx comments in efi_api.h:
* add missing 'struct'
* correct indentation
This commit adds the comment for efi_system_table and
efi_configuration_table structure.
Signed-off-by: Masahisa Kojima <masahisa.kojima@linaro.org>
lmb_size_bytes() is unused.
Acked-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
The extern keyword is not needed in include/lmb.h to declare functions.
Remove it.
Correct Sphinx style comments in include/lmb.h
Add the logical memory block API to the HTML documentation.
Defining static functions in includes should be avoided.
Function lmb_is_nomap() is only used in the unit test.
So move it to the unit test.
If bootloader was updated without running oem format, reboot will cause
boot loop because the SYSTEM stage fails.
Add a final PANIC stage running fastboot to permit recovery.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Signed-off-by: Mattijs Korpershoek <mkorpershoek@baylibre.com>
This can lead to GPT and BCB errors even if fastboot was selected early
by usb rom boot and the eMMC is blank/invalid.
AST2600 leverages the FIT hash/signature verification to fulfill
secure boot trust chain. To improve the performance and save SW
code size for those crypto operations, the two HW crypto engine,
HACE and ACRY, are enabled.
However, both of the engines can only access to data stored in
DRAM space. Therefore, we need to move the FIT image into DRAM
before the booting.
This patch update the CONFIG_BOOTCOMMAND to execute the pre-defined
ENV variable which consists of FIT image copy to memory and booting.
Signed-off-by: Chia-Wei Wang <chiawei_wang@aspeedtech.com>
Move CONFIG_EXTRA_ENV_SETTINGS to board-specific
configuration headers.
Lot of PCIe controllers are using ECAM addressing. So add common ECAM
macros into U-Boot's pci.h header file which can be suitable for most
PCI controller drivers.
Replace custom ECAM address macros in every PCI controller driver by new
ECAM macros from U-Boot's pci.h header file.
Similar macros are defined also in Linux kernel. There is a small
difference between Linux and these new U-Boot macros.
U-Boot's PCIE_ECAM_OFFSET() takes device and function numbers in separate
arguments. Linux's PCIE_ECAM_OFFSET() takes device and function numbers
encoded in one argument. The reason is that U-Boot's PCI_DEVFN() macro is
different than Linux's PCI_SLOT() macro. So having device and function
numbers in separate arguments makes code more straightforward.
Signed-off-by: Pali Rohár <pali@kernel.org>
This has different semantics in different places. Go with the bootm method
and put it in a common function so that the behaviour is consistent in
U-Boot. Update the docs.
To be clear, this changes the way that 'bootelf' and standalone boot
work. Before, if autostart was set to "fred" or "YES", for example, they
would consider that a "yes". This may change behaviour for some boards,
but the only in-tree boards which mention autostart use "no" to disable
it, which will still work.
Suggested-by: Wolfgang Denk <wd@denx.de>
Use a text file for the environment instead of the #define settings.
Reviewed-by: Marek Behún <marek.behun@nic.cz>
At present U-Boot environment variables, and thus scripts, are defined
by CONFIG_EXTRA_ENV_SETTINGS. It is painful to add large amounts of text
to this file and dealing with quoting and newlines is harder than it
should be. It would be better if we could just type the script into a
text file and have it included by U-Boot.
Add a feature that brings in a .env file associated with the board
config, if present. To use it, create a file in a board/<vendor>
directory, typically called <board>.env and controlled by the
CONFIG_ENV_SOURCE_FILE option.
The environment variables should be of the form "var=value". Values can
extend to multiple lines. See the README under 'Environment Variables:'
for more information and an example.
In many cases environment variables need access to the U-Boot CONFIG
variables to select different options. Enable this so that the environment
scripts can be as useful as the ones currently in the board config files.
This uses the C preprocessor, means that comments can be included in the
environment using /* ... */
Also support += to allow variables to be appended to. This is needed when
using the preprocessor.
Tested-by: Marek Behún <marek.behun@nic.cz>
This is a complicated set of #defines and it is painful to convert to a
text file. We can (once pending patches are applied) provide the same
functionality with bootmethod. Drop this for sandbox to allow conversion
to a text-file environment.
Compiler is not happy:
common/image-board.c: In function ‘boot_get_kbd’:
common/image-board.c:902:17: warning: implicit declaration of function ‘do_bdinfo’ [-Wimplicit-function-declaration]
902 | do_bdinfo(NULL, 0, 0, NULL);
Move the forward declaration to a header.
Fix dfu_alt_info to use nor1 instead of the device name.
This reverts a part of commit 59bd18d4c4d7 ("configs: synquacer:
Remove mtdparts settings and update DFU setting") because the
commit a4f2d8341455 ("mtd: spi: nor: force mtd name to "nor%d"")
changed the mtd device naming scheme to nor%d.
Signed-off-by: Masami Hiramatsu <masami.hiramatsu@linaro.org>
"TQ-Systems" is written with a dash.
Signed-off-by: Matthias Schiffer <matthias.schiffer@ew.tq-group.com>
https://source.denx.de/u-boot/custodians/u-boot-efi
Pull request for efi-2022-01-rc2-2
UEFI:
* fix measurement of BootOrder variable for TCG2 protocol
TPM:
* TIS mmio driver. This driver supports QEMU's emulated TPM.
CONFIG_LAST_STAGE_INIT
This symbol has been functionally dead for a long time. Remove the last
and recent re-introductions of setting it, and update the whitelist so
it will not be re-introduced again.
CONFIG_PL011_SERIAL
CONFIG_PL01X_SERIAL
CONFIG_MACB
CONFIG_MD5
CONFIG_MX6
CONFIG_MX7
