path: root/include
2016-09-26armv8: ls1012a: Convert CONFIG_LS1012A to Kconfig option ARCH_LS1021AYork Sun
Move this config to Kconfig option and clean up existing uses. Signed-off-by: York Sun <york.sun@nxp.com> CC: Calvin Johnson <calvin.johnson@nxp.com> CC: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-26driver: ddr: fsl_mmdc: Pass board parameters through data structureYork Sun
Instead of using multiple macros, a data structure is used to pass board-specific parameters to MMDC DDR driver. Signed-off-by: York Sun <york.sun@nxp.com> CC: Shengzhou Liu <Shengzhou.Liu@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-26armv8: ls1046a: Convert CONFIG_LS1046A to Kconfig option ARCH_LS1046AYork Sun
Move this option to Kconfig and clean up existing uses. Signed-off-by: York Sun <york.sun@nxp.com> CC: Mingkai Hu <mingkai.hu@nxp.com> CC: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-14armv8: ls1046aqds: Add LS1046AQDS board supportShaohui Xie
LS1046AQDS Specification: ------------------------- Memory subsystem: * 8GByte DDR4 SDRAM (64bit bus) * 128 Mbyte NOR flash single-chip memory * 512 Mbyte NAND flash * 64 Mbyte high-speed SPI flash * SD connector to interface with the SD memory card Ethernet: * Two XFI 10G ports * Two SGMII ports * Two RGMII ports PCIe: supports Gen 1 and Gen 2 SATA 3.0: one SATA 3.0 port USB 3.0: two micro AB connector and one type A connector UART: supports two UARTs up to 115200 bps for console Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> Signed-off-by: Mingkai Hu <mingkai.hu@nxp.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-14armv8: ls1046ardb: Add LS1046ARDB board supportMingkai Hu
LS1046ARDB Specification: ------------------------- Memory subsystem: * 8GByte DDR4 SDRAM (64bit bus) * 512 Mbyte NAND flash * Two 64 Mbyte high-speed SPI flash * SD connector to interface with the SD memory card * On-board 4G eMMC Ethernet: * Two XFI 10G ports * Two SGMII ports * Two RGMII ports PCIe: * PCIe1 (SerDes2 Lane0) to miniPCIe slot * PCIe2 (SerDes2 Lane1) to x2 PCIe slot * PCIe3 (SerDes2 Lane2) to x4 PCIe slot SATA: * SerDes2 Lane3 to SATA port USB 3.0: one super speed USB 3.0 type A port one Micro-AB port UART: supports two UARTs up to 115200 bps for console Signed-off-by: Mingkai Hu <mingkai.hu@nxp.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-14Export memset for standalone AQ FW load appsShaohui Xie
The 'commit 95279315076c ("board/ls2085rdb: Export functions for standalone AQ FW load apps")' mentioned memset was exported but it was not, this patch exports the memset. Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-14driver/ddr/fsl: Add general MMDC driver and reuse common MMDC driver for ls1012aShengzhou Liu
This general MMDC driver adds basic support for Freescale MMDC (Multi Mode DDR Controller). Currently MMDC is integrated on ARMv8 LS1012A SoC for DDR3L, there will be a update to this driver to support more flexible configuration if new features (DDR4, multiple controllers/chip selections, etc) are implimented in future. Meantime, reuse common MMDC driver for LS1012ARDB/LS1012AQDS/ LS1012AFRDM. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-14nxp: ls102xa: add LS1 PSCI system suspendHongbo Zhang
The deep sleep function of LS1 platform, is mapped into PSCI system suspend function, this patch adds implementation of it. Signed-off-by: Hongbo Zhang <hongbo.zhang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-14nxp: ls102xa: add registers definition for system sleepHongbo Zhang
This patch adds definitions of all the regesters necessary for system sleep. Signed-off-by: Hongbo Zhang <hongbo.zhang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-14armv8: ls2080a: Remove debug server supportYork Sun
Debug server feature has been dropped from roadmap. Signed-off-by: York Sun <york.sun@nxp.com>
2016-09-14fsl: csu: add an API to set R/W permission to PCIeHou Zhiqiang
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-14fsl: csu: add an API to set individual device access permissionHou Zhiqiang
Add this API to make the individual device is able to be set to the specified permission. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-14driver/ddr/fsl: Add more debug registersYork Sun
32 more debug registers are added for newer DDR controllers. Signed-off-by: York Sun <york.sun@nxp.com> Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com>
2016-09-09Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-09-07efi_loader: provide efi_mem_desc versionMian Yousaf Kaukab
Provide version of struct efi_mem_desc in efi_get_memory_map(). EFI_BOOT_SERVICES.GetMemoryMap() in UEFI specification v2.6 defines memory descriptor version to 1. Linux kernel also expects descriptor version to be 1 and prints following warning during boot if its not: Unexpected EFI_MEMORY_DESCRIPTOR version 0 Signed-off-by: Mian Yousaf Kaukab <yousaf.kaukab@gmail.com>
2016-09-07compiler.h: use system endian macros on OpenBSDJonathan Gray
The u-boot endian macros map directly to system endian macros on OpenBSD. Signed-off-by: Jonathan Gray <jsg@jsg.id.au>
2016-09-07global_data.h: Standardize tabs and alignment for commentsRobert P. J. Day
Line up comments for readibility. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-09-07omap3_pandora: Only set bootargs if distro_bootcmd failed to load.Vagrant Cascadian
As bootargs is hard-coded for the default behavior on the omap3_pandora, only set the bootargs if distro_bootcmd fails to load. This leaves distro_bootcmd free to use alternate boot arguments. Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
2016-09-07omap3_pandora: Switch to use config_distro_bootcmd.Vagrant Cascadian
Add support for using distro_bootcmd to the omap3_pandora target, falling back to prior behavior. Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
2016-09-07ARM: armv7: move ARMV7_PSCI_NR_CPUS to KconfigMasahiro Yamada
Move this option to Kconfig and set its default value to 4; this increases the number of supported CPUs for some boards. It consumes 1KB memory per CPU for PSCI stack, but it should not be a big deal, given the amount of memory used for the modern OSes. Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-09-07ARM: armv7: move CONFIG_ARMV7_PSCI to KconfigMasahiro Yamada
Add ARCH_SUPPORT_PSCI as a non-configurable option that platforms can select. Then, move CONFIG_ARMV7_PSCI, which is automatically enabled if both ARMV7_NONSEC and ARCH_SUPPORT_PSCI are enabled. Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-09-06omap3_pandora: Switch to using "load" command to load the autoboot script.Vagrant Cascadian
CONFIG_CMD_FS_GENERIC is enabled; use it to load the autoboot script, rather than first attempting with fatload and falling back to ext2load. Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Acked-by: Grazvydas Ignotas <notasas@gmail.com>
2016-09-06omap3_pandora: Fix mmc loading of autoboot script to use correct syntax.Vagrant Cascadian
fatload/ext2load both require that the device and partition be specified after specifying the device type. Specify the first partition on mmc device 0, which is the only mmc device currently configured on the pandora. Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Acked-by: Grazvydas Ignotas <notasas@gmail.com>
2016-09-06TI: Rework SRAM definitions and maximumsTom Rini
On all TI platforms the ROM defines a "downloaded image" area at or near the start of SRAM which is followed by a reserved area. As it is at best bad form and at worst possibly harmful in corner cases to write in this reserved area, we stop doing that by adding in the define NON_SECURE_SRAM_IMG_END to say where the end of the downloaded image area is and make SRAM_SCRATCH_SPACE_ADDR be one kilobyte before this. At current we define the end of scratch space at 0x228 bytes past the start of scratch space this this gives us a lot of room to grow. As these scratch uses are non-optional today, all targets are modified to respect this boundary. Tested on OMAP4 Pandaboard, OMAP3 Beagle xM Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Paul Kocialkowski <contact@paulk.fr> Cc: Enric Balletbo i Serra <eballetbo@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Thomas Weber <weber@corscience.de> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Heiko Schocher <hs@denx.de> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: "B, Ravi" <ravibabu@ti.com> Cc: "Matwey V. Kornilov" <matwey.kornilov@gmail.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: "Kipisz, Steven" <s-kipisz2@ti.com> Cc: Daniel Allred <d-allred@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Ladislav Michl <ladis@linux-mips.org>
2016-09-06board/BuR/common: increase NET_RETRY_COUNT to 10Hannes Schmelzer
Sometimes boards may need more time to become stable network connection due to several reasons: - phy speed - link-partner (switch) Therefore we increase the retry-count to 10 for making sure that network connection works always. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-06arm: dts: update DTS files for meson-gxbb and odroid-c2Beniamino Galvani
Import DTS files and dt-bindings includes from Linux 4.8-rc1. Signed-off-by: Beniamino Galvani <b.galvani@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-06serial: bcm283x_mu: Detect disabled serial deviceAlexander Graf
On the raspberry pi, you can disable the serial port to gain dynamic frequency scaling which can get handy at times. However, in such a configuration the serial controller gets its rx queue filled up with zero bytes which then happily get transmitted on to whoever calls getc() today. This patch adds detection logic for that case by checking whether the RX pin is mapped to GPIO15 and disables the mini uart if it is not mapped properly. That way we can leave the driver enabled in the tree and can determine during runtime whether serial is usable or not, having a single binary that allows for uart and non-uart operation. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-06warp7: Use PARTUUID to specify the rootfs locationFabio Estevam
warp7 can run different kernel versions, such as NXP 4.1 or mainline. Currently the rootfs location is passed via mmcblk number and the problem with this approach is that the mmcblk number for the eMMC changes depending on the kernel version. In order to avoid such issue, use UUID method to specify the rootfs location. Succesfully tested booting a NXP 4.1 and also a mainline kernel. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-09-06warp7: Modify fdt_file environment variableBreno Lima
Use imx7s-warp.dts as fdt_file because this is the name that upstream kernel will deploy. Signed-off-by: Breno Lima <breno.lima@nxp.com> Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-09-06warp7: Add PMIC supportVanessa Maegima
Add PMIC support. Tested by command "pmic PFUZE3000 dump". Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2016-09-06arm: imx: Add support for Advantech DMS-BA16 boardAkshay Bhat
Add support for Advantech DMS-BA16 board. The board is based on Advantech BA16 module which has a i.MX6D processor. The board supports: - FEC Ethernet - USB Ports - SDHC and MMC boot - SPI NOR - LVDS and HDMI display Basic information about the module: - Module manufacturer: Advantech - CPU: Freescale ARM Cortex-A9 i.MX6D - SPECS: Up to 2GB Onboard DDR3 Memory; Up to 16GB Onboard eMMC NAND Flash Supports OpenGL ES 2.0 and OpenVG 1.1 HDMI, 24-bit LVDS 1x UART, 2x I2C, 8x GPIO, 4x Host USB 2.0 port, 1x USB OTG port, 1x micro SD (SDHC),1x SDIO, 1x SATA II, 1x 10/100/1000 Mbps Ethernet, 1x PCIe X1 Gen2 Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com> Cc: u-boot@lists.denx.de Cc: sbabic@denx.de
2016-09-06imx: ventana: enable splashscreen supportTim Harvey
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2016-09-06board: tbs2910: fix HDMI pre-console bufferSoeren Moch
HDMI output must be enabled very early to also enable the pre-console buffer Signed-off-by: Soeren Moch <smoch@web.de> Reviewed-by: Stefano Babic <sbabic@denx.de>
2016-09-06board: tbs2910: always enable usbkbdSoeren Moch
'usb start' is much faster now, so always enable usb keyboard Signed-off-by: Soeren Moch <smoch@web.de> Reviewed-by: Stefano Babic <sbabic@denx.de>
2016-09-06Revert "sunxi: Move the SPL stack top to 0x1A000 on Allwinner A64/A80"Andre Przywara
This commit moved the SPL stack into SRAM C, which worked when the SPL set the AHB1 clock down to 100 MHz to cope with the flaky SRAM C access from the CPU. However booting with boot0 (and thus not using SPL at all) we still run with a 200 MHz AHB1, so any access to SRAM C is prone to fail. Since this commit does _not_ only affect the SPL code, but also the U-Boot proper, we fail when booting with boot0. As the introduction of tiny-printf reduced the size of the SPL, we can afford to have the SPL stack in SRAM A1. This reverts commit 1a83fb4a17d959d7b037999ab7ed7e62429abe34 and fixes booting the Pine64 when using boot0. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-09-01ARM: tegra: Add support for TK1-SOM board from Colorado EngineeringPeter Chubb
The Colorado TK1 SOM is a small form factor board similar to the Jetson TK1. The main differences lie in the pinmux, and in that the PCIe controller is set to use in 4lanes+1lane, rather than 2+2. The pinmux header here was generated from a spreadsheet provided by Colorado Engineering using the tegra-pinmux scripts. The spreadsheet was converted from v09 to v11 by me. Signed-off-by: Peter Chubb <peter.chubb@data61.csiro.au> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-30x86: efi: Fix EFI 64-bit payload build warningsBin Meng
There are lots of warnings when building EFI 64-bit payload. include/asm-generic/bitops/__fls.h:17:2: warning: left shift count >= width of type if (!(word & (~0ul << 32))) { ^ In fact, U-Boot itself as EFI payload is running in 32-bit mode. So BITS_PER_LONG needs to still be 32, but EFI status codes are 64-bit when booting from 64-bit EFI. Introduce EFI_BITS_PER_LONG to bridge those status codes with U-Boot's BITS_PER_LONG. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-30x86: efi: payload: Make EFI payload build againBin Meng
Since commit 73c5c39 "Makefile: Drop unnecessary -dtb suffixes", EFI payload does not build anymore. This fixes the build. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-28Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2016-08-28ARM: uniphier: support system reset functionality for PSCIMasahiro Yamada
This supports the system reset via PSCI for ARMv7 SoCs. Because the system reset is not supported on PSCI 0.1, let's define CONFIG_ARMV7_PSCI_1_0. (it is supported since PSCI 0.2, but there is no CONFIG to enable it in U-Boot for now.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-26Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2016-08-26ARM: Move SYS_CACHELINE_SIZE over to KconfigTom Rini
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all cases we are mirroring the values used by the Linux Kernel here. Also, so long as (and in this case, it is true) we implement flushes in hunks that are no larger than the smallest implementation (and given that we mirror the Linux Kernel, again we are fine) it is OK to align higher. The biggest changes here are that we always use 64 bytes for CPU_V7 even if for example the underlying core is only 32 bytes (this mirrors Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the Linux Kernel) as we do not need multi-platform support (to this degree) and only the Cavium ThunderX 88xx series has a use for such large alignment. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Stefan Roese <sr@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefan Agner <stefan.agner@toradex.com> Acked-by: Heiko Schocher <hs@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Peter Griffin <peter.griffin@linaro.org> Acked-by: Paul Kocialkowski <contact@paulk.fr> Cc: Anatolij Gustschin <agust@denx.de> Acked-by: "Pali Rohár" <pali.rohar@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Nishanth Menon <nm@ti.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Thomas Weber <weber@corscience.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: David Feng <fenghua@phytium.com.cn> Cc: Alison Wang <b18965@freescale.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com> Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Aneesh Bansal <aneesh.bansal@freescale.com> Cc: Saksham Jain <saksham.jain@nxp.com> Cc: Qianyu Gong <qianyu.gong@nxp.com> Cc: Wang Dongsheng <dongsheng.wang@nxp.com> Cc: Alex Porosanu <alexandru.porosanu@freescale.com> Cc: Hongbo Zhang <hongbo.zhang@nxp.com> Cc: tang yuantian <Yuantian.Tang@freescale.com> Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com> Cc: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Christophe Ricard <christophe-h.ricard@st.com> Cc: Anand Moon <linux.amoon@gmail.com> Cc: Beniamino Galvani <b.galvani@gmail.com> Cc: Carlo Caione <carlo@endlessm.com> Cc: huang lin <hl@rock-chips.com> Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Cc: Xu Ziyuan <xzy.xu@rock-chips.com> Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com> Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com> Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: Bernhard Nortmann <bernhard.nortmann@web.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Alexander Graf <agraf@suse.de> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: "Andrew F. Davis" <afd@ti.com> Cc: Murali Karicheri <m-karicheri2@ti.com> Cc: Carlos Hernandez <ceh@ti.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Daniel Allred <d-allred@ti.com> Cc: Gong Qianyu <Qianyu.Gong@freescale.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Chin Liang See <clsee@altera.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Paul Kocialkowski <contact@paulk.fr>
2016-08-26sunxi: Sync dts files with upstream kernelHans de Goede
Sync dts files with the current (Aug 18th 2016) state of Maxime's linux/sunxi/for-next repo. Note this commit also updates configs/MSI_Primo81_defconfig, adding: "# CONFIG_REQUIRE_SERIAL_CONSOLE is not set", this is necessary because the tablet does not have a reachable uart so the dts sync drops its serial0 alias. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-08-26spl: Remove unused CONFIG_SPL_SPI_* definitionsChris Packham
As of commit 88e34e5 ("spl: replace CONFIG_SPL_SPI_* with CONFIG_SF_DEFAULT_*") these defines are not used. Remove them to avoid confusion. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-08-20Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
[trini: Drop CMD_BOOTI as it's now on by default on ARM64] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-20fastboot: move to KconfigSteve Rae
- move bcm23550_w1d to Kconfig - move bcm28155_ap to Kconfig Signed-off-by: Steve Rae <steve.rae@raedomain.com>
2016-08-20cmd: booti: move CONFIG_CMD_BOOTI to KconfigMasahiro Yamada
This command is used to boot ARM64 Linux. I made DISTRO_DEFAULTS select this option for ARM64 to respect include/config_distro_defaults.h. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-20tests: Introduce DT overlay testsMaxime Ripard
This adds a bunch of unit tests for the "fdt apply" command. They've all been run successfully in the sandbox. However, as you still require an out-of-tree dtc with overlay support, this is disabled by default. Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
