path: root/include
2015-03-02Merge branch 'xnext/zynqmp' of git://www.denx.de/git/u-boot-microblazeTom Rini
2015-03-02arm64: Add Xilinx ZynqMP supportMichal Simek
Add basic Xilinx ZynqMP arm64 support. Serial and SD is supported. It supports emulation platfrom ep108 and QEMU. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-03-02atngwmkii: convert to generic boardAndreas Bießmann
2015-03-02Merge git://git.denx.de/u-boot-usbTom Rini
2015-03-02Merge git://git.denx.de/u-boot-pxaTom Rini
2015-03-02pxa: colibri_pxa270: integrate latest validated register settingsMarcel Ziswiler
Integrate latest validated register settings from Toradex WinCE BSP 4.2 working accross all module versions from early V1.x, V1.2D, V2.2B to V2.4A. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2015-03-02pxa: colibri_pxa270: remove CONFIG_ENV_ADDR_REDUNDMarcel Ziswiler
Usually not required for NOR flash. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2015-03-02pxa: colibri_pxa270: fix wrong comment about voipac ethernet chipMarcel Ziswiler
2015-03-02pxa: colibri_pax270: fix CONFIG_BOOTCOMMANDMarcel Ziswiler
While 'mmc init' is no longer required the address to bootm the kernel from NOR flash was wrong. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2015-03-02pxa: colibri_pxa270: avoid overwriting factory configuration blockMarcel Ziswiler
Specify a CONFIG_BOARD_SIZE_LIMIT of 256 KB in order to avoid overwriting the factory configuration block located at offset 0x40000 in NOR flash. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2015-03-02pxa: colibri_pxa270: disable loadb/s commands and long helpMarcel Ziswiler
To save more than 20 KB of precious space in NOR flash get rid of the following configuration options: CONFIG_CMD_LOADB CONFIG_CMD_LOADS CONFIG_SYS_LONGHELP Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2015-03-02pxa: colibri_pxa270: migrate to generic boardMarcel Ziswiler
Migrate Toradex Colibri PXA270 to use CONFIG_SYS_GENERIC_BOARD. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-03-02pxa: balloon3/colibri_pxa270: fix environment optionally being nowhereMarcel Ziswiler
I couldn't quite figure out whether or not CONFIG_SYS_ENV_IS_NOWHERE actually ever worked but nowadays this is called CONFIG_ENV_IS_NOWHERE. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2015-03-02pxa: balloon3: fix comment about sdram banksMarcel Ziswiler
2015-03-02pxa: balloon3: remove nowhere used symbol CONFIG_SYS_MEM_BUF_IMPMarcel Ziswiler
2015-03-02remove nowhere used symbol CONFIG_SYS_CLKS_IN_HZMarcel Ziswiler
Basically finish what the following commit started a long time ago: 488f5d8790c451fc527fe5d2ef218f2a5e40ea17 Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> For mx35pdk/woodburn: Acked-by: Stefano Babic <sbabic@denx.de>
2015-03-01Merge branch 'master' of git://git.denx.de/u-boot-samsungTom Rini
2015-03-01Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2015-03-01Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
2015-03-01ARM: UniPhier: switch to xHCI for PH1-Pro4Masahiro Yamada
PH1-Pro4 includes both EHCI and xHCI IP cores. Unfortunately, U-Boot cannot enable EHCI and xHCI support simultaneously. Some users may wish Super-Speed connection. Disable CONFIG_USB_EHCI_HCD and enable CONFIG_USB_XHCI_HCD. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-03-01usb: UniPhier: add UniPhier on-chip xHCI host driver supportMasahiro Yamada
Support xHCI host driver used on Panasonic UniPhier platform. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-28Exynos542x: Config: Add various configsAkshay Saraswat
This patch adds "iRAM, CPU state and low power" configs which are the addresses acting as flag registers. iROM code checks CONFIG_LOWPOWER_FLAG address. If it is equal to CONFIG_LOWPOWER_EN then it jumps to the address (0x02020000+CPUID*4). This is a part of iROM logic. Rest other flags are being used at various places during kernel switching and reset. They are nowhere documented because they are part programming. These configs are serving as flags for us because they are representing the addresses in iRAM which we are using for storing and extracting CPU Status and GIC status. Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-02-25Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2015-02-25crypto/fsl - Add progressive hashing support using hardware acceleration.gaurav rana
Currently only normal hashing is supported using hardware acceleration. Added support for progressive hashing using hardware. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> CC: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <yorksun@freescale.com>
2015-02-25usb: gadget: fastboot: Add fastboot eraseDileep Katta
Adds the fastboot erase functionality, to erase a partition specified by name. The erase is performed based on erase group size, to avoid erasing other partitions. The start address and the size is aligned to the erase group size for this. Currently only supports erasing from eMMC. Signed-off-by: Dileep Katta <dileep.katta@linaro.org> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-02-25dfu: samsung: move call to set_dfu_alt_info() to dfu common codePrzemyslaw Marczak
This common call can be used for setting proper entities based on dfu command arguments. The config: CONFIG_SET_DFU_ALT_INFO, was used only for few configs, and now it is common. The board file should implement: - set_dfu_alt_info() function Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [Test HW: Odroid U3 (Exynos 4412)]
2015-02-25arm: rmobile: silk: Add support SDHIVladimir Barinov
This adds GPIO configuration and initialization function of SDHI on Silk board Signed-off-by: Vladimir Barinov <vladimir.barinov+renesas@cogentembedded.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: Add Porter board supportVladimir Barinov
Porter is an entry level development board based on R-Car M2 SoC (R8A7791) This commit supports the following peripherals: - SCIF, I2C, Ethernet, QSPI, SD, USB Host Signed-off-by: Vladimir Barinov <vladimir.barinov@cogentembedded.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: lager: Add support SDHINobuhiro Iwamatsu
Lager board has two SDHI port as SDHI0 and SDHI2. This adds GPIO configuration and initialization function of SDHI, and enables MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: gose: Add support SDHINobuhiro Iwamatsu
Gose board has three SDHI port. This adds GPIO configuration and initialization function of SDHI, and enables MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: koelsch: Add support SDHINobuhiro Iwamatsu
Koelsch board has three SDHI port. This adds GPIO configuration and initialization function of SDHI, and enables MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: alt: Add support SDHINobuhiro Iwamatsu
Alt board has two SDHI port. This adds GPIO configuration and initialization function of SDHI, and enables MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: silk: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Silk board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: alt: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Alt board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: lager: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Lager board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: gose: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Gose board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: koelsch: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Koelsch board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-24zmx25: Convert to generic boardFabio Estevam
Boards need to select CONFIG_SYS_GENERIC_BOARD in order to prevent removal from the project. Cc: Matthias Weisser <weisserm@arcor.de> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-02-24imx31_phycore: Convert to generic boardFabio Estevam
Boards need to select CONFIG_SYS_GENERIC_BOARD in order to prevent removal from the project. Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-02-24mx31ads: Convert to generic boardFabio Estevam
2015-02-24ARM: davinci: remove hawkboard supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Syed Mohammed Khasim <sm.khasim@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove tnetv107x board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Chan-Taek Park <c-park@ti.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove a320evb board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Po-Yu Chuang <ratbert@faraday-tech.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove cm4008 and cm41xx board supportMasahiro Yamada
These are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Greg Ungerer <greg.ungerer@opengear.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove dkb board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Lei Wen <leiwen@marvell.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove jadecpu board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Matthias Weisser <weisserm@arcor.de> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24kconfig: remove unneeded dependency on !SPL_BUILDMasahiro Yamada
Now CONFIG_SPL_BUILD is not defined in Kconfig, so "!depends on SPL_BUILD" and "if !SPL_BUILD" are redundant. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-24kconfig: switch to single .config configurationMasahiro Yamada
When Kconfig for U-boot was examined, one of the biggest issues was how to support multiple images (Normal, SPL, TPL). There were actually two options, "single .config" and "multiple .config". After some discussions and thought experiments, I chose the latter, i.e. to create ".config", "spl/.config", "tpl/.config" for Normal, SPL, TPL, respectively. It is true that the "multiple .config" strategy provided us the maximum flexibility and helped to avoid duplicating CONFIGs among Normal, SPL, TPL, but I have noticed some fatal problems: [1] It is impossible to share CONFIG options across the images. If you change the configuration of Main image, you often have to adjust some SPL configurations correspondingly. Currently, we cannot handle the dependencies between them. It means one of the biggest advantages of Kconfig is lost. [2] It is too painful to change both ".config" and "spl/.config". Sunxi guys started to work around this problem by creating a new configuration target. Commit cbdd9a9737cc (sunxi: kconfig: Add %_felconfig rule to enable FEL build of sunxi platforms.) added "make *_felconfig" to enable CONFIG_SPL_FEL on both images. Changing the configuration of multiple images in one command is a generic demand. The current implementation cannot propose any good solution about this. [3] Kconfig files are getting ugly and difficult to understand. Commit b724bd7d6349 (dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to Kconfig) has sprinkled "if !SPL_BUILD" over the Kconfig files. [4] The build system got more complicated than it should be. To adjust Linux-originated Kconfig to U-Boot, the helper script "scripts/multiconfig.sh" was introduced. Writing a complicated text processor is a shell script sometimes caused problems. Now I believe the "single .config" will serve us better. With it, all the problems above would go away. Instead, we will have to add some CONFIG_SPL_* (and CONFIG_TPL_*) options such as CONFIG_SPL_DM, but we will not have much. Anyway, this is what we do now in scripts/Makefile.spl. I admit my mistake with my apology and this commit switches to the single .config configuration. It is not so difficult to do that: - Remove unnecessary processings from scripts/multiconfig.sh This file will remain for a while to support the current defconfig format. It will be removed after more cleanups are done. - Adjust some makefiles and Kconfigs - Add some entries to include/config_uncmd_spl.h and the new file scripts/Makefile.uncmd_spl. Some CONFIG options that are not supported on SPL must be disabled because one .config is shared between SPL and U-Boot proper going forward. I know this is not a beautiful solution and I think we can do better, but let's see how much we will have to describe them. - update doc/README.kconfig More cleaning up patches will follow this. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-24OMAP3: igep0032: Fix regression due commit f3b4bc45.Enric Balletbo i Serra
Commit referenced in subject breaks IGEP0032 build with the following error: drivers/misc/status_led.c:30:7: error: 'RED_LED_GPIO' undeclared here (not in a function) scripts/Makefile.build:275: recipe for target 'drivers/misc/status_led.o' failed make[2]: *** [drivers/misc/status_led.o] Error 1 scripts/Makefile.build:420: recipe for target 'drivers/misc' failed make[1]: *** [drivers/misc] Error 2 Makefile:1093: recipe for target 'drivers' failed make: *** [drivers] Error 2 Fix this by skipping the status led on IGEP0032 machine as is not available and throw an error for future machines if the status led is not configured to avoid build breakage. Reported-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
2015-02-24mmc: fsl_esdhc: Add support for DDR modeVolodymyr Riazantsev
Add support of the DDR mode for eSDHC driver. Enable it for i.MX6 SoC family only. Signed-off-by: Volodymyr Riazantsev <volodymyr.riazantsev@globallogic.com> Reviewed-by: York Sun <yorksun@freescale.com>
