Add support for fixing usb mode and phy type for
MPH(Multi Port Host) USB controllers in device-tree nodes.
Required for socs like P3060, P5020, etc having MPH USB controller
Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
This patch adds support for the Calimain board from
OMICRON electronics GmbH. The board features a Texas Instruments AM1808
SoC, 128 MB DDR2 memory, and 64 MB NOR flash memory connected to CS2 and
CS3.
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
This patch moves hawkboard to the new spl infrastructure from the
older nand_spl one.
Removed the hawkboard_nand_config build option -- The spl code now
gets compiled with hawkboard_config, after building the main u-boot
image, using the CONFIG_SPL_TEXT_BASE. Modified the README.hawkboard
to reflect the same.
Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
Cc: Christian Riesch <christian.riesch@omicron.at>
Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Cc: Tom Rini <trini@ti.com>
Acked-by: Christian Riesch <christian.riesch@omicron.at>
The V bit of the c1 register of CP15 should not be cleared on DA850
SoCs since they have no valid memory at 0x00000000. This patch
introduces a configuration option CONFIG_SYS_EXCEPTION_VECTORS_HIGH
that allows setting the correct value for the V bit.
Reported-by: Sughosh Ganu <urwithsughosh@gmail.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Sughosh Ganu <urwithsughosh@gmail.com>
This patch reverts commit ca4b55800ed74207c35271bf7335a092d4955416
"arm, arm926ejs: always do cpu critical inits" since it impacts all
arm926ejs based configurations and caused problems, e.g., with
the hawkboard.
Instead the patch removes the CONFIG_SKIP_LOWLEVEL_INIT defines
from the board configurations that need low level initialization.
Acked-by: Heiko Schocher <hs@denx.de>
Tested-by: Heiko Schocher <hs@denx.de>
add support for printing various clock frequency info found
in SOC such as ARM core frequency, DSP core frequency and DDR
frequency as part of bdinfo command.
Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
remove the macro CONFIG_DISPLAY_CPUINFO as it is no longer
required. This is because clock info will be printed as part
'bdinfo' command and also remove support print_cpuinfo() as it will
no longer be called.
This patch adds support for the HTKW mcx AM3517-based board.
Serial, Ethernet, NAND, MMC, RTC, EHCI USB host and both
NAND and MMC SPLs are supported.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
CC: Tom Rini <tom.rini@gmail.com>
Cc: Detlev Zundel <dzu@denx.de>
The mt_ventoux board is a custom board using
the Technexion TAM3517 module.
The patch fixes also the mtdparts variable in the
TAM3517 common configuration file.
CC: Ilya Yanok <yanok@emcraft.com>
CC: Igor Grinberg <grinberg@compulab.co.il>
Changed the EHCI interface using the ulpi framework.
For panda initialise the mux pins for ehci usage and
enable ehci in omap4_panda config file.
Signed-off-by: Govindraj.R <govindraj.raja@ti.com>
Tested-by: Stefano Babic <sbabic@denx.de>
Taken from Beagle code. Tested on mcx board (AM3517-based).
Based on discussion from this thread [1].
Adding omap-view port that helps us in using the generic ulpi
framework for any ulpi phy ops using the INSNREG05_ULPI viewport
reg available on omap platform.
Currently ehci ports are available on omap3/4 platforms so enable the same
for beagle and panda, patch is tested on the same boards.
Thanks to Igor Grinberg <grinberg@compulab.co.il> for reviewing the
omap-ehci patches and suggesting this approach.
[1]: http://www.mail-archive.com/u-boot@lists.denx.de/msg76076.html
Extend the existing ulpi viewport framework
to pass the port number information for any ulpi
ops. Fix the usage of ulpi api's accordingly.
This patch enable support for SMC911X based ethernet device.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
This patch adds support for MMC SPL booting.
SMDK5250 board is based on Samsungs EXYNOS5250 SoC.
CONFIG_SYS_CLK_FREQ_C210 macro giving notion of S5PC2XX (Exynos4)
architecture. Replace CONFIG_SYS_CLK_FREQ_C210 with CONFIG_SYS_CLK_FREQ
to make it generic for exynos architecture.
Since MACH_TYPE_ORIGEN is updated on mach-types,
remove the MACH_TYPE_ORIGEN on config file.
Cc: Chander Kashyap <chander.kashyap@linaro.org>
This patch adds support for Samsung TRATS board
Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
We don't need 3us delay for our i2c bus. Decrease it to 1us.
It would also be possible to use 100ns in the future, but
currently kirkwood has no ndelay implementation.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
Cc: Valentin Longchamp <valentin.longchamp@keymile.com>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
This patch adds support for D-Link DNS-325 ShareCenter NAS.
Signed-off-by: Stefan Herbrechtsmeier <stefan@code.herbrechtsmeier.net>
Cc: prafulla@marvell.com
Cc: albert.u.boot@aribaud.net
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Signed-off-by: David Mueller <d.mueller@elsoft.ch>
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
board_mmc_init() initializes the pins of SDHC1 and
turns on V_MMC1 of the PMIC. Config adds support for EXT2
and FAT.
Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
Add bit definitions for register 32 and 33 of Freescale MC13783.
CONFIG_NET_MULTI is not used anymore, so remove it from board files.
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Kumar Gala <kumar.gala@freescale.com>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Acked-by: Tom Rini <trini@ti.com>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Tested-by: Marek Vasut <marek.vasut@gmail.com>
Signed-off-by: Jason Liu <jason.hui@linaro.org>
Signed-off-by: Eric Miao <eric.miao@linaro.org>
CC: Jason Liu <jason.hui@linaro.org>
CC: Stefano Babic <sbabic@denx.de>
To be able to load the device tree and initrd correctly, set
the fdt_high and initrd_high environment variables.
Using 0xffffffff implies that the device tree and the initrd
are initially copied to working addresses. This will avoid an
additional copy.
Loading the device tree to 0x30000000 and the initrd to 0x3c000000
should work for both boards, the ARM2 and SabreLite.
Example (SabreLite):
fatload mmc 0:2 0x10000000 uImage
fatload mmc 0:2 0x3c000000 uInitrd
fatload mmc 0:2 0x30000000 board.dtb
bootm 0x10000000 0x3c000000 0x30000000
Note: This requires that the kernel has CONFIG_HIGHMEM enabled.
Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com>
Acked-by: Jason Liu <jason.hui@linaro.org>
Since commit 97039ab98 (env_mmc: Allow board code to override the environment address)
mmc_get_env_addr is a weak-aliased function in common/env_mmc.c
The mmc_get_env_addr implementation that exists at
board/freescale/common/sdhc_boot.c is meant to be used only for PowerPC boards,
but currently it is being used for all platforms that have CONFIG_ENV_IS_IN_MMC defined.
Introduce CONFIG_FSL_FIXED_MMC_LOCATION so that the boards that need to use
the mmc_get_env_addr version from board/freescale/common/sdhc_boot.c could activate
this config option on their board file.
This fixes the retrieval of CONFIG_ENV_OFFSET on non-PowerPC boards.
- CONFIG_SYS_MMC_ENV_DEV, needed if environment on mmc
- wait for 1 second timer in board_late_init() only, if
timer is running.
- add UBI/UBIFS support
- add FIT images support
- menu support
- U-Boot max size now 0xa0000
- SPL now Block 0 page 0
- new MTD partitioning
0x00000000 SPL
0x00020000 UBL-Header
0x00040000 UBL-Header
0x00060000 UBL-Header
0x00080000 UBoot (0xa0000(U-Boot length) + 0x60000(3 spare blocks))
0x00180000 ENV- Variablen (1)
0x001a0000 ENV- Variablen (2)
0x001c0000 ENV- Variablen (reserved for Bad Block)
0x001e0000 ENV- Variablen (reserved for Bad Block)
0x00200000 UBI-Device
UBI Volumes:
„default“: contain environment-default values
„rootfs1“: UBIFS root-fs (1); contain linux kernel image
„rootfs2“: UBIFS root-fs (2); contain linux kernel image
„data-ro“: UBIFS data (read only)
„data-rw“: UBIFS data (read/write)
- new environment variables:
- app_reset
(this is only passed per cmdline to linux)
- dvn_app_vers
string from ramdisk description contained in the
FIT image
- dvn_boot_vers
string from ubootimage description contained in the
FIT image
- saveparms, restoreparms, restoretmpparms, savetmpparms
helper for saving network parameter.
- ubiargs
set ubi kernel cmdlinargs for booting with a ubifs rootfs
- ubi_ubi boot with reading kernel image from ubifs, and
use a ubifs as rootfs
Cc: Tom Rini <tom.rini@gmail.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Mike Frysinger <vapier@gentoo.org>
show a menu on startup instead running the shell.
Cc: Jason Hobbs <jason.hobbs@calxeda.com>
Acked-by: Jason Hobbs <jason.hobbs@calxeda.com>
add the possibility to show a statusline when printing a menu
add possibility to add a timeout when reading a line
into a buffer.
Tricorder is a board which is very similar to the Devkit8000. It
is designed as a base platform for further medical devices.
www.corscience.de/en/medical-engineering/products/multiparameter/mp10-board.html
Signed-off-by: Thomas Weber <weber@corscience.de>
it is not necessary to define rootfstype for mass storage devices.
Kernel detects it automatically.
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
The Toshiba AC100 (Compal code-name Paz00, aka Dynabook AZ) is a netbook
derived from the NVIDIA Tegra Harmony reference board. It ships with
Android, but is often repurposed to run Linux. This patch adds just enough
support to get a U-Boot serial console, and the ability access built-in
eMMC and the external SD slot.
v2:
* Rebased on latest HEAD, incorporated changes made to other board files.
* Moved board files from board/nvidia to board/compal.
* Switched to correct odmdata value. This required add the previous patch
to fix U-Boot's interpretation of the odmdata RAM size field.
* Removed nvmem= from default Linux kernel command-line; no drivers use the
reserved memory yet, so there's no point reserving it.
Signed-off-by: Tom Warren <twarren@nvidia.com>
* 'master' of git://git.denx.de/u-boot-nand-flash:
nand/fsl_elbc: Convert to self-init
nand: Introduce CONFIG_SYS_NAND_SELF_INIT
nand_spl: store ecc data on the stack
mtd/nand: Add ONFI support for FSL NAND controller
nand: make 1-bit software ECC configurable
nand: Sanitize ONFI strings.
nand: Merge changes to BBT from Linux nand driver
nand: Merge changes from Linux nand driver
nand: cleanup whitespace
nand: Add more NAND types from Linux nand driver
nand: Merge BCH code from Linux nand driver
NAND: Remove additional (CONFIG_SYS)_NAND_MAX_CHIPS
NAND: remove NAND_MAX_CHIPS definitions
nand_spl_simple: store ecc data on the stack
This driver doesn't yet make use of the added flexibility (not that that
should stop anyone from converting...), but it will with the in-progress
hack to support 4k-page NAND.
This allows a driver to run code between nand_scan_ident() and
nand_scan_tail(), among other things. See the additions to
doc/README.nand for details.
To allow a gradual transition, Boards that don't set
CONFIG_SYS_NAND_SELF_INIT will still be initialized the old way, but
new drivers should not require this, and existing drivers should be
converted when convenient.
Adapt the following patch from spl to nand_spl:
Author: Stefano Babic <sbabic@denx.de>
Date: Thu Dec 15 10:55:37 2011 +0100
Currently nand_spl_simple puts it's temp data at 0x10000 offset in SDRAM
which is likely to contain already loaded data.
The patch saves the oob data and the ecc on the stack replacing
the fixed address in RAM.
CC: Scott Wood <scottwood@freescale.com>
CC: Simon Schwarz <simonschwarzcor@googlemail.com>
CC: Wolfgang Denk <wd@denx.de>
While nand_spl is on its way out, in favor of spl, there are still
many boards using it, and conversions are gradual. This allows us
to get rid of CONFIG_SYS_NAND_ECCSTEPS and CONFIG_SYS_NAND_ECCTOTAL now,
which would otherwise be likely to linger unreferenced after a conversion.
It also eliminates a temporary error in the hawkboard_nand build, since
the spl version of the patch removed ECCSTEPS/TOTAL from hawkboard.h, but
the spl conversion is pending (and may be merged via a different tree).
The software ECC algorithm is not necessary when hardware ECC
is available and can be left out for a smaller image size.
Enable with CONFIG_MTD_ECC_SOFT.
Signed-off-by: Christian Hitz <christian.hitz@aizo.com>
Cc: Scott Wood <scottwood@freescale.com>
[backport from linux commit 02f8c6aee8df3cdc935e9bdd4f2d020306035dbe]
This is part of the synchronization with the nand driver to the
Linux 3.0 state.
This patch synchronizes the nand driver with the Linux 3.0 state.
[scottwood@freescale.com: minor fixes]
This patch merges the BCH ECC algorithm from the 3.0 Linux kernel.
This enables U-Boot to support modern NAND flash chips that
require more than 1-bit of ECC in software.
NAND_MAX_CHIPS has been replaced by CONFIG_SYS_NAND_MAX_CHIPS,
and the latter defaults to 1.
This change follows the change by Wolfgang Grandegger (commit 6c869637fef),
which allows to remove useless NAND_MAX_CHIPS definitions in board config
files.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Cc: Wolfgang Grandegger <wg@grandegger.com>
